ABX00031
ABX00031
    ARDUINO
    ARDUINO NANO 33 BLE SENSE
ABX00031 数据手册
ARDUINO NANO 33 BLE SENSE Code: ABX00031 Small, powerful, BT connected and with all the sensors you may need to design innovative applications. Estimate shipping date, mid July 2019. This compact and reliable Nano board is built around the NINA B306 module for BLE and Bluetooth 5 communication; the module is based on Nordic nRF 52840 processor that contains a powerful Cortex M4F and the board has a rich set of sensors that allow the creation of innovative and highly interactive designs. Its architecture, fully compatible with Arduino IDE Online and Offline, has a 9 axis Inertial Measurement Unit (IMU), temperature, pressure, humidity, light, color and even gestures sensors and a microphone that are managed through our specialised libraries. Its reduced power consumption, compared to other same size boards, together with the Nano form factor opens up a wide range of applications. This allows the design of wearable devices and gesture based projects that need to communicate to other devices at a close range. Arduino Nano 33 BLE Sense is ideal for interactive automation projects thanks to the multiprotocol BT 5.0 radio. Dimensions: 45x18mm TECH SPECS This board is based on the nRF 52840 microcontroller. Clock 64MHz Flash 1MB RAM 256KB Please note: Arduino Nano 33 BLE Sense only supports 3.3V I/Os and is NOT 5V tolerant so please make sure you are not directly connecting 5V signals to this board or it will be damaged. Also, as opposed to Arduino Nano boards that support 5V operation, the 5V pin does NOT supply voltage but is rather connected, through a jumper, to the USB power input. To avoid such risk with existing projects, where you should be able to pull out a Nano and replace it with the new Nano 33 BLE Sense, we have the 5V pin on the header, positioned between RST and A7 that is not connected as default factory setting. This means that if you have a design that takes 5V from that pin, it won’t work immediately, as a precaution we put in place to draw your attention to the 3.3V compliance on digital and analog inputs. 5V on that pin is available only when two conditions are met: you make a solder bridge on the two pads marked as VUSB and you power the NANO 33 IoT through the USB port. If you power the board from the VIN pin, you won’t get any regulated 5V and therefore even if you do the solder bridge, nothing will come out of that 5V pin. The 3.3V, on the other hand, is always available and supports enough current to drive your sensors. Please make your designs so that sensors and actuators are driven with 3.3V and work with 3.3V digital IO levels. 5V is now an option for many modules and 3.3V is becoming the standard voltage for electronic ICs. The Bluetooth is managed by a NINA B306 module. The IMU is a LSM9DS1 and it is managed through I2C. The LPS22HB reads barometric pressure and environmental temperature. The HTS221 senses relative humidity. The ADPS-9960 is a digital proximity, ambient light, RGB and gesture sensor. The MP34DT05 is the digital microphone Crypto keys are managed by the ATECC608A crypto chip. The board has a two 15 pins connectors - one on each side -, pin to pin compatible with the original Arduino Nano. Pin Funcion Type Description 1 D13 Digital GPIO 2 +3V3 Power Out Internally generated power output to external devices 3 AREF Analog 4 A0/DAC0 Analog ADC in/DAC out; can be used as GPIO 5 A1 Analog ADC in; can be used as GPIO 6 A2 Analog ADC in; can be used as GPIO 7 A3 Analog ADC in; can be used as GPIO 8 A4/SDA Analog ADC in; I2C SDA; Can be used as GPIO (*) Analog Reference; can be used as GPIO 9 A5/SCL Analog ADC in; I2C SCL; Can be used as GPIO(*) 10 A6 Analog ADC in; can be used as GPIO 11 A7 Analog ADC in; can be used as GPIO 12 VUSB Power In/Out Normally NC; can be connected to VUSB pin of the USB connector by shorting a jumper 13 RST Digital In Active low reset input (duplicate of pin 18) 14 GND Power Power Ground 15 VIN Power In Vin Power input 16 TX Digital USART TX; can be used as GPIO 17 RX Digital USART RX; can be used as GPIO 18 RST Digital Active low reset input (duplicate of pin 13) 19 GND Power Power Ground 20 D2 Digital GPIO 21 D3/PWM Digital GPIO; can be used as PWM 22 D4 GPIO 23 D5/PWM Digital GPIO; can be used as PWM 24 D6/PWM Digital GPIO; can be used as PWM 25 D7 Digital GPIO 26 D8 Digital GPIO 27 D9/PWM Digital GPIO; can be used as PWM 28 D10/PWM Digital GPIO; can be used as PWM 29 D11/MOSI Digital SPI MOSI; can be used as GPIO 30 D12/MISO Digital SPI MISO; can be used as GPIO Digital (*) As opposed to other Arduino Nano boards, pins A4 and A5 have an internal pull up and default to be used as an I 2 C Bus so usage as analog inputs is not recommended. Opposed to Arduino Nano boards that support 5V operation, the 5V pin does NOT supply voltage but is rather connected, through a jumper, to the USB power input. On the bottom side of the board, under the communication module, debug signals are arranged as 3x2 test pads with 100 mil pitch. Pin 1 is the bottom left one with the USB connector on the left and the test pads on the right. Pin Function Type Description 1 +3V3 Power Out Internally generated power output to be used as voltage reference 2 SWD Digital 3 SWCLK Digital In nRF52480 Single Wire Debug Clock 5 GND Power Power Ground 6 RST Digital In Active low reset input nRF52480 Single Wire Debug Data https://store.arduino.cc/usa/nano-33-ble-sense/6-11-19
ABX00031 价格&库存
很抱歉,暂时无法提供与“ABX00031”相匹配的价格&库存,您可以联系我们找货
