10G00
10G00
    APEM(埃斐)
    圆形,凹陷 触动式 开关盖帽 蓝色 套入式
10G00 数据手册
EC M PANEL PCB SWITCHES 10 S/ 0 -1 /1 0U 1 T/ 01 21 0V 10S/10T/10U/10V Many design combinations • floating caps • low total height Round caps in two sizes + square cap + triangle cap h=7.5 mm Convex top surface Floating mounting - easy alignment of PCB and front panel 2,60 [0,102] 7,50 [0,295] DISTINCTIVE FEATURES Many combination possibilities to customize your panel 0,90 [0,035] 0,90 [0,035] 7,50 [0,295] 6,50 [0,256] 7,50 [0,295] [0,059] 1,50 [0,512] 13,00 11,50 [0,453] R3,00 [R0,118] 0,90 [0,035] 1,50 [0,059] 5,00 [0,197] 1,50 [0,059] 7,50 [0,295] 11,50 [0,453] 1,80 [0,071] 1,80 [0,071] 5,00 [0,059] 1,50[0,197] 5,00 [0,197] 5,00 [0,197] 5,00 [0,197] 5,00 [0,197] 2,50 [0,098] 2,50 [0,098] 2,50 [0,098] 0,90 [0,035] Correction 8,00 [0,315] Note:Geometry 11,50 [0,453] Part rev. Dwg. rev. Dwg. Creator Apprvd. Edited Da 4/7 4/7 1,50 [0,059] 5,00 [0,197] 1,50 [0,059] 5,00 [0,197] 2,50 [0,098] 2,50 [0,098] 0,90 [0,035] Material: Scale 1:1 Surface finish: C:\AIS_Workspace\mec\R&D\A. New R&D Structure\Sandbox\ABA\Marketing Drawing to Rika\ Part: 13,00 [0,512] x 3 Drawing to Rika\ Dwg: C:\AIS_Workspace\mec\R&D\A. New R&D Structure\Sandbox\ABA\Marketing Description: 11,50 [0,453] x 3 Tool no. 10 USTV Note:Geometry Note:Geometry according according to 3D to 3D CAD CAD model. model. 0,90 [0,035] 11,50 [0,453] 7,50 [0,295] 11,50 [0,453] 7,50 [0,295] 6C+10V - J-BEND Correction Correction 0,90 [0,035] 7,50 [0,295] 13,00 [0,512] [0,295] 7,50 [0,512] 13,00 [R0,118] [R0,118] R3,00R3,00 No. 2,50 [0,098] 0,90 [0,035] 8,008,00 [0,315] [0,315] 11,50 11,50 [0,453][0,453] 6C+10U - J-BEND No.No. 0,90 [0,035] 6,50 [0,256] 7,50 [0,295] 6,50 [0,256] 7,50 [0,295] 6C+10T - J-BEND 2,60 [0,102] 2,60 [0,102] 7,50 [0,295] 7,50 [0,295] 6C+10S - J-BEND 2,50 [0,098] 2,50 [0,098] SWITCH SPECIFICATIONS : see Ultramec™ series MECMEC ApSApS Status: Status: WorkInProgress WorkInProgress Industriparken Industriparken 23 23 Status: Status: WorkInProgress WorkInProgress DK-2750 DK-2750 Ballerup Ballerup Date Date Sign. Sign. Sheet Sheet 1 / 4 1 / 4 Denmark Denmark Tel: Tel: +45 +45 44 97 4433 9766 33 66 Theoretical Mass Mass Dwg. Dwg. 4/7/2020 4/7/2020 ABAABA Theoretical R3,00 [R0,118] www.apem.com www.apem.com Creator Creator 4/7/2020 4/7/2020 ABAABA e-mail e-mail danmec@mec.dk danmec@mec.dk Note:Geom N/A N/A No. Correction The company reserves the right to change specifications without notice. All tolerance if not otherwise specified ±0.2mm. Material: Material: Scale Scale Apprvd. Apprvd. Part rev. 1 : 1 : 1 Edited Dwg. rev. Edited Surface Surface finish: finish: PartPart rev. rev. 11,50 [0,453] 11,50 [0,453] Dwg. Dwg. rev. rev. C:\AIS_Workspace\mec\R&D\A. New R&D New Structure\Sandbox\ABA\Marketing R&D Structure\Sandbox\ABA\Marketing Drawing Drawing to Rika\10S to Rika\10S på kontakt.iam på kontakt.iam Part: Part:C:\AIS_Workspace\mec\R&D\A. 13,00 [0,512] 13,00x [0,512] 3 x3 C:\AIS_Workspace\mec\R&D\A. C:\AIS_Workspace\mec\R&D\A. New R&D New Structure\Sandbox\ABA\Marketing R&D Structure\Sandbox\ABA\Marketing Drawing Drawing to Rika\10 to Rika\10 - USTV.dwg - USTV.dwg 18 PCB SWITCHES 10S/10T/10U/10V Many design combinations • floating caps • low total height BUILD YOUR PART NUMBER NON- ILLUMINATED 6C POLES MOUNTING SERIES J 1 J-bend single pole FUNCTION NO PACKAGING POSITIONING PINS* P normally open pins R tape & reel NON- ILLUMINATED (FOLLOWING) UV CAP COLOR PRINT TYPE* PRINT 10S Ø6.5 00 blue 118 10T 11.5 x 11.5 03 grey 123 10U Ø11.5 08 red 10V 11.5 x3 09 black 36 signal white OK *optional NOTICE : In case of the standard printed legends the anti-rotation cut-out is placed downwards from the legend. Please note that the switches and caps are ordered separately. MOUNTING • Panel cut-out : 10S: min. Ø6.7 mm 10T: min. 11.7 x 11.7 mm, R 3,2 mm 10U: min. Ø11.7 mm 10V: min. 11.7 mm x3, R 3,2 mm • Switch spacing AxB : 10S: min. 9.0 x 9.0 mm 10T: min. 14.0 x 14.0 mm 10U: min. 14.0 x 14.0 mm 10V: min. 14.0 x 14.0 mm 19 MATERIALS • Cap : ABS UL94HB COLOR 06 white 08 EC Ultramec™ 6C M RA LT U EC PANEL PCB SWITCHES 20 6C M High performance tactile switches • low profile • IP67 DISTINCTIVE FEATURES Low profile h=2.5 mm 8 x 8 mm Normally open momentary switch Sealed to IP67 3,000,000 cycles lifetime ENVIRONMENTAL SPECIFICATIONS • Sealing : IP67 according to IEC 60529 • Working and storage temperature :-40 °C/+85 °C (-40 °F to 185°F) • Soldering : JEDEC J-STD-020E ELECTRICAL SPECIFICATIONS • Recommended load : 0.5-50 mA 24 VDC • Contact resistance : 10 MΩ • Contact bounce :
10G00 价格&库存
很抱歉,暂时无法提供与“10G00”相匹配的价格&库存,您可以联系我们找货
