A000002
A000002
    ARDUINO
    KIT BLUE TOOTH ARDUINO
A000002 数据手册
... The Arduino BT is a microcontroller board based on the ATmega168 (datasheet) and the Bluegiga WT11 bluetooth module (details and datasheet [pdf]). It supports wireless serial communication over bluetooth (but is not compatible with Bluetooth headsets or other audio devices). It has 14 digital input/output pins (of which 6 can be used as PWM outputs and one can be used to reset the WT11 module), 6 analog inputs, a 16 MHz crystal oscillator, screw terminals for power, an ICSP header, and a reset button. It contains everything needed to support the microcontroller and can be programmed wirelessly over the Bluetooth connection. Instructions are available for getting started with the Arduino BT. Technical Specifications Microcontroller ATmega168 Operating Voltage 5V Input Voltage 1.2-5.5 V Digital I/O Pins 14 (of which 6 provide PWM output) Analog Input Pins 6 DC Current per I/O Pin 40 mA DC Current for 3.3V Pin 50 mA Flash Memory 16 KB (of which 2 KB used by bootloader) SRAM 1 KB EEPROM 512 bytes Clock Speed 16 MHz If you want to give a closer look to this board we advice you to visit the official Arduino Bluetooth page in the Hardware Section. 1
A000002 价格&库存
很抱歉,暂时无法提供与“A000002”相匹配的价格&库存,您可以联系我们找货
