AS5172B-HTSM
AS5172B-HTSM
    AMSOSRAM(艾迈斯半导体)
    TSSOP14
    霍尔效应 传感器 角度 外磁铁,不含 鸥翼
AS5172B-HTSM 数据手册
AS5172A / AS5172B High-Resolution On-Axis Magnetic Angular Position Sensor with PSI5 Output General Description The AS5172 is a magnetic position sensor with a high resolution 12-bit PSI5 output according PSI5 specification Version 1.3 and 2.1. Based on a Hall sensor technology, this device measures the orthogonal component of the flux density (Bz) over a full-turn rotation and compensates for external stray magnetic fields with a robust architecture based on a 14-bit sensor array and analog front-end (AFE). A sub-range can programmed to achieve the best resolution for the application. To measure the angle, only a simple two-pole magnet rotating over the center of the package is required. The magnet may be placed above or below the device. The absolute angle measurement provides an instant indication of the magnet’s angular position. The AS5172 operates up to a voltage of 16.5V and is protected against overvoltage up to +20V. In addition, the supply pins are protected against reverse polarity up to –18V. Programmability over the VDD pin reduces the number of pins on the application connector. The AS5172 is available in a TSSOP14 package and in a SIP package. The SIP package (System in Package) has integrated the AS5172 sensor die together with the decoupling capacitors necessary to pass system level ESD and EMC requirements. No additional components and PCB on the sensor side are needed. The product is defined as SEooC (Safety Element out of Context) according ISO26262. The product is fully system level EMC and ESD tested according OEM standards. Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-03] 2017-Sep-06 Page 1 Document Feedback AS5172A / AS5172B − General Description Key Benefits and Features The benefits and features of this device are listed below: Figure 1: Added Value of Using AS5172 Benefits Features • Resolve small angular excursion with high accuracy • 12-bit resolution @90° minimum arc • Accurate angle measurement • Low output noise, low inherent INL • Higher durability and lower system costs (no shield needed) • Magnetic stray field immunity • Enabler for safety critical applications • Functional safety, diagnostics • Suitable for automotive applications • AEC-Q100 Grade 0 qualified (AS5172B) • AEC-Q100 Grade 1 qualified (AS5172A) • SIP Package • System cost reduction – no PCB and additional components are needed Applications The AS5172 is ideal for automotive applications like brake and gas pedals, throttle valve and tumble flaps, steering angle sensors, chassis ride, EGR, fuel-level measurement systems, 2/4WD switch, and contactless potentiometers. Page 2 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − General Description Block Diagram The functional blocks of this device are shown below: Figure 2: Functional Blocks of the AS5172 SM7 Power Management LDO VDD3V3 SM5 SM9 Velocity SM2 AFE SM3 Cordic (ATAN2) 14 Bit ADC 14-Bit Mode DSP HV Protection VDD PSI5 I/F Broken Hall detection (SM14) SM4 Signature monitor (SM10) AGC UART-over-PSI5 Register Setting OTP Oscillator Watchdog ( SM1) HV Protection GND Note(s): 1. Detailed safety mechanism information can be found in chapter Diagnostic ams Datasheet [v1-03] 2017-Sep-06 Page 3 Document Feedback AS5172A / AS5172B − Pin Assignments Pin Assignments Pin Diagram Figure 3: AS5172B Pin Assignment (Top View, TSSOP14) 1 14 VDD NC 2 13 NC TP2 3 12 GND NC 4 11 NC TP3 5 10 VDD3V3 NC 6 9 NC TP4 7 8 NC AS5172B TP1 Figure 4: AS5172B Pin Description Pin Number Name Type 1 TP1 Test pin Connected to GND in application 2 NC Not connected Connected to GND in application 3 TP2 Test Pin Connected to GND in application 4 NC Not connected Connected to GND in application 5 TP3 Test Pin Connected to GND in application 6 NC Not connected Connected to GND in application 7 TP4 Test Pin Connected to GND in application 8 NC Not connected Connected to GND in application 9 NC Not connected Connected to GND in application 10 VDD3V3 Supply Page 4 Document Feedback Description Requires a 470nF capacitor to GND ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Pin Assignments Pin Number Name Type 11 NC Not connected 12 GND Supply 13 NC Not connected 14 VDD Supply ams Datasheet [v1-03] 2017-Sep-06 Description Connected to GND in application Ground Connected to GND in application Supply/PSI5 interface/UART-over-PSI5 programming Requires a 15nF capacitor to GND Page 5 Document Feedback AS5172A / AS5172B − Pin Assignments Figure 5: AS5172A in SIP Package 1 2 3 VDD GND NC Figure 6: AS5172A Pin Description Pin Number Name Type 1 VDD Supply Supply/PSI5 interface/UART-over-PSI5 programming 2 GND Supply Ground 3 NC Not connected Page 6 Document Feedback Description Left open in application ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 7: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD DC Supply Voltage at VDD pin -18 20 V VREGOUT DC Voltage at the VDD3V3 pin -0.3 5 V ISCR Input Current (latch-up immunity) ±100 mA Not operational AEC-Q100-004 Continuous Power Dissipation (TAMB = 70°C) PT_Tssop Continuous Power Dissipation 377 mW PT_SIP Continuous Power Dissipation 377 mW Electrostatic Discharge ESDHBM on all ESDHBM on TSSOP ESDHBM on SIP ams Datasheet [v1-03] 2017-Sep-06 Electrostatic Discharge HBM ±2 kV AEC-Q100-002 On VDD and GND ±4 kV AEC-Q100-002 On VDD and GND ±8 kV AEC-Q100-002 Page 7 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Temperature Ranges and Storage Conditions TAMB Operating Temperature Range -40 125 °C AS5172A ambient temperature TAMB_LM Operating Temperature Range -40 150 °C AS5172B ambient temperature TaProg Programming Temperature 5 45 °C Programming@ room temperature (25°C ± 20°C) -55 125 °C TSTRG Storage Temperature Range TBODY Package Body Temperature RHNC Relative Humidity (non-condensing) MSL Moisture Sensitivity Level 5 3 260 °C 85 % The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is “Matte Tin” (100% Sn) Represents a maximum floor life time of 168 hours System Electrical and Timing Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. All in this datasheet defined tolerances for external components need to be assured over the whole operation conditions range and also over lifetime. Overall Condition: TAMB= -40°C to 125°C for AS5172A; TAMB=-40°C to 150°C for AS5172B; VDD= 4V – 12V (sync pulse voltage not included); Components spec; unless otherwise noted Page 8 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Figure 8: Operating Conditions Symbol Parameter VDD Positive Supply Voltage Static condition VDD_Rx Positive Supply Voltage Dynamic condition VDD3 Conditions Regulator Voltage Min Typ Max Unit 4 12 V 4 16.5 V 3.3 3.45 3.6 V 11 15 19 mA IDD Current Consumption No programming and no PSI5 communication IDDProg Current Consumption During programming IDDProgUN Current Consumption of Unprogrammed Device Unprogrammed device @ TAMB = 25°C ± 10°C 49 mA IDD max Current Consumption IDD + IS_Common 49 mA IS_Common Sink Current (common mode) IS_low power mode IDD_D IDD_DRate Sink current (low power mode) Current Drift of IS in Low Power Mode 80 mA 22 26 30 mA 11 13 15 mA 4 mA -4 Current Drift Rate Not tested 1 mA/s Start-Up Time, With ±2mA Tolerance in Respect to the Trimmed ILO Value (IL) Functional mode 5 ms Fall/Rise Time of the Current Slope Programmed in production 300 500 700 ns PSI5_TBITL Bit Time 125kbit/s Mode Not tested - Guaranteed by Design 7.6 8.0 8.4 μs PSI5_TBITH Bit Time 189kbit/s Mode Not tested - Guaranteed by Design 5.0 5.3 5.6 μs Mark/Space Ratio (tfall,80% - trise, 20%)/PSI5_TBIT or (tfall,20% - trise, 80%)/PSI5_TBIT Programmed in production 47 50 53 % TSUP PSI5_T PSI5_MSR ams Datasheet [v1-03] 2017-Sep-06 Page 9 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Electrical System Characteristics TAMB= -40°C to 125°C for AS5172A; TAMB=-40°C to 150°C for AS5172B; VDD = 4V – 12V (sync pulse voltage not included); Magnetic Characterization; unless otherwise noted Figure 9: Electrical System Characteristics Symbol CRES Parameter Conditions Min Core Resolution Typ 14 ≥ 90° slope OutputRes Max Unit bit 12 bit INLopt Integral Non-Linearity (optimum) Best aligned reference magnet (1) at 25°C over full turn 360° -0.5 0.5 deg INLtemp Integral Non-Linearity (optimum) Best aligned reference magnet (1) over temperature -40°C to 150°C over full turn 360° -0.9 0.9 deg INL Integral Non-Linearity Reference magnet (1) over temperature -40°C to 150°C over full turn 360º and displacement -1.4 1.4 deg ST Sampling Time SPDF CoreClk System Propagation Delay Fast 128 Depending on the PSI5 standard 200 Core Clock Coreclk tol Tolerance of the Core Clock ON Output Noise Peak to Peak μs 500 16 -3.5 Related to 12-bit Not tested Us MHz 3.5 % 4 LSB Note(s): 1. Reference magnet: NdFeB, 8mm diameter, 2.5mm thickness. Page 10 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Figure 10: Power Management – Supply Monitor - Timing Symbol Parameter Conditions Min Typ Max Unit VDDUVTH VDD Undervoltage Upper Threshold 3.6 3.8 4.0 V VDDUVTL VDD Undervoltage Lower Threshold 3.4 3.6 3.8 V VDDUH VDD Undervoltage Hysteresis 150 200 250 mV UVDT VDD Undervoltage Detection Time 10 50 250 μs UVRT Undervoltage Recovery Time 10 50 250 μs 16.7 18 19.1 V 14.5 15.5 16.5 V Info parameter If sensor in overvoltage condition, ECU gets the Error flag. --> overheating possible in the application VDDOVTH VDD Overvoltage Upper Threshold VDDOVTL VDD Overvoltage Lower Threshold OVDT VDD Overvoltage Detection Time From the time VDD exceeding 16.5V 1000 2000 μs OVRT VDD Overvoltage Recovery Time From the time VDD returning from VDD > 16.5V to normal operating voltage (4V< VDD < 17V) 1000 2000 μs VDD3V3UVTH VDD3V3 Reset Upper Threshold 2.5 2.8 2.95 V VDD3V3UVTL VDD3V3 Reset Lower Threshold 2.4 2.6 2.72 V 105 175 245 mV 12 ms VDD3V3UVHYS TDETWD ams Datasheet [v1-03] 2017-Sep-06 VDD3V3 Reset Hysteresis WatchDog Error Detection Time Info parameter Page 11 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Magnetic Characteristics TAMB= -40°C to 125°C for AS5172A; TAMB=-40°C to 150°C for AS5172B; VDD= 4V – 12V (sync pulse voltage not included); unless otherwise noted. Two-pole cylindrical diametrically magnetized source: Figure 11: Magnetic Characteristics Symbol Bz BzE Disp (1) Parameter Conditions Min Orthogonal Magnetic Field Strength Required orthogonal component of the magnetic field strength measured at the package surface along a circle of 1.25 mm @= 0 Orthogonal Magnetic Field Strength –Extended Mode Required orthogonal component of the magnetic field strength measured at the package surface along a circle of 1.25mm MFER = 1 Displacement Radius Offset between defined device center and magnet axis. Dependent on the selected magnet. Typ Max Unit 30 70 mT 10 90 mT 0.5 mm Note(s): 1. Reference magnet: NdFeB, 8mm diameter, 2.5mm thickness Page 12 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Electrical and Timing Characterization of the PSI5 Interface This chapter describes the synchronization signal from the ECU according to the PSI5 specification V1.3 and V2.1. The parameters in this chapter are not reflecting the full specification range of the detection circuit for the synchronization signal. Synchronization Signal PSI5 V1.3 Figure 12: Synchronization Signal The synchronization signal start time t0 is defined as a crossing of the Vt0 value. In the “Sync Start” phase before this point, a “rounding in” of the voltage starting from VCE, Base to Vt0 is allowed for a maximum of t1. During the “Sync Slope” phase, the voltage rises within given slew rates to a value between the minimum sync signal voltage Vt2 and the maximum interface voltage VCE, max. After maintaining the voltage between this limits until a minimum of t3, the voltage decreases in the “Sync Discharge” phase until having reached the initial VCE, base value until latest t4. ams Datasheet [v1-03] 2017-Sep-06 Page 13 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Figure 13: Synchronization Signal PSI5 V1.3 (1) Symbol VBase Parameter Conditions Base Supply Voltage Voltage value at ECU Vto Sync Slope Reference Voltage Reference to VBase Vt2 Sync Signal Sustain Voltage Reference to VBase Vce,max Maximum Interface Voltage Typ 5.7 Max Unit 11 V 0.5 V 3.5 V 16.5 t0 Reference Time Reference time base; time when the sync signal crosses Vt0 t1 Sync Signal Earliest Start V=VCE Delta current less than 2mA t2 Sync Signal Sustain Start @ Vt2 Sync Slope Rising Slew Rate Lower limit is valid for Vt0 to Vt2 Sync Slope Falling Slew Rate Min 0 -3 μs 0 7 0.43 1.0 V μs μs 1.5 -1.5 V/μs V/μs t3 Sync Signal Sustain Time 16 μs t4 Discharge Time Limit 35 μs Tslot1 Start of Time Slot 1 44 51 59 μs Tslot2 Start of Time Slot 2 181.3 195 210 μs Tslot3 Start of Time Slot 3 328.9 350 373 μs Note(s): 1. The parameters in this table are just info parameters and therefore not production tested. The production related parameters are in the PSI5 Block Parameters table. Page 14 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Figure 14: Synchronization Signal PSI5 V2.1 (1) Symbol Conditions Min Base Supply Voltage Voltage value at ECU 5.7 (4.4) Vto Sync Slope Reference Voltage Reference to VBase Vt2 Sync Signal Sustain Voltage Reference to VBase Vce,max Maximum Interface Voltage VBase Parameter Reference Time Reference time base; time when they sync signal crosses Vt0 t1 Sync Signal Earliest Start V=VCE Delta current less than 2mA t2 Sync Signal Sustain Start @ Vt2 Sync Slope Rising Slew Rate Lower limit is valid for Vt0 to Vt2 t3 Sync Signal Sustain Time t4 Discharge Time Limit Tslot1 Start of Time Slot 1 Max Unit 11 V 0.5 V 3.5 (2.5) V 16.5 t0 Sync Slope Falling Slew Rate Typ 0 -3 μs 0 7 0.43 μs μs 1.5 -1.5 V/μs V/μs 16 μs 35 44 V μs μs Note(s): 1. The parameters in this table are just info parameters and therefore not production tested. The production related parameters are in the PSI5 Block Parameters table. ams Datasheet [v1-03] 2017-Sep-06 Page 15 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Synchronization Signal Detection The AS5172 has to detect the trigger within the “trigger window” during the rising slope of the synchronization signal at the trigger point with the trigger voltage V TRIG and the trigger time t TRIG Figure 15: Trigger Window In order to take into account voltage differences at different points of the interface lines, an additional safety margin for the trigger detection is defined by V EMC and t EMC. The values are based on the PSI5 specification and shows the detection of the synchronization signal from the ECU according the PSI5 specification. Page 16 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Figure 16: Synchronization Detection (1) Symbol Parameter Max Unit VEMC_C Margin for Voltage Variations Common power mode -0.9 0.9 V VEMC_LP Margin for Voltage Variations Low power mode -0.7 0.7 V VTrig_C Trigger Voltage Threshold Common power mode 1.4 2.0 2.6 V VTrig_LP Trigger Voltage Threshold Low power mode 1.2 1.5 1.8 V tTRIG Nominal Trigger Detection Time @ VTRIG, @ AS5172 Pins; Referenced to a straight sync signal slope with nominal slew rate of 0.43 V/μs 2.1 3.5 4.9 μs VCE,max Maximum Interface Voltage 16.5 V tEMC Margin for Timing Variations of the Signal on the Interface Line 2.1 μs ttol detect Tolerance of Internal Trigger Detection Delay 3 μs 10 μs TTRIG Trigger Detection Time Conditions Relative to nominal trigger window time T TRIG = tTRIG + ttol detect + tEMC; Reference for AS5172 time base Min -2.1 0 Typ Note(s): 1. The parameters in this table are just info parameters and therefore not production tested. The production related parameters are in the PSI5 Block Parameters table. ams Datasheet [v1-03] 2017-Sep-06 Page 17 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Synchronization Signal with Discharge by AS5172 This chapter describes the modifications required if the ECU uses a special transreceiver. The parameters in this chapter are not reflecting the full specification range of the detection circuit for the synchronization signal Figure 17: Synchronization Signal from ECU with Discharge by the AS5172 VDD [V] Phase 1 Sync Start Phase 2 Sync Slope Phase 3 Sync Sustain Phase 4 Sync Discharge VCE,max Upper Boundary VCE,sync Vt2 Lower Boundary Trigger Point VTRIG Vt0 VCE,BASE t1 t0 tTRIG t2 td1 t3 td2 t4 t5 tslot2 IVDD [mA] t [s] Tbit IHIGH ILO t1 t0 Page 18 Document Feedback tTRIG t2 td1 t3 td2 t4 t5 tslot2 t [s] ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings Figure 18: Synchronization Signal from ECU with Discharge Parameter (1) Symbol Parameter Conditions Min Typ Max Unit VCE, BASE Base Supply Voltage Mean voltage value at ECU 5.0 6.0 7.0 V VCE, BASE_R Base Supply Voltage Including Ripple 4.5 6.0 7.0 V Vt0 Sync Slope Reference Voltage Referenced to VCE, BASE Vt2 Sync Signal Sustain Voltage Referenced to VCE, BASE 0.5 V +3.5 +5.0 +6.0 V VCE,max Sync Signal Max. Voltage 10 11 14.5 V VCE,max_R Sync Signal Max. Voltage Including Ripple 10 14 16.5 V t0 Reference Time Reference time base; time when the synchronization signal crosses Vt0 t1 Sync Signal Earliest Start V=VCE, BASE -3 t2 Sync Signal Sustain Start @ Vt2 3 Ssync,r Sync Slope Rising Slew Rate 10% to 90% of VCE,max Ssync,f Sync Slope Falling Slew Rate t3 Sync Signal Sustain Time td1 AS5172 Signals Discharge td2 0 μs 0 μs 4 5 μs 0.7 1.0 1.6 V/μs 90% down to 10% of VCE,max -1.6 -1.0 -0.7 V/μs V=VCE,sync 27.5 31 35.1 μs 18.5 22.75 28 μs Discharge Stop Time 38 43.25 50 μs t4 Enable Pull Down to VCE,BASE by ECU 62.5 65 65.5 μs t5 Receiver (ECU) Enable Start Time 63 66.2 65.5 μs VTRIG Trigger Voltage Threshold 1.4 2.0 2.6 V 1.25 2.15 3.05 μs -1.25 1.25 μs Receiver (ECU) read for transmission tTRIG Nominal Trigger Detection Time @ VTRIG, @ AS5172 Pins; Referenced to a straight sync signal slope with nominal slew rate of 0.7 V/μs tEMC Margin for Timing Variations of the Signal on the Interface Line Relative to nominal trigger window time ams Datasheet [v1-03] 2017-Sep-06 Page 19 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Symbol Parameter ttol detect Tolerance of Internal Trigger Detection Delay Conditions Min Typ Max Unit 3 μs 7.5 μs T TRIG Trigger Detection Time T TRIG = tTRIG + ttol detect + tEMC; Reference for sensor time base tslot 1 Start of Time Slot 1 Time slot 1 cannot be used in this communication mode tslot2 Start of Time Slot 2 181.3 195 210 μs tslot3 Start of Time Slot 3 328.9 350 373 μs 0 44 51 59 μs Note(s): 1. The parameters in this table are just info parameters and therefore not production tested. The production related parameters are in the PSI5 Block Parameters table. Page 20 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Absolute Maximum Ratings PSI5 Block Parameters Figure 19: Block Parameters Symbol VCE,BASE ECU Parameter Conditions Min Typ Max Unit Base ECU Supply Voltage Voltage at ECU 4.4 11 V VCE,BASE Base Supply Voltage Voltage at the Sensor 4.0 11 V VSUPPLY Low Supply Voltage Supply voltage for comparator 3.3 3.6 V Vt0 Sync Slope Reference Referred to VCE,BASE Vt2 Minimum Sync Signal Sustain Voltage (common mode) Referred to VCE,BASE 3.5 V Vt2_L Minimum Sync Signal Sustain Voltage (low power mode) Referred to VCE,BASE 2.5 V VCE MAX Maximum Interface Voltage t2 SLRISE Sync Signal Sustain Start 3.45 0.5 Voltage @ Vt2 Rising Slope 0.43 V 16.5 V 7 μs 1.6 V/μs Falling Slope Depends on voltage and discharge limit, external load has to meet these values Sync Signal Sustain Time Info parameter: Recommended ECU timing 16 35.1 μs Discharge Time Limit Info parameter: Allowed variation of synch pulse width for synch pulse detection circuit 17.67 62 μs TSYNC Synchronization Period Info parameter: To prevent shifts of detection threshold VTRIG VTRIG_L SLFALL t3 t4 -1.75 V/μs 250 500 Trigger Voltage Threshold (common mode) 1.4 2.0 2.6 V Trigger Voltage Threshold (low power mode) 1.2 1.5 1.8 V ams Datasheet [v1-03] 2017-Sep-06 μs Page 21 Document Feedback AS5172A / AS5172B − Absolute Maximum Ratings Symbol Conditions Min Typ Max Unit Trigger Voltage Threshold Under EMC (common mode) At SLRISE = 0.43 V/μs; For EMC ≤1VPEAK ≥ 100kHz Not tested - Guaranteed by Design 0.5 2.0 3.5 V VTRIG EMC Trigger Voltage Threshold Under EMC (low power mode) At SLRISE = 0.43 V/μs; For EMC ≤ 1VPEAK ≥ 100kHz Not tested - Guaranteed by Design 0.5 1.5 2.5 V ttol detect Tolerance of Internal Trigger Detection Delay 3 μs 135 μs VTRIG EMC Parameter Blanking of trigger signal in digital part after first rising edge to avoid multiple trigger signals during EMC events. Not tested - Guaranteed by Design tBLANK Output Signal Blanking Time VCOM Comparator Input Common Mode Voltage RESdiv Resistor Divider Division Factor Not tested - Guaranteed by Design 2% mismatch 7.84 8 8.16 V/V fC_LP Low Pass Filter Cut-Off Frequency Not tested - Guaranteed by Design 2.5 5 7.5 kHz Page 22 Document Feedback 121 1.5 V ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Detailed Description Detailed Description The AS5172 is a Hall-based rotary magnetic position sensor using a CMOS technology. The lateral Hall sensor array converts the magnetic field component perpendicular to the surface of the chip into a voltage. The signals coming from the Hall sensors are first amplified and filtered before being converted by the analog-to-digital converter (ADC). The output of the ADC is processed by the CORDIC block (Coordinate-Rotation Digital Computer) to compute the angle and magnitude of the magnetic field vector. The sensor and analog front-end (AFE) section works in a closed loop alongside an AGC to compensate for temperature and magnetic field variations. The calculated magnetic field strength (MAG), the automatic gain control (AGC) and the angle can be read through the UART-over-PSI5 protocol during programming. The magnetic field coordinates provided by the CORDIC block are fed into a linearization block (DSP) which generates the transfer function. The output of the AS5172 can be programmed to define a starting position (zero angle) and a stop position (maximum angle). The AS5172 can be programmed through the VDD Pin with a special UART-over-PSI5 protocol which allows writing an on-chip non-volatile memory (One Time Programmable memory) where the specific settings are stored. The AS5172 is equipped with a PSI5 Interface current driver and a PSI5 Interface receiver. The current driver drives the additional sink current to reach the I_high level on the VDD. The receiver is comparing the voltage level at the VDD Pin with the internal voltage thresholds. The Sensor to ECU communication is described in the chapters below and is based upon the PSI5 standard. The AS5172 supports, according the PSI5 standard, the synchronous mode or in asynchronous mode. In PSI5 V1.3 (10-bit mode), the asynchronous modes can only use one time slot per period. For a transmission of one 12/16 bit data word, two periods are necessary AS5172 supports the bus modes PSI5-U and PSI5-P. The daisy chain mode is not supported. ams Datasheet [v1-03] 2017-Sep-06 Page 23 Document Feedback AS5172A / AS5172B − Register Description Register Description OTP (non-volatile memory) Register Description Figure 20: OTP (non-volatile memory) Register Description Address Bit Nr. Symbol Description 0 Factory settings ams factory settings 2 Direction Changes direction in 14-bit mode 3 PSI5_14bit_angle Enables 14-bit angle output 4 PSI5_quad_info Enables quadrant information 5 PSI5_16bit_frame Enables the PSI5 16-bit frame 6 Velocity_extended_range 0 = 1250 deg/s 1 = 5000 deg/s 7 Extended_init_phase 0 = 22 datablocks during Init phase 1 = 32 datablocks during Init phase 0 Factory settings ams factory settings 7:1 ams ID ams ID (F9) 7:0 ams ID ams ID (F9) 5:0 ams ID ams ID (F9) 7:6 Factory settings ams factory settings Factory settings ams factory settings 1 0x01 0x02 0x03 0x04 0x05 7:0 0x06 7:0 0x07 7:0 0x08 7:0 0x09 7:0 0x0A 7:0 0x0B 7:0 Page 24 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Address Bit Nr. Symbol 0 Month[3] 1 Year[0] 2 Year[1] 3 Year[2] 4 Year[3] 5 Year[4] 6 Year[5] 7 Year[6] 0 Day[0] 1 Day[1] 2 Day[2] 3 Day[3] 4 Day[4] 5 Month[0] 6 Month[1] 7 Month[2] 0 Type[0] 1 Type[1] 2 Type[2] 3 Type[3] 4 Parameter[4] 5 Parameter[5] 6 Parameter[6] 7 Parameter[7] 0x0C Description Sensor Production Date (F8) 0x0D Sensor Production Date (F8) Sensor Type (F4) 0x0E Sensor Parameter (F5) ams Datasheet [v1-03] 2017-Sep-06 Page 25 Document Feedback AS5172A / AS5172B − Register Description Address Bit Nr. Symbol 0 Parameter[0] 1 Parameter[1] 2 Parameter[2] 3 Parameter[3] 4 Sensor_Code_Man[4] 5 Sensor_Code_Man[5] 6 Sensor_Code_Man[6] 7 Sensor_Code_Man[7] 0 Sensor_Code_Man[0] 1 Sensor_Code_Man[1] 2 Sensor_Code_Man[2] 3 Sensor_Code_Man[3] 4 Sensor_Code_Veh[3] 5 Sensor_Code_Veh[3] 6 Sensor_Code_Veh[3] 7 Sensor_Code_Veh[3] Description Sensor Parameter (F5) 0x0F Sensor Code Manufacturer (F6) Sensor Code Manufacturer (F6) 0x10 Sensor Code Vehicle (F7) 0x11 7:0 PSI5Mode PSI5 mode selection 0 Sync_discharge Enables sync pulse discharging 1 Init_phase_repetition[0] 2 Init_phase_repetition[1] 3 PSI5_timeslot[0] 4 PSI5_timeslot[1] 5 Init_phase_disable Disables the PSI5 initialization phase 6 Velocity_info Enables PSI5 velocity output 7 - Not used PSI5 initialization phase repetition factor (k-times) PSI5 timeslot for bus mode 0x12 Page 26 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Address Bit Nr. Symbol 0 - Not used 1 - Not used 2 - Not used 3 Quadrant[0] 4 Quadrant[1] 5 Velocity_filter[0] 6 Velocity_filter[1] 7 Velocity_filter[2] Quadrant selection 0x13 0x14 Description 7:0 CLH[7:0] 0 CLH[8] 1 CLH[9] 2 CLH[10] 3 CLH[11] 4 CLL[0] 5 CLL[1] 6 CLL[2] 7 CLL[3] Filter configuration for velocity measurement Clamping level high Clamping level high 0x15 Clamping level low 0x16 7:0 CLL[11:4] Clamping level low 0x17 7:0 Offset[7:0] Offset 0x18 7:0 Offset[15:8] Offset 0 Offset[16] 1 Offset[17] 2 Offset[18] 3 Offset[19] 4 Gain[0] 5 Gain[1] 6 Gain[2] 7 Gain[3] Offset 0x19 Gain 0x1A 7:0 ams Datasheet [v1-03] 2017-Sep-06 Gain[11:4] Gain Page 27 Document Feedback AS5172A / AS5172B − Register Description Address Bit Nr. Symbol 0 Gain[12] 1 Gain[13] 2 Gain[14] 3 Gain[15] 4 Gain[16] 5 BP[0] 6 BP[1] 7 BP[2] Description Gain 0x1B 0x1C 7:0 BP[10:3] Breakpoint / 14-Bit Mode zero offset Breakpoint / 14-Bit Mode zero offset 0 BP[11] 1 BP[12] 2 BP[13] 3 Extended_range_disable Disables the extended range for magnetic input field 4 Reduced_angle_range Enables the reduced angle range for segments smaller 23 degree 5 - Not used 6 - Not used 7 Customer_lock Customer lock 0x1E 7:0 VendorID[7:0] Vendor ID (F3) 0x1F 7:0 Signature[7:0] Signature calculated across the full OTP Breakpoint / 14-Bit Mode zero point offset 0x1D Page 28 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Volatile Memory Register Description Figure 21: Volatile Memory Register Description Address Bit Nr. 4:0 Symbol R/W - Description Not used 5 DSP_reset R/W Reset of the DSP (Digital Signal Processing) 6 GLoad R/W Enables GLoad 7 - 0x23 0x32 Not used 7:0 Angle_CORDIC[7:0] R 5:0 Angle_CORDIC[13:8] R 7:6 - 0x34 7:0 Magnitude R Magnitude at the CORDIC output 0x35 7:0 AGC R AGC (Automatic Gain Control) 0x36 7:0 Angle_DSP[7:0] R 3:0 Angle_DSP[11:8] R 7:4 - 7:0 Velocity[7:0] R 3:0 Velocity[11:8] R 7:4 - 0x3A 7:0 FUSA[7:0] R 0x3B 5:0 FUSA[13:8] R 14-Bit Angle information (raw value without zero offset) 0x33 Not used 12-Bit Angle information (with zero offset, and customer settings) 0x37 0x38 Not used Velocity output 0x39 Not used FUSA output SFR Description Figure 22: SFR Description Address Bit Nr. 0x60 7:0 0x61 7:0 0x62 7:0 0x63 7:0 ams Datasheet [v1-03] 2017-Sep-06 Symbol Description Pass2Function Pass-to-function, see Programming chapter BurnOTP BurnOTP, see Programming chapter Page 29 Document Feedback AS5172A / AS5172B − Register Description Programming UART-Over-PSI5 The AS5172 is equipped with a one wire UART-over-PSI5 interface based on a “Tooth Gap” similar method according PSI5 specification, which allows reading and writing the registers as well as permanent programming of the non-volatile OTP memory (One Time Programmable). By default the AS5172 is in the so-called Communication Mode. In this mode, it is possible to configure the register settings. A voltage modulation on the supply lines (VDD and GND) is used to realize a Programmer-to-Sensor communication. The Sensor-to-Programmer communication is done with current modulation. The physical layer of the two communication modes is shown in Figure 23 and Figure 24 below. Figure 23: Bit Encoding of Programmer-to-Sensor Communication VH 0 1 0 1 0 1 0 1 0 0 1 VL tBIT A logical “0” is represented by a sync pulse (V H) on the VDD line for a duration of t BIT. A logical “1” by the absence of the sync pulse (V L) for a duration of tBIT. Page 30 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 24: Bit Encoding of Sensor-to-Programmer Communication 0 IH 1 0 1 0 1 0 1 0 0 1 IL tBIT A logical “0” is represented by an increased sink current (I H) on the VDD line for a duration of t BIT. A logical “1” by normal sink current (I H) for a duration of tBIT. Figure 25: UART-Over-PSI5 Protocol Symbol Parameter Conditions Value Unit VH High Level Voltage 10 V VL Low Level Voltage 7 V IH High Level Sink Current Typical value 49 mA IL Low Level Sink Current Typical value 19 mA tBIT ±5% 26 μs Baudrate ±5% 38400 Baud For further information please refer to application note AN_AS5172_Programming_Procedure_V1-00 ams also provides a programmer which supports the above-mentioned protocol. Please get in contact with the application engineering team. ams Datasheet [v1-03] 2017-Sep-06 Page 31 Document Feedback AS5172A / AS5172B − Register Description UART Protocol The UART interface allows reading and writing two consecutive addresses. The standard UART sequence consists of four frames. Each frame begins with a start bit (START), which is followed by 8 data bits (D[0:7]), one parity bit (PAR), and a stop bit (STOP), as shown in Figure 26. Figure 26: UART Protocol Frame START D[0] D[1] D[2] D[3] D[4] D[5] D[6] D[7] PAR STOP The PAR bit is even parity calculated over the data bits (D[7:0]). Each frame is transferred from LSB to MSB. The first frame is the synchronization frame and consists D[7:0] = 0x55. This frame synchronizes the baud rate between the AS5172 and the programmer. The second frame contains the register address (D[6:0] = ADDRESS) and the write/read command (WRITE: D[7]=0; READ: D[7]=1). The third and fourth frame will be written/read to/from the location specified by ADDRESS and ADDRESS+1, respectively. Figure 27 and Figure 28 show examples of a WRITE and READ sequence. Figure 27: Example of WRITE (Reg[0x23] = 0x20 and Reg [0x24] = 0x00) Sync Frame 0x55 Low Byte 0x20 Register Address 0x23 High Byte 0x00 Page 32 Document Feedback MSB PAR STOP LSB MSB PAR STOP START LSB MSB WRITE PAR STOP START LSB MSB PAR STOP START LSB START 0 1 0 1 0 1 0 1 0 0 1 0 1 1 0 0 0 1 0 0 1 1 0 0 0 0 0 0 1 0 0 1 1 0 0 0 0 0 0 0 0 0 0 1 ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 28: Example of READ (Reg[0x32] = 0xB6 and Reg [0x24] = 0x2C) Sync Frame 0x55 Low Byte 0xB6 Register Address 0x32 High Byte 0x2C MSB PAR STOP LSB MSB PAR STOP START LSB MSB READ PAR STOP START LSB MSB PAR STOP START LSB START 0 1 0 1 0 1 0 1 0 0 1 0 0 1 0 0 1 1 0 1 0 1 0 0 1 1 0 1 1 0 1 1 1 0 0 0 1 1 0 1 0 0 1 1 Reading of the 14-Bit Angle Information To read the current position of the magnet (Angle) the following procedure is necessary: 1. Set the DSP_reset bit in Reg(0x23) to 1. (WRITE Reg(0x23) = 0x20) 2. Read Angle_CORDIC register (READ Reg(0x32) and Reg(0x33)) 3. Set the DSP_reset bit in Reg(0x23) to 0. (WRITE Reg(0x23) = 0x00) The DSP_reset bit resets the internal DSP. After a reset, the Angle_CORDIC register is updated. Reading the Magnitude and AGC To read the current Magnitude and AGC value following procedure is necessary: 1. Set the DSP_reset bit in Reg(0x23) to 1. (WRITE Reg(0x23) = 0x20) 2. Read Magnitude and AGC register (READ Reg(0x34) and Reg(0x35)) 3. Set the DSP_reset bit in Reg(0x23) to 0. (WRITE Reg(0x23) = 0x00) The DSP_reset bit resets the internal DSP. After a reset, the Magnitude and AGC registers are updated. Exiting the Communication Mode To exit the Communication Mode and enter Functional Mode a special Pass-to-function command is necessary. Therefore a specific value has to be written into registers 0x60 and 0x61. Pass2Function: WRITE Reg(0x60) = 0x70 and Reg(0x61) = 0x51 The device is temporarily set to operational mode until a sensor reset happens. ams Datasheet [v1-03] 2017-Sep-06 Page 33 Document Feedback AS5172A / AS5172B − Register Description Burn the OTP Registers To permanently program the device a special BurnOTP command is necessary. Therefore a specific value has to be written into registers 0x62 and 0x63. BurnOTP: WRITE Reg(0x62) = 0x70 and Reg(0x63) = 0x51 This commands permanently burns the OTP memory based on poly silicon fuses. After fusing a verification of the burn quality is mandatory to avoid bit-flips over temperature and lifetime. This can be done with the GLoad operation. For further information please refer to application note AN_AS5172_Programming_Procedure_V1-00. AS5172 Transfer Function After programming the Customer_lock in the OTP or by using the Pass-to-function command the AS5172 is working in the selected PSI5 mode over the VDD pin. The DSP block generates a linear transfer function proportional to the angle of the rotating magnet which is fed into the PSI5 interface. The PSI5 interface works with 10-bit resolution in PSI5 V1.3 and 12-bit resolution in PSI5 V2.1. Figure 29 shows the transfer function in detail. Figure 29: Transfer Function 90° T1 Application range OT2 180° 0° PSI5 output code Breakpoint OT1 T2 270° Page 34 Document Feedback 0° T1 180° T2 360° Mechanical angle ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 30: PSI5 Protocol Output Resolution Symbol Conditions Value Unit PSI5 V1.3 10 Bit OT1 -480 LSB OT2 +480 LSB 12 Bit OT1 -2048 LSB OT2 +2048 LSB OTR_V1.3 OTR_V2.1 Parameter Output Resolution PSI5 V1.3 Output Resolution PSI5 V2.1 PSI5 V2.1 The PSI5 output characteristic is programmable in the OTP memory. The parameters T1, T2 and BP define the linear transfer function. Figure 29 shows a simple example of a typical output function. The mechanical starting point T1 and the mechanical end point T2 define the mechanical range. The BP (Breakpoint) defines the transition point between OT1 and OT2. These parameters are input parameters. Using a DLL provided by ams, these parameters are converted into the final OTP parameters: CLH, CLL, Offset, Gain and BP. For detailed information regarding the calculation DLL please get in contact with the application engineering team at ams. ams Datasheet [v1-03] 2017-Sep-06 Page 35 Document Feedback AS5172A / AS5172B − Register Description Multiple Quadrants The multiple quadrant option allows repeating the same output slope up to four times over a full 360° rotation as shown in Figure 32, Figure 33, Figure 34 and Figure 35. The Quadrant bits in register (0x13) set the number of quadrant as shown in Figure 31. Additionally a built-in quadrant detection can indicate the currently active quadrant in a special PSI5 data frame. For more information please refer to chapter PSI5 Modes. Figure 31: Quadrant Selection Quadrant Number of Quadrants Max. Mechanical Range 00 Single 360° 01 Dual 180° 10 Triple 120° 11 Quadruple 90° Figure 32: Single Quadrant PSI5 output code OT2 OT1 0° 90° 180° 270° 360° Mechanical angle Figure 33: Dual Quadrant PSI5 output code OT2 OT1 0° 90° 180° 270° 360° Mechanical angle Page 36 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 34: Triple Quadrant PSI5 output code OT2 OT1 0° 90° 180° 270° 360° Mechanical angle Figure 35: Quadruple Quadrant PSI5 output code OT2 OT1 0° 90° 180° 270° 360° Mechanical angle Extended Magnetic Input Range By default the AS5172A and AS5172B operates in Extended Mode. This mode extends the magnetic input field range and allows increasing of the air gap between sensor and magnet. The extended range can be disabled with Extended_range_ disable bit. For further information about the Extended Mode please refer to application note “AN_AS5172_ExtendedMode_ V1-00.pdf”. Rolling Counter The frame control bits in the PSI5 frame can be used as a rolling counter. This setting can be enabled in the OTP. If this setting is enabled the rolling counter starts incrementing from value 0x0 once the initialization is finished. When reaching a value of 0x7 the counter is reset at starts with 0x0 again. In PSI5 16-bit frame mode, the rolling count enables a toggle bit in A14 of the frame. ams Datasheet [v1-03] 2017-Sep-06 Page 37 Document Feedback AS5172A / AS5172B − Register Description Angular Velocity Measurement The AS5172 features an average angular velocity calculation algorithm with 12-bit resolution. This angular velocity information can be used without further averaging in the ECU. The sensor calculates the velocity for each CORDIC cycle (typ. 128μs). Due to the PSI5 interface limitation the information can only be send every 500μs. To optimize the signal-to-noise performance the cut off frequency is programmable via Velocity_filter[2:0] bits in register 0x13. The velocity information is available in all P20CRC-500 and P16CRC-500 modes. Additionally the range of the velocity can be programmed by Velocity_extended_range bit in register 0x01. Figure 36: Angular Velocity Measurement Parameter Symbol VRes Parameter Min Velocity Signal Resolution Typ Max 12 Unit Comments Bit VRange Measurement Range (default) 1250 1374 °/s Only typical value is guaranteed VRangeE Measurement Range (extended) 5000 5496 °/s Only typical value is guaranteed VSens Velocity Sensitivity (default) 0.671 °/s/Bit 12-bit resolution VSensE Velocity Sensitivity (extended) 2.684 °/s/Bit 12-bit resolution, only in Extended Mode FCutOff Cut Off Frequency 19 VNoise Velocity Noise 4.9 VError Velocity Total Error Page 38 Document Feedback 77 260 Hz Programmable with Velocity_ filter[2:0] 70.5 °/s RMS noise depending on Velocity_filter[2:0] ±3.5 % Clock frequency accuracy ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 37: Angular Velocity Measurement Filter Parameters Velocity_filter[2:0] FCutOff [Hz] VNoise [°/s] VDelay [ms] VStepResponse [ms] 000 260 70.5 0.61 0.9 001 152 37.3 1.05 1.8 010 77 19.2 2.07 3.7 011 39 9.7 4.08 6.7 100 19 4.9 8.38 13.9 Special Functions The AS5172 features special functions which can be activated in the OTP. This settings are not according the PSI5 V2.1 standard. 14-Bit Mode The 14-bit mode is only available for AS5172A and AS5172B. In this mode the 14-bit angle information is provided on the PSI5 interface. The 14-bit mode can be activated by PSI5_14bit_ angle bit. (Quadrant setting must be 00) This special setting works different to the typical AS5172 transfer function. If this mode is activated, the sensor uses registers 0x1B to 0x1D as zero offset registers. Additionally the bit Direction in register 0x01 changes the direction of the output function. Figure 38: PSI5 Protocol Output Resolution Symbol Parameter Conditions Value Unit OTR_14 Output Resolution 14-Bit Mode PSI5 V2.1 14 Bit OT1 -8192 LSB OT2 +8192 LSB Quadrant Detection The PSI5 protocol includes an information of the used quadrant. Detection necessary for safety relevant application to detect a movement from one quadrant to the next. See detailed Protocol Information. Extended PSI5 Initialization Phase Extending to 32 datablock during Init phase. D1 to D22 according Figure 67. D23 to D32 = 0000. Extension necessary for systems with 32 Datablocks during Init Phase. ams Datasheet [v1-03] 2017-Sep-06 Page 39 Document Feedback AS5172A / AS5172B − Register Description PSI5 Interface Bit Encoding - AS5172 to ECU Communication A "low" level (I S,Low) is represented by the normal (quiescent) current consumption of the Sensor(s). A "high" level (I S,High) is generated by an increased current sink of the Sensor (I S,Low + ΔI S). The current modulation is detected within the receiver Sensor. Figure 39: Bit Encoding Using Supply Current Modulation tBIT Manchester coding is used for data transmission. A logic "0" is represented by a rising slope and a logic "1" by a falling slope of the current in the middle of t Bit. Figure 40: Bit Encoding Timing Symbol Parameter Min Typ Max Unit Comments tBit_L Bit Time (125 kbit/s mode) 8 μs 16 CLK cycles of the internal 2 MHz clock tBit_H Bit Time (189 kbit/s mode) 5.3 μs 14 CLK cycles of the internal 2.67 MHz clock Page 40 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Data Frames - AS5172 to ECU Communication Each PSI5 data frame consists of N bits containing two start bits and one parity bit with even parity (or 3 CRC bits) and N-3 (N-5) data bits. Data bits are transmitted LSB first. The data frames are sent periodically from the sensor to the ECU. A minimum gap time t Gap larger than one maximum bit duration tBit is required between two data frames. Figure 41: Example of a 10-Bit Data Frame tGap tBIT Data Ranges The AS5172 supports the data range according PSI5 standard V2.1 and V1.3. PSI5 data messages are divided into three separate ranges: A data range for the sensor output signal, a range for status and error messages and a range for initialization data. Data Range According PSI5 V1.3 If AS5172 is used in the 10-bit mode, the decimal values –480 to +480 are used for the sensor output signal. The range –512 to –481 is reserved block and data IDs which are used for transmitting initialization data during startup of the AS5172. The range from +481 to +511 is used for status and error messages. The 10 bit data range is used only in the LowRes mode of the sensor. The 12 bit output value from the DSP has to be mapped to the data range of -480 to +480 (10 bit, signed) by taking only the 10 higher order bits, subtracting the mid-code, and apply clamping to the data range of -480 to +480. ams Datasheet [v1-03] 2017-Sep-06 Page 41 Document Feedback AS5172A / AS5172B − Register Description Figure 42: Data Range for 10-Bit Mode Dec Hex +511 0x1FF Reserved (ECU internal use) *1 : : Reserved (ECU internal use) *1 +504 0x1F8 Reserved (ECU internal use) *1 +503 0x1F7 Reserved (Sensor use) *2 +502 0x1F6 Reserved (Sensor use) *2 +501 0x1F5 Reserved (Sensor use) *2 +500 0x1F4 “Sensor Defect” +499 0x1F3 Reserved (ECU internal use) *1 : : Reserved (ECU internal use) *1 +496 0x1F0 Reserved (ECU internal use) *1 +495 0x1EF Reserved (Sensor use) *2 : : Reserved (Sensor use) *2 +489 0x1E9 “Sensor in Diagnostic Mode” +488 0x1E8 “Sensor Busy” +487 0x1E7 “Sensor Ready” +486 0x1E6 “Sensor Ready but Unlocked” +485 0x1E5 Reserved (Sensor use) *2 +484 0x1E4 Reserved (Sensor use) *2 +483 0x1E3 Reserved (Sensor use) *2 +482 0x1E2 Bidirectional Communication: RC “Error” +481 0x1E1 Bidirectional Communication: RC “OK” +480 0x1E0 Highest Positive Sensor Signal : : 0 0x000 : : -480 0x220 Page 42 Document Feedback Signification Range Status and Error Messages 2 Sensor Output Signal 1 : Signal Amplitude “0” : Highest Negative Sensor Signal ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Dec Hex Signification -481 0x21F : : -496 0x210 Status Data 0000 -497 0x20F Block ID 16 : : -512 0x200 Range Status Data 1111 : Block ID‘s and Data for Initialization 3 : Block ID 1 When using the AS5172 in 10-bit mode the data frame consists of 2 start bits (S1, S2), 10 data bits (D0-D9) which represent the angle and an even parity bit (P). Figure 43: Data Frame for 10-Bit Mode Start Bits 10-Bit Sensor Data (LSB first) Parity S1 S2 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 P 0 0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 P The AS5172 has also the possibility to provide the 12-bit angle value in the PSI5 V1.3 specification. The substandard vehicle describes this method to map a 12-bit word into a 16 bit data frame and splitting of this into two 10-bit frames. ams Datasheet [v1-03] 2017-Sep-06 Page 43 Document Feedback AS5172A / AS5172B − Register Description Data Range According PSI5 V2.1 If AS5172 is used in the 20-bit mode, the decimal values –30720 to +30720 are used for the sensor output signal. The range –32768 to –30784 is reserved block and data IDs which are used for transmitting initialization data during startup of the AS5172. The range from +31168 to +32767 is used for status and error messages. Figure 44: Data Range for 20-Bit Mode Dec Hex 32767 0x7FFF Signification Reserved (ECU internal use) +31168 0x79FF : : +30720 0x7800 : : 0 0x0000 : : -30720 0x8800 Highest Negative Sensor Signal -30784 0x87FF Status Data 1111 : : -31744 0x8400 Status Data 0000 -31808 0x83FF Block ID 16 : : -32768 0x8000 Page 44 Document Feedback Range Status and Error Messages 2 Sensor Output Signal 1 Block ID‘s and Data for Initialization 3 “Sensor Ready” Highest Positive Sensor Signal : Signal Amplitude “0” : : : Block ID 1 ams Datasheet [v1-03] 2017-Sep-06 A S 5 1 7 2 A / A S 5 1 7 2 B − Register Description PSI5 Data Frame 20-Bit Mode with 12-Bit Sensor Data In 20-bit mode the PSI5 frame consists of 2 start bits (S1, S2), 3 frame control bits (F0, F1, F2), an error status bit (E0), 16 data bits (A0 to A15), and 3 CRC bits (C2, C1, C0). As described in chapter Rolling Counter the 3 frame control bits can be used as rolling counter. The error status bit is used to indicate a failure of the sensor to ECU (E0 = 1). If no failure is present this bit is always set to 0. The 12-bit angle information is transmitted on A0 – A11. The upper fields A12 – A15 are set to 0. Figure 45: PSI5 Data Frame 20-Bit Mode with 12-Bit Sensor Data Start Bits Frame Control Error Status 12-Bit Sensor Data (LSB first) CRC S1 S2 F0 F1 F2 E0 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 C2 C1 C0 0 0 C0 C1 C2 E0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 D10 D11 0 0 0 0 C2 C1 C0 PSI5 Data Frame 20-Bit Mode with 12-Bit Sensor Data and Quadrant Detection For safety relevant applications, where multiple quadrant mode is used, additionally to the 12-bit angle information a quadrant information can be transmitted in A12 and A13. For more information refer to chapter Multiple Quadrants. Figure 46: PSI5 Data Frame 20-Bit Mode with 12-Bit Sensor Data and Quadrant Detection Start Bits Frame Control Error Status Quadrant Info 12-Bit Sensor Data (LSB first) CRC S1 S2 F0 F1 F2 E0 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 C2 C1 C0 0 0 C0 C1 C2 E0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 D10 D11 Q0 Q1 0 0 C2 C1 C0 ams Datasheet [v1-03] 2017-Sep-06 Page 45 Document Feedback AS5172A / AS5172B − Register Description Figure 47: Quadrant Information Quadrant Quadrant Mode Quadrant Info on PSI5 00 Single Q1 = 00 Q2 = 01 01 Dual Q1 = 00 Q2 = 01 10 Triple Q1 = 00 Q2 = 01 Q3 = 10 Quadruple Q1 = 00 Q2 = 01 Q3 = 10 Q4 = 11 11 Page 46 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 A S 5 1 7 2 A / A S 5 1 7 2 B − Register Description PSI5 Data Frame 20-Bit Mode with 14-Bit Sensor Data For special applications where the full sensor resolution is necessary over a 360° rotation the AS5172 features a special 14-bit mode. In this mode the 14-bit angle information is transmitted from A0 – A13. A14 and A15 are filled with 0. For more information refer to chapter 14-Bit Mode. Figure 48: PSI5 Data Frame 20-Bit Mode with 14-Bit Sensor Data Start Bits Frame Control Error Status 14-Bit Sensor Data (LSB first) CRC S1 S2 F0 F1 F2 E0 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 C2 C1 C0 0 0 C0 C1 C2 E0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 D10 D11 D12 D13 0 0 C2 C1 C0 PSI5 Data Frame 16-Bit Mode In 16-bit mode the PSI5 frame consists of 2 start bits (S1, S2), an error status bit (E0), 15 data bits (A0 to A14), and 3 CRC bits (C2, C1, C0). The error status bit is used to indicate a failure of the sensor to ECU (E0 = 1). If no failure is present this bit is always set to 0. The 16-bit frame can transmit the 12-bit angle information (A0 – A11) but also the 14-bit angle by activating the 14-bit mode in the OTP. (A0 – A13). The field A14 is by default set to 0 but can also be used as a toggle bit by activating the Rolling Counter. Figure 49: PSI5 Data Frame 16-Bit Mode with 12-Bit Sensor Data Start Bits Error Status 14-Bit Sensor Data (LSB first) CRC S1 S2 E0 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 C2 C1 C0 0 0 E0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 D10 D11 D12 D13 0 C2 C1 C0 ams Datasheet [v1-03] 2017-Sep-06 Page 47 Document Feedback AS5172A / AS5172B − Register Description PSI5 Modes The AS5172 can be configured in several PSI5 modes according standard V1.3 and V2.1. This modes can be selected via registers 0x01, 0x11 and 0x12. The tables in Figure 45 and Figure 46 show the different modes. Independent from the specific mode also other options can be activated in this registers: • Low Power Mode • Initialization phase repetition factor • Extended Initialization phase (32 blocks) • Rolling Counter • 14-Bit Mode • Velocity Extended Range Figure 50: PSI5 Modes V1.3 Register PSI5 Mode Timeslot Discharge High Resolution 0x11 0x12 P10P-500/3L Timeslot 1 - - 0x00 0x00 P10P-500/3L Timeslot 2 - - 0x00 0x08 P10P-500/3L Timeslot 3 - - 0x00 0x10 P10P-500/3L Timeslot 2 X - 0x00 0x09 P10P-500/3L Timeslot 3 X - 0x00 0x11 P10P-500/3L Timeslot 1 and 2 - X 0x40 0x00 P10P-500/3L Timeslot 2 and 3 - X 0x40 0x08 P10P-500/3L Timeslot 2 and 3 X X 0x40 0x09 A10P-500/1L - - - 0x10 0x00 A10P-250/1L - - - 0x30 0x00 A10P-500/1L - - X 0x50 0x00 A10P-250/1L - - X 0x70 0x00 Page 48 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 51: PSI5 Modes V2.1 Register PSI5 Mode Timeslot Angle Timeslot Velocity 0x01 0x11 0x12 P20CRC-500/1L Timeslot 1 - 0x00 0x02 0x00 P20CRC-500/2L Timeslot 2 - 0x00 0x02 0x08 P20CRC-500/2L Timeslot 1 Timeslot 2 0x00 0x02 0x40 P20CRC-500/2H Timeslot 1 - 0x00 0x03 0x00 P20CRC-500/2H Timeslot 2 - 0x00 0x03 0x08 P20CRC-500/2H Timeslot 1 Timeslot 2 0x00 0x30 0x48 P20CRC-500/3H Timeslot 1 - 0x00 0x0B 0x00 P20CRC-500/3H Timeslot 2 - 0x00 0x0B 0x08 P20CRC-500/3H Timeslot 3 - 0x00 0x0B 0x10 P20CRC-500/3H Timeslot 1 Timeslot 2 0x00 0x0B 0x48 P20CRC-500/3H Timeslot 2 Timeslot 3 0x00 0x0B 0x50 P20CRC-500/3H Timeslot 1 Timeslot 3 0x00 0x0B 0x58 P16CRC-500/3H Timeslot 1 - 0x20 0x01 0x00 P16CRC-500/3H Timeslot 2 - 0x20 0x01 0x08 P16CRC-500/3H Timeslot 3 - 0x20 0x01 0x10 P16CRC-500/3H Timeslot 1 Timeslot 2 0x20 0x01 0x48 P16CRC-500/3H Timeslot 2 Timeslot 3 0x20 0x01 0x50 P16CRC-500/3H Timeslot 1 Timeslot 3 0x20 0x01 0x58 A20CRC-200/1H - - 0x00 0x33 0x00 A20CRC-500/1H - - 0x00 0x13 0x00 A20CRC-500/2H - - 0x00 0x1B 0x00 A20CRC-300/1L - - 0x00 0x12 0x00 ams Datasheet [v1-03] 2017-Sep-06 Page 49 Document Feedback AS5172A / AS5172B − Register Description PSI5 Timing The following chapter describes the timings for the different PSI5 modes. The timing is according the internal clock rate of 2 MHz or 2.67 MHz respectively. This clock rates are derived from the main clock of 16 MHz with a ±3.5 % variation. Timing Synchronous Mode P10P-500/3L Figure 52: Timing Synchronous Mode P10P-500/3L PSI5_RX tdisch tTRIG HIGH LO t0 t [s] PSI5_TX PSI5 cycle tframe TBit HIGH LO t0 Page 50 Document Feedback tslot1 tslot2 tslot3 tslot3,end tcycle t [s] ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 53: Timings Symbol tBit_L tframe_10L Parameter Bit Time Frame Duration Min Typ Max Unit Comments 7.7 8 8.3 μs 16 CLK cycles of the internal 2 MHz clock 100.4 104 107.6 μs 208 CLK cycles of the internal 2 MHz clock tTRIG Trigger Detection Time 0 4.5 10 μs From start of synch. pulse tslot1 Start of Time Slot 1 44 51 59 μs 88 CLK cycles of the internal 2 MHz clock tslot2 Start of Time Slot 2 181.3 195 210 μs 376 CLK cycles of the internal 2 MHz clock tslot3 Start of Time Slot 3 328.9 350 372.8 μs 686 CLK cycles of the internal 2 MHz clock tslot3,end End of Time Slot 3 427.7 454 482 μs tcycle,P500 Cycle Time P10P-500/3L 250 500 - μs ams Datasheet [v1-03] 2017-Sep-06 Page 51 Document Feedback AS5172A / AS5172B − Register Description Timing Synchronous Mode P10P-500/3L with Discharge Pulse Figure 54: TBD PSI5_RX tTRIG HIGH LO t0 t3 td2 t [s] PSI5_TX PSI5 cycle td1 TBit tframe HIGH LO t0 td1 tslot1 Page 52 Document Feedback tslot2 tslot3 tslot3,end tcycle t [s] ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Figure 55: TBD Symbol tBit_L tframe_10L Parameter Bit Time Frame Duration Min Typ Max Unit Comments 7.7 8 8.3 μs 16 CLK cycles of the internal 2 MHz clock 100.4 104 107.6 μs 208 CLK cycles of the internal 2MHz clock 0 3.25 7.5 μs From start of synch. pulse 18.5 22.75 28 μs 39 CLK cycles of the internal 2 MHz clock tTRIG Trigger Detection Time td1 Signal Discharge td2 Discharge Stop Time 38 43.25 50 μs 80 CLK cycles of the internal 2 MHz clock tslot1 Start of Time Slot 1 44 51 59 μs 88 CLK cycles of the internal 2 MHz clock tslot2 Start of Time Slot 2 181.3 195 210 μs 376 CLK cycles of the internal 2 MHz clock tslot3 Start of Time Slot 3 328.9 350 372.8 μs 686 CLK cycles of the internal 2 MHz clock tslot3,end End of Time Slot 3 427.7 454 482 μs tcycle,P500 Cycle Time P10P-500/3L 250 500 - μs ams Datasheet [v1-03] 2017-Sep-06 Page 53 Document Feedback AS5172A / AS5172B − Register Description Timing Asynchronous Modes A10P-250/1L and A10P-500/1L Figure 56: Timing Asynchronous Modes A10P- 50/1L and A10P-500/1L Figure 57: Timings Symbol tBit_L Parameter Bit Time Min Typ Max Unit Comments 7.7 8 8.3 μs 16 CLK cycles of the internal 2 MHz clock tframe_10L Frame Duration 100.4 104 107.6 μs 208 CLK cycles of the internal 2 MHz clock tcycle,250L Cycle Time A10P-250/1L 241.2 250 258.8 μs 500 CLK cycles of the internal 2 MHz clock tcycle,500L Cycle Time A10P-500/1L 482.5 500 517.5 μs 1000 CLK cycles of the internal 2 MHz clock Page 54 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Timing Synchronous Modes P20CRC-500/1L, P20CRC-500/2L, P20CRC-500/2H, P20CRC-500/3H, P16CRC-500/3H The supported protocol modes for synchronous transmission with 20bit format are P20CRC-500/1L, P20CRC-500/2L, P20CRC-500/2H and P20CRC-500/3H. For all these modalities except P20CRC-500/1L it is possible to select also the velocity output. In this case two consecutive timeslots will be used. The protocol P20CRC-500/3H is specifically studied for sensors that must transmit more data on two consecutive timeslots (e.g. angle and velocity). Usually there should be on the bus one sensor transmitting data on timeslot 1 & 2 and another sensor transmitting on timeslot 3, or a sensor transmitting on timeslot 1 and another transmitting on timeslot 2 & 3. Because of the relative tolerances due to the different clocks on the different sensors, the timing of the second timeslot is different when the sensor is transmitting only on one timeslot (not legacy situation for timeslot 2 only but allowed) and when is transmitting also the velocity using 2 consecutive timeslots, differentiating from the case of timeslot 1 & 2 or timeslot 2 & 3. When there is a new synchronization pulse from the ECU before the current transmission of the AS5172 is finished the current transmission must be stopped and a new transmission has to be started in the programmed time slots. Figure 58: Timings Symbol tBit_L tframe_20L TBit_H tframe_20H tTRIG tslot1_20L Parameter Min Typ Max Unit Bit Time P20CRC-500/1L/2L 7.7 8 8.3 μs 16 CLK cycles of the internal 2 MHz clock Frame Duration P20CRC-500/1L/2L 193 200 207 μs 400 CLK cycles of the internal 2 MHz clock Bit Time P20CRC-500/2H/3H 5.06 5.25 5.44 μs 14 CLK cycles of the internal 2.67 MHz clock 126.66 131.25 135.84 μs 350 CLK cycles of the internal 2.67 MHz clock Trigger Detection Time 0 4.5 10 μs From start of synch. pulse Start of Time Slot 1 P20CRC-500/1L/2L 44 48.5 56 μs 88 CLK cycles of the internal 2 MHz clock Frame Duration P20CRC-500/2H/3H ams Datasheet [v1-03] 2017-Sep-06 Comments Page 55 Document Feedback AS5172A / AS5172B − Register Description Symbol Parameter Min Typ Max Unit Comments tslot1_20L,end End of Time Slot 1 P20CRC-500/1L/2L 234 251 269 μs 400 CLK cycles of the internal 2 MHz clock tslot1_20H Start of Time Slot 1 P20CRC-500/2H 44 51 59 μs 119 CLK cycles of the internal 2.67 MHz clock End of Time Slot 1 P20CRC-500/2H 169 182.25 198 μs Start of Time Slot 1 P20CRC-500/3H 44 45 56 μs End of Time Slot 1 P20CRC-500/3H 175.4 177.5 190.5 μs Start of Time Slot 2 P20CRC-500/2L 267.5 273 288 μs 464 473 492 μs Start of Time Slot 2 P20CRC-500/2H 203.5 218.25 235.5 μs End of Time Slot 2 P20CRC-500/2H 328.5 349.5 374.5 μs 183 186.5 199.5 μs 313.5 319 334 μs 180 183.5 196.5 μs End of Time Slot 2 P20CRC-500/3H with Velocity on Time Slot 1 & 2 310.5 316 331 μs Start of Time Slot 2 P20CRC-500/3H with Velocity on Time Slot 2 & 3 195.5 199 212 μs 326 331.5 346.5 μs tslot1_20H,end tslot1_20H tslot1_20H,end tslot2_20L tslot2_20L,end tslot2_20H tslot2_20H,end tslot2_20H tslot2_20H,end tslot2_20H tslot2_20H,end tslot2_20H tslot2_20H,end End of Time Slot 2 P20CRC-500/2L Start of Time Slot 2 P20CRC-500/3H End of Time Slot 2 P20CRC-500/3H Start of Time Slot 2 P20CRC-500/3H with Velocity on Time Slot 1 & 2 End of Time Slot 2 P20CRC-500/3H with Velocity on Time Slot 2 & 3 Page 56 Document Feedback 112 CLK cycles of the internal 2.67 MHz clock 540 CLK cycles of the internal 2 MHz clock 570 CLK cycles of the internal 2.67 MHz clock 490 CLK cycles of the internal 2.67 MHz clock 482 CLK cycles of the internal 2.67 MHz clock 524 CLK cycles of the internal 2.67 MHz clock ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Symbol tslot3_20H tslot3_20H,end Parameter Start of Time Slot 3 P20CRC-500/3H End of Time Slot 3 P20CRC-500/3H Min Typ Max Unit Comments 336 341.5 357 μs 905 CLK cycles of the internal 2.67 MHz clock 466.5 474 491.5 μs tcycle,P500 Cycle Time P20CRC-500/1L/2L 270 500 - μs tcycle,P500 Cycle Time P20CRC-500/2H/3H 250 500 - μs For P16CRC-500/3H mode, bit timings and the frame start timings are the same as of the P20CRC-500/3H mode. All other timings are reported in table below: Figure 59: Timings Symbol Min Typ Max Unit Comments Frame Duration P16CRC-500/3H 106.4 110.25 114.1 μs 294 CLK cycles of the internal 2.67 MHz clock tslot1_16H,end End of Time Slot 1 P16CRC-500/3H 153.5 156.5 169.5 μs tslot2_16H,end End of Time Slot 2 P16CRC-500/3H 292.5 298 313 μs tslot3_16H,end End of Time Slot 3 P16CRC-500/3H 445.5 453 470.5 μs tframe_16H Parameter ams Datasheet [v1-03] 2017-Sep-06 Page 57 Document Feedback AS5172A / AS5172B − Register Description Timing Asynchronous Modes A20CRC-200/1H and A20CRC-300/1L Figure 60: Timing Asynchronous Modes A20CRC-200/1H and A20CRC-300/1L PSI5_TX Startbits 0 0 Status Bit PSI5 cycle Frame Control 1 0 1 0 Tbit Data-Bits 0 1 1 1 0 0 1 0 0 Startbits CRC 1 1 0 0 0 0 0 1 0 0 0 0 HIGH LO t0 tframe tcycle t [s] Figure 61: Timings Symbol Parameter Min Typ Max Unit tBit_L Bit Time A20CRC-300/1L 7.7 8 8.3 μs 16 CLK cycles of the internal 2 MHz clock tframe_20L Frame Duration A20CRC-300/1L 193 200 207 μs 400 CLK cycles of the internal 2 MHz clock tcycle,300L Cycle Time A20CRC-300/1L 298.5 300 310.5 μs 600 CLK cycles of the internal 2 MHz clock tBit_H Bit Time A20CRC-200/1H 5.06 5.25 5.44 μs 14 CLK cycles of the internal 2.67 MHz clock tframe_20H Frame Duration A20CRC-200/1H 126.66 131.25 135.84 μs 350 CLK cycles of the internal 2.67 MHz clock tcycle,200H Cycle Time A20CRC-200/1H 193 200 207 μs 533 CLK cycles of the internal 2.67 MHz clock Page 58 Document Feedback Comments ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description PSI5 Initialization The Startup and Initialization is working according the PSI5 standard. After each power on or undervoltage reset, the AS5172 performs an internal initialization which is divided into three phases: Figure 62: Start-Up and Initialization Initialization Phase I During the first initialization phase, no data is transmitted and the ECU can perform a connectivity test. Duration 50 – 150ms; typical 100ms. If using synchronous transmission mode the ECU can terminate the initialization phase I by sending the sync pulse at least 4ms after AS5172 power on. Initialization Phase II During the second initialization phase, the AS5172 transmits sensor and application specific information to the ECU. In High Resolution mode the AS5172 transmits the same PSI5 frame on both programmed time slots. The same is valid if the velocity output is activated. For the 20-bit mode the 10-bit values are extended to 20 bits. This is done by shifting the data bits [9:0] to bits A15 to A6. The remaining 6 LSBs are filled with “0”. The frame control bits (F0 to F2) and the status bit (E0) are at “0”. ams Datasheet [v1-03] 2017-Sep-06 Page 59 Document Feedback A S 5 1 7 2 A / A S 5 1 7 2 B − Register Description Figure 63: Initialization Phase in 20-Bit Mode Start Bits Frame Control Error Status 16-Bit Sensor Data (LSB first) CRC S1 S2 F0 F1 F2 E0 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 C2 C1 C0 0 0 0 0 0 0 0 0 0 0 0 0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 C2 C1 C0 Figure 64: Initialization Phase in 16-Bit Mode Start Bits Error Status 15-Bit Sensor Data (LSB first) CRC S1 S2 E0 A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 C2 C1 C0 0 0 0 0 0 0 0 0 D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 C2 C1 C0 Initialization Phase III During the third initialization phase, the sensor transmits “Sensor Ready”, “Sensor Defect” or other status data. If the sensor is defective, it will continue to send the “Sensor Defect” messages and other optional status data until it is powered off. “Sensor Ready” Code 0x1E7 at A15 to A6 – if the sensor is OK “Sensor Defect” Code 0x1F4 at A15 to A6 – if there is an diagnostic error In High Resolution mode the AS5172 transmits the same PSI5 frame on both programmed time slots. The same is valid if the velocity output is activated. In overvoltage, undervoltage case and AGC High, Low the AS5172 is not reporting this errors in initialization phase III but it will send the error code in the run mode Page 60 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Initialization Phase Data Format ID blocks and data blocks are sent in an alternating sequence, “k” times each. The block identifiers are used for a numbering of the following data nibbles. After any power-on or undervoltage reset, the internal logic starts up with an initialization program. The factor “k” can vary between 1 and 4 and can be configured with “Init_phase_repetition” in register 0x12. Figure 65: Block ID and Data Nibbles Figure 66: Startup Sequence ams Datasheet [v1-03] 2017-Sep-06 Page 61 Document Feedback AS5172A / AS5172B − Register Description Initialization Data Content TBD Figure 67: Initialization Content Field ID# F1 F2 Nibble ID# D1 D2, D3 Name Description Register Address Value PSI5 V1.3 Hard-coded 0100 PSI5 V2.1 Hard-coded 0110 Number of data blocks = 22 Hard-coded 0001 0000 Number of data blocks = 32 Hard-coded 0010 0110 Protocol revision Number of data blocks F3 D4, D5 Manufacturer code Vendor ID 0x1E Customer F4 D6, D7 Sensor type Sensor type 0x0E Customer F5 D8, D9 Sensor parameter Sensor parameter 0x0E, 0x0F Customer F6 D10, D11 Sensor code (sensor) Sensor code (sensor) 0x0F, 0x10 Customer F7 D12 Sensor code (vehicle) Sensor code (vehicle) 0x10 Customer F8 D13 – D16 Production date Production date 0x0C, 0x0D Customer F9 D17 – D22 Lot and serial number ams ID 0x02, 0x03, 0x04 Factory Run Mode After finishing Initialization Phase III the AS5172 enters Run Mode. If the sensor is configured in asynchronous mode it will start transmitting data continuously according PSI5 standard. Using the synchronous mode, the transmission is triggered by a sync pulse of the ECU. If the AS5172 is configured in asynchronous mode, it will transmit the data continuously according the PSI5 Specification. In case of an application or sensor error, AS5172 is performing in run mode according the description in chapter Diagnostic Page 62 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Communication Modes Asynchronous Mode (PSI5-A) PSI5-A describes a point-to-point connection for unidirectional, asynchronous data transmission. Each sensor is connected to the ECU by two wires. After switching on the power supply, the sensor starts transmitting data to the ECU periodically. Timing and repetition rate of the data transmission are controlled by the sensor. Figure 68: Asynchronous Single Sensor Configuration ams Datasheet [v1-03] 2017-Sep-06 Page 63 Document Feedback AS5172A / AS5172B − Register Description Synchronous Parallel Bus Mode (PSI5-P) PSI5-P describes a bus configuration for synchronous data transmission of one or more sensors. Each sensor is connected to the ECU by a separate pair of wires (star topology). Each data transmission period is initiated by a voltage synchronization signal from the ECU to the sensors. Having received the synchronization signal, each sensor starts transmitting its data with the corresponding time shift in the assigned time slot. Figure 69: Synchronous Parallel Bus Mode (PSI5-P) Page 64 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Synchronous Universal Bus Mode (PSI5-U) PSI5-U describes a bus configuration for synchronous data transmission of one or more sensors. The sensors are connected to the ECU in different wiring topologies including splices or pass-through configurations. Each data transmission period is initiated by a voltage synchronization signal from the ECU to the sensors. Having received the synchronization signal, each sensor starts transmitting its data with the corresponding time shift in the assigned time slot. Figure 70: Synchronous Parallel Bus Mode (PSI5-P) ams Datasheet [v1-03] 2017-Sep-06 Page 65 Document Feedback AS5172A / AS5172B − Register Description Diagnostic The AS5172 allows a high ASIL level in the application through a robust embedded self-diagnostic. (e.g. ASIL A) In general, AS5172 sensor is developed as SEooC according the ISO26262. For more information refer to the AS5172 Safety Manual which is available on request to the application engineering team. Figure 71: Diagnostic Table SM Failure Mode Recoverable 10-Bit Mode Error Info 16-Bit Mode Error Info 20-Bit Mode Error Info SM1 Watchdog fail - Permanent low level Permanent low level Permanent low level SM2 Offset compensation X 0x1ED 0x1ED at A9 to A0 E0 = 1 0x1ED at A15 to A6 E0 = 1 SM3 CORDIC overflow - 0x1F4 0x1F4 at A9 to A0 E0 = 1 0x1F4 at A15 to A6 E0 = 1 A0 = 1 SM4 Magnetic field out of range X 0x1EB 0x1EB at A9 to A0 E0 = 1 0x1EB at A15 to A6 E0 = 1 SM5 VDD3V3 undervoltage X Permanent low level Permanent low level Permanent low level SM6 Reverse polarity X Permanent low level Permanent low level Permanent low level SM7 VDD overvoltage X 0x1EA 0x1EA at A9 to A0 E0 = 1 0x1EA at A15 to A6 E0 = 1 SM8 VDD undervoltage under POR level - Permanent low level Permanent low level Permanent low level SM9 VDD undervoltage X 0x1EC 0x1EC at A9 to A0 E0 = 1 0x1EC at A15 to A6 E0 = 1 SM10 OTP checksum error - 0x1F4 0x1F4 at A9 to A0 E0 = 1 0x1F4 at A15 to A6 E0 = 1 A2 = 1 SM11 Broken Hall element - 0x1F4 0x1F4 at A9 to A0 E0 = 1 0x1F4 at A15 to A6 E0 = 1 A3 = 1 Note(s): 1. Recoverable: Sensor is working if the error condition is solved Page 66 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Register Description Diagnostic Procedure in PSI5 If a OTP checksum error (SM10) occurs after the first OTP download the PSI5 interface shows a “Sensor Defect” Code 0x1F4 in initialization phase III. This error code will be sent until the device is powered off. If any other diagnostic error condition occurs during initialization phase I or II the error will be masked. It will then be reported in initialization phase III by transmitting “Sensor Defect” Code - 0x1F4. When a diagnostic error condition appears during PSI5 run mode the specific error code will be transmitted on the PSI5 interface. During Run Mode: When a diagnostic error condition appears during the PSI5 run mode the error code “Sensor Defect” (0x1F4) has to be transmitted on the PSI5 interface until the AS5172 is reset by the ECU. The internal diagnostic error conditions are: • CORDIC Overflow • OTP Check fail • Broken Hall element • Broken channel • Watchdog When an watchdog error is present the PSI5_out signal from the digital part is forced to “0”. Therefore the PSI5 interface shows a permanent low level current as long as the watchdog error is present. When an VDD3 undervoltage is present the PSI5_out signal from the digital part is forced to “0”. Therefore the PSI5 interface shows a permanent low level current as long as the VDD3 undervoltage is present. In magnet field strength out of spec, the AS5172 is transmitting the error code 0x1EB during the PSI5 run mode and keeps transmitting this error code until the flag goes to low or the AS5172 is powered off by ECU. In overvoltage, the AS5172 is transmitting the error code 0x1EA during the PSI5 run mode and keeps transmitting this error code until the flag from the analog part goes to low or AS5172 is powered off by ECU. In undervoltage (between threshold and min VDD), the AS5172 is transmitting the error code 0x1EC during the PSI5 run mode and keeps transmitting this error code until the flag from the analog part goes to low or AS5172 is powered off by ECU. ams Datasheet [v1-03] 2017-Sep-06 Page 67 Document Feedback AS5172A / AS5172B − Register Description When an undervoltage below the POR threshold is present the PSI5_out signal from the digital part is forced to “0”. Therefore the PSI5 interface shows a permanent low level current as long as the undervoltage is present. When using the 20bit or 16Bit mode the status message “Sensor Defect” (code 0x1F4) is transmitted at the bits A15 to A6 and also the bit E0 is set to “1” when there is a diagnostic error condition. The frame control bits (F2 to F0) keep the functionality of the frame counter. On the bits A5 to A0 a detailed failure code is transmitted with the following bit assignment System Level EMC/ESD AS5172A in the (SiP Package) is built to fulfill system level EMC and ESD standards. A full certified test report is available upon request. Please get in contact with the application engineering team. Page 68 Document Feedback ams Datasheet [v1-03] 2017-Sep-06 AS5172A / AS5172B − Application Information Application Information Signature Calculation The OTP of AS5172 uses a BIST technique with Multiple Input Signature Register circuits. To activate this BIST a calculation of the Signature Byte is necessary which has to be stored in the OTP during programming. For calculating the signature byte the content of the whole memory (0x01 to 0x1F) has to be read out. Out of this information the following calculation has to be done. Byte: 0x01 = data1 Byte: 0x02 = data2 … Byte: 0x1F = data31 unsigned int misr, misr_shift, misr_xor, misr_msb; misr = 0; for (int i = 0; i
AS5172B-HTSM 价格&库存
很抱歉,暂时无法提供与“AS5172B-HTSM”相匹配的价格&库存,您可以联系我们找货
AS5172B-HTSM
  • 1+45.215941+5.86085
  • 5+40.583495+5.26040
  • 10+38.8727010+5.03865
库存:11
AS5172B-HTSM
  • 500+32.07076500+4.15698
库存:11
