APSDM016GQ2WN-ETM1
APSDM016GQ2WN-ETM1
    APACERMEMORYAMERICA(宇瞻科技)
    SATA3 DISK MODULE 7-PIN/90 DEGRE
APSDM016GQ2WN-ETM1 数据手册
RoHS Recast Compliant SATA-Disk Module 5A-M SDM5A-M 7P/90D MP2 Product Specifications (Toshiba 15nm) November 24, 2016 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX Features:  Standard Serial ATA Interface – Serial ATA Revision 3.1 – SATA 6.0 Gbps interface – ATA-8 command set – Backward compatible with SATA 1.5/3.0 Gbps  Capacity – 8, 16, 32, 64 GB  Performance* – Burst read/write: 600 MB/sec – Sustained read: up to 245 MB/sec – Sustained write: up to 75 MB/sec  Flash Management – Built-in hardware ECC – Static/dynamic wear-leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase  NAND Flash Type: MLC  MTBF: >1,000,000 hours  Temperature Range – Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 100°C  Supply Voltage – 5.0 V ± 5%  Power Consumption* – Active mode: 205 mA – Idle mode: 80 mA  Connector Type – 7-pin SATA signal connector – 15-pin SATA power connector  Form Factor – SATA Disk Module: 7-pin/90 degree Middle Profile 2 – Dimensions: 52.25x24.00x15.20, unit: mm  Shock & Vibration** – Shock:1,500 G – Vibration: 15 G  Write Protect Switch (optional)  RoHS Recast Compliant – Complies with 2011/65/EU standard *Varies from capacities. The values for performances and power consumptions presented are typical and may vary depending on flash configurations or platform settings. The term idle refers to the standby state of the device. **Non-operating 1 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 2. PIN ASSIGNMENTS ............................................................................................................... 3 3. PRODUCT SPECIFICATIONS .............................................................................................. 4 3.1 CAPACITY ............................................................................................................................................................. 4 3.2 PERFORMANCE .....................................................................................................................................................4 3.3 ENVIRONMENTAL SPECIFICATIONS .......................................................................................................................4 3.4 MEAN TIME BETWEEN FAILURES (MTBF) ...........................................................................................................5 3.5 CERTIFICATION AND COMPLIANCE .......................................................................................................................5 4. FLASH MANAGEMENT ........................................................................................................ 6 4.1 ERROR CORRECTION/DETECTION .........................................................................................................................6 4.2 BAD BLOCK MANAGEMENT .................................................................................................................................6 4.3 WEAR LEVELING ..................................................................................................................................................6 4.4 PAGE MAPPING FTL .............................................................................................................................................6 4.5 POWER FAILURE MANAGEMENT........................................................................................................................... 6 4.6 ATA SECURE ERASE ............................................................................................................................................7 5. SOFTWARE INTERFACE ..................................................................................................... 8 5.1 COMMAND SET .....................................................................................................................................................8 5.2 S.M.A.R.T............................................................................................................................................................ 8 6. ELECTRICAL SPECIFICATIONS ..................................................................................... 10 7. MECHANICAL SPECIFICATIONS ................................................................................... 11 7.1 DIMENSIONS ....................................................................................................................................................... 11 7.2 WRITE PROTECT SWITCH (OPTIONAL) ................................................................................................................ 12 8. PRODUCT ORDERING INFORMATION ......................................................................... 13 8.1 PRODUCT CODE DESIGNATIONS ......................................................................................................................... 13 2 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 1. General Description Apacer’s SDM5A-M (SATA Disk Module 5A-M) is our next generation disk-on-module (DOM) series that offers elevated speed boost and higher error correction capabilities. Built with SATA 6.0 Gb/s interface, SDM5A-M delivers higher performance in data transfer than its previous SDM selections, reaching up to 245 MB/s in read and 75 MB/s in write. With its SATA interface compliance and compact size, this high-speed disk module defines an ideal balance of performance, capacities, reliability and cost. SDM5A-M comes in moderate capacities that are suitable to boot industrial applications and light operating systems for specific operations, while with some extra memory space for data storage. The architectural nature of SATA disk module provides higher resistance to external environmental influences and better flexibility for motherboard space. Regarding data reliability, SDM5A-M is built in with powerful ECC engine that can correct up to 40 bits per 1KB data. In addition, the controller unit of this DOM device supports wear-leveling, SMART and power failure management for data integrity. With its trustable reliability, performance and cost effectiveness, Apacer’s SDM5A-M is definitely the ideal storage or cache solution for embedded and industrial computers, servers and thin clients. 2. Pin Assignments Power P1 of power cable connector Table 1-1 Signal Segment Pin Type Table 1-2 Power Segment Description S1 GND S2 RxP + Differential Receive Signal S3 RxN - Differential Receive Signal S4 GND S5 TxN - Differential Transmit Signal S6 TxP + Differential Transmit Signal S7 GND Pin Signal/Description P1 VCC (5V) P2 GND 3 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 3. Product Specifications 3.1 Capacity Capacity specifications of SDM5A-M are available as shown in Table 3-1. It lists the specific capacity and the default numbers of heads, sectors and cylinders for each product line. Table 3-1 Capacity Specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 *Display of total bytes varies from file systems, which means not all of the bytes can be used for storage. **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 3.2 Performance Performance of SDM5A-M is listed below in Table 3-2. Table 3-2 Performance Capacity 8 GB 16 GB 32 GB 64 GB Sustained Read (MB/s) 105 215 210 245 Sustained Write (MB/s) 24 48 42 75 Performance Note: Results may differ from various flash configurations or host system setting. 3.3 Environmental Specifications Environmental specifications of SDM5A-M product family follow the MIL-STD-810 standards are available as shown in Table 3-3. Table 3-3 Environmental Specifications Item Specifications Operating temp. 0°C to 70°C (Standard); -40°C to 85°C (Extended) Non-operating temp. Operating vibration -40°C to 100°C 7.69 Grms, 20~2000 Hz/random (compliant with MIL-STD-810G) Non-operating vibration 4.02 Grms, 15 ~ 2000 Hz/sine (compliant with MIL-STD-810G) Operating shock 50(G), 11(ms), half-sine wave Non-operating shock 1,500(G), 0.5(ms), half-sine wave 4 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 3.4 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in SDM5A-M. The prediction result for SDM5A-M is more than 1,000,000 hours. Note: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 3.5 Certification and Compliance SDM5A-M complies with the following standards:     CE FCC RoHS Recast MIL-STD-810 5 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 4. Flash Management 4.1 Error Correction/Detection SDM5A-M implements a hardware ECC scheme, based on the BCH algorithm. It can detect and correct up to 16 bits or 24 bits error in 1K bytes. 4.2 Bad Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 4.3 Wear Leveling Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 4.4 Page Mapping FTL Page mapping is a 4K-based firmware technology whose essence lies in the ability to gather data, distribute the data into 4KB blocks automatically, and then schedule the data to be evenly written. This implementation is also evidenced by JEDEC that 4KB is the most frequently used block size for data read/write access, constituting 67% of server workload. Thus, 4K page mapping is adopted to increase random access speed and improve SSD lifespan, reduce block erase frequency, and achieve optimized performance and lifespan. 4.5 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 6 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 4.6 ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 7 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 5. Software Interface 5.1 Command Set This section defines the software requirements and the format of the commands the host sends to SDM5A-M. Commands are issued to SDM5A-M by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. Table 5-1 Command Set Code Command Code Command E5h Check Power Mode F3h Security Erase Prepare 06h Data Set Management F4h Security Erase Unit 90h Execute Device Diagnostic F5h Security Freeze Lock E7h Flush Cache F1h Security Set Password EAh Flush Cache EXT F2h Security Unlock Ech Identify Device 70h Seek E3h Idle EFh Set Features E1h Idle Immediate C6h Set Multiple Mode 91h Initialize Device Parameters E6h Sleep C8h Read DMA B0h SMART 25h Read DMA EXT E2h Standby C4h Read Multiple E0h Standby Immediate 29h Read Multiple EXT CAh Write DMA 20h Read Sector 35h Write DMA EXT 24h Read Sector EXT C5h Write Multiple 40h Read Verify Sectors 39h Write Multiple EXT 42h Read Verify Sectors EXT 30h Write Sector 10h Recalibrate 34h Write Sector EXT F6h Security Disable Password 5.2 S.M.A.R.T. S.M.A.R.T. is an abbreviation for Self-Monitoring, Analysis and Reporting Technology, a self-monitoring system that provides indicators of drive health as well as potential disk problems. It serves as a warning for users from unscheduled downtime by monitoring and displaying critical drive information. Ideally, this should allow taking proactive actions to prevent drive failure and make use of S.M.A.R.T. information for future product development reference. Apacer devices use the standard SMART command B0h to read data out from the drive to activate our S.M.A.R.T. feature that complies with the ATA/ATAPI specifications. S.M.A.R.T. Attribute IDs shall include initial bad block count, total later bad block count, maximum erase count, average erase count, power on hours and power cycle. When the S.M.A.R.T. Utility running on the host, it analyzes and reports the disk status to the host before the device reaches in critical condition. 8 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX Note: Attribute IDs may vary from product models due to various solution design and supporting capabilities. Apacer memory products come with S.M.A.R.T. commands and subcommands for users to obtain information of drive status and to predict potential drive failures. Users can take advantage of the following commands/subcommands to monitor the health of the drive. Code D0h D1h D2h D4h D5h D6h D8h D9h DAh Byte 0 1–2 3 4 5*-11 SMART Subcommand READ DATA READ ATTRIBUTE THRESHOLDS Enable/Disable Attribute Autosave Execute Off-line Immediate Read Log (optional) Write Log (optional) Enable Operations Disable operations Return Status General SMART attribute structure Description ID (Hex) Status flag Value Worst Raw Data *Byte 5: LSB ID (Hex) 9 (0x09) 12 (0x0C) 163 (0xA3) 164 (0xA4) 166 (0xA6) 167 (0xA7) 168 (0xA8) 175 (0xAF) 192 (0xC0) 194 (0xC2) 241 (0xF1) SMART attribute ID list Attribute Name Power-on hours Power cycle count Max. erase count Avg. erase count Total later bad block count SSD Protect Mode (vendor specific) SATA PHY Error Count Bad Cluster Table Count Unexpected Power Loss Count Temperature Total sectors of write 9 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 6. Electrical Specifications Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 6-1 Operating Range Ambient Temperature 0°C to 70°C Extended Temperature Supply Voltage -40°C to 85°C 5V ± 5% (4.75-5.25V) Table 6-2 Typical Power Consumption Capacity 8 GB 16 GB 32 GB 64 GB Active (mA) 155 175 175 205 Idle (mA) 80 80 80 80 Modes Note: Results may differ from various flash configurations or host system setting. 10 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 7. Mechanical Specifications 7.1 Dimensions Unit: ㎜ Tolerance: ± 0.25 11 © 2016 Apacer Technology Inc. Rev. 1.1 e SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 7.2 Write Protect Switch (optional) Write Protect Switch Enable Disable Description of Apacer Write Protect: Apacer implements the Virtual Write scheme that allows write commands to go through the flash controller and data temporarily stored, but no data has been actually written into the flash. Since the Virtual Write scheme runs at device level, it requires no software or driver installation and is independent from the host OS. 12 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 8. Product Ordering Information 8.1 Product Code Designations AP SDM x x x G Q 2 X N – E TM1 X X Cable Type Blank: Power cable type C: Cable-less type (7+2) Operating Temperature Range Blank: 0°C to 70°C W: -40°C to 85°C Flash Type FW Version N: Standard A: Standard W: Write Protect Solution Version Form Factor Q: 7P90D MP2 Capacity 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB Serial ATA Flash Module Apacer Product Code 13 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX 8.2 Valid Combinations 8.2.1 Without Write Protect Capacity 8GB 16GB 32GB 64GB Standard Temperature APSDM008GQ2AN-ETM1 APSDM016GQ2AN-ETM1 APSDM032GQ2AN-ETM1 APSDM064GQ2AN-ETM1 Extended Temperature APSDM008GQ2AN-ETM1W APSDM016GQ2AN-ETM1W APSDM032GQ2AN-ETM1W APSDM064GQ2AN-ETM1W 8.2.2 With Write Protect Capacity 8GB 16GB 32GB 64GB Standard Temperature APSDM008GQ2WN-ETM1 APSDM016GQ2WN-ETM1 APSDM032GQ2WN-ETM1 APSDM064GQ2WN-ETM1 Extended Temperature APSDM008GQ2WN-ETM1W APSDM016GQ2WN-ETM1W APSDM032GQ2WN-ETM1W APSDM064GQ2WN-ETM1W Note: 1) The P/Ns are for models with power cable. However, for models without power cable, P/Ns vary depending on the type of cable-less solution: For 7+2 cable-less solution, an additional digit “C” will be added at the end of the P/N. 2) Valid combinations are those products in mass production or will be in mass production. Consult your Apacer sales representative to confirm availability of valid combinations and to determine availability of new combinations. 14 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX Revision History Revision Date Description Remark 1.0 10/18/2016 Official release 1.1 11/24/2016 Added valid combinations with Write Protect support 15 © 2016 Apacer Technology Inc. Rev. 1.1 SATA-Disk Module 5A-M APSDMxxxGQ2XN-ETM1XX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9551 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 16 © 2016 Apacer Technology Inc. Rev. 1.1
APSDM016GQ2WN-ETM1 价格&库存
很抱歉,暂时无法提供与“APSDM016GQ2WN-ETM1”相匹配的价格&库存,您可以联系我们找货
