AS1906C31-T
AS1906C31-T
    AMSOSRAM(艾迈斯半导体)
    TO-236-3,SC-59,SOT-23-3
    监控器 开路漏极或开路集电极 1 通道 SOT-23-3
AS1906C31-T 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com AS1904, AS1905, AS1906 Data Sheet Wor ld's Ultra Low-Power µP Supervisory Circuit Low P o Con wer est sum 1 General Description 2 Key Features ptio n! The AS1904/5/6 family is an ultra low-power supervisory Low 150nA (typical) Supply Current ! The device can be used to monitor the supply voltage of digital systems and microprocessors and initiate a reset when the voltage goes below a predefined threshold. The duration of the reset is 5/20/100/500ms (typ.) after the supply voltage has risen above the threshold. ! Precision Monitoring of 2.5-, 3-, and 3.3V-Power Supplies ! Supply Voltage Range 1.0 to 3.6V ! Reset Threshold Available from 2.2 to 3.1V ! Available in three Versions lv The device exhibits excellent reliability and can reduce application costs by eliminating all external components. - AS1904 Push-Pull RESETN - AS1905 Push-Pull RESET The device is available with different output drivers: - AS1906 Open Drain RESETN The AS1904 has a push-pull driver with an active low reset. ! The AS1905 uses the same output stage as the AS1904, but has an active high reset. am lc s on A te G nt st il ! ! al id circuit device. The AS1906 has an open drain output with active low reset. All devices operate down to a voltage of 1V. ! 4 Time-Out Periods Ranging from 5 to 500ms ! Detection Voltage Accuracy: ±1.5% ! Temperature Range: -40 to +85°C ! SOT23-3 Package ! Superior Upgrade to austriamicrosystems AS1901/2/3 Device Family The reset thresholds are factory-trimmable between 2.2V and 3.08V in steps of approximately 100mV. Each device of the AS1904/5/6 family is offered with four time-out periods of 5/20/100/500ms. The extremely low current consumption of only 150nA (typ) at 3.3V makes the device ideal for use in portable applications. 3 Applications The devices are ideal for computers, intelligent instruments, controllers, critical microprocessor and microcontroller, power monitoring and portable/batterypowered equipment. ca All devices are available in a 3-pin SOT23 package. VCC ni Figure 1. Functional Block Diagrams VCC 3 3 ch VDD Te AS1904 AS1905 RESET, RESETN VCC VDD Microprocessor 2 GND www.austriamicrosystems.com AS1906 RESET RESETN GND GND 1 VCC Microprocessor 2 RESET I/O GND 1 Revision 1.41 1-9 AS1904, AS1905, AS1906 Data Sheet - P i n o u t 4 Pinout Pin Assignments Figure 2. Pin Assignments (Top View) 1 AS1904 AS1905 AS1906 RESETN, RESET VDD 2 am lc s on A te G nt st il SOT23-3 Pin Descriptions 3 lv GND al id Top View Table 1. Pin Descriptions Pin Number AS1904/AS1906 1 2 - Description 1 GND Ground - RESETN Active-low reset output. RESETN remains low while VDD is below the reset threshold and for tTP after VDD rises above the reset threshold. RESETN is open-drain on the AS1906 and push-pull on the AS1904. 2 RESET Active-high reset output. RESET remains high while VDD is below the reset threshold and for tTP after VDD rises above the reset threshold. 3 VDD Supply voltage. Te ch ni ca 3 Pin Name AS1905 www.austriamicrosystems.com Revision 1.41 2-9 AS1904, AS1905, AS1906 Data Sheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Limits Units VDD to GND -0.3 to +5 V RESET/RESETN to GND -0.3 to VDD + 0.3 V Input Current (VDD) 20 mA Output Current (RESET, RESETN) 20 mA 100 V/µs -40 to +85 °C Storage Temperature Range -65 to +150 °C The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020C “Moisture/Reflow Sensitivity Classification for non-hermetic Solid State Surface Mount Devices” am lc s on A te G nt st il Rate of Rise (VDD) Operating Temperature Range (TA) Notes lv Parameter al id Table 2. Absolute Maximum Ratings (TA = 25°C Unless Otherwise Noted) +260 °C Te ch ni ca Package-Body Peak Temperature www.austriamicrosystems.com Revision 1.41 3-9 AS1904, AS1905, AS1906 Data Sheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics VDD = Full Range; TA = -40º to +85°C; Unless Otherwise Specified Table 3. Electrical Characteristics VDD Range VDD Supply Current IDD RESET Threshold Voltage1 Conditions Min TA = 0 to +70°C 1.0 TA = -40 to +85°C 1.2 VDD = 3.3V, No Load RESET Active Time-Out Period3 tTP Unit 3.6 V 3.6 150 RESETN Output Voltage (AS1904/AS1906) VOL RESETN Output Voltage (AS1904) VOH VOH RESET Output Voltage (AS1905) VOL RESET Threshold Hysteresis VHYST Open-Drain RESETN Output Leakage Current (AS1906) ILEAK Notes: V 290 nA VTH 1.5% VTH VTH + 1.5% V TA = -40 to +85°C VTH 2.5% VTH VTH + 2.5% V 20 50 µs tTP + 60% ms 0.4 V 0.4 V VDD = VTH to (VTH - 100mV) tTP 40% ISINK = 1.2mA, VDD = 2.1V, reset asserted tTP am lc s on A te G nt st il tRD Max TA = +25°C VTH VDD to Reset Delay2 Typ al id Symbol lv Parameter ISINK = 400µA, VDD = 1.2V, reset asserted ISOURCE = 1.2mA, VDD = 3.2V 0.8 x VDD V ISOURCE = 500µA, VDD = 2.1V, reset asserted 0.8 x VDD V ISOURCE = 100µA, VDD = 1.2V, reset asserted 0.8 x VDD V ISINK = 1.2mA, VDD = 3.2V, reset not asserted 0.4 10 0.1 See Table 6, “Coding of Factory-Trimmed Reset Threshold Voltages,” on page 6. 2 Guaranteed by design. 3 See Table 4, “Coding of Factory-trimmed Reset Active Time-Out Period,” on page 6. mV µA Te ch ni ca 1 V www.austriamicrosystems.com Revision 1.41 4-9 AS1904, AS1905, AS1906 Data Sheet - Ty p i c a l O p e r a t i n g C h a r a c t e r i s t i c s 7 Typical Operating Characteristics Figure 3. Supply Current vs. Temperature Figure 4. Power Down Reset Delay vs. Temp. 0.5 200 VOD = 10mV 0.2 0.1 al id 0.3 150 125 100 75 50 lv . 0.4 Reset Delay (µs) Supply Current (mA) . 175 25 -15 0 -40 am lc s on A te G nt st il 0 -40 10 35 60 85 Temperature(°C) Max. Transient Duration (µs) 150 125 100 75 50 25 0 -40 -15 10 35 60 85 60 300 275 250 225 200 175 150 125 100 75 50 25 0 1 85 10 100 1000 Reset Th. Overdrive VTH-VCC (mV) Te ch ni ca Temperature(°C) Overdrive 35 Figure 6. Max. Trans. Duration vs. Reset Th. . . Power-Up Reset Timeout (ms) 175 10 Temperature(°C) Figure 5. Power-Up Reset Timeout vs. Temperature 200 -15 www.austriamicrosystems.com Revision 1.41 5-9 AS1904, AS1905, AS1906 Data Sheet - D e t a i l e d D e s c r i p t i o n 8 Detailed Description Interfacing to Microprocessors with Bi-Directional Reset Pins The device has an open drain RESETN output, which enables easy interfacing to microprocessors (µP) with bi-directional reset pins, such as the Motorola 68HC11. The RESETN pin of the microcontroller (µC) can be connected directly to the µP supervisor's RESETN output with a single pull-up resistor (see Figure 1 on page 1). al id Negative-Going VDD Transients The device is optimized to ignore short-duration, negative-going VDD transients (glitches) in order to avoid incorrect resets. lv In the graph Maximum Transient Duration vs. Reset Threshold Overdrive (page 6) , the conditions are shown, for which the reset pulses are not generated. In the graph the maximum pulse width that a negative VDD transient may have when a reset signal is generated. As the amplitude of the transient increases, the maximum allowable pulse width decreases. am lc s on A te G nt st il Options Table 4. Coding of Factory-trimmed Reset Active Time-Out Period Device tTP in Milliseconds Suffix Min Typ Max AS190x_xx A 3 5 8 AS190x_xx B 12 20 32 AS190x_xx C 60 100 160 AS190x_xx D 300 500 800 Table 5. Output Variants Device AS1904xxx AS1905xxx AS1906xxx Output Functionality Active Low (RESETN) Active High (RESET) Open Drain (RESETN) Table 6. Coding of Factory-Trimmed Reset Threshold Voltages Reset Threshold Voltage, VTH in V Suffix AS190xx__ TA = -40 to +85°C Min Typ Max Min Max 22 2.167 2.2 2.233 2.145 2.255 23 2.285 2.32 2.355 2.262 2.378 ni AS190xx__ TA = +25°C ca Device 24 2.364 2.4 2.436 2.340 2.460 AS190xx__ 25 2.463 2.5 2.538 2.438 2.563 AS190xx__ 26 2.591 2.63 2.669 2.564 2.696 AS190xx__ 27 2.660 2.7 2.741 2.633 2.768 AS190xx__ 28 2.758 2.8 2.842 2.730 2.870 AS190xx__ 29 2.886 2.93 2.974 2.857 3.003 Te ch AS190xx__ AS190xx__ 30 2.955 3.0 3.045 2.925 3.075 AS190xx__ 31 3.034 3.08 3.126 3.003 3.157 www.austriamicrosystems.com Revision 1.41 6-9 AS1904, AS1905, AS1906 Data Sheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 9 Package Drawings and Markings The device is available in a 3-pin SOT-23 package. Te ch ni ca am lc s on A te G nt st il lv al id Figure 7. 3-Pin SOT-23 Package. www.austriamicrosystems.com Revision 1.41 7-9 AS1904, AS1905, AS1906 Data Sheet - O r d e r i n g I n f o r m a t i o n 10 Ordering Information The device is available in the following standard versions. Standard Part Threshold (V) Duration (mS) Marking 2.32 100 ASGI AS1904C26 2.63 100 ASDB AS1904C31 3.08 100 ASDG AS1905C23 2.32 100 AS1905C26 2.63 100 AS1905C31 3.08 100 AS1906C23 2.32 100 AS1906C26 2.63 100 100 3.08 100 ASDQ ASDS ASDV lv 2.8 AS1906C31 ASDI ASDL ASDX ASGK am lc s on A te G nt st il AS1906C28 al id AS1904C23 Te ch ni ca Non-standard versions require a minimum order of 30,000 units. Contact austriamicrosystems for availability of nonstandard versions. www.austriamicrosystems.com Revision 1.41 8-9 AS1904, AS1905, AS1906 Data Sheet Copyrights Copyright © 1997-2007, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. al id Disclaimer am lc s on A te G nt st il lv Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or lifesustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. ni ca The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. ch Contact Information Te Headquarters austriamicrosystems AG A-8141 Schloss Premstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com Revision 1.41 9-9
AS1906C31-T 价格&库存
很抱歉,暂时无法提供与“AS1906C31-T”相匹配的价格&库存,您可以联系我们找货
