AS1352
AS1352
    AMSOSRAM(艾迈斯半导体)
    VQFN12_EP
    PMIC - 稳压器 - 线性 正 可编程 4 输出 200mA 12-QFN(4x4)
AS1352 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com AS1352 Data Sheet Programmable Quad LDO 2 Key Features ! The one-time-programmable (OTP) function provides greater design flexibility by allowing for independent programming of the output voltage for each regulator onsite. The OTP function allows for fast prototyping reducing development times and costs significant. Factory trimmed versions for full-production are also available. ! ! ! ! ! ! am lc s on A te G nt st il ! 4 Independent Voltage Regulators with Shutdown Output Current: 200mA each LDO One Time Programmable Output Voltage (User- or Factory-Trimmed) Programmable Output Voltage Range: 1.8 to 3.3V in 0.1V Steps Accuracy: ±2% PSRR: 70dB at 1kHz, 40dB at 100kHz Line Regulation: ±2mV Load Regulation: ±0.6mV Supply Range: 3 to 5.5V 0.2V Dropout Voltage @ I = 200mA Shutdown Current: ≤1µA Supply Current Without Load: 225µA Softstart for Low Inrush Current Stable with Low ESR Ceramic Capacitors from 1 to 4.7µF Low Noise: 40µV rms @10Hz to 100kHz Bandwidth Thermal Protection Over-Current Protection Temperature Range: -40 to +85°C Package Types al id The AS1352 is a high-performance quad CMOS lowdropout voltage regulator in a single QFN package. The efficient set of programmable power supplies is optimized to deliver the best compromise between quiescent current and regulator performance for mobile phones, PDAs, MP3 players, and other battery powered devices. lv 1 General Description Stability is guaranteed with ceramic output capacitors of only 1µF (±20% – X5R) up to 4.7µF (±20% – X5R). The low equivalent series resistance (ESR) of these capacitors ensures low output impedance at high frequencies. Regulation performance is excellent even under low dropout conditions, when the power transistor has to operate in linear mode. ! ! ! ! ! ! ! ! The low-noise performance allows direct connection of noise sensitive circuits without additional filtering networks. The AS1352 is available in a 12-pin QFN 4x4 package and a 16-pin QFN 3x3 package. ! ! ! - 12-pin QFN 4x4 - 16-pin QFN 3x3 3 Applications ca The AS1352 is ideal for cordless and mobile phones, MP3 players, CD and DVD players, PDAs, handheld computers, digital cameras, and any other hand-held battery-powered device. ni Figure 1. Pinout Assignments (Top View) EN4 REF 12 11 10 ch EN3 1 EN1 VDD 9 12-pin QFN 4x4 2 8 3 7 4 5 6 VOUT1 VOUT2 VOUT3 www.austriamicrosystems.com 1 VDD 2 VDD 3 VDD 4 EN3 EN4 REF 16 15 14 13 12 GND GND AS1352 Te EN2 EN1 EN2 11 GND AS1352 16-pin QFN 3x3 VDD 10 VDD VOUT4 13 GND (Exposed Pad) Revision 1.31 9 5 6 7 VDD 8 VOUT1 VOUT2 VOUT3 VOUT4 1 - 10 AS1352 Data Sheet - Pinout 4 Pinout Pin Assignments Figure 2. Pin Assignments (Top View – Not To Scale) REF EN2 EN3 EN4 REF 11 10 16 15 14 13 1 9 EN1 VDD 2 8 3 7 5 2 VDD 3 VDD 4 VOUT4 13 GND 10 VDD 9 5 (Exposed Pad) 11 GND AS1352 16-pin QFN 3x3 VDD 6 VOUT1 VOUT2 VOUT3 Pin Descriptions VDD 12 GND 6 7 VDD 8 am lc s on A te G nt st il 4 1 GND AS1352 12-pin QFN 4x4 EN1 al id EN4 12 lv EN2 EN3 VOUT1 VOUT2 VOUT3 VOUT4 Table 1. Pin Descriptions 12-pin QFN 4x4 16-pin QFN 3x3 Pin Number Pin Number Pin Name Description 1 EN1 VOUT1 Digital Input Enable 16 EN2 VOUT2 Digital Input Enable 15 EN3 VOUT3 Digital Input Enable 14 EN4 VOUT4 Digital Input Enable 11, 12 GND Negative Supply Voltage. Note: All GND pins must be connected together externally. - GND Negative Supply Voltage. This pin is the exposed pad. Note: All GND pins must be connected together externally. 13 REF Analog Reference Voltage. Note: Connect to 100nF capacitor during normal operation. 3, 8 2, 3, 4, 9, 10 VDD Positive Supply Voltage. Note: All VDD pins must be connected together externally. 4 5 VOUT1 Regulated Analog Output Voltage 1 6 VOUT2 Regulated Analog Output Voltage 2 7 VOUT3 Regulated Analog Output Voltage 3 8 VOUT4 Regulated Analog Output Voltage 4 2 1 12 11 9 13 ch 6 ni 5 ca 10 Te 7 www.austriamicrosystems.com Revision 1.31 2 - 10 AS1352 Data Sheet - Absolute Maximum Ratings 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics on page 4 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Min Max Units VDD to GND -0.3 7 V -0.3 VDD + 0.3 V 1100 2800 mW Operating Ambient Temperature -40 85 ºC Storage Temperature -65 150 ºC Electrostatic Discharge Protection (ESD) Level 1 Min value measured at TAMB = 85ºC; max value measured at TAMB = 25ºC am lc s on A te G nt st il Any other Pin to GND Continuous Power Dissipation QFN12 4x4mm Comments lv Parameter al id Table 2. Absolute Maximum Ratings +260 HBM – Norm: MIL 883 E method 3015 ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020C “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. Te ch ni ca Package-Body Peak Temperature kV www.austriamicrosystems.com Revision 1.31 3 - 10 AS1352 Data Sheet - Electrical Characteristics 6 Electrical Characteristics VDD = 4V; TAMB = -40 to +85ºC. Typ values are @ TAMB = 25ºC, CLOAD = 1µF (Ceramic); (unless otherwise specified). Table 3. Electrical Characteristics Parameter Conditions VDD Supply Voltage Range VOUT Output Voltage Range RON On Resistance Min Max Unit 3 5.5 V 1.8 3.3 V 1 Ω f = 1kHz, CREF = 100nF 70 f = 100kHz, CREF = 100nF 40 IOFF Shut Down Current ENx = Low IVDD Supply Current Without Load 1 Output Voltage Settling Time ILOAD Switched from 0 to 100mA dB 225 CREF = 100nF Pre-charged tstart 1 µA 350 µA 50 µs am lc s on A te G nt st il tset 1 lv Power Supply Rejection Ratio PSRR Typ al id Symbol 1 Start-up Time 2 VOUT Output Voltage Tolerance VLINEREG Line Regulation, Static VLOADREG Load Regulation, Static Enable Input Voltage High VIL Enable Input Voltage Low ILOAD Output Current ILIMIT Output Current Limitation VNoise Output Noise Voltage 300 µs CREF = 100nF Uncharged 15 ms ILOAD = 0 to 200mA -2 2 % VDD = 5.5V -1 1 % VDD = 3 to 4.5V -2 2 mV ILOAD = 0 to 50 mA 0.3 2.5 mV ILOAD = 0 to 200 mA (referenced to 100mA) 0.6 5 mV 0.6 x VDD 0 10 to 100kHz, CREF = 100nF Thermal Protection 1 1 1 V 0.8 V 200 mA 400 mA 40 µVRMS 145 ºC ni Notes: µs CREF = 0nF Uncharged ca VIH 300 Te ch 1. Guaranteed by design and verified by lab evaluation. 2. Startup is performed if any EN pin goes high. www.austriamicrosystems.com Revision 1.31 4 - 10 AS1352 Data Sheet - Application Information 7 Application Information Figure 3. Typical AS1352-uxyz Application VOUT1 VDD 3V 2.5V VOUT2 CMOS Sensor 2.9V VOUT3 VDD lv VCORE 1µF ±20% (X5R) 2.2µF +100/-50% (Z5U) al id VPERI 1µF ±20% (X5R) 2.2µF +100/-50% (Z5U) 3.0V am lc s on A te G nt st il VPERI 1µF ±20% (X5R) 2.2µF +100/-50% (Z5U) Camera IC EN1 VOUT4 1.8V VCORE EN2 Microprocessor 1µF ±20% (X5R) 2.2µF +100/-50% (Z5U) EN3 EN4 AS1352-7BC0 REF GND 100nF (Improved Noise Performance) GND ca One-Time Programming Procedure Output Voltages The four LDOs can be programmed and burned to any output voltage between 1.8V and 3.3V in steps of 0.1V. Customers can burn the desired output voltages onsite using the austriamicrosystems programming board. Te ch ni Furthermore, the AS1352 is available in pre-programmed versions with fixed output voltages (see Ordering Information on page 9). www.austriamicrosystems.com Revision 1.31 5 - 10 AS1352 Data Sheet - Application Information AS1352 Block Diagram VDD VOUT1 Thermal Protection Softstart VREF EN1 Control lv VOUT2 al id Overcurrent Protection Thermal Protection am lc s on A te G nt st il Overcurrent Protection Softstart VREF EN2 Control VDD VOUT3 Thermal Protection Overcurrent Protection Softstart VREF EN3 Control ni ca VOUT4 Overcurrent Protection Softstart VREF Control Te ch EN4 Thermal Protection Reference Voltage REF AS1352 GND www.austriamicrosystems.com Revision 1.31 6 - 10 AS1352 Data Sheet - Package Drawings and Markings 8 Package Drawings and Markings The AS1352 is available in a 12-pin QFN 4x4 package and a 16-pin QFN 3x3 package. Figure 4. 12-pin QFN 4x4 and 16-pin QFN 3x3 Packages D2 -A- D2/2 Index Area (D/2 xE/2) al id D/2 -B- E2/2 e E/2 NXL 4 E aaa C 2x lv -B- See Detail B E2 D 2 1 am lc s on A te G nt st il Pin 1 Marker aaa C 2x 4 SEE Detail B NXb -A- N N-1 6 Index Area (D/2 xE/2) 5 bbb ddd C A B C Bottom View Top View 11 0.08 C NX Seating Plane Side View Datum A or B Datum A or B 12 L1 L1 12 ca ni e/2 ch e Terminal Tip e Terminal Tip 5 5 Detail B Odd Terminal Side Te Even Terminal Side -C- A3 9 A1 8 A ccc C Notes: 1. Dimensioning and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters; angles in degrees. www.austriamicrosystems.com Revision 1.31 7 - 10 AS1352 Data Sheet - Package Drawings and Markings am lc s on A te G nt st il lv al id 3. N is the total number of terminals. 4. The terminal #1 identifier and terminal numbering convention shall conform to JEDEC 95 SPP-012. Details of terminal #1 identifier are optional but must be located within the zone indicated. The terminal #1 identifier may be either a mold or marked feature. 5. Dimension b applies to metallized terminal and is measured between 0.15 and 0.30mm from terminal tip. If one end of the terminal has the optional radius, the b dimension should not be measured in that radius area. 6. Dimensions ND and NE refer to the number of terminals on each D and E side, respectively. 7. Depopulation is possible in a symmetrical fashion. 8. Figure 4 is shown for illustration only and does not represent any specific variation. 9. All variations may be constructed per Figure 4, however variations may alternately be constructed between square or rectangle shape per dimensions D and E. 10. Refer to the Dimensions Table for a complete set of dimensions. 11. Bilateral coplanarity zone applies to the exposed heat sink slug as well as the terminals. 12. Depending on the method of lead termination at the edge of the package, pullback (L1) may be present. L minus L1 to be ≥ 0.33mm. 13. For variations with more than one lead count for a given body size and terminal pitch, each lead count for that variation is denoted by a dash number (e.g., -1 or -2). 16-pin QFN 3x3 Dimensions Symbol aaa bbb ccc ddd b e Min 0.18 Nom 12-pin QFN 4x4 Dimensions Notes Symbol 0.15 1, 2 aaa 0.15 1, 2 0.10 1, 2 bbb 0.10 1, 2 0.10 1, 2 ccc 0.10 1, 2 0.05 1, 2 ddd 0.05 1, 2 1, 2 b 0.25 Max 0.30 0.50 Min 0.25 e Nom 0.30 Max Notes 0.35 1, 2 0.80 A 0.80 0.90 1.00 1, 2 A 0.80 0.90 1.00 1, 2 A1 0.00 0.02 0.05 1, 2 A1 0.00 0.02 0.05 1, 2 1, 2 A3 L1 D BSC E BSC 0.20 REF 0.03 0.15 0.20 REF 0.03 1, 2 1, 2 L1 3.00 1, 2, 10 D BSC 4.00 1, 2, 10 3.00 1, 2, 10 E BSC 4.00 1, 2, 10 ca A3 0.15 1, 2 1.30 1.45 1.55 1, 2, 10 D2 2.00 2.15 2.25 1, 2, 10 E2 1.30 1.45 1.55 1, 2, 10 E2 2.00 2.15 2.25 1, 2, 10 L 0.30 0.40 0.50 0.45 0.55 0.65 L 16 1, 2, 10 N ND 4 1, 2, 10 ND 3 1, 2, 10 4 1, 2, 10 NE 3 1, 2, 10 ni 1, 2, 10 N ch D2 1, 2, 10 1, 2, 10 Te NE 12 www.austriamicrosystems.com Revision 1.31 8 - 10 AS1352 Data Sheet - Ordering Information 9 Ordering Information The AS1352 is available with preset LDO output voltages or customer-specific versions (with a minimum order quantity of 30,000). Customer-specific devices are factory trimmed to the desired output voltage (see Table 5) Table 4. Ordering Information LDO Values AS1352-T AS1352V-T User-programmable LDO values. 2 User-programmable LDO values. Delivery Form Package 1 Tape and Reel 12-pin QFN 4x4 1 Tape and Reel 16-pin QFN 3x3 al id Model Factory-trimmed LDO values: VOUT1 = 2.5V, VOUT2 = 2.9V, VOUT3 = 3.0V, VOUT4 = 1.8V Tape and Reel 12-pin QFN 4x4 AS1352-C0CF-T Factory-trimmed LDO values: VOUT1 = 3.0V, VOUT2 = 1.8V, VOUT3 = 3.0V, VOUT4 = 3.3V Tape and Reel 12-pin QFN 4x4 3 Customer-specific factory-trimmed LDO values. Tape and Reel 12-pin QFN 4x4 2, 3 Customer-specific factory-trimmed LDO values. Tape and Reel 16-pin QFN 3x3 AS1352V-uxyz-T am lc s on A te G nt st il AS1352-uxyz-T lv AS1352-7BC0-T 1. The values are programmed via the AS1352 programming board. 2. Available upon request. Contact austriamicrosystems, AG for more information. 3. Customer-specific values are as follows: u = Customer-specific VOUT1 value suffix. x = Customer-specific VOUT2 value suffix. y = Customer-specific VOUT3 value suffix. z = Customer-specific VOUT4 value suffix. Table 5. Output Voltage Suffix Guide Output Voltage F 3.3V E 3.2V D 3.1V C 3.0V B 2.9V A 2.8V 9 2.7V 8 7 2.6V 6 2.4V 2.3V 4 2.2V 3 2.1V 2 2.0V 1 1.9V 0 1.8V Te ch 2.5V 5 ni AS1352-uxyz uxyz Suffix ca Model www.austriamicrosystems.com Revision 1.31 9 - 10 AS1352 Data Sheet Copyrights Copyright © 1997-2007, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. al id Disclaimer am lc s on A te G nt st il lv Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. ni ca The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. ch Contact Information Te Headquarters austriamicrosystems AG A-8141 Schloss Premstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com Revision 1.31 10 - 10
AS1352
物料型号:AS1352
器件简介: AS1352是一款高性能四路CMOS低压降电压稳压器,集成在一个QFN封装中。该稳压器专为移动电话、PDA、MP3播放器等电池供电设备设计,提供一组可编程电源,以最佳平衡静态电流和稳压器性能。该器件具有一次性可编程(OTP)功能,允许现场独立编程每个稳压器的输出电压,从而提高设计灵活性。该功能有助于快速原型设计,减少开发时间和成本。同时提供工厂校准版本以供全面生产使用。
引脚分配: - 12引脚QFN 4x4封装和16引脚QFN 3x3封装。 - 引脚包括使能输入(EN)、参考电压(REF)、地(GND)、正电压(VDD)、输出电压(VOUT)。 - 所有GND引脚必须外部连接在一起,所有VDD引脚也必须外部连接在一起。
参数特性: - 4个独立电压稳压器,每个LDO输出电流200mA。 - 可编程输出电压范围:1.8至3.3V,步进0.1V。 - 精度:±2%。 - 电源抑制比(PSRR):1kHz时70dB,100kHz时40dB。 - 静态线压降:±2mV。 - 静态负载压降:±0.6mV。 - 供电范围:3至5.5V。 - 低至0.2V的压降电压。 - 关断电流:≤1µA。 - 无负载时供电电流:225µA。 - 软启动功能,低内阻(ESR)陶瓷电容器稳定。
功能详解: - 低噪声性能,允许直接连接对噪声敏感的电路,无需额外的滤波网络。 - 热保护和过流保护。 - 温度范围:-40至+85°C。
应用信息: AS1352适用于无绳和移动电话、MP3播放器、CD和DVD播放器、PDA、手持计算机、数字相机等手持电池供电设备。
封装信息: - 12引脚QFN 4x4封装和16引脚QFN 3x3封装。 - 封装细节包括尺寸、引脚数、标记等。
AS1352 价格&库存
很抱歉,暂时无法提供与“AS1352”相匹配的价格&库存,您可以联系我们找货
