AF1TSTIA-2BBXX
AF1TSTIA-2BBXX
    ATPELECTRONICS
    固态硬盘(SSD) FLASH - NAND(TLC) 1TB SATA III M.2 模块
AF1TSTIA-2BBXX 数据手册
M.2 SATA Targeted Product Portfolio, Engineered Specifically for Your Mission Critical Applications Key Features • MCU-based Power Loss Protection Design* • LDPC & RAID Data Recovery • End-to-End Data Protection • TRIM / Global Wear Leveling support * Customization available on a project basis ATP's Industrial M.2 Serial ATA (SATA) solid state modules are available in types 2242 and 2280. These lean modules provide higher performance and capacity while minimizing the overall module footprint, making them perfect choices for small systems installed in limited spaces. Available in both double- and single-sided configurations, M.2 SATA SSDs are packed with high densities and can withstand severe temperature shifts common in industrial environments, thanks to wide operating temperature ratings of -40°C to 85°C. ATP M.2 modules are suitable for networking and thin storage systems, point-of-sale systems (POS), and industrial computer applications. Select M.2 SATA SSDs feature a microcontroller unit (MCU) design for enhanced power loss protection (PLP) in various temperatures, power glitches and charge states, thus safeguarding data and storage device for higher levels of integrity and reliability. Technologies & Add-On Services S S.M.A.R.T. Hardware-based Power Loss Protection AutoRefresh Advanced Wear Leveling Dynamic Data Refresh End-to-End Data Protection Secure Erase Premium ▲ Superior ▲ TCG Opal 2.0 Industrial Temperature ▲ Anti-Sulfur Resistors Conformal Coating ▲ ▲ ▲ ▲ Value ▲: Customization option available on a project basis. PRODUCT FLYER M.2 SATA 1 Specifications M.2 SATA Premium Product Line A800Pi Superior A700Pi A750Pi A650Si Interface A600Si A600Sc A600Vc SATA III 6 Gb/s Flash Type SLC 3D TLC (pSLC mode) 3D TLC Form Factor Operating Temperature (Tcase)1 Value A650Sc 2242 D2-B-M -40°C to 85°C -40°C to 85°C Power Loss Protection Options Optional SED Features -40°C to 85°C 0°C to 70°C -40°C to 85°C 0°C to 70°C - 0°C to 70°C Firmware Based Hardware + Firmware Based AES 256-bit Encryption, TCG Opal 2.0 - Capacity 8 GB to 64 GB 40 GB to 160 GB Sequential Read (MB/s) up to 530 560 560 560 Sequential Write (MB/s) up to Random Reads IOPS (4K, QD32) up to Random Writes IOPS (4K, QD32) up to 400 520 480 510 525 76,000 68,000 100,000 100,000 70,500 76,000 88,000 90,000 88,000 81,000 1,396 TB 2,792 TB 120 GB to 480 GB 32 GB to 1 TB Performance 560 Endurance and Reliability Endurance (TBW)2 up to 5,333 TB 9,600 TB 6,400 TB 2,327 TB Reliability MTBF @ 25°C >2,000,000 hours Dimensions: L x W x H (mm) 42 x 22 x 3.5 Others Certifications Warranty CE, FCC CE, FCC, BSMI, UKCA, RoHS, REACH 5 years 2 years M.2 SATA Premium Product Line A750Pi Superior A700Pi A650Si A650Sc Interface Value A600Si A600Sc A600Vc SATA III 6 Gb/s Flash Type 3D TLC (pSLC mode) 3D TLC Form Factor 2280 D2-B-M Operating Temperature (Tcase)1 -40°C to 85°C 0°C to 70°C 2280 S2-B-M -40°C to 85°C 0°C to 70°C 0°C to 70°C Power Loss Protection Options Optional SED Features - Capacity 80 GB to 320 GB Sequential Read (MB/s) up to 560 560 560 560 Sequential Write (MB/s) up to 520 480 510 525 90,000 100,000 100,000 72,000 88,000 90,000 88,000 85,000 2,792 TB 2,792 TB Firmware Based Hardware + Firmware Based AES 256-bit Encryption, TCG Opal 2.0 120 GB to 960 GB 32 GB to 1 TB Performance Random Reads IOPS (4K, QD32) up to Random Writes IOPS (4K, QD32) up to Endurance and Reliability Endurance (TBW)2 up to 19,200 TB 12,800 TB 4,655 TB Reliability MTBF @ 25°C >2,000,000 hours Others Dimensions: L x W x H (mm) 80 x 22 x 3.35 Certifications Warranty 80 x 22 x 2.2 CE, FCC, BSMI, UKCA, RoHS, REACH 5 years 2 years 1 Case Temperature, the composite temperature as indicated by SMART temperature attributes. 2 Under highest Sequential write value. May vary by density, configuration and applications. PRODUCT FLYER M.2 SATA 2 Hot Items Ordering Information Product Line Capacity1 Operating Temperature2 Power Loss Protection3 SED4 P/N A650Si (M.2 2280) 120GB -40°C to 85°C Hardware + Firmware Based - AF120GSTIC-7BCIP A650Si (M.2 2280) 240GB -40°C to 85°C Hardware + Firmware Based - AF240GSTIC-7BCIP A650Si (M.2 2280) 480GB -40°C to 85°C Hardware + Firmware Based - AF480GSTIC-7BCIP A650Si (M.2 2280) 960GB -40°C to 85°C Hardware + Firmware Based - AF960GSTIC-7BCIP A650Sc (M.2 2280) 120GB 0°C to 70°C Hardware + Firmware Based - AF120GSTIC-7BCXP A650Sc (M.2 2280) 240GB 0°C to 70°C Hardware + Firmware Based - AF240GSTIC-7BCXP A650Sc (M.2 2280) 480GB 0°C to 70°C Hardware + Firmware Based - AF480GSTIC-7BCXP A650Sc (M.2 2280) 960GB 0°C to 70°C Hardware + Firmware Based - AF960GSTIC-7BCXP A600Vc (M.2 2280) 32GB 0°C to 70°C Firmware Based - AF32GSTIC-2BAXX A600Vc (M.2 2280) 64GB 0°C to 70°C Firmware Based - AF64GSTIC-2BAXX A600Vc (M.2 2280) 128GB 0°C to 70°C Firmware Based - AF128GSTIC-2BAXX A600Vc (M.2 2280) 256GB 0°C to 70°C Firmware Based - AF256GSTIC-2BAXX A600Vc (M.2 2280) 512GB 0°C to 70°C Firmware Based - AF512GSTIC-2BAXX A600Vc (M.2 2280) 128GB 0°C to 70°C Firmware Based - AF128GSTIC-2BBXX A600Vc (M.2 2280) 256GB 0°C to 70°C Firmware Based - AF256GSTIC-2BBXX A600Vc (M.2 2280) 512GB 0°C to 70°C Firmware Based - AF512GSTIC-2BBXX A600Vc (M.2 2280) 1TB 0°C to 70°C Firmware Based - AF1TSTIC-2BBXX A600Vc (M.2 2242) 128GB 0°C to 70°C Firmware Based - AF128GSTIA-2BBXX A600Vc (M.2 2242) 256GB 0°C to 70°C Firmware Based - AF256GSTIA-2BBXX A600Vc (M.2 2242) 512GB 0°C to 70°C Firmware Based - AF512GSTIA-2BBXX A600Vc (M.2 2242) 1TB 0°C to 70°C Firmware Based - AF1TSTIA-2BBXX 1 Amount of actual usable storage that can be utilized. 2 Refers to Case Temperature range during device operation, as indicated by SMART temperature attributes. 3 Hardware + Firmware-based power loss protection design with Level 4 (data-in-flight) protection; Firmware-based power loss protection design with Level 1 (data-at-rest) protection. 4 Allows data written to and read from the SSD to be constantly and automatically encrypted and decrypted. Conforms to TCG Opal 2.0 and uses AES 256-bit HW encryption. Product spec and its related information are subject to change without advance notice. Please refer to www.atpinc.com for latest information v1.1 202205 © Copyright 2022 ATP Electronics, Inc. All rights reserved. The Global Leader in Specialized Storage and Memory Solutions We build With you ATP TAIWAN (HQ) ATP USA ATP EUROPE ATP JAPAN ATP CHINA TEL: +886-2-2659-6368 sales-apac@atpinc.com TEL: +1-408-732-5000 sales@atpinc.com TEL: +49-89-374-9999-0 sales-europe@atpinc.com TEL: +81-3-6260-0797 sales-japan@atpinc.com TEL: +86-21-5080-2220 sales@cn.atpinc.com
AF1TSTIA-2BBXX 价格&库存
很抱歉,暂时无法提供与“AF1TSTIA-2BBXX”相匹配的价格&库存,您可以联系我们找货
