CT series
Sealed toggle switches
Distinctive features and specifications
❑ Completely sealed switching chamber
❑ Three types of terminals
❑ UL approved
ELECTRICAL SPECIFICATIONS
MATERIALS
• Max. current/voltage rating with resistive load and electrical life at full load:
see table below
• Initial contact resistance : 10 mΩ max. at 1A 2VDC
• Insulation resistance : 1.000 MΩ min. at 500VDC
• Dielectric strength : 2.500 Vrms 50 Hz min. between terminals
3.000 Vrms 50 Hz min. between terminals and frame
• Case : mineral filled polyester
UL94-V0
• Bushing and cover : zamac
• Actuator : bright nickel
• Contacts : silver alloy
Gold plated : on request
ELECTRICAL RATING AND LIFE
Alternate current
Direct current
ON-OFF
and
ON-ON
15A 125/250VAC
resistive
10.000 cycles
15A 28VDC resistive
5A 28VDC lamp load
10.000 cycles
Other
functions
10A 125/250VAC
resistive
10.000 cycles
10.000 cycles, T20°C
15A 28VDC resistive
15A 28VDC inductive
5A 28VDC lamp load
ON-OFF
and
ON-ON
15A 125/250VAC
resistive
10.000 cycles
15A 28VDC resistive
5A 28VDC lamp load
10.000 cycles
Other
functions
10A 125/250VAC
resistive
10.000 cycles
15A 28VDC resistive
15A 28VDC inductive
5A 28VDC lamp load
DOUBLE POLE
SINGLE POLE
FUNCTIONS
UL
AGENCY APPROVAL
File E83438
Availability : consult factory for
details of approved models.
10A 125/250 VAC
according to
UL 1054
Marking : to order switches
marked UL, complete appropriate
box of ordering format.
GENERAL SPECIFICATIONS
• Torque : 2 Nm (1.47 Ft.lb) max. applied to nut
• Panel thickness : see “Mounting Accessories” on the following pages
• Mechanical life : 100.000 cycles
• Operating temperature : -40°C to +85°C
• Front panel sealing : IP67
APEM
www.apem.com
1
CT series
Overview
CT
SERIES
Number of poles
3
4
Single pole
Double pole
Electrical functions
1-0
2-0
3-0
4-1
4-2
4-3
ON
ON
OFF
ON
ON
MOM
3ON4
3ON4
3ON4
Terminals
Electrical functions (continued)
OFF
m.OFF
MOM
ON▲
MOM▲
MOM▲
5-0
6-0
7-0
8-0
9-0
ON
ON
MOM
ON
ON
OFF
OFF
OFF
MOM
ON
MOM
MOM
ON
3
Screw
Solder lug/quick-connect
Normalized quickconnect
▲ Function 4 : double pole only
Lever finish
Lever styles
1
Standard, length 17,5 mm
(.688)
N
Bright nickel
Locking lever
No locking
Agency approval
None
UL
Accessories
2 hex nuts, 1 locking
ring and 1 lockwasher
2 hex nuts and 1 sealing
washer
APEM has the ability to develop custom configurations. Please contact us with your requirements.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
ABOUT THIS SERIES
On the following pages, you will find successively :
- model structure of switches
- their options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketted numbers.
Security caps are available to prevent inadvertent lever operation. On request.
Packaging unit : 25 pieces
2
www.apem.com
APEM
CT series
• Screw, solder lug or quick-connect terminals
➞ Keyway
2
10.80
(.425)
3
MODEL
STRUCTURE
6.35x0.80
(.25x.031)
6.35x0.80
(.25x.031)
4.50
(.177)
Ø3.50
(.137DIA)
1
10.80
(.425)
Ø3.10
(.122DIA)
Shown with standard lever
FUNCTIONS
III
A2-A3
B5-B6
ON
ON
OFF
ON
ON
MOM
ON
ON
MOM
ON
ON
BASIC PART NUMBER
II
I
*A3-B4 A1-A2
A1-B6 B5-B4
ON*
ON*
ON*
OFF
OFF
OFF
OFF
m.OFF
MOM
ON
MOM
MOM
MOM
ON
MOM
MOM
ON
Screw terminals
Solder lugs and
quick-connect term.
Normalized quickconnect terminals
Single
pole
Double
pole
Single
pole
Double
pole
Single
pole
Double
pole
CT31-00
CT32-00
CT33-00
CT41-00
CT42-00
CT43-00
CT44-10
CT44-20
CT44-30
CT45-00
CT46-00
CT47-00
CT48-00
CT49-00
CT31-02
CT32-02
CT33-02
CT41-02
CT42-02
CT43-02
CT44-12
CT44-22
CT44-32
CT45-02
CT46-02
CT47-02
CT48-02
CT49-02
CT31-03
CT32-03
CT33-03
CT41-03
CT42-03
CT43-03
CT44-13
CT44-23
CT44-33
CT45-03
CT46-03
CT47-03
CT48-03
CT49-03
CT35-00
CT36-00
CT37-00
CT38-00
CT39-00
CT35-02
CT36-02
CT37-02
CT38-02
CT39-02
CT35-03
CT36-03
CT37-03
CT38-03
CT39-03
➞ Keyway
Single pole
2 POS. 22˚
3 POS. 30˚
A2
A1
A
A
Ø11.90 32NS
(15/32 32NS)
III
B6
B5
A
B4
I
II
III
A1
A3
A2
31.40
(1.236)
31.40
(1.236)
A1
A3
A1
A3
11.40
(.449)
11.40
(.449)
17.50
(.689)
10.80
(.425)
A2
Ø11.90 32NS
(15/32 32NS)
10.80
(.425)
II
A
17.50
(.689)
I
2 POS. 22˚
3 POS. 30˚
23.00
(.905)
15.00
(.59)
A
A
Double pole
32.00
(1.26)
A3
A1
A3
A1
A3
A2
A2
A1
A3
A2
APEM
10.80
(.425)
A2
10.00 10.00
(.393) (.393)
10.00 10.00
(.393) (.393)
www.apem.com
1.80
(.07)
10.80
(.425)
32.00
(1.26)
11.00
(.433)
3
CT series
LEVER STYLES
Ø7.00
(.275DIA)
Ø7.00
(.275DIA)
Ø11.00
(.433DIA)
25.40
(1.000)
30.00
(1.1811)
25.00
(.984)
24.00
(.944)
30.00
(1.181)
20.00
(.787)
15.00
(.59)
Ø7.00
(.236DIA)
17.50
(.688)
Ø6.00
(.236DIA)
Ø10.50
(.413DIA)
20.00
(.787)
Ø6.00
(.236DIA)
1
Standard
C35LL1N/A
C35LL2N/A
C35LL3N/A
C35LL4N/A
C35LL5N/A
C35LL6N
LEVER FINISH
N
Bright nickel
LOCKING LEVER
Fichier C3500DL
No locking
AGENCY APPROVAL
None
UL
4
www.apem.com
APEM
CT series
MOUNTING ACCESSORIES
For NON-SEALED mounting (panel cut-out fig. 1, 2 or 3)
2 hex nuts 14 mm (.551) across flats, 1 locking ring U121 or U12, 1 lockwasher U13
Panel thickness : 5 mm (.196) max.
2
For SEALED mounting (panel cut-out fig. 2)
2 hex nuts 14 mm (.551) across flats and 1 sealing washer U60
Panel thickness : 4 mm (.157) max.
Special hardware : black cap nut U129. Order separately.
PANEL CUT-OUT
Ø12.50 Ø12.50
Ø12.50
(.492DIA)(.492DIA)
(.492DIA)
Figure 1
5.10
5.10
(.20)
(.20)
5.10
(.20)
Ø3.50 Ø3.50
Ø3.50
(.137DIA)(.137DIA)
(.137DIA)
1.70
(.066)
9.60
9.60
(.377)
(.377)
Ø12.20 Ø12.20
Ø12.20
(.48DIA) (.48DIA)
(.48DIA)
9.60
(.377)
Ø12.20 Ø12.20
Ø12.20
(.48DIA) (.48DIA)
(.48DIA)
1.70
1.70
(.066)
(.066)
Figure 2
Figure 3
C T 0 9 0 5 - A re v. 7
APEM
www.apem.com
5
很抱歉,暂时无法提供与“CT31021N022”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+218.28960
- 195+87.10200
- 495+84.18600
- 国内价格 香港价格
- 15+136.7347015+17.68872
- 30+132.4670130+17.13663
