10C1616LMH12309
10C1616LMH12309
    APEM(埃斐)
    圆形,凹陷 触动式 开关盖帽 白色,磨砂 卡入式
10C1616LMH12309 数据手册
10C -1 M Round caps • ergonomic feel DISTINCTIVE FEATURES Slightly concave round cap Ø19.2 mm h=13.7 mm Consists of two pieces Designed for excellent illumination SWITCH SPECIFICATIONS : see Multimec™ 5 series. 13,7 (0,540) 11,2 (0,441) 5G+10C - SMD Ø 19,2 (0,754) Ø2 7,62 (0,300) 14 (0,551) 2,0 (0,8 66) 11,2 (0,441) 5G+10C - TH W/LED Min 10,16 (0,400) Max 12,5 (0,492) 13,7 (0,540) EC PANEL PCB SWITCHES 08 20 0C Ø 19,2 (0,754) Ø2 7,62 (0,300) 2,0 (0,8 66) The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm. 1 Round caps • ergonomic feel MOUNTING MATERIALS • Top part of the cap: : - solid color : ABS UL94HB - illuminated : polycarbonate UL94HB • Panel cut-out : Ø19.8 mm • Switch spacing AxB : illuminated 30.2 x 30.2 mm non-illuminated 24 x 24 mm • Bottom part of the cap : polycarbonate UL94HB ASSEMBLY 1. LED PLACEMENT 2. SMD 14,0 (0,551) 14,0 (0,551) 7,0 (0,276) 1,2 (0,047) 7,62 (0,300) 7,0 (0,276) 2,5 (0,098) 12,5 (0,492) TH 14,0 (0,551) 10,16 (0,400) 2 Ø 1 14,0 (0,551) 7,0 (0,276) 7,0 (0,276) 7,62 (0,300) PCB SWITCHES 10C (0 ,0 39 ) Round caps • ergonomic feel BUILD YOUR PART NUMBER ILLUMINATED 5G SERIES LED MOUNTING TH9 through-hole SH9 surface mount ACTUATION FORCE CAP COLOR TOP 10C 16 02 blue 22 green 29 high intensity green 42 yellow PRINT TYPE frosted white R Reverse print LMH Hard paint laser marked COLOR BOTTOM PAINT COLOR 20 2.0N 61 white 35 3.5N 82 red 65 6.5N 2242 green/yellow 8222 red/green 118 8242 red/yellow 123 16 09 frosted white black LEGEND OK NON-ILLUMINATED 5G MOUNTING SERIES ACTUATION FORCE TH9 through-hole 20 2.0N SH9 surface mount 35 65 CAP 10C COLOR TOP LEGEND 00 blue 118 3.5N 03 grey 123 6.5N 08 red 09 black 36 signal white COLOR BOTTOM 16 frosted white OK LEGEND COLOR 06 white ABOUT THIS SERIES Notice : please note that not all combinations of above numbers are available. Contact APEM for more information. For more information on legends see the next two pages. 3 PANEL PCB SWITCHES 10C PCB SWITCHES Legends Available for Multimec caps STANDARD LEGENDS STANDARD LEGENDS LEGEND 1DS09_ 1FS096R_ 0 000 000 1 001 001 2 002 002 3 003 003 4 004 004 5 005 005 6 006 006 7 007 007 8 008 008 9 009 009 # 107 107 019 019 1ZB09D_ 1ZB16DLMH_ 1ZCS_ 1Z_ 1ZW_ 10Q_ 10QM16_ 10R_ & 10RF_ 10RM16_ 054 054 054 059 059 059 123 123 10A_ 10C_ 10D_ 033 133 034 134 135 135 + 136 123 123 136 123* 136 123 123 123 ON/OFF 017 017 STOP 018 018 031 031 038 038 048 048 105 105 118 118 START RESET 038 CANCEL ENTER ESC 051 ON 116 OFF 117 OK 118* SET 119 MENU 120 FUNC 121 HOME 122 118 118 118 STANDARD OPTIONS 1 • 1DS: pad printed • 10A: pad printed / laser marked • 1FS: reverse printed • 10C: pad printed / laser marked • 1ZB: pad printed / laser marked • 10D: UV printed / laser marked • 1ZCS: pad printed / *reverse printed / *laser marked • 10R(F) & 10Q: pad printed / reverse printed • 1Z & 1ZW: pad printed / laser marked • 10RM & 10QM: metal symbol Available for Multimec caps HOW TO ORDER POSITIONING OF LEGENDS ON ROCKER-ACTION CAPS LEGEND ILLUMINATION • Option 1 - laser marked: In case of laser marked legends an “LM” is added after the cap colour, before the legend code. We recommend using hard paint (additional “H” ) for increased lifetime of the paint. E.g. 1ZB16DLMH13609 When ordering legends for caps with hinge-type cap retention system, it is important to note the position of the cap. An extra letter (U, D, R or L) needs to be added to the part number to refer to the position of the hinges in relation to the legend. See samples: • Option 2 - reverse printed: In case of reverse printed caps an “R” is added after the cap colour, before the legend code. Especially relevant when standard legends have both negative and positive print options. E.g. 1FS096R00009 Rocker-action caps without a lens: 1A, 1B, 1M, 1ZA and 1ZB ON/OFF UP 1A09U01706 ON/OFF RIGHT 1ZB16RLMH11809 OK ON/OFF • Option 3 - metal symbol: Only available ON/OFF for 10RM andON/OFF 10QM (therefore the “M”). E.g. ON/OFF ON/OFF 10RM16059 ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF 3 1 + ON/OFF - 4 DOWN 2 1B09D01706 2 4 1 + ORIENTATION OF THE SWITCH LEFT 1ZB09L00106 1 3 3 + 1 1 + 3 + - 1 4 4 2 UP - 2 - 4 2 2 1 1 + 4 3 + 3 DOWN STANDARD AND CUSTOM LEGENDS 3 • Standard are only certain legends on certain caps. See the table on the previous page. • All standard pad-printed legends are white on black caps. • All standard reverse-printed and laser marked legends are black on frosted white cap. STANDARD LEGENDS CAP COLOR CAP DIRECTION* TYPE* LEGEND LEGEND COLOR* 1DS 00 Blue D Down UV UV printed 001 1 00 Blue 1FS 02 Green U Up 2 02 Green ... Grey R Right Laser marked on soft paint 002 03 LM 3 03 Grey Yellow L Left Laser marked on hard paint 003 04 LMH etc 04 Yellow 06 White 06 White 08 Red 08 Red 09 Black 09 Black 16 Frosted white ... Etc ... Etc R *Only for hingetype caps Reverse printed *In case of illumination ... *In case of reverse printed and laser marked legends the colour of the paint Notice: The size of the legends listed may not correspond to the actual size. If you decide to use one of the standard legends without any adjustments (without a new cliché or programming) on another cap than designated in the table, then there is no cliché or programming cost, for this to apply the cap has to be black and the print white. For further information on legends please contact your local distributor or MEC. 2 PANEL PCB SWITCHES Legends • • • • • • • 1B • • • • • • • 1DS • • • • • • • • • • • • 1ES/1FS 1GAS/1GCS • • • • • • 1H 36 38 40 42 50 53 57 58 • • • • • • • • 1JS • • • • • • • 1KS • • • • • • • • 1LS • 1M • • • 1NS 1PS • 1QS • • • • • • • • • • • • 1RS 1SS • 1TS/1US/1VS • • • • • • • • • • 1WAS/ 1WDS/1WPS • 1XS • • • 1ZA • • • • • • • • • • 1ZB • • • • • • • • • • 1ZCS • • • • • • • • • • 1Z/1ZW • • 10A • • • • • • 10C • 10R/10RF + 10Q • • 10D • • • • • • • • • • • The RAL Codes mentioned are the codes nearest to the solid colors in the multimec™ range. 3 Metal bordeaux / No ral code 1A Metal dark grey / No ral code 08 Metal light grey / No ral code 06 Metal dark blue / No ral code 04 Aqua blue / 5021 Melon / 1028 • 03 Dusty blue / 5014 Tele grey / 7046 • 02 CODE Noble red / 3002 Mint green / 6029 • 00 CAP Signal white / 9003 Ultra blue / 5002 • Red / 3000 34 White / 9010 33 Yellow / 1023 32 Grey / 7004 30 green / 6018 09 Blue / 5012 Black / 9004 Available for Multimec™ caps Colour / RAL Code PCB SWITCHES Solid colors • ■ Designed for 5G cap retention system ■ Stackable, giving the possibility to match most overall heights ■ h =5-10 mm ■ Material: Nylon Extender for 5G cap range Range: Extender 5Grange cap range 5G + caps Extender Extender for■ Temp. 5Gfor cap 5G + Extender 2SS 2SS Multimec™ • Switch: -40/+160°C • LED: -30/+85°C ■ Designed for 5G cap retention system • Solid keycap: -40/+65°C ■ Designed for 5G cap retention system giving the possibility to match most overall ■ Designed for 5G cap retention system • Transparent keycap: -40/+85°C ■ Stackable, ACCERSSORY SPECIFICATIONS All dimensions in mm Tolerances -/+0.2mm ■ Stackable, giving the possibility to match most overall heights ■ Stackable, giving the possibility to match most overall MATERIAL PARTS TEMP. LIMIT UL RATING heights ■ h =5-10 mm heights DIMENSIONS ABS Solid color 1A, 1B, 1DS, 1ES, 1FS, 1H, 1JS, 1KS, 1LS, 1M, 1NS, 1PS, 1QS, 1RS, 1TS, 1US, 1VS, Max 65 °C UL94HB ■ hmm =5-10 mm 1WAS, 1WDS, 1WPS, 1XS, 1Z, 1ZA, ■ Material: ■ h =5-10 1ZB, 1ZCS,Nylon 1ZW, 10A, 10C, 10Q, 10R, 10RF and AQCS Max 149 °F reflectors 1KBS, 1KCS, 1YS and 1YASSMD + 2SS+1DS 2SS■ Material: SMD + 2SS+1GCS TH + 2SS+1TS ■forTemp. Range: ■ Material: Nylon NylonBezels 2C, 2D and 2K, Polycarbonate All lenses and transparent colour caps, lids for 1KBS & 1KCS Max 85 °C UL94HB ■ Temp. Range: • Switch: -40/+160°C ■ Temp. Range: 1GCS Max 185 °F 1GCS 5 mm, 6 mm, 7 mm, 8 mm, 15 -40/+160°C • LED: -30/+85°C 15 • Switch:• Switch: -40/+160°C 9 mm, 10 mm 1GAS, 1GCS, 1SS and 2SS Max 160 °C UL94V2 • LED: -30/+85°C • Solid keycap: -40/+65°C • Polyamide LED: -30/+85°C Max 320 °F • Solid keycap: -40/+65°C • Transparent keycap: -40/+85°C • Legends Solid keycap: -40/+65°C adhesion DS/EN ISO 2409 Class 1 & ASTM D3359 Class 4B All dimensions in mm Tolerances -/+0.2mm • Transparent -40/+85°C • Transparent keycap:keycap: -40/+85°C DIMENSIONS DIMENSIONS EXTENDERS 0,3 0,3 14 0,8 7,62 PANEL PCB SWITCHES Total height 19,9 - 24,9 5 - 10 Height 5 - 10 5 - 10 Total height 19,9 - 24,9 Height 5 - 10 Total height 19,9 - 24,9 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 10 Tolerances Tolerances -/+0.2mm-/+0.2mm DIMENSIONS 0,8 Total height 17,5 - 22,5 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 10 Height 5 - 10 5 - 10 Total height 19,9 - 24,9 Height 5 - 10 All dimensions All dimensions in mm in mm Total height 17,5 - 22,5 Cap & Bezel Specifications multimec® multimec® multimec® 0,3 0,8 7,62 Height Total height 19,9 - 24,9 Height 5 - 10 Total height Height 19,9 - 524,9 5 - 10 - 10 Height Total height 5 - 10 17,5 - 22,5 Height Total height 5 - 10 19,9 - 24,9 5 - 10 Height 5 - 10 Total height 17,5 - 22,5 Total height 17,5 - 22,5 Total height 17,5 - 22,5 Total height 19,9 - 24,9 Height 5 - 105 - 10 Ordering example: 5GTH935+1GAS09+2SS09-06.0 OR *5GSH920Q or 5GTH92082Q (quiet 4version) Please colour codes, of products and changes of specifications on www.mec.dk Ordering example: 5GTH935+1GAS09+2SS09-06.0 ORsee *5GSH920Q or updates 5GTH92082Q (quiet version) Ordering example: 5GTH935+1GAS09+2SS09-06.0 OR *5GSH920Q or 5GTH92082Q (quiet version) Height 5 - 10 Total height Total height 0,3 19,9 - 24,9 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 10 0,3 0,3 H1 H2 H1 H3 H1 H2 H3 H2 H3 H1 H2 H3 Height Total height 5 - 10 19,9 - 24,9 Height 5--10 10height 5Total 17,5 - 22,5 Total height 19,9 - 24,9 Height 0,3 5 - 10 Total height 17,5 - 22,5 Height Height 5 - 10 5 - 10 Height Total height 5 - 10 0,3 Total19,9 height - 24,9 17,5 - 22,5 Height Total 5 - 10height 17,5 - 22,5 0,3 Total height 17,5 - 22,5 Height 5 - 10 Height 5 - 10 Height Total 5 height - 10 17,5 - 22,5 5 - 10 Total height 17,5 - 22,5 Total height 17,5 - 22,5 Height 5 - 10 Total height Height 17,5 - 522,5 - 10 Height 5 - 10 Total height 19,9 - 24,9 Total height 17,5 - 22,5 Height 5 - 10 0,3 0,3 0,3 Height 5 - 10 Total height 17,5 - 22,5 Height 5 - 105 - 10 0,3 5 - 10 Total height 19,9 - 24,9 19,9 - 24,9 Height 5Total - 10height 17,5 - 22,5 Height 5 - 10 Min 10,16 1GCS + 2SS+1DS 2SS 14 SMD + 2SS+1GCS SMD 15Max 12,5 2SS SMD + 2SS+1GCS SMD + 2SS+1DS TH + 2SS+1TS 2SS SMD + 2SS+1GCS SMD + 2SS+1DS TH + 2SS+1TS 1GCS 1GCS HOW TO ORDER 5 mm, 6 mm, 7 mm, 8 mm, 15 5 mm, 6 mm, 1GCS 15 1GCS 1GCS 1GCS mmmm , 8 mm, 1GCS 9 mm,715 10 5 mm, 615mm, 7 mm, 8 mm, 15 5 mm, 6 mm, 7 mm, 8 mm, 15  15 9 mm, 10 mmLED (optional) Cap Extender 2SS Switch Actuation force mm, 10 mm Mounting 9 mm, 109mm 0,8 height 7,62 14 + 5 G 2 S S 0 9 . 0 See the table TH9 through-hole 20 02 blue below0,8 0,805.0 SH9 surface mount 35 22 green 7,62 14 0,8 7,62 14 0,8 0,8 06.0 0,8 42 yellow 65 0,8 0,3 7,62 0,3 0,8 0,8 7,62 14 7,62 14 7,62 14 7,62 Min 10,16 14Q* Min 10,16 07.0 61 white 1GCS 1GCS 7 7,62 Max 12,5 15Max 12,5 15 08.0 82 red HOW TO ORDER 09.0 2242 green/yellowSMD + 2SS+1DS HOW TO ORDER HOW TO ORDER TH+2SS+1TS 2SS Cap LED (optional) Switch Mounting Actuation force 10.0 8222 red/green *For an illuminated quiet 2.0N switchActuation add Q Cap Extender 2SS LED8242 (optional) Cap Extender 2SS LED (optional) Switch SwitchMountingMounting Actuation force 5force red/yellow 14 + G to the end of the switch part number. 0,8 height 0,8 height 7,62 14 + 7,62 5 G 14 + 5 G See the tab TH9 through-hole 20 02 blue . 0 2 S S 20 S9 S- 0 9 - . 0 below HOW TO USE 1GAS/1GCS + 2SS FOIL CANthe BE table USED WITH ALL See the table 02 blue TH9 through-hole surface mount 2SS35 225G-TYPE green SNAP-ON CAPS See 02 blue SH9 TH9 through-hole 20UNDER20 How tosurface useSH9 1GAS/1GCS + 2SS foil 2SS can be used with all 5G-type snap-on below 05.0caps below 05.0 surface mount 42 yellow 65 SH9 mount 35under35 22 green22 green 06.0 the possibility to All 2SS 06.0 65 Q* extenders are stackable 61 whitegiving 42 yellow42 yellow A65 match most overall heights. Foil All 2SS extenders are stackable giving the possibility to match most overall 07.0 Q* 82 red 07.0 Q* 61 white 61 white heights. 08.0 08.0 green/yellow 2242 82 red 82 red HEIGHT WITH A ORIGINAL 09.0 SINGLE EXTEN09.0 2242 green/yellow 8222 red/green 2242 green/yellow CAP SERIES *For an illuminated quiet 2.0N switch add Q HEIGHT (H1) Cap Original with a single extender DER (H2;H3) 10.0 Height 10.0height 8222 red/green 8242 red/yellow red/green to the8222 end of the switch part number. *For an illuminated quiet 2.0N switch *For an illuminated quiet 2.0N switch add Q add Q (H2;H3) (H1) 1DS/1ES/1FS 14.9 19.9-24.9 8242 red/yellow 8242 red/yellow to of thethe end of the switch part number. to the end switch part number. 19.9-24.9 14.9 12.5 1DS/1ES/1FS 1GAS/1GCS 17.5-22.5 17.5-22.5 12.5 1GAS/1GCS 24.1; 25.2; 25.1-29.1; How to use 1GAS/1GCS + 2SS under foil1KS/1KBS/1KCS 2SS can30.1 be used with all 5G-t 19.1 ; 20.2 ; 20.1 PCB 30.2; 24,1; 25,2; 25,1-29,1; 30,2; 30,1 19.1; 20.2; 20.1 1KS/1KBS/1KCS How to use 1GAS/1GCS + 2SS 2SSused can be used5G-type with all 5G-type snap-on caps How to use 1GAS/1GCS + 2SS under foilunder foil snap-on caps A be Panel 2SS can 19.9-24.9 14.9 14.9 1NSwith all 1NS 19.9-24.9 Foil All 2SS extenders are stackab A you toAallocate enough space for travel of the foil and 19.9-24.9 14.9 14.9 1TS/1US/1VS 1TS/1US/1VS 19.9-24.9 recommend heights. Foil All 2SS extenders are stackable giving the possibility to match most overall Foil •A=We A=We recommend space for travel of the foil and leave All 2SS extenders are stackable giving the possibility to match most overall 20.7-25.7 15.7 1WAS/1WDS/1WPS leave the area free from adhesive 1WAS/1WDS/1WPS 15.7 20.7-25.7 heights. heights. the area free from adhesive. 23.5-28.5 18.5 18.5 1XS H=We recommend you to calculate this dimension from the top of the PCB 1XS 23.5-28.5 Cap Orig •toHthe =We recommend youwith to calculate this dimension 16.7-21.7 11.7 1ZCS inner top of the panel a small pretention 0.1-0.2mm from Cap 1ZCSOriginal height 16.7-21.7 Cap Original11.7 height Height withextender a single extender(H1) Height with a single the top of the PCB to the inner top of the panel. (H1) 13.7(H2;H3) (H2;H3) 10C(H1) 18.7-23.7 14.9 1DS/1ES/1FS 17.0-22.0 14.9 12.019.9-24.919.9-24.9 1DS/1ES/1FS10D14.9 12.5 1GAS/1GCS 1DS/1ES/1FS PCB 17.5-22.5 12.5 1GAS/1GCS 19.1; 1KS/1KBS/1KCS 17.5-22.5 12.5 1GAS/1GCS Ordering example: 5GTH935+1GAS09+2SS09-06.0 OR *5GSH920Q or 5GTH92082Q (quiet version) PCB PCB Panel 24,1; 25,2; 25,1-29,1; 30,2; 30,1 19.1; 20.2; 20.1 1KS/1KBS/1KCS 14.9 1NS 24,1; 25,2; 25,1-29,1; 30,2; 30,1 19.1; 20.2; 20.1 1KS/1KBS/1KCS Please see colour codes, updates of products and changes of specifications on www.mec.dk Panel Panel 19.9-24.9 14.9 1NS 14.9 1TS/1US/1VS 19.9-24.9 14.9 1NS A=We recommend you to allocate enough space for travel of the foil and 19.9-24.9 14.9 1TS/1US/1VS 15.7 1WAS/1WDS/1WPS 19.9-24.9 14.9 1TS/1US/1VS thefoil area free A=We recommend you to enough allocatespace enough for travel ofand the foilfrom andadhesive A=We recommend you to allocate forspace travelleave of the 20.7-25.7 15.7 1WAS/1WDS/1WPS 18.5 1XS 20.7-25.7 15.7 1WAS/1WDS/1WPS the area from adhesive H=We recommend you to calculate this dimension from the top of the PCB leave theleave area free fromfree adhesive 23.5-28.5 18.5 1XS 11.7 1ZCS to the inner top of the panel with a small pretention 0.1-0.2mm 23.5-28.5 18.5 1XS H=We recommend you to calculate this dimension of the PCB H=We recommend you to calculate this dimension from the from top ofthe thetop PCB 16.7-21.7 11.7 1ZCS to the inner top of the panel with a small pretention 0.1-0.2mm 16.7-21.7 11.7 1ZCS to the inner top of the panel with a small pretention 0.1-0.2mm PCB SWITCHES Cap & Bezel Specifications Multimec™ caps HOW TO ORDER EXTENDERS + SWITCH 5G 5 MOUNTING ACTUATION FORCE LED (OPTIONAL) 2SS09- CAP See the table on the previous page .0 EXTENDER 2SS HEIGHT TH9 Through-hole 20 02 blue 05 SH9 Surface mount 35 22 green 06 65 42 yellow 07 61 white 08 82 red 09 2242 green/yellow 10 8222 red/green 8242 red/yellow Multimec™ 5G M U -M EC I LT PANEL PCB SWITCHES EC 8 10 -2 5G M High performance tactile switches • MIL-PRF-28855H • excellent illumination DISTINCTIVE FEATURES Large range of accessories Momentary switches with NO or NC/NO function Sealed to IP67 Single or bi-color illumination option Illumination with integrated chip-LEDs ENVIRONMENTAL SPECIFICATIONS • Sealing : IP67 according to IEC 60529 • Working and storage temperature : - non-illuminated: -40 °C/+160 °C (-40 °F to +320 °F) - illuminated: -30 °C/+85 °C (-22 °F to +185 °F) • Soldering : - through-hole : IEC 60068-2-20 8 - surface mount : JEDEC J-STD-020E ELECTRICAL SPECIFICATIONS • Recommended load : - Gold contacts : 0.5µ-50 mA 24 VDC - Silver contacts : 0.5-50 mA 24 VDC • Contact resistance : 10 MΩ • Contact bounce : 10,000,000 cycles - NC/NO : >1,000,000 cycles The company reserves the right to change specifications without notice. • Actuator : PPS UL94V0 • Sealing : Silicone rubber • Terminals : SnCu + 2 µNI + 3 µSn100 All tolerance if not otherwise specified ±0.2 mm. 1 High performance tactile switches • MIL-PRF-28855H • excellent illumination RAS 6,4 13,8 12 0,8 0,8 Min 10,16 5,5 Max 12,5 7,62 10 11 14 7,62 0,8 7,62 7,62 7,62 5,08 5G ILLUMINATED 7,62 7,62 4 0,8 • SMD, TH or right angle TH • NO or NC/NO Min 10,16 Max 12,5 5,08 0,3 6,4 10 14 12 11 4 0,3 10 13,8 5,5 6,4 6,4 TH 10 SMD 5G NON-ILLUMINATED 4,85 7,62 SMD TH 8,5 8,5 4:1 0,3 10,0 0,3 14 10,0 Min 10,16 Max 12,5 4:1 5G RAS • SMD or TH • NO • single or bi-color LEDs 0,8 0,8 7,62 7,62 All tolerances unless otherwise noted : ±0.2 mm PCB LAYOUT & CIRCUIT DIAGRAM -2 4 3 12,50 2 -2 4 +3 -2 1 4 2,5 +3 1 1 4 +3 2,50 2 1 4 3 3 Ø1,0(3x) 12,50 1,20 1,2 3 +3 Ø 0,9 7,62 -2 7,62 2,5 1 Ø 0,9 12,50 1 1,2 *not for sale in Japan 1 Ø 0,9 2 4 NC/NO function 7,62 5,08 1 7,62 4 RAS 10,16 7,62 10,16 Bicolor - 2 LEDs 10, 16 7,62 2 Single LED 7,62 Non-illuminated 7,62 PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination BUILD YOUR PART NUMBER ILLUMINATED 5G ACTUATION FORCE MOUNTING SERIES LED OPTIONAL TH9 Through-hole 20 2.0 N 02 Blue SH9 Surface mount 35 3.5 N 22 Green 65 6.5 N 29 High intensity Green 42 Yellow 61 White 82 Red 2242 Green/yellow 8222 Red/green 8242 Red/yellow Q Quiet contact (with 2.0 N only) R Tape & reel (with SMD only) G Gold contacts NON-ILLUMINATED 5G MOUNTING SERIES OPTIONAL ACTUATION FORCE TH9 Through-hole 20 2.0 N SH9 Surface mount 35 3.5 N 65 6.5 N Q RAS NCNO Quiet contact (with 2.0 N only) Right angle (with TH only) Normally closed/ normally open function (with 3.5 N only) R Tape & reel (with SMD only) G Gold contacts ABOUT THIS SERIES Laser marking on the switch for identification : WWYS, WW=week, Y=year, S=suffix for the type of switch, e.g. P=2.0 N and silver contacts, S=3.5 N and silver contacts, E6.5 N and silver contacts Caps and accessories : for the full range of accessories for Multimec™ 5G please see the website. 3 PANEL PCB SWITCHES Multimec™ 5G PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination TAPE & REEL Tape and reel is available for the parts listed and has the following specifications PART NO. ORDERING CODE PITCH QUANTITY PER REEL 5GSH9XX 5GSH9XXR 16 500 • Reel diameter: Ø330 mm 5GSH9XX1SSXX-08.0 5GSH9XXR1SSXX-08.0 20 250 • Tape width: 24 mm 5GSH9XX1SSXX-09.5 5GSH9XXR1SSXX-09.5 20 250 • Pitch: see list 5GSH9XX1SSXX-10.4 5GSH9XXR1SSXX-10.4 20 250 5GSH9XX1SSXX-11.0 5GSH9XXR1SSXX-11.0 20 250 5GSH9XX1SSXX-12.0 5GSH9XXR1SSXX-12.0 20 250 5GSH9XX02 5GSH9XX02R 20 250 5GSH9XX22 5GSH9XX22R 20 250 5GSH9XX29 5GSH9XX29R 20 250 5GSH9XX42 5GSH9XX42R 20 250 5GSH9XX61 5GSH9XX61R 20 250 • Tape and reel material: antistatic or better • Quantity per reel: see list 5GSH9XX82 5GSH9XX82R 20 250 5GSH9XX2242 5GSH9XX2242R 20 250 5GSH9XX8222 5GSH9XX8222R 20 250 5GSH9XX8242 5GSH9XX8242R 20 250 OPERATING FORCE 2.0 N 10 FORCE 6.5 N 10 FORCE 9 9 8 8 8 7 7 7 6 6 6 5 2N 5 F(N) 9 F(N) F(N) 10 3.5 N 3,5N 5 4 4 4 3 3 3 2 2 2 1 1 1 TRAVEL TRAVEL 0 0 0 4 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 FORCE 6,5N TRAVEL 0 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 High performance tactile switches • MIL-PRF-28855H • excellent illumination RECOMMENDED OPERATING CONDITIONS 0,3 [0.012 in] Max. e tio ng ec ra dir e l gl ca an rti g (ve in an 4° Le ° ± 90 Plunger n) Switch For the optimal performance of the switch use the recommended operating conditions. MOUNTING MOUNTING TOOLS FOR MULTIMEC™ THROUGH-HOLE SWITCHES Part No. 9861000 1 2 3 4 5 MULTIMEC™ SPACING EXAMPLES 15.4 Min 10.16 Max 12.5 12.7 25.3 Min 10.16 Max 12.5 14.0 1.4 14.0 10.16 15.14 15.4 10.16 10.16 10.16 2.54 10.16 5.24 10.16 5GT+1B+2C/D 12.7 5GS+1B+2C/D 5GT+1M 5GT+1A/H 12.7 1VS+1TS+1VS 5 PANEL PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination MOUNTING (CONTINUED) Min. 12,7 Min. 12,7 Min. 15,24 Min. 10,3 Min. 10,3 Through-hole (TH) Min. 10,3 SPACE REQUIREMENT - MATRIX MOUNTING Min. 10,3 PCB SWITCHES Multimec™ 5G Surface mount (SMD) Min. 15,24 SPACE REQUIREMENT - SWITCH/CAP Cap dimensions Switch spacing Panel cut-out 6 CAP SERIES RECOMMENDED MIN.SWITCH SPACING AxB NOMINAL CAP DIMENSION WxH RECOMMENDED MIN. PANEL CUT-CUT 1A/1H 12.7x10.3 12.6x10.1 13.0x10.5 1B+2C/2D 15.4x15.4 15.1x15.1 15.5x15.5 1DS/1ES/1FS 12.7x11.3 Ø9.6 Ø10.0 1GAS 12.7x11.3 Ø11.0 Ø11.4 1GCS 15.3x15.3 Ø15.0 Ø15.4 1JS 12.7x10.3 Ø10.0 Ø10.4 1KS/1KBS/1KCS 14.6x14.6 14.3x14.3 14.7x14.7 1M 25.3x10.3 25x10 25.7x10.5 1NS 13.6x11.3 Ø9.8/ 14.9 Ø10.2/15.1 1PS/ 1QS/1RS 12.8x10.3 6.5x12.5 7x13, R max. 1.0 1SS/1IS/1LS 12.7x10.3 Ø6.5 Ø7.0 1TS 12.7x12.3 10.6x10.6 11.0x11.0 1US 12.7x12.3 Ø10.6 Ø11.0 1VS 15.95x12.1 10.6x13.25 11.0x13.65 1WAS/1WPS 14.2x10.3 12.5x6.5 12.9x6.9 1WDS 16.9X10.3 15.2x8.0 15.6x8.4 1XS 12.7x10.3 9.4x7.4 9.8x7.9 1ZA 19.0X10.3 18.7x10.1 19.4x10.5 1ZB 24.34x12.1 R1=7.4; R2=17.5 90° R1=7.1; R2=17.5-17.75 90° 1ZCS 14.6x14.6 Ø14.3 Ø14.7 1Z/1ZW 35.5x35.5; 41.6x41.6 Ø29.5 Ø30.3 Ø19.2 Ø19.8 Ø16.4 10C 22.3x22.3 10D (+10DWY) 19x19 (27x27) Ø16 10R/10RF/10RM 37.3X37.3 Ø30.0 Ø30.6 10Q/10QM 29.3X29.3 22x22 22.5x22.5 High performance tactile switches • MIL-PRF-28855H • excellent illumination LED COMPONENT SPECIFICATIONS LED COMPONENT SPECIFICATIONS Color Blue Green Yellow White Red High Intensity Green Color Codes 02 22 42 61 82 29 ABSOLUTE MAXIMUM RATINGS (Ta= 25°C) Power mW 75 75 60 46.5 65 102.5 Current forward mA 20 30 25 15 25 25 Forward peak current mA 100 80 60 100 100 150 Voltage reverse V 5 5 5 5 12 5 Operating temperature °C -40/+85 -55/+85 -40/+85 -40/+85 -30/+85 -40/+85 Storage temperature °C -40/+90 -55/+85 -40/+90 -40/+85 -40/+85 -40/+85 Soldering temperature °C 2 3.3 245 for max 10 sec ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25 °C) Voltage forward Typ. V 2.7 Max. V Current reverse (VR=5V) Max. µA Wave length nm Spread nm 1.75** 2.85 3.7 2.4 2.35 3.1 2.5 4.1 50 100 10 10 100 50 468 571 591 NA 633 525 25 NA 15 NA 16 30 120 130 120 150 160 60 Min. mcd 45 18 28.5 56 28 500 Typ. mcd 112* 35 72* max 450* max 180* 1000 Lm/w NA NA NA 36 7 NA Spread angle degree Luminous Intensity Optical intensity 2 */F=20 mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50 mA, ****Luminous Flux mlm 7 PANEL PCB SWITCHES Multimec™ 5G PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination USAGE GUIDELINES HOW TO GET THE BEST RESULTS WITH MEC SWITCHES ? case situation with water jets, complete immersion into a liquid with a temperature below the board or surface tension reducing additives. These guidelines are offered to users of MEC Switches as an aid to ensure successful and reliable switch operation. Please see the technical specifications for details on operating and storage temperatures and soldering guidelines to make sure you select the best switch for your application. When reflow soldering is taking place, MEC strongly recommend that the temperature profile is analyzed and compared with the temperature rating of the switch. It is also important to monitor the accumulated heat buildup from both the pre-heat zones and the solder zone. Recommended cleaning methods are demineralized water. Any surface tension reducing agents, such as soap, must not be used as they risk causing a potential leakage of the switch. Most standard accessories for multimec™ 5 series switches are made from ABS plastic with a maximum operating temperature of 65 °C. It is strongly recommended that accessories are mounted after soldering of the switch. If this is not possible care must be taken not to overheat the accessories during the soldering process. The 1SS and 1GAS/1GCS caps are, however, made of high temperature materials and will meet the same temperature specifications as the switches. For accessories made from other plastic materials please see multimec™ 5 series cap & bezel technical specifications. Wave soldering: heat built up in the switch during pre-heating and soldering must not exceed the maximum operating temperature of the switch. Peak temperature must not exceed 260 °C, and soldering time is max 10 sec. (IEC 60068-2-20 8) SOLDERING - THROUGH HOLE VERSIONS Hand soldering: max. 350 °C for max. 3 sec SOLDERING - SURFACE MOUNT VERSIONS LEDs have their own temperature specifications. When fitted in a switch the LED will determine the max. operating temperature, i.e. 5GTH93522 has an upper temperature limit of 85 °C! For all methods - infrared, convection and vapor phase. The upper limit 240 °C/40 sec must be observed. The soldering temperature profile must have moderate temperature gradients. (JEDEC J-STD020E) MOUNTING AND DISMOUNTING ROHS COMPLIANCE If switches are to be mounted in rows it is essential that the recommendations regarding spacing are followed. PC board thickness should be 1.4 ±0.2 mm and terminal hole diameter should be 0.9 mm. As of 1 July 2006 MEC has completed the conversion to RoHS compliance. For more info please see our homepage www.apem.com All multimec™ 5 series caps and bezels are easily snapped onto the switch modules and can be changed at a later time. TEMPERATURE LIMITS: A mounting tool is available for through hole multimec™ 5 series switches. SOLDERING AND CLEANING MULTIMEC™ SERIES Multimec™ 5 series switches are fully sealed to IP67 specifications to minimize solder flux and aqueous based cleaning solutions from entering the switch and contaminating the contacts. The switches can be placed on the PC board with other components and reflow soldered. Multimec™ 5 series offers a high level of sealing, however, with aqueous solvent solutions care must be taken to avoid the worst 8 Switch LEDs Accessories 160 °C 85/90 °C 65/85/160 °C PACKAGING Multimec™ 5 series switches are packed in rigid tubes of 50 pieces each. A box contains 1.000 pcs. The surface mount versions of multimec™ 5 series switches with a height up to 12.5 mm can also be delivered on tape/reel. Each reel contains 250/500 pcs. Right angle switches are packed into trays. Each tray contains 100 pcs.
10C1616LMH12309 价格&库存
很抱歉,暂时无法提供与“10C1616LMH12309”相匹配的价格&库存,您可以联系我们找货
10C1616LMH12309
  • 1+101.357801+13.17620
  • 10+87.7628010+11.40890
  • 20+83.5585020+10.86240
  • 50+79.2584050+10.30340
  • 100+76.45560100+9.93900
  • 200+71.80810200+9.33490
  • 500+68.03500500+8.84440
  • 1000+65.052501000+8.45670
