APSDM064G12AN-CTM1W
APSDM064G12AN-CTM1W
    APACERMEMORYAMERICA(宇瞻科技)
    SATA3 DISK MODULE 22-PIN/90 DEGR
APSDM064G12AN-CTM1W 数据手册
SDM5A 22P90D SDM5A 22P90D Overview The SDM5A-M SATA DOM (SATA disk of module) series is available with a 22-pin connector that is oriented at 90 degrees or 180 degrees and is designed for a adopted in industrial, embedded, and commercial computers. Supporting SATA 6.0 Gb/s and read and write speeds up to 200 MB/s and 85MB/s respectively, the SDM5AM DOM offers outstanding reliability based on flash vendor guaranteed wide-temp MLC chip in capacities of 8GB to 64GB and also can work at extended temperatures (-40°C~ 85°C) under harsh operating environment,particularly well-suited for applications such as POS, kiosk, gaming, digital signage, STB, low-cost NB surveillance systems and Thin client.The actual available memory on the device is less than what is listed on the package. This is due to small discrepancies in file formats and algorithms used by various operating systems. In addition, a portion of memory space is reserved for system files and data sectors for better performance. Feature ‧ 22-pin SATA Standard Connector ‧ Global Wear-leveling and Block Management ‧ Built in ATA Secure Erase and S.M.A.R.T. Function ‧ Intelligent Power Failure Recovery ‧ TRIM Command Support ‧ MLC Extended Temperature Support Specifications Model SDM5A 22P90D Interface SATA 3.0 (6Gb/s) Connector (7+15) pin male NAND Flash Type Capacity External DRAM SLC 1GB~32GB No Sustained Read Performance (MB/sec) Up to 65 Sustained Write Performance (MB/sec) Up to 105 ECC Engine Built-in 40-bit per 1K bytes BCH ECC Standard Operating Temperature ( °C ) 0 ~ + 70 Extended Operating Temperature ( °C ) -40 ~ + 85 Storage Temperature ( °C ) -40 ~ + 100 Thermal Sensor Shock Vibration Operating Voltage Power Consumption Dimension (L x W x H ) MTBF (hours) Optional Operation: 50G, 11ms Non-operation: 1500G, 0.5ms Operation: 7.69 Grms, 20~2000 Hz/random (compliant with MIL-STD-810G) "Non-operation: 4.02 Grms, 15 ~ 2000 Hz/sine (compliant with MIL-STD-810G) 5.0 V ± 5% Active mode: 260 mA & Idle mode: 70 mA 44 x 30 x 11 (mm) >2,000,000 Mechanical Specification Unit: mm Ordering Info Operation Temp. 8GB 16GB 32GB 64GB Standard Grade APSDM008G12ANCTM1 APSDM016G12ANCTM1 APSDM032G12ANCTM1 APSDM064G12ANCTM1 Industrial Grade APSDM008G12ANCTM1W APSDM016G12ANCTM1W APSDM032G12ANCTM1W APSDM064G12ANCTM1W Global Presence Taiwan (Headquarters) Apacer Technology Inc. Tel: +886-2-2267-8000 Fax: +886-2-2267-2261 Europe Apacer Technology B.V. Tel: +31-40-267-0000 Fax: +31-40-290-0686 Japan Apacer Technology Corp. Tel: +81-3-5419-2668 Fax: +81-3-5419-0018 India Apacer Technologies Pvt. Ltd. Tel: +91-80-41529061~3 Fax: +91-80-41700215 U.S.A. Apacer Memory America, Inc. Tel: +1-408-518-8699 Fax: 1-510-249-9551 China Apacer Electronic(Shanghai) Co., Ltd. Tel: +86-21-6228-9939
APSDM064G12AN-CTM1W 价格&库存
很抱歉,暂时无法提供与“APSDM064G12AN-CTM1W”相匹配的价格&库存,您可以联系我们找货
