5GSH93522
5GSH93522
    APEM(埃斐)
    顶部触动 触摸开关 SPST-NO 表面贴装型
5GSH93522 数据手册
Multimec™ 5G M U -M EC I LT PANEL PCB SWITCHES EC 3 30 -2 5G M High performance tactile switches • MIL-PRF-28855H • excellent illumination DISTINCTIVE FEATURES Large range of accessories Momentary switches with NO or NC/NO function Sealed to IP67 Single or bi-color illumination option Illumination with integrated chip-LEDs ENVIRONMENTAL SPECIFICATIONS • Sealing : IP67 according to IEC 60529 • Working and storage temperature : - non-illuminated: -40 °C/+160 °C (-40 °F to +320 °F) - illuminated: -30 °C/+85 °C (-22 °F to +185 °F) • Soldering : - through-hole : IEC 60068-2-20 8 - surface mount : JEDEC J-STD-020E ELECTRICAL SPECIFICATIONS • Recommended load : - Gold contacts : 0.5µ-50 mA 24 VDC - Silver contacts : 0.5-50 mA 24 VDC • Contact resistance : 10 MΩ • Contact bounce : 10,000,000 cycles - NC/NO : >1,000,000 cycles The company reserves the right to change specifications without notice. • Actuator : PPS UL94V0 • Sealing : Silicone rubber • Terminals : SnCu + 2 µNI + 3 µSn100 All tolerance if not otherwise specified ±0.2 mm. 1 High performance tactile switches • MIL-PRF-28855H • excellent illumination RAS 6,4 13,8 12 0,8 0,8 Min 10,16 5,5 Max 12,5 7,62 10 11 14 7,62 0,8 7,62 7,62 7,62 5,08 5G ILLUMINATED 7,62 7,62 4 0,8 • SMD, TH or right angle TH • NO or NC/NO Min 10,16 Max 12,5 5,08 0,3 6,4 10 14 12 11 4 0,3 10 13,8 5,5 6,4 6,4 TH 10 SMD 5G NON-ILLUMINATED 4,85 7,62 SMD TH 8,5 8,5 4:1 0,3 10,0 0,3 14 10,0 Min 10,16 Max 12,5 4:1 5G RAS • SMD or TH • NO • single or bi-color LEDs 0,8 0,8 7,62 7,62 All tolerances unless otherwise noted : ±0.2 mm PCB LAYOUT & CIRCUIT DIAGRAM -2 4 3 12,50 2 -2 4 +3 -2 1 4 2,5 +3 1 1 4 +3 2,50 2 1 4 3 3 Ø1,0(3x) 12,50 1,20 1,2 3 +3 Ø 0,9 7,62 -2 7,62 2,5 1 Ø 0,9 12,50 1 1,2 *not for sale in Japan 1 Ø 0,9 2 4 NC/NO function 7,62 5,08 1 7,62 4 RAS 10,16 7,62 10,16 Bicolor - 2 LEDs 10, 16 7,62 2 Single LED 7,62 Non-illuminated 7,62 PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination BUILD YOUR PART NUMBER ILLUMINATED 5G MOUNTING SERIES ACTUATION FORCE LED OPTIONAL TH9 Through-hole 20 2.0 N 02 Blue SH9 Surface mount 35 3.5 N 22 Green 65 6.5 N 29 High intensity Green 42 Yellow 61 White 82 Red 2242 Green/yellow 8222 Red/green 8242 Red/yellow Q Quiet contact (with 2.0 N only) R Tape & reel (with SMD only) G Gold contacts NON-ILLUMINATED 5G MOUNTING SERIES ACTUATION FORCE TH9 Through-hole 20 2.0 N SH9 Surface mount 35 3.5 N 65 6.5 N OPTIONAL Q RAS NCNO Quiet contact (with 2.0 N only) Right angle (with TH only) Normally closed/ normally open function (with 3.5 N only) R Tape & reel (with SMD only) G Gold contacts ABOUT THIS SERIES Laser marking on the switch for identification : WWYS, WW=week, Y=year, S=suffix for the type of switch, e.g. P=2.0 N and silver contacts, S=3.5 N and silver contacts, E6.5 N and silver contacts Caps and accessories : for the full range of accessories for Multimec™ 5G please see the website. 3 PANEL PCB SWITCHES Multimec™ 5G PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination TAPE & REEL Tape and reel is available for the parts listed and has the following specifications PART NO. ORDERING CODE PITCH QUANTITY PER REEL 5GSH9XX 5GSH9XXR 16 500 • Reel diameter: Ø330 mm 5GSH9XX1SSXX-08.0 5GSH9XXR1SSXX-08.0 20 250 • Tape width: 24 mm 5GSH9XX1SSXX-09.5 5GSH9XXR1SSXX-09.5 20 250 • Pitch: see list 5GSH9XX1SSXX-10.4 5GSH9XXR1SSXX-10.4 20 250 5GSH9XX1SSXX-11.0 5GSH9XXR1SSXX-11.0 20 250 5GSH9XX1SSXX-12.0 5GSH9XXR1SSXX-12.0 20 250 5GSH9XX02 5GSH9XX02R 20 250 5GSH9XX22 5GSH9XX22R 20 250 5GSH9XX29 5GSH9XX29R 20 250 5GSH9XX42 5GSH9XX42R 20 250 5GSH9XX61 5GSH9XX61R 20 250 • Tape and reel material: antistatic or better • Quantity per reel: see list 4 1,75 Direction of tape 2 2 4 0,3 24 +- 0,1 11,50 1 3 See list 5GSH9XX82 5GSH9XX82R 20 250 5GSH9XX2242 5GSH9XX2242R 20 250 5GSH9XX8222 5GSH9XX8222R 20 250 5GSH9XX8242 5GSH9XX8242R 20 250 OPERATING FORCE 2.0 N 10 FORCE 6.5 N 10 FORCE 9 9 8 8 8 7 7 7 6 6 6 5 2N 5 F(N) 9 F(N) F(N) 10 3.5 N 3,5N 5 4 4 4 3 3 3 2 2 2 1 1 1 TRAVEL TRAVEL 0 0 0 4 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 FORCE 6,5N TRAVEL 0 0 0,2 0,4 0,6 0,8 1 L(mm) 1,2 1,4 1,6 1,8 2 High performance tactile switches • MIL-PRF-28855H • excellent illumination MOUNTING MOUNTING TOOLS FOR MULTIMEC™ THROUGH-HOLE SWITCHES Part No. 9861000 1 2 3 4 5 Min. 12,7 Min. 12,7 Min. 15,24 Min. 10,3 Min. 10,3 Through-hole (TH) Min. 10,3 Min. 10,3 SPACE REQUIREMENT - MATRIX MOUNTING Surface mount (SMD) Min. 15,24 MULTIMEC™ SPACING EXAMPLES 15.4 Min 10.16 Max 12.5 12.7 25.3 Min 10.16 Max 12.5 14.0 1.4 14.0 10.16 15.14 15.4 10.16 10.16 10.16 2.54 10.16 5.24 10.16 5GT+1B+2C/D 12.7 5GS+1B+2C/D 5GT+1M 5GT+1A/H 12.7 1VS+1TS+1VS 5 PANEL PCB SWITCHES Multimec™ 5G PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination MOUNTING (CONTINUED) SPACE REQUIREMENT - SWITCH/CAP Cap dimensions Switch spacing Panel cut-out 6 CAP SERIES RECOMMENDED MIN.SWITCH SPACING AxB NOMINAL CAP DIMENSION WxH RECOMMENDED MIN. PANEL CUT-CUT 1A/1H 12.7x10.3 12.6x10.1 13.0x10.5 1B+2C/2D 15.4x15.4 15.1x15.1 15.5x15.5 1DS/1ES/1FS 12.7x11.3 Ø9.6 Ø10.0 1GAS 12.7x11.3 Ø11.0 Ø11.4 1GCS 15.3x15.3 Ø15.0 Ø15.4 1JS 12.7x10.3 Ø10.0 Ø10.4 1KS/1KBS/1KCS 14.6x14.6 14.3x14.3 14.7x14.7 1M 25.3x10.3 25x10 25.7x10.5 1NS 13.6x11.3 Ø9.8/ 14.9 Ø10.2/15.1 1PS/ 1QS/1RS 12.8x10.3 6.5x12.5 7x13, R max. 1.0 1SS/1IS/1LS 12.7x10.3 Ø6.5 Ø7.0 1TS 12.7x12.3 10.6x10.6 11.0x11.0 1US 12.7x12.3 Ø10.6 Ø11.0 1VS 15.95x12.1 10.6x13.25 11.0x13.65 1WAS/1WPS 14.2x10.3 12.5x6.5 12.9x6.9 1WDS 16.9X10.3 15.2x8.0 15.6x8.4 1XS 12.7x10.3 9.4x7.4 9.8x7.9 1ZA 19.0X10.3 18.7x10.1 19.4x10.5 1ZB 24.34x12.1 R1=7.4; R2=17.5 90° R1=7.1; R2=17.5-17.75 90° 1ZCS 14.6x14.6 Ø14.3 Ø14.7 1Z/1ZW 35.5x35.5; 41.6x41.6 Ø29.5 Ø30.3 10C 22.3x22.3 Ø19.2 Ø19.8 10R/10RF/10RM 37.3X37.3 Ø30.0 Ø30.6 10Q/10QM 29.3X29.3 22x22 22.5x22.5 High performance tactile switches • MIL-PRF-28855H • excellent illumination LED COMPONENT SPECIFICATIONS LED COMPONENT SPECIFICATIONS Color Blue Green Yellow White Red High Intensity Green Color Codes 02 22 42 61 82 29 ABSOLUTE MAXIMUM RATINGS (Ta= 25°C) Power mW 75 75 60 46.5 65 102.5 Current forward mA 20 30 25 15 25 25 Forward peak current mA 100 80 60 100 100 150 Voltage reverse V 5 5 5 5 12 5 Operating temperature °C -40/+85 -55/+85 -40/+85 -40/+85 -30/+85 -40/+85 Storage temperature °C -40/+90 -55/+85 -40/+90 -40/+85 -40/+85 -40/+85 Soldering temperature °C 2 3.3 245 for max 10 sec ELECTRICAL-OPTICAL CHARACTERISTICS (Ta=25 °C) Voltage forward Typ. V 2.7 Max. V Current reverse (VR=5V) Max. µA Wave length nm Spread nm 1.75** 2.85 3.7 2.4 2.35 3.1 2.5 4.1 50 100 10 10 100 50 468 571 591 NA 633 525 25 NA 15 NA 16 30 120 130 120 150 160 60 Min. mcd 45 18 28.5 56 28 500 Typ. mcd 112* 35 72* max 450* max 180* 1000 Lm/w NA NA NA 36 7 NA Spread angle degree Luminous Intensity Optical intensity 2 */F=20 mA, **Pulse width 1ms Duty cycle 1:5, ***/F=50 mA, ****Luminous Flux mlm 7 PANEL PCB SWITCHES Multimec™ 5G PCB SWITCHES Multimec™ 5G High performance tactile switches • MIL-PRF-28855H • excellent illumination USAGE GUIDELINES HOW TO GET THE BEST RESULTS WITH MEC SWITCHES ? case situation with water jets, complete immersion into a liquid with a temperature below the board or surface tension reducing additives. These guidelines are offered to users of MEC Switches as an aid to ensure successful and reliable switch operation. Please see the technical specifications for details on operating and storage temperatures and soldering guidelines to make sure you select the best switch for your application. When reflow soldering is taking place, MEC strongly recommend that the temperature profile is analyzed and compared with the temperature rating of the switch. It is also important to monitor the accumulated heat buildup from both the pre-heat zones and the solder zone. Recommended cleaning methods are demineralized water. Any surface tension reducing agents, such as soap, must not be used as they risk causing a potential leakage of the switch. Most standard accessories for multimec™ 5 series switches are made from ABS plastic with a maximum operating temperature of 65 °C. It is strongly recommended that accessories are mounted after soldering of the switch. If this is not possible care must be taken not to overheat the accessories during the soldering process. The 1SS and 1GAS/1GCS caps are, however, made of high temperature materials and will meet the same temperature specifications as the switches. For accessories made from other plastic materials please see multimec™ 5 series cap & bezel technical specifications. Wave soldering: heat built up in the switch during pre-heating and soldering must not exceed the maximum operating temperature of the switch. Peak temperature must not exceed 260 °C, and soldering time is max 10 sec. (IEC 60068-2-20 8) SOLDERING - THROUGH HOLE VERSIONS Hand soldering: max. 350 °C for max. 3 sec SOLDERING - SURFACE MOUNT VERSIONS LEDs have their own temperature specifications. When fitted in a switch the LED will determine the max. operating temperature, i.e. 5GTH93522 has an upper temperature limit of 85 °C! For all methods - infrared, convection and vapor phase. The upper limit 240 °C/40 sec must be observed. The soldering temperature profile must have moderate temperature gradients. (JEDEC J-STD020E) MOUNTING AND DISMOUNTING ROHS COMPLIANCE If switches are to be mounted in rows it is essential that the recommendations regarding spacing are followed. PC board thickness should be 1.4 ±0.2 mm and terminal hole diameter should be 0.9 mm. As of 1 July 2006 MEC has completed the conversion to RoHS compliance. For more info please see our homepage www.apem.com All multimec™ 5 series caps and bezels are easily snapped onto the switch modules and can be changed at a later time. TEMPERATURE LIMITS: A mounting tool is available for through hole multimec™ 5 series switches. SOLDERING AND CLEANING MULTIMEC™ SERIES Multimec™ 5 series switches are fully sealed to IP67 specifications to minimize solder flux and aqueous based cleaning solutions from entering the switch and contaminating the contacts. The switches can be placed on the PC board with other components and reflow soldered. Multimec™ 5 series offers a high level of sealing, however, with aqueous solvent solutions care must be taken to avoid the worst 8 Switch LEDs Accessories 160 °C 85/90 °C 65/85/160 °C PACKAGING Multimec™ 5 series switches are packed in rigid tubes of 50 pieces each. A box contains 1.000 pcs. The surface mount versions of multimec™ 5 series switches with a height up to 12.5 mm can also be delivered on tape/reel. Each reel contains 250/500 pcs. Right angle switches are packed into trays. Each tray contains 100 pcs.
5GSH93522
物料型号:MEC-MULTIMEC5G-2303
器件简介: - 这是Multimec™ 5G系列的高性能触觉开关,符合MIL-PRF-28855H标准,具有出色的照明效果。
引脚分配: - 提供了SMD(表面贴装)和TH(通孔)或直角TH的安装选项。 - 有NO(常开)或NC/NO(常闭/常开)功能。 - 支持单色或双色LED照明。
参数特性: - 密封等级:IP67,根据IEC 60529标准。 - 工作和存储温度范围:非照明型为-40°C至+160°C,照明型为-30°C至+85°C。 - 焊接规格:通孔焊接符合IEC 60068-2-20标准,表面贴装符合JEDEC J-STD-020E标准。
功能详解: - 推荐负载:金触点0.5µA至50 mA 24 VDC,银触点0.5至50 mA 24 VDC。 - 接触电阻:<30 mΩ,典型值为10 mΩ。 - 绝缘电阻:>10 MΩ。 - 接触回弹:<2毫秒,典型值为0.5毫秒。
应用信息: - 提供了多种配件和选项,如不同的激活力度、LED颜色、是否带有静音版本等。
封装信息: - 外壳、执行器材料:PPS UL94V0。 - 密封材料:硅橡胶。 - 接触弹簧材料:不锈钢,银触点表面有3微米银层,金触点表面有1微米金层。 - 固定触点材料:银触点为锡铜加上2微米镍和3微米银,金触点为锡铜加上2微米镍和1微米金。 - 使用寿命:NO(常开)超过1000万次循环,NC/NO(常闭/常开)超过100万次循环。
5GSH93522 价格&库存
很抱歉,暂时无法提供与“5GSH93522”相匹配的价格&库存,您可以联系我们找货
5GSH93522
    库存:100
