GCLAC3F480
GCLAC3F480
    ARCSUPPRESSION
    AC POWER CONTACT ARC SUPPRESSOR
GCLAC3F480 数据手册
NOsparc® GCLAC3F480 DATA SHEET PRODUCT OVERVIEW The NOsparc® GCLAC3F480 contact arc suppressor (AC power applications) protects, cleans, and restores the contact points of 3-phase relays and contactors. This improves their overall performance and extends contact life to the mechanical life of the relay or contactor. The NOsparc GCLAC3F480 arc suppressor is designed to suppress contact arcing from 110Vac to 480Vac. NOsparc AC arc suppressors connect across the contact terminals on existing products and equipment using two wires per contact, plus a connection to the contactor’s coil. NOsparc AC power arc suppressors support the following AC power loads: • General Purpose • Capacitive • Pilot Duty • Resistive • Inductive • Tungsten • Ballast • Heater • Motor NOsparc is effective even under mixed load conditions. - CONTACT LIFE CONTACTS LAST TO MECHANICAL LIFE OF RELAY OR CONTACTOR • REDUCES • ROHS MAINTENANCE, REPAIR, AND REPLACEMENT COSTS COMPLIANT • REDUCES CARBON FOOTPRINT • REDUCES GREENHOUSE GASSES • EASY Additional information and a full User Manual are available on our website: www.ArcSuppressionTechnologies.com DIMENSIONS AND DRAWINGS FEATURES AND BENEFITS • EXTENDS HVACR & Automation Note that the GCLAC3F480 comes with an “L”-shaped mounting bracket screws that may be used as needed for installation. Product dimensions without optional mounting bracket: INSTALLATION - ARC SUPPRESSION CONNECTED IN PARALLEL ACROSS EACH CONTACT - COIL POWER CONNECTION DRAWS APPROX. 10mA FROM CONTROLLER • SMALL FOOTPRINT - EASILY ADAPTED TO EXISTING INFRASTRUCTURE - QUICK AND SIMPLE PANEL MOUNT RETROFIT PROCESS • LOWER EMI - AVERAGE 30dB REDUCTION OF EMI OVER 30MHz TO 1GHz RANGE Product dimensions with optional mounting bracket: LED INDICATOR LIGHTS READY Lights: 3 green LEDs will light when arc suppressor installed in a powered circuit and contacts are open. ARMED Lights: 3 red LEDs will light when the contactor’s coil is on and arc suppressor is ready for operation. Light patterns other than those shown above indicate either improper installation or product malfunction. This product is manufactured under the following patents: US 8,619,395; US 9,087,653; US 9,423,442; US 9,508,501; US 9,847,185; US 10,134,536; US 10,566,150; US 10,727,005; and US 10,727,010. Other patents pending. 7900 INTERNATIONAL DRIVE, SUITE 300, BLOOMINGTON, MN 55425 // 612-928-5546 // www.ArcSuppressionTechnologies.com © 2020. Infor mation contained in this document is subject to change without notice. “NOsparc” is a registered trademark of Arc Suppression Technologies, LLC. All rights reserved. Page 1 of 2 NOsparc® GCLAC3F480 DATA SHEET SPECIFICATIONS CONTACT Specifications ABSOLUTE MAXIMUM CURRENT RATING 235Arms at 60Hz / 195Arms at 50Hz — this absolute maximum current rating also represents the maximum allowable Locked Rotor Amperage (LRA) for motor loads and the cold filament inrush current for tungsten loads duration: ½ AC power cycle (maximum) ARC SUPPRESSION 100A for general purpose, heater, and resistive loads, 50A for inductive, motor, and pilot duty loads 20A for ballast, capacitive, and Tungsten loads CIRCUIT BREAKER / FUSE (MAXIMUM) CLAMPING VOLTAGE CYCLING 820V (typical at 1mA) maximum cycle time: per relay specifications (DO NOT EXCEED relay or contactor operating specs) 2.5mA @ 110 Vac to 10mA @ 480Vac LEAKAGE CURRENT 110Vac to 480Vac (nominal +/-10%) OPERATING VOLTAGE PHASE TO PHASE TERMINAL DIELECTRIC ISOLATION VOLTAGE TERMINATION 4000Vac across contacts: two (2) 0.250” insulated quick connect terminals per contact/phase, six (6) total COIL Specifications one (1) coil connection; either AC or DC (non-polarized) CIRCUITS 470V (typical at 1mA) CLAMPING VOLTAGE 10mA (+/- 10 %) OPERATING CURRENT OPERATING VOLTAGE 24Vac to 240Vac (nominal +/-10%); COIL TO PHASE TERMINAL DIELECTRIC ISOLATION VOLTAGE TERMINATION 24Vdc to 250Vdc (nominal +/-10%) 4000Vac across coil: two (2) 0.250” insulated quick connect terminals for the coil connection GENERAL Specifications DIMENSIONS (WITHOUT BRACKET) length: 6.750in (17.145cm) width: 3.250in (8.255cm) height: 1.524in (3.871cm) DIMENSIONS (WITH BRACKET) length: 6.760in (17.170cm) width: 3.850in (9.779cm) height: 3.024in (7.681cm) ENVIRONMENTAL MOUNTING MTBF / RELIABILITY POWER FREQUENCIES POWER TYPE operating temperature: -40°C to 75°C (-40°F to 167°F), storage temperature: -50°C to 125°C (-58°F to 257°F), humidity: 5% to 95% (non-condensing) orientation: any number of holes: two (2) 800,000 hours (MIL-HDBK-217F) typical operating frequencies: 50Hz / 60Hz AC (sinusoidal alternating current) WEIGHT WIRE GAUGE hole diameter: 0.188in (#10 screw) (4.775mm) 7.875oz (223g) wire length between Nosparc and contact terminals: up to 24in: #14AWG (minimum); 24in to 36in: #12AWG (minimum). NOTE: DO NOT use wire lengths over 3 feet SYSTEM WIRING Arc suppressor connects in parallel across each respective contact (phase) as shown, with a separate connection to the contactor coil. Make sure installation uses accepted proper crimping standards and is compliant with all safety regulations. IMPORTANT NOTE NOsparc will be damaged if arc suppressor connected across the following locations where there is NO arcing: LOAD, POWER, and/or COIL. left: GCLAC3F480 connected to three-phase contactor File No:E346457 UL Recognized Component, certified as “Component - Auxiliary Devices” Industrial Control Equipment for both Canada and the United States, per UL 508 and CSA-C22.2 No 14. 7900 INTERNATIONAL DRIVE, SUITE 300, BLOOMINGTON, MN 55425 // 612-928-5546 // www.ArcSuppressionTechnologies.com 104-0059E Page 2 of 2
GCLAC3F480 价格&库存
很抱歉,暂时无法提供与“GCLAC3F480”相匹配的价格&库存,您可以联系我们找货
