LSTC12-4A-RGB-AS
LSTC12-4A-RGB-AS
    APEM(埃斐)
    RGB LED CONTROLLER
LSTC12-4A-RGB-AS 数据手册
Product Specifications Model number:LSTC12-4A-RGB-AS Product name:Aluminum shell RF 24 keys RGB controller Product Description 24-key aluminum RF controller uses an advanced micro control unit, The product can be used for controlling a variety of lamps whose source of light is LED. For instance, point source of light, flexible light strip, wall washer lamps, glass curtain wall lights and so on. Advantages include ease of connection and simplicity in use. RF remote control enables customers to adjust brightness, static colour choices and various dynamic changes in lighting effects. Technical Parameters Working temperature -20-60℃ Supply voltage 12V~24V optional 0utput 3 channels Connecting mode common anode External dimension L130*W64*H24 mm Packing size L137*W80*H54mm Net weight 185g Gross weight 215g Static power consumption
LSTC12-4A-RGB-AS 价格&库存
很抱歉,暂时无法提供与“LSTC12-4A-RGB-AS”相匹配的价格&库存,您可以联系我们找货
LSTC12-4A-RGB-AS
  • 3+437.94820
  • 6+420.35579
  • 23+403.57348
  • 58+387.41990
  • 180+371.96760
库存:25
