AS7331_M OLGA16 LF T&RDP
    AMSOSRAM(艾迈斯半导体)
    TFLGA16
    光学传感器 紫外线(UV) 260nm ~ 360nm I²C 16-TFLGA 模块
AS7331_M OLGA16 LF T&RDP 数据手册
Datasheet DS001047 AS7331 Spectral UVA/B/C Sensor v1-00 • 2022-Oct-27 Document Feedback AS7331 Content Guide Content Guide 7.7 7.8 Temperature Measurement ........................ 41 I2C Communication ..................................... 42 8 Register Description .................... 48 Ordering Information .................... 6 8.1 8.2 Register Overview ...................................... 48 Detailed Register Description ..................... 49 3 Pin Assignment ............................. 7 9 Application Information............... 64 3.1 3.2 Pin Diagram .................................................. 7 Pin Description ............................................. 7 4 Absolute Maximum Ratings ......... 9 9.1 9.2 9.3 Schematic ................................................... 64 External Components ................................. 64 PCB Layout................................................. 64 10 Package Drawings and Markings65 5 Electrical Characteristics............ 10 11 Tape & Reel Information.............. 66 6 Typical Operating Characteristics ............................ 12 12 Soldering & Storage Information 68 6.1 6.2 Optical Characteristics ............................... 12 Optical Responsivity ................................... 13 13 Revision Information ................... 69 14 Legal Information ......................... 70 7 Functional Description................ 15 7.1 7.2 7.3 7.4 7.5 7.6 Operational States ...................................... 15 Measurement Modes .................................. 17 Energy Saving Options ............................... 23 Transfer Function ....................................... 30 Divider ........................................................ 39 Conversion Time Measurement in SYND Mode........................................................... 41 1 General Description ...................... 3 1.1 1.2 1.3 Key Benefits and Features ........................... 4 Applications .................................................. 4 Block Diagram .............................................. 4 2 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 2 Document Feedback 1 AS7331 General Description General Description The AS7331 is a low-power, low noise integrated UV sensor. The three separated UVA, UVB and UVC channels convert optical radiation signals via photodiodes to a digital result and realize a continuous or triggered measurement. The irradiance responsivity can be adjusted via Gain, conversion time and internal clock frequency to effect sensitivity, full scale range and LSB. The by the AS7331 detected amount of radiation in the set Gain and conversion time configuration will be provided as digital counts by the AS7331. The AS7331 offers a range of 12 Gain steps by a factor of two for each step. The conversion time is internally controlled over a wide range of 15 steps by a factor of two for each step. With the input pin (SYN), the conversion time can be externally controlled to adapt the measurement to the given environment and time base. With its irradiance responsivity factor and conversion time, the AS7331 supports an overall huge dynamic range up to 3.43E+10 (resolution multiplied by gain range). It achieves an accuracy of up to 24-bit signal resolution (internal via I²C and shifter 16-bit), with an irradiance responsivity per count down to 2.38 nW/cm² at 64 ms integration time. Via an integrated divider, the 16-bit I²C output can be adjusted to the significant bits of interest. Equation 1: 𝐷𝑦𝑛𝑎𝑚𝑖𝑐 𝑅𝑎𝑛𝑔𝑒 = 𝑀𝐴𝑋 𝑚𝑒𝑎𝑠𝑢𝑟𝑒𝑎𝑏𝑙𝑒 𝑣𝑎𝑙𝑢𝑒 = 𝑀𝑎𝑥. 𝐹𝑢𝑙𝑙 𝑆𝑐𝑎𝑙𝑒 𝑅𝑎𝑛𝑔𝑒 𝑀𝐼𝑁 𝑚𝑒𝑎𝑠𝑢𝑟𝑒𝑎𝑏𝑙𝑒 𝑣𝑎𝑙𝑢𝑒 = 𝑀𝑖𝑛. 𝐿𝑒𝑎𝑠𝑡 𝑆𝑖𝑔𝑛𝑖𝑓𝑖𝑐𝑎𝑛𝑡 𝐵𝑖𝑡 Automatic Power Down (sleep function) between subsequent measurements offers operation with very low current consumption. Furthermore, a synchronized mode and other control modes adjustable by user programming can be used. The supported operating modes of the AS7331 are: ● ● ● CMD Mode – single measurement and conversion (controlled via I²C interface). CONT Mode – continuous measurement and conversion (periodically recurring measuring cycles) start and stop controlled via I²C interface. SYN[x] Modes - synchronized measurement and conversion: ● ● [SYNS Mode] synchronization of start via the control signal at pin SYN. [SYND Mode] synchronization of start and stop of measuring cycles via control signal at pin SYN. The conversion data can be accessed by the I²C interface with programmable slave addresses via 16- bit / 400 kHz fast mode. The measurement of the current conversion time for an externally triggered measurement can be performed. The measurement modes will not affect the settings of the irradiance responsivity and conversion time. Furthermore, the converter supports functions like power down and standby, which is suitable in mobile applications. Based on the high flexibility the AS7331 is suitable as an optical converter for three different wavelength ranges. The device achieves a high dynamic range for fluorescence applications and for measurements of UV radiations. This makes the UV sensors excellently suited for photometry applications (UV exposure, UV-index), for monitoring of UVC disinfection treatments, fluorescence detection, and mobile devices for UV radiation measurements. The AS7331 contains an integrated temperature sensor for rough compensation of the thermic behavior. The device is available in a small SMD package. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 3 Document Feedback 1.1 AS7331 General Description Key Benefits and Features The benefits and features of AS7331, Spectral UVA/B/C Sensor are listed below: Figure 1: Added Value of Using AS7331 Benefits Features Separated UVA, UVB and UVC radiation measurements Three separated UV detectors with interference filter technology UV-radiation measurements from low to high radiation conditions High dynamic range up to 3.43E+10 (16…24-Bit ADC) Usable for fluorescence light conditions High sensitivity up to 421 counts/(µW/cm²) in UVA, Smallest LSB 2.38 nW/cm² (at 64 ms integration time). Up to four AS7331 sensors on the same I²C bus in parallel 1.2 Mobile applications Low-power operation, Power-on Reset, Power-down and standby, small OLGA package Temperature compensation of measurement results Integrated temperature sensor Applications ● ● ● ● ● ● 1.3 Adjustable I²C addresses UV-Disinfection (water, air, surfaces) UV-Curing Phototherapy Analytics Home Appliances Horticulture Block Diagram Figure 2 shows the main components of the AS7331. The photodiodes convert the incoming radiation to a photo current and with a subsequent current-to-digital converter to digital data. An internal reference generator provides all the necessary references for the A/D conversion and the photodiodes by using an external resistor REXT at pin REXT. The results of the A/D conversion are stored in three 16-bit registers and can be accessed via the I²C interface. For the externally triggered start or start and stop of the measurement, the input pin SYN can be used. The output READY reflects the status of the conversion. The internal temperature sensor delivers the on-chip temperature, stored as a 12-bit value in a 16-bit register, which can be accessed via the I²C interface as well. The pins A0 and A1 set the I²C slave address. Separated analog and digital power supply and ground pins reduce noise coupling. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 4 Document Feedback AS7331 General Description Figure 2: Functional Blocks of the AS7331 V DDA V SS A UV A UV B A/D c on versio n UV C 3 x 1 6 Bit Cou nt er / Reg iste r Con trol Reg iste r Sta te Con trol Te mpe ra tu re sen so r R EX T Ref eren ces + Bias Gen erat ion Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 Clock Gen era tio n R EA DY S YN 1 2 Bit Cou nt er / Reg iste r I²C Int erfa ce S CL S DA A1 A0 V SS A V DDD V SS D 70 │ 5 Document Feedback 2 AS7331 Ordering Information Ordering Information Ordering Code Package Marking Delivery Form Delivery Quantity AS7331-AQFM OLGA16 AS7331 Tape & Reel 1000 pcs/reel AS7331-AQFT OLGA16 AS7331 Tape & Reel 5000 pcs/reel Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 6 Document Feedback 3 Pin Assignment 3.1 Pin Diagram AS7331 Pin Assignment Figure 3: AS7331 Pin Diagram 3.2 Pin Description Figure 4: Pin Description of the AS7331 Pin Number Pin Name Pin Type(1) Description 1, 2 VSSA P Analog ground. 3 VDDA P Analog power supply. 4 REXT A_I/O External reference resistor. 5, 6 VSSA P Analog ground. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 7 Document Feedback AS7331 Pin Assignment Pin Number Pin Name Pin Type(1) Description 7 A1 DI Variable I²C slave address bit 1. 8 SYN DI Input for external controlled conversion. 9 READY DO Conversion status, configurable as push pull or open drain output stage (default push pull). 10 VDDD P Digital power supply. 11 VSSD P Digital ground. 12 SDA D_I/O_OD I²C data input / output, open drain output stage. 13 SCL DI I²C clock input. 14 A0 DI Variable I²C slave address bit 0. 15,16 VSSA P Analog ground. (1) Explanation of abbreviations: DI Digital Input DO Digital Output P Power pin A_I/O Analog in-/output D_I/O_OD Digital in-/output, open drain Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 8 Document Feedback 4 AS7331 Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5 Absolute Maximum Ratings of the AS7331 Symbol Parameter Min Max Unit Comments Maximum power supply voltage range -0.5 5 V VDDA and VDDD Supply voltage difference -0.3 0.3 V VDDA - VDDD Input and output voltages -0.5 VDD+0.5 V A0, A1, SCL, SDA, SYN, READY Electrical Parameters VDD DIFFVDD Electrostatic Discharge ESDHBM Electrostatic discharge HBM ± 500 V JS-001-2014 ESDCDM Electrostatic discharge CDM ± 500 V JEDEC JESD22-C101F Oct 2013 Optical Parameters αI Angle of incidence -10 10 ° Temperature Ranges and Storage Conditions TA Operating ambient temperature -40 105 °C TSTRG Storage temperature range - 55 125 °C TBODY Package body temperature 260 °C RHNC Relative humidity (noncondensing) 85 % MSL Moisture sensitivity level (1) 5 3 IPC/JEDEC J-STD-020 (1) Maximum floor life time of 168h The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Nonhermetic Solid State Surface Mount Devices.” The lead finish for Pb-free leaded packages is “Matte Tin” (100 % Sn). Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 9 Document Feedback 5 AS7331 Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with Min and Max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. All voltages are with respect to ground (GND). Device parameters are guaranteed at VDD = 3.3 V and TA = 25 °C unless otherwise noted. Figure 6: Electrical Characteristics of the AS7331 Symbol Parameter Conditions Min Typ Max Unit VDD Operating Power Supply Voltage VDDA and VDDD 2.7 3.3 3.6 V REXT External Resistor at Pin REXT 3.267 3.3 3.333 MΩ IVDD Current Consumption Active mode during measurement. 1.5 2 mA IVDDSB Standby Current Consumption Standby state 970 µA IVDDPD Power Down Current Consumption Power down state. 1 µA VIH Input High Level A0, A1, SCL, SYN VIL Input Low Level A0, A1, SCL, SYN VOH Output High Level REXT (TCREXT ≤ 50ppm/K) READY 0.7 VDDD 0.3 0.8 VDDD VDDD IOHL ≤ 3 mA SDA, READY VOL Output Low Level IOHL Output Drive Strength Concerning to VOH and VOL IILEAK Input Leakage Current VSSD ≤ VIN ≤ VDDD fCLKMIN Min. Internal Clock Frequency CREG3:CCLK = 00b 0.975 MHz fCLKMAX Max. Internal Clock Frequency CREG3:CCLK = 11b 7.8 MHz Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 IOHL ≤ 3 mA 3 -10 0.4 V 6 mA 10 µA 70 │ 10 Document Feedback Symbol Parameter Conditions TSTARTSB Startup Time after Standby state(1) TSTARTPD Startup Time after Power Down state(1) TSYNDEL SYN Trigger Delay TSYN SYN Negative or Positive Pulse Width(1) (1) AS7331 Electrical Characteristics Min Typ Max Unit Until the start of the first measurement. 4 5 µs Until the start of the first measurement. 1.2 2 ms 3 1/fCLK From falling SYN-edge to the start of the measurement. SYN recognized as the start or end pulse of the measurement. 3 1/fCLK Temperature Sensor(1) T_abs_err Temperature Absolute Error -10 10 K ADC Resolution 10 24 bit CREG3:CCLK = 00b fCLKMIN 1 16384 ms CREG3:CCLK = 11b fCLKMAX 0.125 2048 ms Related to fCLK -25 25 % -0.02 0.02 % ADC RES TCONV Conversion Time ∆TCONV Conversion Time Tolerance INL Integral Nonlinearity DNL Differential Nonlinearity No missing codes. -0.5 0.5 LSB DFSR Full Scale ADC Code Per channel 1024 65535 counts DDARK Dark ADC Count Value Ee = 0; GAIN = 2048x TCONV = 64 ms @ fCLKMIN 8 counts ENOB Effective Number of Bits GAIN = 64x TCONV = 64 ms @ fCLKMIN (1) 15.4 bit These parameters are representative results by lab characterization and not included in the mass production test. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 11 Document Feedback AS7331 Typical Operating Characteristics 6 Typical Operating Characteristics 6.1 Optical Characteristics Figure 7: Optical Characteristics of the AS7331 Symbol Parameter(1) Conditions A channel λ = 360 nm ReGAIN2048 Irradiance Responsivity for CREG1:GAIN = 2048x B channel λ = 300 nm C channel λ = 260 nm A channel λ = 360 nm ReGAIN1 Irradiance Responsivity for CREG1:GAIN = 1x B channel λ = 300 nm C channel λ = 260 nm A channel λ = 360 nm FSRGAIN2048 Full Scale Range of detectable Irradiance for CREG1:GAIN = 2048x B channel λ = 300 nm C channel λ = 260 nm A channel λ = 360 nm FSRGAIN1 Full Scale Range of detectable Irradiance for CREG1:GAIN = 1x B channel λ = 300 nm C channel λ = 260 nm (1) Min Typ Max Unit 421 321 counts/ (µW/cm²) 668 0.205 0.157 counts/ (µW/cm²) 0.326 156 204 µW/cm² 98 3.19e5 4.18e5 µW/cm² 2.01e5 The optical Characteristics are representative results by lab characterization and not included in the mass production tests. All values are measured at an integration time of 64 ms. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 12 Document Feedback 6.2 AS7331 Typical Operating Characteristics Optical Responsivity Figure 8: Normalized Spectral Responsivity of the AS7331 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 13 Document Feedback AS7331 Typical Operating Characteristics Figure 9: Normalized Spectral Responsivity of the AS7331 to UVA Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 14 Document Feedback 7 AS7331 Functional Description Functional Description The AS7331 includes three internal photodiodes with different spectral sensitivities and three ADCs, each one for each spectral photodetector. The irradiance responsivity Re and the time of conversion TCONV are user-defined and determined by the registers CREG1: GAIN and CREG1:TIME. Both, Gain and conversion time can be adapted to match the measurement conditions. At the end of each conversion, the digital equivalents of the filtered input light signal regarding the area of the sensor are stored in the output registers (MRES1 … MRES3). With the divider, the 16-bit of interest can be selected out of the 24-bit ADC output. Additionally, a temperature sensor works in parallel to the three optical channels, delivering the on-chip temperature at the end of conversion. The READY pin remains at a low logic level during the conversion. The rising edge and the following high logic level of READY signal, the end of the conversion. Internal information related to the conversion is available in a status register as well. Figure 10: Photodiode Array A B C 7.1 Operational States The AS7331 operates in two different states “Configuration” and “Measurement”. The three least significant bits of the Operational State Register (OSR) as Device Operational State (DOS) define the current state. After applying the power supply voltage, including power-on reset, or after software reset, the AS7331 stays in the Power-Down state. Then it is ready to be programmed via the I²C interface. When Power-Down is switched off (OSR: PD set to ‚0‘), the AS7331 starts in the Configuration state (CONFIG) or the Measurement state (MMODE) according to its DOS programming. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 15 Document Feedback AS7331 Functional Description Figure 11: Simplified State Diagram Power On VDD > VDD-POR Power Down OSR PD: 0" DOS: 010 PD: 0 DOS: 011 DOS: 011 Configuration State Measurement State End of conversion 7.1.1 Configuration State This state enables access to the configuration registers (CREG1, CREG2, and CREG3). Irradiance responsivity (Re) and conversion time (TCONV) can be determined by the settings of the registers CREG1: GAIN and CREG1:TIME as well as the kind of measurement mode that can be chosen via the register CREG3:MMODE. A measurement is not possible in this state. Because of that, any access to the measurement result registers is disabled. 7.1.2 Measurement State In this state the signal-to-digital conversion can be performed. Access to the output result registers is enabled, but at this time, there is no access possible to the configuration registers. Specific settings for the measurement should be performed by programming the configuration registers before the measurement is started (see chapter 8.2.6). The change between the Configuration and Measurement states can be performed by programming the DOS value of the operational state register OSR (see Figure 45). Afterward, a change from Measurement state to Configuration state will occur immediately. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 16 Document Feedback AS7331 Functional Description Any active measurement is stopped and all output result registers as well as the status register are reset as well. 7.2 Measurement Modes The AS7331 provides four different modes to perform the measurement. The register CREG3:MMODE (see Figure 50) defines the measurement mode that is performed by the device. In general, it is recommended not to communicate via the I²C during the conversion. Use pause times between two conversion cycles for data transfer via the I²C interface. To support such behavior, a variable pause time (TBREAK) is implemented (register BREAK in Figure 51), which delays the start of the next conversion cycle in the measurement modes CONT, SYNS, and SYND. The I²C commands sent to the AS7331 always take effect after the complete I²C write cycle with an I²C Stop condition at the end. 7.2.1 Continuous Measurement Mode – CONT The A/D conversion is sequentially performed. The first conversion starts by setting the bit OSR:SS to “1”. If the Power Down or Standby option is switched on, the device deactivates it and initializes the continuous measurement. The measurement can only be stopped by resetting the OSR:SS bit. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 17 Document Feedback AS7331 Functional Description Figure 12: State Machine of CONT Mode PD = 0 MMODE = 0 PD = 1 CONFIG POWDOWN PD = 1 Power-up PD = 0 MMODE = 0 SB = 0 PD = 0 MMODE = 0 SB = 0 PD = 1 PD = 0 SS = 1 MMODE = 1 SB = 1 PD = 0 MMODE = 1 SB = 0 PD = 1 PD = 0 MMODE = 0 SB = 1 PD = 0 MMODE = 0 SB = 0 M_IDLE PD = 0 SS = 1 MMODE = 1 SB = 0 CONT PD = 0 MMODE = 0 SB = 0 PD = 0 SS = 0 MMODE = 1 SB = 0 STANDBY PD = 0 SS = 1 MMODE = 1 SB = 1 SS = 1 SB = 0 PD = 0 MMODE = 1 SB = 1 PD = 0 SS = 1 MMODE = 1 SB = 0 PD = 1 PD = 1 PAUSE MMODE = 1 The conversion time (TCONV) is determined by the content of the register CREG1:TIME (see Figure 48). The rising edge of READY signalizes the end of each conversion and its available valid results. Figure 48 shows the principle sequence for a measurement starting in CONT mode, while waiting in the Measurement state shows IDLE: 1. OSR programming: 83h, start of continuous measurement via OSR:SS = “1”, while the device is already in measurement mode (OSR:DOS = 011b), 2. OSR programming: 03h, abortion of continuous measurement via OSR:SS = “0” while pause time (TBREAK) is already activated to get the last measurement results. It is recommended to read the measurement results during the break between two consecutive conversions. This pause time (TBREAK) can be configured in steps of 8 μs up to 2040 μs (Figure 53). Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 18 Document Feedback AS7331 Functional Description Information Please note that the break time should be long enough to prevent overlapping of data fetch activities with the measurement for avoiding measurement disturbances, which could cause distortions of the measurement results. Figure 13: Principle Sequence for a Measurement Start in CONT Mode TBREAK STATE MEASUREMENT 1 IDLE PAUSE TBREAK aborted MEASUREMENT 2 P IDLE PAUSE TCONV READY TCONV MRES1 … MRES3 RESULTS 1 data fetch I²C activity start (OSR:SS ← ,1') a) 7.2.2 RESULTS 2 data fetch stop (OSR:SS ← ,0') b) Command Measurement Mode – CMD The CMD mode enables a start of a single conversion. Each conversion starts by setting the bit OSR:SS to “1”. The conversion time (TCONV) is determined by the content of the register CREG1:TIME (see Figure 48). Figure 14 shows the first measurement starting from the Configuration state by setting the bits of the Device Operational State (OSR:DOS) and Start/Stop (OSR:SS) at the same time with OSR = 83h. To start the next measurement, OSR = 80h is set (only bit OSR:SS, OSR:DOS = 000b corresponds to NOP – no operation, see also Figure 45. The rising edge of READY signalizes the end of conversion and its valid output data can be read via the I²C interface (data fetch). Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 19 Document Feedback AS7331 Functional Description Figure 14: State Machine of CMD Mode Figure 15 shows the principle sequence for a measurement to start in CMD mode coming from the Configuration state and waiting in the Measurement state between the measurements is shown as IDLE: ● ● OSR programming: 83h, changes to the Measurement state and starts measurement via OSR:SS = “1”, “Automatically” OSR programming: 03h, reset bit OSR:SS to “0” at the end of the conversion. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 20 Document Feedback AS7331 Functional Description Figure 15: Principle Sequence for a Measurement Start in CMD Mode Coming From Configuration State LDATA = "0" NDATA = "0" LDATA = "0" NDATA = "0" STATE CONFIGURATION READY LDATA = "0" NDATA = "1" MEASUREMENT 1 LDATA = "1" NDATA = "1" IDLE MEASUREMENT 2 TCONV TCONV MRES1 MRES3 RESULTS 1 RESULTS 2 data fetch I²C activity OSR = 83h start (OSR:SS "1") 7.2.3 IDLE start (OSR:SS "1") Synchronous Measurement Mode – SYNS In this measurement mode, the input pin, SYN, acts as a trigger event for the start of A/D conversion. The falling edge at the SYN pin starts the measurement. The conversion time (TCONV) is determined by the content of the register CREG1:TIME (see Figure 48). The READY pin signalizes the progress of conversion (see Figure 16) its rising edge shows the end of conversion and its available valid results. The data fetch should be performed between the rising edge of signal READY and the next falling edge of signal SYN, in order to allow distortion-free measurements. SYN pulses during the programmed pause time TBREAK are ignored to avoid a start of the measurement during a running data fetch. The bit OSR:SS also takes effect in the SYNS mode, because the start of the measurement is only possible with OSR:SS = “1”. Figure 16 shows the principle sequence for a measurement to start in SYNS mode, OSR:DOS = 011b and OSR:SS = “1” already set and waiting in Measurement state is shown as IDLE. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 21 Document Feedback AS7331 Functional Description Figure 16: Principle Sequence for a Measurement Start in SYNS Mode, OSR:DOS = 011b and OSR:SS = “1” TBREAK STATE IDLE MEASUREMENT 1 PAUSE IDLE MEASURMENT 2 SYN start READY start TCONV MRES1 … MRES3 I²C activity 7.2.4 RESULTS 1 data fetch Synchronous Measurement Start and End Mode – SYND In this mode, the signal at pin SYN completely controls the start and stop of measurement. When the device is waiting in the Measurement state and OSR:SS is set to “1” the first falling edge at pin SYN starts the measurement. Each following falling edge of signal SYN, which occurs within the conversion time, can continue or stop the measurement. The content of the register EDGES determines which edge is the stopping one. That means the measurement will not stop until a certain number of falling edges at pin SYN pass within the conversion time. The value of register EDGES determines the number of edges (see Figure 17 and chapter 8.2.7). Figure 17 shows the principle sequence for a measurement to start in SYND mode. While waiting in the Measurement state is shown as IDLE, after OSR:SS is set to “1” (see Figure 45) the AS7331 waits for signal SYN to start. The conversion time is set to 06h in register EDGES, during the pause time (TBREAK), and falling edges at pin SYN are ignored. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 22 Document Feedback AS7331 Functional Description Figure 17: Principle Sequence for a Measurement Start in SYND Mode IDLE TBREAK STATE IDLE MEASUREMENT 1 PAUSE ID MEASUREMENT 2 SYN start 1. 2. 3. 4. 5. 6. start 1. 2. 3. TCONV READY MRES1 … MRES3 RESULTS 1 OUTCONV RESULT 1 I²C activity data fetch OSR 80h The conversion time (TCONV) is determined by the duration between the edges of the start and stop of the SYN signal. If CREG2:EN_TM is set to “1”, the register OUTCONV contains an equivalent amount of TCONV as counts of the internal clock. With the value of OUTCONV, the measurement results can be calculated more precisely (see chapter 7.6). 7.3 Energy Saving Options The usage of the energy-saving options is consistent for all measurement modes. The signal path at pin READY always represents, independent of wake-up times or synchronizing events at pin SYN concerning the internal clock, the real measurement process. Every measurement mode can be terminated with OSR:SS = “0” or changing to the configuration state at every time, whereas uncompleted A/D conversions are not stored. In the case of both energy-saving options power down state (POWDOWN) and standby state (STANDBY) are switched on (OSR:PD = “1” and CREG3:SB = “1”). The startup times (TSTARTPD and TSTARTSB) run one after the other after power down and standby are switched off. 7.3.1 Power Down Power down is an option to reduce power consumption. After applying the power supply voltage including power-on reset or after software reset the AS7331 stays in power down state. The clock generator and all analog parts of the device are turned off. The power consumption of the device is close to zero. The digital part of the AS7331 stays idle, but full communication via the I²C interface is granted in the configuration and measurement state. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 23 Document Feedback AS7331 Functional Description In case the Device Operational State (DOS) is set to the measurement mode, the start/stop of measurement is possible by setting the OSR:SS bit and reading measurement data. The power down can be switched on and off by the bit OSR:PD (Figure 45). Switching on power down via the bit OSR:PD = “1”, changes the AS7331 to the power down state after the end of an ongoing measurement. Switching off power down (OSR:PD = ‚0‘) results in a change to the Idle state (IDLE for waiting) or standby state depending on the bit CREG3:SB. This change to another operational state is delayed by the startup time (TSTARTPD) typically of 1.2 ms. A conversion can start in all the measurement modes while the power down state is activated (OSR:PD = “1”). In the measurement modes CMD and CONT it is done by setting the bit OSR:SS to ‚1‘. In addition, the falling edge of the signal at pin SYN for the measurement modes SYNS and SYND initiate the start. In all cases, the start of the conversion is delayed by the startup time (TSTARTPD). After the conversion in the CMD, SYNS and SYND modes the AS7331 changes back into the power down state, whereas the measurement of the CONT mode is interactive until it is stopped by setting the bit OSR:SS = to “0” before it changes back into the power down state. There are two methods for startup the AS7331: 1. After applying the power supply voltage, including power-on reset, or after software reset, the OSR:PD bit must be set to “0” via the I²C interface communication. The analog part and the internal clock system start to work along with the defined configuration of the AS7331. Nevertheless, it is still possible to change the configuration in front of the time b) in Figure 18. The Device Operational State changes to the Measurement state to start the measurement (OSR:SS = “1”) without further delay caused by energy-saving options. Figure 18 shows the principle sequence after power-on reset and separated writing of the bits OSR:PD, OSR:DOS, and OSR:SS: a) b) c) OSR programming: 02h, after TSTARTPD continuing within only the configuration state, OSR programming: 03h, change to the Measurement state – waiting is shown as IDLE, OSR programming: 80h, start of the measurement as stated in the device’s configuration. Figure 18: Principle Sequence After Power-On Reset and Separated Writing of the Bits OSR:PD, OSR:DOS and OSR:SS STATE CONFIGURATION POWDOWN IDLE MEASUREMENT TSTARTPD I²C activity OSR:PD ← ‚0' a) Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 OSR:DOS 011b b) Start OSR:SS ← ‚1' c) 70 │ 24 Document Feedback 2. AS7331 Functional Description Coming from power down state activated by OSR:PD = “1” the AS7331 is not actively switched on until OSR:SS is set to “1” (together while or with OSR:DOS = 011b). This means the bit OSR:SS is a direct start condition for the CMD and CONT modes, whereas for both SYN modes, the falling edge at pin SYN is necessary for the startup. The programmed measurement mode follows after startup, marked by the falling edge of the signal path at the READY pin. If the configuration contains CREG3:SB = “1” (as the example in Figure 19 shows), additionally after startup time (TSTARTPD), the wake-up time (TSTARTSB) of 4 µs follows, before the measurement starts. Figure 19: Principle Start of the Measurement from OSR:PD = “1” and CREG3:SB = “1” TSTARTSB STATE CONFIGURATION POWDOWN S TSTARTPD MEASUREMENT STANDBY I²C activity CREG3:SB ← ‚1' a) OSR C3h b) Figure 19 shows the principle start of the measurement from OSR:PD = “1” and CREG3:SB = “1”: a) b) CREG3 programming: bit CREG3:SB = “1”, OSR programming: C3h, start of the measurement with prior run of TSTARTPD and TSTARTSB. The programmed energy-saving option (before or when the measurement is started or during the measurement) is switched on after the regular end of the measurement and storing of the results within the buffer registers. In case of an abortion of the measurement with OSR:SS = “0” or switching to the configuration state the energy saving option is switched on without saving any results. 7.3.2 Standby Standby is another option for reducing the power consumption, but compared to power down, fewer internal analog components are switched off to be able to become active again in a very short time. The digital part of the AS7331 stays idle, but full communication via the I²C interface is granted in configuration and measurement states. The CREG3:SB bit can only be changed in the configuration mode. The wake-up process is possible in combination with the start condition of the configured measurement mode. Standby is automatically deactivated by starting the CMD or CONT measurement mode by setting the bit OSR:SS to “1”. In addition, for the measurement modes SYNS and SYND, an initiated start is necessary by the falling edge of the signal at pin SYN. While starting Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 25 Document Feedback AS7331 Functional Description the measurement, the A/D conversion follows immediately after the wake-up time (TSTARTSB) of about 4 µs. Figure 20 shows the principle start and stop sequence of measurement after startup with OSR:PD = “0” and CREG3:SB = “1”: a) b) c) CREG3 programming: bit CREG3:SB = “1”, OSR programming: 02h, after startup continuing with configuration mode, OSR programming: 83h, measurement start, wake-up and conversion, return to standby after measurement ends. Figure 20: Principle Start and Stop Sequence of a Measurement After Startup with OSR:PD = “0” and CREG3:SB = “1” TSTARTSB CONFIGURATION POWDOWN STATE STANDBY MEASUREMENT STANDBY TSTARTPD I²C activity CREG3:SB ← ‚1' OSR:PD ← ‚0' a) 7.3.3 b) OSR 83h c) Examples For both modes, CONT and SYN, it is recommended to configure a pause time, TBREAK, (register BREAK Figure 51), to avoid disturbances during the A/D conversion caused by the I²C interface communication. The selectable pause time using the register BREAK should be long enough, such that all the output results are read before the next conversion starts (automatically in CONT modus or synchronized via pin SYN in SYN modes). While the pause time (TBREAK) is running it is possible to save energy if the bit CREG3:SB is configured to “1”. The wake-up time, TSTARTSB, of about 4 µs is short, compared to the necessary time for the I²C communication protocol represented by the BREAK register. Figure 21 shows the principle sequence of CONT mode: if CREG3:SB is set to “1”, saving energy is possible while the pause time TBREAK is activated for I²C interface communication. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 26 Document Feedback AS7331 Functional Description Figure 21: Principle Sequence of CONT Mode – if CREG3:SB is Set to “1” TBREAK TSTARTSB STATE STANDBY MEASUREMENT 1 TSTARTSB PAUSE MEASUREMENT 2 STANDBY TCONV READY PAUSE STANDBY TCONV MRES1 … MRES3 RESULTS 1 RESULTS 2 data fetch data fetch I²C activity MEASUREMENT 3 OSR 83h Another example shows, that after the end of a conversion in CMD mode the AS7331 returns to power down and/or standby state depending on the bits OSR:PD and CREG3:SB. In case of both bits are “0” while the measurement state the device would return to idle, waiting for the next measurement to start. Figure 22 shows the principle sequence whereas measurement starts in CMD mode with power down and standby switched on (device is already in measurement state): a) CREG3 programming: bit CREG3:SB = “1” was set in Configuration state (not shown), b) OSR programming: C0h, “startup” and “wake-up” before conversion starts, c) “Automatically” OSR programming: 43h, the end of conversion resets bit OSR:SS, to power down. Figure 22: Principle Sequence Whereas Measurement is Started in CMD Mode with Power Down, Standby Switched On STATE POWDOWN SB MEASUREMENT POWDOWN STANDBY TCONV READY TSTARTPD TSTARTSB MRES1 … MRES3 RESULTS data fetch I²C activity start (OSR:SS ← ’1') b) Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 clear (OSR:SS ← ’0') c) 70 │ 27 Document Feedback AS7331 Functional Description It is also possible to use the power down state in combination with SYNS mode. The falling edge at pin SYN immediately starts the conversion after power down ends shown by the signal at pin READY. That kind of measurement is only useful in case the distance between falling edges at pin SYN is more than the conversion time, pause time, and startup time altogether. Figure 23 shows the principle sequence of measurement in SYNS mode being ready (bits OSR:PD = “1” and OSR:SS = “1”) and waiting for the falling edge at pin SYN to startup. Figure 23: Principle Sequence of Measurement in SYNS Mode TSTARTPD STATE TSTARTPD TBREAK POWDOWN MEASUREMENT 1 PAUSE MEASUREMENT POWDOWN SYN start start TCONV READY MRES1 … MRES3 RESULTS 1 data fetch I²C activity OSR C0h By additionally activating standby (bit CREG3:SB = “1”) a maximum amount of energy can be saved, because the operational readiness is not given until shortly before A/D conversion starts. When starting reading process of the results (pause time), the device is also saving energy in the standby state (see Figure 24). Figure 24 shows the principle sequence of measurement in SYNS mode being ready with OSR:PD = “1” (as in Figure 23), but with bit CREG3:SB = “1” to save a maximum amount of energy as explained above. Figure 24: Principle Sequence of Measurement in SYNS Mode Being Ready with OSR:PD = “1” TSTARTPD STATE POWDOWN TSTARTSB S MEASUREMENT 1 TBREAK TSTARTPD PAUSE SBY POWDOWN TSTARTSB S MEASUREMENT STANDBY SYN STANDBY start start TCONV READY MRES1 … MRES3 RESULTS 1 I²C activity data fetch OSR C0h Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 28 Document Feedback AS7331 Functional Description The following example of a SYNS mode shows the correct measurement procedure but with an unfavorable chosen application. After the start of measurement with bit OSR:SS = “1” only the falling edges marked in red (see Figure 25) at pin SYN are accepted as the start condition. Because of the tight distances of the SYN edges, many falling edges are ignored during the startup phase (TSTARTPD), conversion time (TCONV), and pause time (TBREAK). Figure 25: Principle Sequence of Measurement in SYNS Mode (OSR:PD , OSR:SS are set to “1”) TSTARTPD STATE POWDOWN MEASUREMENT 1 TBREAK TSTARTPD PAUSE POWDOWN MEAS SYN start start TCONV READY MRES1 … MRES3 RESULTS 1 I²C activity data fetch OSR C0h Continuously occurring SYN pulses (e.g. generated by a PWM controlling the measurement mode SYND) are ignored in the configuration state and whilst pause time, TBREAK, (see Figure 26) is activated. It is recommended to increase the default value of the BREAK register accordingly, if the time reference result OUTCONV must be read via the I²C interface. The EDGES register gives the conversion time, but as shown in Figure 26 the real conversion time is always represented by TCONV at pin READY. Furthermore, the output result OUTCONV can be used to get the right measurement result (see also chapters 7.4 and 7.6). Figure 26 shows the principle sequence of measurement in SYND mode, which is ready for wake-up after switching off the power down state with OSR:PD = “0”, and setting OSR:SS to “1” in the configuration state, then waiting for the start via pin SYN (with exemplary settings of EDGES = 06h and CREG3:SB = “1” for energy-saving during pause time TBREAK). Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 29 Document Feedback AS7331 Functional Description Figure 26: Principle Sequence of Measurement in SYND Mode Ready for Wake-Up After Switch Off Power Down State CONFIGURATION TSTARTSB STATE C SB TBREAK TSTARTSB PAUSE STANDBY MEASUREMENT 1 MEASUREMENT 2 STANDBY SYN start 1. 2. 3. 4. 5. 6. start 1. 2. 3. TCONV READY MRES1 … MRES3 RESULTS 1 OUTCONV RESULT 1 data fetch I²C activity OSR 83h 7.4 Transfer Function In general, the implemented A/D converter represents a delta-sigma converter, which performs charge balancing between the input light at the photodiodes and an internal reference. The input currents of the photodiodes result in pulse density modulated digital signals, further filtered by counters up to 24- bits. The counters will be set by definition of TINT. A 64 ms conversion time is required as minimum for a 16-bit I²C output (Figure 27) In the end, each channel’s counter status represents a digital equivalent of the average input light irradiance regarding the channel’s sensor area within the conversion time interval. The input light irradiance can be calculated from the measurement result by: Equation 2: Ee  MRES FSREe   MRES Re NCLK Equation 3: Ee  FSREe TCONV  f CLK Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27  MRES 70 │ 30 Document Feedback AS7331 Functional Description Where: MRES = Digital output value of the conversion (content of output registers MRES1 to MRES3). Ee = Input light irradiance regarding to the photodiode’s area within the conversion time interval. FSREe = Full Scale Range of detectable input light irradiance Ee. Re = Irradiance responsivity (see Figure 12). TCONV = Conversion time interval. NCLK = Number of clock cycles within the conversion time interval TCONV (see Figure 11). fCLK = Clock frequency. In the CONT, CMD and SYNS modes the conversion time, TCONV, is internally generated1. In the SYND mode the conversion time is defined by the timing of the external pulses at the SYN pin and the number of pulses stored in the EDGES register (see Figure 17 chapter 7.6 and chapter 8.2.7). The number of clock counts within this interval is a constant number, which keeps the output result independent of the internal clock frequency. In this case, the input light irradiance, Ee, regarding the area of the photodiode of the channel can be represented by Equation 2. In SYND mode. Equation 3 represents the externally generated conversion time, TCONV, and the conversion result. If the conversion time measurement is activated (CREG2:EN_TM = “1”) the number of clock counts within the externally given conversion time can also be internally captured. So the input light irradiance Ee regarding the photodiode’s area of the channel can be calculated as: Equation 4: Ee  FSREe OUTCONV  MRES Where: MRES = Digital output value of the conversion (content of output registers MRES1 to MRES3). Ee = Input light irradiance regarding the photodiode’s area within the conversion time interval. FSREe = Full Scale Range of detectable input light irradiance Ee. OUTCONV = Conversion time duration expressed as the number of clock counts within this time. In this way, the input light irradiance can be measured independently of the internal frequency and the external conversion time variations in SYND mode. 1 The system clock is internally generated and is subject to technological tolerances. As such, the clock frequency may vary, which must be considered when calculating the time to be programmed (e.g. registers BREAK for pause time TBREAK or CREG1:TIME for conversion time TCONV). Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 31 Document Feedback AS7331 Functional Description The calculation of the input light irradiance by Equation 4 is more precise than the result of Equation 3 because the tolerances of the clock frequency, fCLK, are eliminated. The irradiance responsivity, Re, and internal conversion time TCONV are determined by the content of register bits CREG1:GAIN and CREG1:TIME (see Figure 48). Their values directly determine the sensitivity, the LSB value, and the full-scale range (FSR) of the detectable irradiance, Ee, of the A/D conversion. Information The values in the Figures 27 up to 32 are calculations based on the general sensitivity without any influences of system and opto-mechanical setup. These values are only an indication for the sensor configuration. Figure 27: UVA-Channel (λ = 315 nm – 410 nm) Programmable FSR and LSB of the Detectable Input Light Irradiance Ee TIME(1) 0 1 2 3 4 5 6 7 NCLK(1) 1024 2048 4096 8192 16384 32768 65536 131072 1 2 4 8 16 32 64 128 10 11 12 13 14 15 16 17 (1) TCONV[ms] RESOL[bit] (1) (1) FSR [µW/cm²] of detectable irradiance Ee (channel A) GAIN 2048x 156.000(2) 78.000 1024x 312.000 156.000 512x 624.000 312.000 256x 1248.000 624.000 128x 2496.000 1248.000 64x 4992.000 2496.000 32x 9984.000 4992.000 16x 19968.000 9984.000 8x 39936.000 19968.000 4x 79872.000 39936.000 2x 159744.000 79872.000 319488.000 159744.000 1x LSB [nW/cm²] – least significant bit of FSR (channel A) (1) GAIN 2048x 152.344 76.172 38.086 19.043 9.521 4.761 2.380 1.190 1024x 304.688 152.344 76.172 38.086 19.043 9.521 4.761 2.380 512x 609.375 304.688 152.344 76.172 38.086 19.043 9.521 4.761 256x 1218.750 609.375 304.688 152.344 76.172 38.086 19.043 9.521 128x 2437.500 1218.750 609.375 304.688 152.344 76.172 38.086 19.043 64x 4875.000 2437.500 1218.750 609.375 304.688 152.344 76.172 38.086 32x 9750.000 4875.000 2437.500 1218.750 609.375 304.688 152.344 76.172 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 32 Document Feedback (1) (2) AS7331 Functional Description TIME(1) 0 1 2 3 4 5 6 7 16x 19500.00 9750.00 4875.00 2437.50 1218.75 609.38 304.69 152.34 8x 39000.00 19500.00 9750.00 4875.00 2437.50 1218.75 609.38 304.69 4x 78000.00 39000.00 19500.00 9750.00 4875.00 2437.50 1218.75 609.38 2x 156000.00 78000.00 39000.00 19500.00 9750.00 4875.00 2437.50 1218.75 1x 312000.00 156000.00 78000.00 39000.00 19500.00 9750.00 4875.00 2437.50 TIME (TCONV) – given by CREG1:TIME = 0 … 7 dec, NCLK – number of clock cycle within conversion time TCONV, RESOL – Resolution of internal A/D conversion, GAIN = 1x given by CREG1:GAIN = 11 dec up to GAIN = 2048x given by CREG1:GAIN = 0 dec (see Figure 48) Basic sensitivity of the UVA-channel. Figure 28: UVA-Channel (λ = 315 nm – 410 nm) Programmable FSR and LSB of the Detectable Input Light Irradiance Ee TIME(1) 8 9 10 11 12 13 14 15 NCLK(1) 262144 524288 1.05E+06 2.10E+06 4.19E+06 8.39E+06 1.68E+07 1024 0.256 0.512 1.024 2.048 4.096 8.192 16.384 0.001 18 19 20 21 22 23 24 10 (1) TCONV[s] (1) RESOL[bit] GAIN(1) FSR [µW/cm²] of detectable irradiance Ee (channel A) 2048x 39.00 19.50 9.75 4.88 2.44 1.22 0.61 156.00 1024x 78.00 39.00 19.50 9.75 4.88 2.44 1.22 312.00 512x 156.00 78.00 39.00 19.50 9.75 4.88 2.44 624.00 256x 312.00 156.00 78.00 39.00 19.50 9.75 4.88 1248.00 128x 624.00 312.00 156.00 78.00 39.00 19.50 9.75 2496.00 64x 1248.00 624.00 312.00 156.00 78.00 39.00 19.50 4992.00 32x 2496.00 1248.00 624.00 312.00 156.00 78.00 39.00 9984.00 16x 4992.00 2496.00 1248.00 624.00 312.00 156.00 78.00 19968.00 8x 9984.00 4992.00 2496.00 1248.00 624.00 312.00 156.00 39936.00 4x 19968.00 9984.00 4992.00 2496.00 1248.00 624.00 312.00 79872.00 2x 39936.00 19968.00 9984.00 4992.00 2496.00 1248.00 624.00 159744.00 1x 79872.00 39936.00 19968.00 9984.00 4992.00 2496.00 1248.00 319488.00 LSB [nW/cm²] – least significant bit of FSR (channel A) GAIN(1) 2048x 0.60 0.30 0.15 0.07 0.04 0.02 0.01 152.34 1024x 1.19 0.60 0.30 0.15 0.07 0.04 0.02 304.69 512x 2.38 1.19 0.60 0.30 0.15 0.07 0.04 609.38 256x 4.76 2.38 1.19 0.60 0.30 0.15 0.07 1218.75 128x 9.52 4.76 2.38 1.19 0.60 0.30 0.15 2437.50 64x 19.04 9.52 4.76 2.38 1.19 0.60 0.30 4875.00 32x 38.09 19.04 9.52 4.76 2.38 1.19 0.60 9750.00 16x 76.17 38.09 19.04 9.52 4.76 2.38 1.19 19500.00 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 33 Document Feedback (1) AS7331 Functional Description TIME(1) 8 9 10 11 12 13 14 15 8x 152.34 76.17 38.09 19.04 9.52 4.76 2.38 39000.00 4x 304.69 152.34 76.17 38.09 19.04 9.52 4.76 78000.00 2x 609.38 304.69 152.34 76.17 38.09 19.04 9.52 156000.00 1x 1218.75 609.38 304.69 152.34 76.17 38.09 19.04 312000.00 TIME (TCONV) – given by CREG1:TIME = 8 … 15 dec, NCLK – number of clock cycle within conversion time TCONV, RESOL – Resolution of internal A/D conversion, GAIN = 1x given by CREG1:GAIN = 11 dec up to GAIN = 2048x given by CREG1:GAIN = 0 dec (see Figure 48). Figure 29: UVB-Channel (λ = 280 nm – 315 nm) Programmable FSR and LSB of the Detectable Input Light Irradiance Ee TIME(1) NCLK (1) (1) TCONV[ms] RESOL[bit](1) 0 1 2 3 4 5 6 7 1024 2048 4096 8192 16384 32768 65536 131072 1 2 4 8 16 32 64 128 10 11 12 13 14 15 16 17 GAIN(1) FSR [µW/cm²] of detectable irradiance Ee (channel B) 2048x 204.00(2) 102.00 1024x 408.00 204.00 512x 816.00 408.00 256x 1632.00 816.00 128x 3264.00 1632.00 64x 6528.00 3264.00 32x 13056.00 6528.00 16x 26112.00 13056.00 8x 52224.00 26112.00 4x 104448.00 52224.00 2x 208896.00 104448.00 417792.00 208896.00 1x GAIN LSB [nW/cm²] – least significant bit of FSR (channel B) (1) 2048x 199.22 99.61 49.80 24.90 12.45 6.23 3.11 1.56 1024x 398.44 199.22 99.61 49.80 24.90 12.45 6.23 3.11 512x 796.88 398.44 199.22 99.61 49.80 24.90 12.45 6.23 256x 1593.75 796.88 398.44 199.22 99.61 49.80 24.90 12.45 128x 3187.50 1593.75 796.88 398.44 199.22 99.61 49.80 24.90 64x 6375.00 3187.50 1593.75 796.88 398.44 199.22 99.61 49.80 32x 12750.00 6375.00 3187.50 1593.75 796.88 398.44 199.22 99.61 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 34 Document Feedback (1) (2) AS7331 Functional Description TIME(1) 0 1 2 3 4 5 6 7 16x 25500.00 12750.00 6375.00 3187.50 1593.75 796.88 398.44 199.22 8x 51000.00 25500.00 12750.00 6375.00 3187.50 1593.75 796.88 398.44 4x 102000.00 51000.00 25500.00 12750.00 6375.00 3187.50 1593.75 796.88 2x 204000.00 102000.00 51000.00 25500.00 12750.00 6375.00 3187.50 1593.75 1x 408000.00 204000.00 102000.00 51000.00 25500.00 12750.00 6375.00 3187.50 TIME (TCONV) – given by CREG1:TIME = 0 … 7 dec, NCLK – number of clock cycle within conversion time TCONV, RESOL – Resolution of internal A/D conversion, GAIN = 1x given by CREG1:GAIN = 11 dec up to GAIN = 2048x given by CREG1:GAIN = 0 dec (see Figure 48). Basic sensitivity of the UVB-channel. Figure 30: UVB-Channel (λ = 280 nm – 315 nm) Programmable FSR and LSB of the Detectable Input Light Irradiance Ee TIME(1) NCLK (1) (1) TCONV[s] RESOL[bit](1) 8 9 10 11 12 13 14 15 262144 524288 1.05E+06 2.10E+06 4.19E+06 8.39E+06 1.68E+07 1024 0.256 0.512 1.024 2.048 4.096 8.192 16.384 0.001 18 19 20 21 22 23 24 10 GAIN(1) FSR [µW/cm²] of detectable irradiance Ee (channel B) 2048x 51.00 25.50 12.75 6.38 3.19 1.59 0.80 204.00 1024x 102.00 51.00 25.50 12.75 6.38 3.19 1.59 408.00 512x 204.00 102.00 51.00 25.50 12.75 6.38 3.19 816.00 256x 408.00 204.00 102.00 51.00 25.50 12.75 6.38 1632.00 128x 816.00 408.00 204.00 102.00 51.00 25.50 12.75 3264.00 64x 1632.00 816.00 408.00 204.00 102.00 51.00 25.50 6528.00 32x 3264.00 1632.00 816.00 408.00 204.00 102.00 51.00 13056.00 16x 6528.00 3264.00 1632.00 816.00 408.00 204.00 102.00 26112.00 8x 13056.00 6528.00 3264.00 1632.00 816.00 408.00 204.00 52224.00 4x 26112.00 13056.00 6528.00 3264.00 1632.00 816.00 408.00 104448.00 2x 52224.00 26112.00 13056.00 6528.00 3264.00 1632.00 816.00 208896.00 104448.00 52224.00 26112.00 13056.00 6528.00 3264.00 1632.00 417792.00 1x GAIN LSB [nW/cm²] – least significant bit of FSR (channel B) (1) 2048x 0.78 0.39 0.19 0.10 0.05 0.02 0.01 199.22 1024x 1.56 0.78 0.39 0.19 0.10 0.05 0.02 398.44 512x 3.11 1.56 0.78 0.39 0.19 0.10 0.05 796.88 256x 6.23 3.11 1.56 0.78 0.39 0.19 0.10 1593.75 128x 12.45 6.23 3.11 1.56 0.78 0.39 0.19 3187.50 64x 24.90 12.45 6.23 3.11 1.56 0.78 0.39 6375.00 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 35 Document Feedback (1) AS7331 Functional Description TIME(1) 8 9 10 11 12 13 14 15 32x 49.80 24.90 12.45 6.23 3.11 1.56 0.78 12750.00 16x 99.61 49.80 24.90 12.45 6.23 3.11 1.56 25500.00 8x 199.22 99.61 49.80 24.90 12.45 6.23 3.11 51000.00 4x 398.44 199.22 99.61 49.80 24.90 12.45 6.23 102000.00 2x 796.88 398.44 199.22 99.61 49.80 24.90 12.45 204000.00 1x 1593.75 796.88 398.44 199.22 99.61 49.80 24.90 408000.00 TIME (TCONV) – given by CREG1:TIME = 8 … 15 dec, NCLK – number of clock cycle within conversion time TCONV, RESOL – Resolution of internal A/D conversion, GAIN = 1x given by CREG1:GAIN = 11dec up to GAIN = 2048x given by CREG1:GAIN = 0 dec (see Figure 48). Figure 31: UVC-Channel (λ = 240 nm – 280 nm) Programmable FSR and LSB of the Detectable Input Light Irradiance Ee TIME(1) 0 1 2 3 4 5 6 7 NCLK(1) 1024 2048 4096 8192 16384 32768 65536 131072 1 2 4 8 16 32 64 128 10 11 12 13 14 15 16 17 TCONV[ms](1) (1) RESOL[bit] GAIN (1) FSR [µW/cm²] of detectable irradiance Ee (channel C) 2048x 98.00(2) 49.00 1024x 196.00 98.00 512x 392.00 196.00 256x 784.00 392.00 128x 1568.00 784.00 64x 3136.00 1568.00 32x 6272.00 3136.00 16x 12544.00 6272.00 8x 25088.00 12544.00 4x 50176.00 25088.00 2x 100352.00 50176.00 1x 200704.00 100352.00 LSB [nW/cm²] – least significant bit of FSR (channel C) GAIN(1) 2048x 95.70 47.85 23.93 11.96 5.98 2.99 1.50 0.75 1024x 191.41 95.70 47.85 23.93 11.96 5.98 2.99 1.50 512x 382.81 191.41 95.70 47.85 23.93 11.96 5.98 2.99 256x 765.63 382.81 191.41 95.70 47.85 23.93 11.96 5.98 128x 1531.25 765.63 382.81 191.41 95.70 47.85 23.93 11.96 64x 3062.50 1531.25 765.63 382.81 191.41 95.70 47.85 23.93 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 36 Document Feedback (1) (2) AS7331 Functional Description TIME(1) 0 1 2 3 4 5 6 7 32x 6125.00 3062.50 1531.25 765.63 382.81 191.41 95.70 47.85 16x 12250.00 6125.00 3062.50 1531.25 765.63 382.81 191.41 95.70 8x 24500.00 12250.00 6125.00 3062.50 1531.25 765.63 382.81 191.41 4x 49000.00 24500.00 12250.00 6125.00 3062.50 1531.25 765.63 382.81 2x 98000.00 49000.00 24500.00 12250.00 6125.00 3062.50 1531.25 765.63 1x 196000.00 98000.00 49000.00 24500.00 12250.00 6125.00 3062.50 1531.25 TIME (TCONV) – given by CREG1:TIME = 0 … 7 dec, NCLK – number of clock cycle within conversion time TCONV, RESOL – Resolution of internal A/D conversion, GAIN = 1x given by CREG1:GAIN = 11 dec up to GAIN = 2048x given by CREG1:GAIN = 0 dec (see Figure 48). Basic sensitivity of the UVC-channel. Figure 32: UVC-Channel (λ = 240 nm – 280 nm) Programmable FSR and LSB of the Detectable Input Light Irradiance Ee 8 9 10 11 12 13 14 15 262144 524288 1.05E+06 2.10E+06 4.19E+06 8.39E+06 1.68E+07 1024 TCONV[s](1) 0.256 0.512 1.024 2.048 4.096 8.192 16.384 0.001 RESOL[bit](1) 18 19 20 21 22 23 24 10 TIME(1) NCLK (1) GAIN (1) FSR [µW/cm²] of detectable irradiance Ee (channel C) 2048x 24.50 12.25 6.13 3.06 1.53 0.77 0.38 98.00 1024x 49.00 24.50 12.25 6.13 3.06 1.53 0.77 196.00 512x 98.00 49.00 24.50 12.25 6.13 3.06 1.53 392.00 256x 196.00 98.00 49.00 24.50 12.25 6.13 3.06 784.00 128x 392.00 196.00 98.00 49.00 24.50 12.25 6.13 1568.00 64x 784.00 392.00 196.00 98.00 49.00 24.50 12.25 3136.00 32x 1568.00 784.00 392.00 196.00 98.00 49.00 24.50 6272.00 16x 3136.00 1568.00 784.00 392.00 196.00 98.00 49.00 12544.00 8x 6272.00 3136.00 1568.00 784.00 392.00 196.00 98.00 25088.00 4x 12544.00 6272.00 3136.00 1568.00 784.00 392.00 196.00 50176.00 2x 25088.00 12544.00 6272.00 3136.00 1568.00 784.00 392.00 100352.00 50176.00 25088.00 12544.00 6272.00 3136.00 1568.00 784.00 200704.00 1x GAIN LSB [nW/cm²] – least significant bit of FSR (channel C) (1) 2048x 0.37 0.19 0.09 0.05 0.02 0.01 0.01 95.70 1024x 0.75 0.37 0.19 0.09 0.05 0.02 0.01 191.41 512x 1.50 0.75 0.37 0.19 0.09 0.05 0.02 382.81 256x 2.99 1.50 0.75 0.37 0.19 0.09 0.05 765.63 128x 5.98 2.99 1.50 0.75 0.37 0.19 0.09 1531.25 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 37 Document Feedback (1) AS7331 Functional Description 64x 11.96 5.98 2.99 1.50 0.75 0.37 0.19 3062.50 32x 23.93 11.96 5.98 2.99 1.50 0.75 0.37 6125.00 16x 47.85 23.93 11.96 5.98 2.99 1.50 0.75 12250.00 8x 95.70 47.85 23.93 11.96 5.98 2.99 1.50 24500.00 4x 191.41 95.70 47.85 23.93 11.96 5.98 2.99 49000.00 2x 382.81 191.41 95.70 47.85 23.93 11.96 5.98 98000.00 1x 765.63 382.81 191.41 95.70 47.85 23.93 11.96 196000.00 TIME (TCONV) – given by CREG1:TIME = 8 … 15 dec, NCLK – number of clock cycle within conversion time TCONV, RESOL – Resolution of internal A/D conversion, GAIN = 1x given by CREG1:GAIN = 11 dec up to GAIN = 2048x given by CREG1:GAIN = 0 dec (see Figure 48). In the SYND mode, the maximum value of the conversion result depends on the externally controlled conversion time. This maximum achievable count is equal to OUTCONV and differs from the full-scale count achievable in CMD, CONT, and SYNS modes. The value of CREG1:TIME defines the number of clock counts during the conversion time. It defines the conversion time duration and maximal resolution of the A/D conversion. This is valid for the CONT, CMD, and SYNS modes. In the SYND mode, the value of CREG1:TIME does not have any meaning for the conversion time duration, because this time is externally defined. For values of CREG1:TIME higher than 6 dec (0110b), TCONV becomes bigger than 216, which results in A/D conversions with a higher resolution starting from 17-bit up to 24-bit. Only the least 16 significant bits are further processed and stored in the result registers. Using the implemented divider (see chapter 7.5) helps to access the upper 8-bits, too. The value of CREG1:GAIN defines the A/D converter’s gain (see Figure 48 and the FSR values in Figure 27 to Figure 32), which determines the sensor’s irradiance responsivity, Re. The values of CREG1:GAIN, of the referred tables, are only valid for a clock frequency, fCLK, of 1 MHz. For higher clock frequencies, some gain increments are not accessible. Figure 33 shows the valid gains dependent on the chosen internal system clock via CREG3:CCLK. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 38 Document Feedback AS7331 Functional Description Figure 33: Achievable GAIN for Different Internal Clock Frequencies Chosen by CREG3:CCLK CREG3:CCLK 0 1 2 3 1.024 2.048 4.096 8.192 [dec] fCLK [MHz] CREG1:GAIN [dec] Adjustable GAIN 0 2048x 1 1024x 2 512x 512x 3 256x 256x 256x 4 128x 128x 128x 5 64x 64x 64x 6 32x 32x 32x 7 16x 16x 16x 8 8x 8x 8x 9 4x 4x 4x 10 2x 2x 2x 11 1x 1x 1x 1024x 512x 256x 64x 16x 4x 1x During the measurement cycle, within the conversion time, TCONV, an input signal overdrive must be avoided - even if it occurs limited in time, related to TCONV. In this case, the input light is too much concerning the chosen irradiance responsivity, Re, of the AS7331 tolerates. An internal function of the analog conversion monitors all channels during the conversion process, in terms of the relation of input light and chosen irradiance responsivity, Re, determined via CREG1:GAIN. In case the input light of at least one of the channels is too much, the status bit STATUS:ADCOF (see Figure 55) is set to signal the problem and the chosen GAIN of the A/D converter (CREG1:GAIN) has to be decreased, to reduce the irradiance responsivity, Re, of the sensor. 7.5 Divider To expand the measurement ranges, an internally implemented divider or prescaler can be used to scale the results. This might be necessary if the resolution of the conversion is set to a value higher than 16 bits. If the digital divider is used the conversion result is downscaled according to the equation: Equation 5: 21 DIV [dec]  MRES FSREe 1 DIV [dec] Ee   2  MRES Re N CLK Where: Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 39 Document Feedback AS7331 Functional Description MRES = Digital output value of the conversion (content of output registers MRES1 to MRES3). Ee = Input light irradiance regarding the photodiode’s area within the conversion time interval. FSREe = Full Scale Range of detectable input light irradiance Ee.. Re = Irradiance responsivity (see Figure 48). NCLK = Number of clock cycles within the conversion time interval TCONV (see Figure 48). 21+DIV[dec] = Value of the divider factor respectively prescaler (CREG2:DIV = 7…0), see Figure 49. The A/D converters of the AS7331 operate with a resolution of 24 bits, but their results are only provided as 16-bit wide values. The divider allows you to read out the otherwise unavailable upper 8 bits, depending on the value of CREG2:DIV if CREG2:EN_DIV is set to “1”. Therefore, the divider acts as a feature to digitally downscale the converter gain, but with a larger fullscale range (FSR). The effective dynamic range of the device is increased without changing the conversion time. Figure 34: Relation of the Measurement Result to the Conversion Time Without Divider Respectively Prescaler 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 OUTCONV CREG2:EN_DIV = ‚0' 8 7 6 5 4 3 2 1 0 MRES 15 14 13 12 11 10 9 Figure 34 shows the width of the register for the conversion time (OUTCONV), which represents the internal resolution of the A/D conversion. Furthermore, the measurement result (MRES[1…3]) is shown, which is 16-bit wide. For all conversion times from 210 to 216, there is no need to use the divider, because OUTCONV is limited to the conversion time length. For conversion times bigger than 216, the conversion result is longer than 16-bits. Without the function of the divider, the result always contain the 16 least significant bits. The divider makes it possible to access the most significant bits by shifting the 16-bit resolution of the measurement result over the possible range of the resolution given by the conversion time register (OUTCONV). Figure 35 shows an example, where CREG2:DIV = 2 dec, and therefore the divider factor is 23. Thus, MRES corresponds to the bits 18 to 3 of register OUTCONV, making the least significant bits and the full-scale range eight times higher than if the divider is not used. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 40 Document Feedback AS7331 Functional Description Figure 35: Relation of the Measurement Result to the Conversion Time with Enabled and Set Divider 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 CREG2:EN_DIV = ‚1' CREG2:DIV = 2 dec 15 14 13 12 11 10 9 8 7 6 8 7 6 5 4 3 5 4 3 2 1 0 2 1 0 OUTCONV MRES DIV = 7 … 2 … 0 7.6 Conversion Time Measurement in SYND Mode In the case of SYND measurement mode, the conversion time is fully controlled by the external signal at the SYN pin. The relative deviation of this time to the internal clock frequency2 can produce some deviations in the conversion result. However, this time can be measured in time units of the internal system clock extended up to 24 bits. It allows for the recalculation of the measured input light more precisely (see chapter 7.4). Furthermore, the measurement result can be compensated for any deviation, which can occur in the clock frequency due to temperature or supply voltage variations. The conversion time measurement can be enabled by setting bit CREG2:EN_TM bit to “1” (see Figure 49). At the end of the conversion, the result is stored into the output register, OUTCONV, (see Figure 54) synchronously with the measurement results (MRES). The stored value follows the relation: Equation 6: OUTCONV  TCONV  f CLK The bit STATUS:OUTCONVOF of the status register (see Figure 55) shows an overflow of the conversion time counter, OUTCONV. In case it happens and the conversion is still in process, the counter, OUTCONV, starts again at 0. For the calculation of the full-scale range (FSR) see Equation 2, Equation 3, Equation 4 in chapter 7.4. 7.7 Temperature Measurement In addition to the three optical channels, a temperature measurement is done in parallel. The measurement result is available as TEMP of the output result registers. The resolution of the temperature measurement is 12 bits by a step size of 0.05 K per bit, which means 20 counts per Kelvin. The value of the chip temperature (silicon – measured in °C) is equal to: 2 The system clock is internally generated and is subject to technological tolerances, which means that clock frequencies of different devices may vary. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 41 Document Feedback AS7331 Functional Description Equation 7: TCHIP  TEMP  0.05C  66.9C In other words TEMP = 922h (2338 dec) corresponds to 50 °C as a reference point to start calculations. The temperature measurement is available in the measurement modes CONT, CMD, and SYNS. With the values of CREG1:TIME < 2 dec, the resolution of the temperature measurement is reduced, but in this case, the output value of TEMP is internally corrected. In the SYND measurement mode it is important to enable the conversion time measurement (CREG2:EN_TM = “1”) to get any result of the temperature measurement. In addition, the value of output register, OUTCONV has to be more than 212, given by the external conversion time at the SYN pin! 7.8 I2C Communication The two-wired serial interface is compatible with the fast mode I²C protocol, with a bit rate of up to 400 kbit/s. The AS7331 exclusively operates as a slave with its slave address [6:0] = (1, 1, 1, 0, 1, A1, A0). The input pins A1 and A0, which allows running four AS7331 on the same I²C bus concurrently, define the two lowest-order bits. Within the AS7331, the SCL pin of the I²C interface is realized as an input pin, where in single master applications, the I²C master could drive the SCL line with a push-pull stage. In all other cases, the requirements for bus termination using standard pull-up according to the I²C (pins SCL and SDA) should be considered - especially regarding noise environments and EMC in PCB design. For the I²C interface, the timing diagram and its timing specification, please see Figure 39 . Clock stretching is not supported by the AS7331. I²C commands towards the AS7331 take effect after the end of the I²C write cycle (I²C Stop condition). Each data transfer begins with a start (S) condition, defined by a high to low transition of SDA while SCL is high. The transfer is terminated by a stop (P) condition, which is defined by a low to high transition of SDA while SCL is high. A repeated start condition (Sr) can be generated instead of a stop condition if the transfer should be continued with a new data block. The start and repeated start conditions are functionally equivalent. Figure 36: Start and Stop Conditions of the I²C Bus SDA SCL Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 S Sr P S = START condition Sr = repeated START condition P = STOP condition 70 │ 42 Document Feedback AS7331 Functional Description After the protocol starts, the data at the SDA pin must be fully stable during the high phase of the I²C clock at the SCL pin. The change of the communication data at the SDA pin is only allowed during the low phase of the SCL clock. Figure 37: Bit – Transfer on I²C Bus data line stable; data valid change of data allowed SDA SCL Each data transfer consists of 1 byte, which has to be followed by an acknowledge bit (A) (see Figure 38). The bits arrive with the MSB first. The acknowledge signal shall be pulled low by the receiver during the high period of the ninth clock pulse while the transmitter releases the SDA line. When SDA stays high during the ninth clock pulse, the not acknowledge signal (NA) is output. After the not acknowledge signal, the master generates either a stop or a repeated start condition, depending on whether the master either wants to abort or start a new transfer. In the case of the AS7331 as a slave, a not acknowledge (NA) is only generated if the device address did not match. Figure 38: I²C Write and Read Sequences write sequence: S SLAVE ADDR. R/W A REG ADDR. A DATA A ... DATA A P 0 data transferred from slave to master A: acknowledge data transferred from master to slave S: START cond. P: STOP cond. read sequence: S SLAVE ADDR. R/W A REG ADDR. A Sr SLAVE ADDR.R/W A 0 DATA A ... DATA NA P 1 data transferred from slave to master data transferred from master to slave A: acknowledge S: START cond. P: STOP cond. NA: not acknowledge Sr: repeated START cond. short read sequence: S SLAVE ADDR. R/W A DATA A ... DATA NA P 1 data transferred from slave to master A: acknowledge data transferred from master to slave Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 S: START cond. P: STOP cond. 70 │ 43 Document Feedback 7.8.1 AS7331 Functional Description I2C Timing Characteristics Figure 39: I2C Slave Timing Characteristics of the AS7331 7.8.2 Symbol Parameter Conditions Min Typ fSCL I²C Clock Frequency at SCL. tHIGH SCL High Pulse Width. 0.6 µs tLOW SCL Low Pulse Width. 1.3 µs tR SCL and SDA Rise Time. 0.3 µs tF SCL and SDA Fall Time. 0.3 µs tHD;STA Hold Time Start Condition. 0.6 µs tSU;SDA Setup Time Start Condition. 0.6 µs tHD;DATM SDA Data Hold Time (Master). Data transfer from master to slave 0.02 µs tHD;DATS SDA Data Hold Time (Slave). Data transfer from slave to master 0.3 tSU;DAT Data Setup Time. 0.1 µs tSU;STO Setup Time Stop Condition. 0.6 µs tBUF Bus Free Time between a Stop and a Start Condition. 1.3 µs RPULLUP ≥ 820 Ω CL(SCL, SDA) ≤ 400 pF Max Unit 400 kHz 0.9 µs I2CTiming Diagrams Figure 40: I2C Slave Timing Diagram tR tF tLOW tSU;DAT SCL tHIGH tBUF tHD;DAT tSU;STA tHD;STA tSU;STO SDA S S = start condition 7.8.3 Sr Sr = repeated start condition P S P = stop condition I2C Write Protocol The start byte consists of the slave address followed by the bit R/W set to “0” for the write direction. The first byte after the start byte is always the address pointer to the internal register, which the master wants to write. When the master sends the next byte, it is stored in the internal register, Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 44 Document Feedback AS7331 Functional Description addressed by the address pointer (REG ADDR.) before. Then acknowledge is sent by the device, and it internally increments the address pointer to the next internal register address. Each next data byte, which is transferred by the master, is sequentially stored in the internal register. If the master generates a stop condition, the transfer is aborted, and a new write sequence must be started from the beginning. 7.8.4 I2C Read Protocol The start byte consists of the slave address followed by the bit R/W set to “0” for the write direction. The first byte after the start byte is always the address pointer to the internal register, which the master wants to read and acknowledge. After that, the master sends a repeated start condition and repeats the slave address but with the bit R/W reversed. An acknowledge is then sent by the slave, which starts the data transfer to the master. The first transferred byte is the content of the internal register, which was pointed by the address pointer. Then the master acknowledges each transferred byte. The internal address pointer of the AS7331 automatically increments after each transferred register, which allows a sequential read-out of the internal registers. If a not acknowledge occurs from the master, it sends the stop condition next and the transfer is finished. A shortened read sequence is also possible, as shown in Figure 53. With the default of the bit OPTREG:INIT_IDX = “1” (see Figure 53) the internal address pointer starts at register address 2h, if the Measurement state is activated (OSR:DOS = 011b). In the case the Configuration state is activated (OSR:DOS = 010b), the internal address pointer starts at register address 0h. 7.8.5 I2C Addressable Register Space Figure 41 shows the overview of the internal registers of the AS7331, which can be accessed via the I²C interface. The control register bank can only be accessed in the configuration state, and the registers are all 8 bits long. The output registers can only be accessed in the measurement state. They are read-only registers and 16 bits long, except OUTCONV, which is 24 bits long. OUTCONV is separated into two parts to fit into the output register’s structure. OUTCONV_L contains the first lower bytes, and OUTCONV_H contains the most significant byte of OUTCONV in the first byte. The second byte is 00h. The AS7331 transfers the output data registers with the least significant byte first. The output register data transfer can start at any address. If during the sequential data read the highest possible address is achieved (CREG2:EN_TM = “0”: address 4h; CREG2:EN_TM = “1”: address 6h), the internal pointer is reset to the address 2h, so that the next transferred data byte corresponds to the low byte of MRES1. However, the maximum number of output data transferred must not exceed a total number of bytes accessible if all (6 bytes if conversion time measurement (CREG2:EN_TM) is not activated, otherwise 10 bytes). The register OUTCONV is only available in case bit CREG2:EN_TM is set to “1”. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 45 Document Feedback AS7331 Functional Description Figure 41: Register Access Overview Address (1) [hex] Access in Measurement State Write Write (1 Byte) Read (2 Bytes) Read 0 OSR OSR OSR + STATUS 1 – – TEMP 2 – – MRES1 (A) 3 – – MRES2 (B) 4 – – MRES3 (C) 5 – – OUTCONV_L (2) 6 CREG1 – OUTCONV_H (2) 7 CREG2 – – 8 CREG3 – – 9 BREAK – – A EDGES – – B OPTREG – – (1) (2) 7.8.6 Access in Configuration State AGEN The 4 MSB bits of the register address are ignored. OUTCONV is only available in SYND measurement mode with bit CREG2:EN_TM = “1”. The least significant byte comes first. I2C General Procedure to Start with the AS7331 After applying the power supply voltage, the AS7331 is in the configuration state, but in the power down mode. The user can now set up the device for the application by writing the control registers. The success of the configuration can be proven by reading the control registers. Before starting a measurement, the state must be changed to the Measurement state. The last three bits (DOS) of the register OSR should be loaded with 011b. Now a conversion can be started with the measurement mode, which is selected by CREG3:MMODE. A falling slope of the output pin READY indicates the start. The rising edge at pin READY signals the end of conversion, and the measurement results can be read via I²C communication. If a new configuration should be implemented, the device’s state needs to be changed to the configuration state. Therefore the value 010b should be written into the bits OSR:DOS. This operation resets all measurement result registers to 00h, while the configuration registers keep their actual values. Afterward, the new configuration can be done. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 46 Document Feedback AS7331 Functional Description Figure 42: Example of Addressing the AS7331 to Read the Configuration Registers E8h S register address: 1110100 SLAVE ADDR. 0 R/W A 06h address CREG1 A 6h 7h 9Ch A write CREG1 CBh 8h A write CREG2 10h 9h A write CREG3 data transferred from slave to master A: acknowledge data transferred from master to slave NA: not acknowledge Ah 52h A write BREAK 01h A P write EDGES S: START cond. P: STOP cond. Sr: repeated START condition Figure 43: Example of Addressing the AS7331 to Read the Measurement Result Registers Starting at Address 4h E8h S 1110100 SLAVE ADDR. E9h 0 R/W A 04h address MRES3 data transferred from slave to master data transferred from master to slave SLAVE ADDR. 4h reg. addr.: A Sr 1 1 1 0 1 0 0 1 R/W A MRES3 read low byte A: acknowledge NA: not acknowledge A 2h MRES3 A MRES1 read high byte read low byte A MRES1 A . . . NA P read high byte P: STOP cond. The access of the result register bank with 2 byte addresses each (starting with the low byte), which is only possible within the measurement state, has a special feature (see Figure 43). After reaching the last valid result register address (4h or 6h if SYND mode is activated with CREG2:EN_TM = “1”) the next result register address is the default one, 2h, during read on. The setback of the result register address 2h in the measurement mode does not take place if an address was set above the valid addressable space. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 47 Document Feedback 8 AS7331 Register Description Register Description The device is controlled and monitored by registers accessed through the I²C interface. These registers provide device control functions and can be read to determine the device status and acquire device data. The register set is summarized below in Figure 44. The values of all registers and fields that are listed as reserved, or are not listed, must not be changed. Two-byte fields are always latched with the low byte, followed by the high byte. The “Name” column illustrates the purpose of each register by highlighting the function associated with each bit. The bits are shown from MSB (D7) to LSB (D0). The grey fields are reserved, and their values must not be changed. 8.1 Register Overview Figure 44: Register Overview Addr Name 0 OSR SS PD SW_RES DOS 2 AGEN DEVID MUT 6 CREG1 GAIN TIME 7 CREG2 8 CREG3 MMODE 9 BREAK BREAK A EDGES EDGES B OPTREG [hex] Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 EN_TM EN_DIV SB RDYOD DIV CCLK INIT_IDX 70 │ 48 Document Feedback AS7331 Register Description 8.2 Detailed Register Description 8.2.1 Operational State Register - OSR (Address 0h) Figure 45: Operational State Register Addr: 0h OSR Bit Default 7 6 Bit Name SS PD 0 1 Access Bit Description Number Function 0 Stop of measurement. 1 Start of measurement (only if DOS = MEASUREMENT). Number Function 0 Power Down state switched OFF. 1 Power Down state switched ON. RW RW Only active during write access, a read access always returns “0”. 3 SW_RES 0 RW Number Function 0 - 1 Software reset Device operational state. The OSR result of a register read process always returns 010b or 011b for the DOS bits. 2:0 DOS 010 RW Number Function 00X NOP (no change of DOS). 010 Operational state: CONFIGURATION 011 Operational state: MEASUREMENT 1XX NOP (no change of DOS). DOS switches the operational state of the AS7331 between configuration and measurement. The configuration state enables access to the control register bank (Figure 44) and no measurement takes place. The measurement access to the result registers can only be performed in the measurement Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 49 Document Feedback AS7331 Register Description state. Then any access to the control register bank (except OSR) will not be possible. If the operational state is switched back to the configuration state by DOS = 010b, the control registers will keep their values and the measurement result registers will be cleared. Any ongoing measurement will be stopped immediately. The DOS sequence, “NOP”, (00Xb or 1XXb) does not change the operational state, but the values of the other written OSR bits are effective. Setting SW_RES to “1” causes a software reset of the AS7331. A running measurement stops immediately and the AS7331 is set to the configuration state and all registers are reset to their initial values. The start of measurement is controlled by the value of bit SS. This bit is only interpreted in the measurement state. The Power Down mode is controlled by the value of the PD bit. The Power Down takes effect in both operational states: configuration and measurement. If the Power Down state is switched on while the device is in measurement state, the power down is only performed during the breaks between two conversions. Bit 0 DOS Bit 1 Bit 3 SW_RES Bit 2 Bit 4 - Bit 5 - Bit 6 PD Bit 7 SS Figure 46: Examples for Programming the Operational State Registers at Address 0h 0 1 - - 0 0 1 0 Configuration state (Power Down state switched on) 42h 0 0 - - 0 0 1 0 Configuration state (Power Down state switched off) 02h 0 0 - - 0 0 1 1 Measurement state (Power Down state switched off) 03h 1 0 - - 0 0 1 1 Measurement state and Start of measurement (Power Down state switched off) 83h 1 0 - - 0 0 0 0 Provided that Measurement state is active – Start of measurement (Power Down state switched off) 80h 0 1 - - 0 0 1 1 Measurement state (Power Down state switched on) 43h 1 1 - - 0 0 1 1 Measurement state, Start of measurement and internal startup (“overwrite” of PD = “1”) C3h 1 1 - - 0 0 0 0 Provided that Measurement state is active – Start of measurement and internal startup C0h Operational State (“overwrite” of PD = "1“) (0) (1) Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 - - 1 (0) (1) (0) Software reset 0Ah 70 │ 50 Document Feedback 8.2.2 AS7331 Register Description API Generation Register - AGEN (Address 2h) The value of this read-only register indicates the generation of the Control Register Bank. The register’s value changes whenever any formal modification is introduced to the Control Register Bank. This case indicates that the Application Programming Interface (API) has been changed. The default value for the AS7331 is 21h. Figure 47: API Generation Register Addr: 2h 8.2.3 AGEN Bit Bit Name Default Access Bit Description 7:4 DEVID 0010 RO Device ID number. 3:0 MUT 0001 RO Mutation number of Control Register Bank. Configuration Register 1 – CREG1 (Address 6h) CREG1:GAIN determines the irradiance responsivity of the sensor, which is different regarding the channels A, B, and C, and in each case regarding to the used wave length λ. Internally the A/D converter runs with different gain factors concerning the bit CREG1:GAIN (see Figure 33). CREG1:TIME controls the conversion time duration as a multiple of the internal clock periods. In case the start and end of measurement are controlled externally via the input trigger signal at the SYN pin (equal to SYND mode). CREG1:TIME does not influence the conversion time. Figure 48: Configuration Register 1 Addr: 6h CREG1 Bit Default Bit Name Access Bit Description Defines the irradiance responsivity of the AS7331. CREG1:TIME = 1010b (1024 ms) CREG3:CCLK = 00b (1 MHz) 7:4 GAIN Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 1010 Value [b] Index Channels A/B/C Full Scale Range Ee [µW/cm2] Effective LSB of FSR [nw/cm2] 0000 GAINA = 2048x 9.75 0.15 RW 70 │ 51 Document Feedback Addr: 6h CREG1 Bit Default Bit Name Access Bit Description 0001 0010 0011 0100 0101 0110 Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 AS7331 Register Description GAINB = 2048x 12.75 0.19 GAINC = 2048x 6.13 0.09 GAINA = 1024x 19.50 0.30 GAINB = 1024x 25.50 0.39 GAINC = 1024x 12.25 0.19 GAINA = 512x 39.00 0.60 GAINB = 512x 51.00 0.78 GAINC = 512x 24.50 0.37 GAINA = 256x 78.00 1.19 GAINB = 256x 102.00 1.56 GAINC = 256x 49.00 0.75 GAINA = 128x 156.0 2.38 GAINB = 128x 204.00 3.11 GAINC = 128x 98.00 1.50 GAINA = 64x 312.00 4.76 GAINB = 64x 408.00 6.23 GAINC = 64x 196.00 2.99 GAINA = 32x 624.00 9.52 GAINB = 32x 816.00 12.45 GAINC = 32x 392.00 5.98 70 │ 52 Document Feedback Addr: 6h CREG1 Bit Default Bit Name Access AS7331 Register Description Bit Description 0111 1000 1001 1010 1011 GAINA = 16x 1248.00 19.04 GAINB = 16x 1632.00 24.90 GAINC = 16x 784.00 11.96 GAINA = 8x 2496.00 38.09 GAINB = 8x 3264.00 49.80 GAINC = 8x 1568.00 23.93 GAINA = 4x 4992.00 76,17 GAINB = 4x 6528.00 99.61 GAINC = 4x 3136.00 47.85 GAINA = 2x 9984.00 152.34 GAINB = 2x 13056.00 199.22 GAINC = 2x 6272.00 95.70 GAINA = 1x 19968.00 304.69 GAINB = 1x 26112.00 398.44 GAINC = 1x 12544.00 191.41 Defines the integration time of the AS7331 measurement. Conversion time (fCLK = 1024 MHz) 3:0 TIME Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 0110 RW Value [b] Value [dec] TCONV in ms Number of clocks 0000 0 1 1024 210 0001 1 2 2048 211 0010 2 4 4096 212 0011 3 8 8192 213 0100 4 16 16384 214 70 │ 53 Document Feedback 8.2.4 Addr: 6h CREG1 Bit Default Bit Name Access AS7331 Register Description Bit Description 0101 5 32 32768 215 0110 6 64 65536 216 0111 7 128 131072 217 1000 8 256 262144 218 1001 9 512 524288 219 1010 10 1024 1048576 220 1011 11 2048 2097152 221 1100 12 4096 4194304 222 1101 13 8192 8388608 223 1110 14 16384 16777216 224 1111 15 1 1024 210 Configuration Register 2 – CREG2 (Address 7h) In general, the registers CREG2 and CREG3 define the measurement modes and additional device specific options. Figure 49: Configuration Register 2 Addr: 7h Bit 6 CREG2 Bit Name EN_TM Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 Default 1 Access Bit Description Value Function 0 In combination with SYND mode, the internal measurement of the conversion time is disabled and no temperature measurement takes place. 1 Internal measurement of the externally defined conversion time via SYN pulse in SYND mode is enabled (OUTCONV results are generated as well as temperature values for output register TEMP). RW 70 │ 54 Document Feedback Addr: 7h Bit 3 2:0 AS7331 Register Description CREG2 Bit Name EN_DIV DIV Default 0 000 Access Bit Description Value Function 0 Digital divider of the measurement result registers is disabled. 1 Digital divider of the measurement result registers is enabled (might be needed @ CREG1:TIME > 6 dec). Value Value of the divider (21+DIV[dec]) 000 21 001 22 010 23 011 24 100 25 101 26 110 27 111 28 RW RW In SYND mode, the conversion time is externally controlled via pin SYN. In that case, the bit CREG2:EN_TM enables the counting of internal clocks within the externally given conversion time, as well as the access to the output register, OUTCONV, which contains the counting result. It is possible to count several clocks up to 24 bits. In case this function is not used in SYND mode (equal to CREG2:EN_TM = “0”), no result for temperature measurement is generated and the values for the output register TEMP will not be valid. The bit CREG2:EN_DIV enables the internal prescaler, which could be interesting for conversion times more than 16-bits (CREG1:TIME ≥ 0111b) and if SYND mode is used. The value of CREG2:DIV is only valid with CREG2:EN_DIV = “1”. Then the measurement range is extended while the resolution of the 16-bit register results is reduced at the same time (see chapter 7.5). Thus, it is also possible to generate complete measurement results for conversion times from 217 to 224 system clocks (CREG1:TIME). If the chosen value of the prescaler is too small, a counter overflow could occur, which is shown by the bit STATUS:MRESOF of the result register bank. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 55 Document Feedback 8.2.5 AS7331 Register Description Configuration Register 3 – CREG3 (Address 8h) Figure 50: Configuration Register 3 Addr: 8h Bit 7:6 4 3 1:0 CREG3 Bit Name MMODE SB RDYOD CCLK Default 01 0 0 00 Access Bit Description Value [b] Function 00 CONT mode (continuous measurement). 01 CMD mode (measurement per command). 10 SYNS mode (externally synchronized start of measurement). 11 SYND mode (start and end of measurement are externally synchronized). Value [b] Function 0 Standby is switched OFF. 1 Standby is switched ON. Value [b] Function 0 Pin READY operates as Push Pull output. 1 Pin READY operates as Open Drain output. Value [b] Internal clock frequency fCLK 00 1.024 MHz 01 2.048 MHz 10 4.096 MHz 11 8.192 MHz RW RW RW RW The bits CREG3:MMODE specify the measurement mode, which should be compatible with the given application. The bit CREG3:SB controls the operational state Standby of the AS7331. In the Standby state the power consumption of the device is reduced, but the internal circuit is ready to continue after 4 µs wake-up time by switching off Standby. With bit CREG3:RDYOD the output READY pin can be changed from push-pull to open-drain behavior. The open-drain output allows running two or more AS7331 simultaneously whilst connected Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 56 Document Feedback AS7331 Register Description to one READY line with a pull-up resistor. As long as one device still measures, the READY line is active low. The internal clock frequency, fCLK, is controlled by the bits of CREG3:CCLK. Higher clock rates result in shorter conversion times for the measurement. However take care of CREG1:GAIN – with higher frequencies than 1 MHz, in some cases, the irradiance responsivity is reduced (see Figure 33). 8.2.6 BREAK Register (Address 9h) The register BREAK defines the time between two consecutive measurements of CONT, SYNS, and SYND modes. Figure 51: BREAK Register Addr: 9h Bit 7:0 8.2.7 BREAK Bit Name BREAK Default 19h Access RW Bit Description Value [dec] Function 0…255 Break time TBREAK between two measurements (except CMD mode): from 0 to 2040 μs, step size 8 μs. The value 0h results in a minimum time of 3 clocks of fCLK. EDGES Register (Address Ah) The register EDGES becomes operative in SYND mode. After a measurement was started in SYND mode, it defines the necessary number of additional falling edges at input SYN until the conversion is terminated. The value EDGES = “0” is not allowed and results in the initial value “1”. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 57 Document Feedback AS7331 Register Description Figure 52: EDGES Register Addr: Ah EDGES Bit Default 7:0 8.2.8 Bit Name EDGES Access 01h RW Bit Description Value [dec] Function 1…255 Number of SYN falling edges. Option Register - OPTREG (Address Bh) The register bit OPTREG:INIT_IDX allows to communicate via the I²C with simple masters, which do not support the I²C Repeated START condition. In this case, the start address for a read operation can only be set by complete write access with the I²C STOP condition at the end. For this kind of simple I²C master, the bit INIT_IDX has to be “0”. Then, the reading of data starts at the given index address. After each data transfer, the index address is incremented. With INIT_IDX set to “1”, each short read operation starts at the default address 2h in Measurement mode and 0h in Configuration mode. The setting of the internal read index address followed by the I²C repeated START condition, works as usual. After each data transfer, the index address is incremented. Please also see chapter 7.8.4. Figure 53: Option Register Addr: Bh OPTREG Bit Default [b] 7:1 Bit Name - Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 0111001 Access Bit Description - Reserved (Default value after power-on reset and software reset, but different, irrelevant values after changing CREG1:GAIN or CREG3:CCLK. The recommended write value is 0000000b in case of OPTREG:INIT_IDX should be changed.) 70 │ 58 Document Feedback Addr: Bh OPTREG Bit Default [b] 0 8.2.9 Bit Name INIT_IDX 1 Access AS7331 Register Description Bit Description Value [b] Function 0 Defining the index address is only possible via write sequence and not affected by I²C STOP condition, which is necessary, if the I²C master does not support the I²C Repeated START condition. 1 Each I²C STOP condition sets the internal register address to the default value. After writing an index address, it is possible to change the data direction for reading using I²C Repeated START condition. RW Output Register Bank All output result registers are 16-bit registers. The read access of the registers is only possible if the Measurement state is activated. One exception offers register OSR, which is also writable. In that case, one byte is assigned to the address 0h (see chapter 8.2.1). However, the read access of address 0h in the Measurement state results in the first byte for OSR information and the second byte for STATUS information. Figure 54: Output Result Register Bank Address(1) [hex] Access(2) Name Number of Bits Description RW OSR 8(1) Operational State Register. RO STATUS 8(1) Status Register. 1 RO TEMP 16(2) Temperature Measurement Result (0h + 12 bits for the value). 2 RO MRES1 16(2) Measurement Result A-Channel. (2) Measurement Result B-Channel. 0 3 RO MRES2 16 4 RO MRES3 16(2) Measurement Result C-Channel. 5 RO OUTCONVL 16(2) Time reference, result of conversion time measurement (least significant byte and middle byte). Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 59 Document Feedback AS7331 Register Description Address(1) [hex] Access(2) Name Number of Bits Description 6 RO OUTCONVH 16(2) Time reference, result of conversion time measurement (most significant byte and one empty byte with 00h). (1) (2) Read access of address 0h in measurement state results in a first byte for OSR information and a second byte for STATUS information. The Least Significant Byte comes first. STATUS Register (Address 0h) Figure 55: STATUS Register Addr: 0h STATUS Bit Bit Name Default Access Bit Description 7 OUTCONVOF (1)(2) - RO Digital overflow of the internal 24bit time reference OUTCONV. 6 MRESOF(2) - RO Overflow of at least one of the measurement result registers MRES1 … MRES3. RO Overflow of at least one of the internal conversion channels during the measurement (e.g. caused by pulsed light) – analog evaluation is made. RO Measurement results in the buffer registers were overwritten before they were transferred to the output result registers. A transfer takes place as part of an I²C read process of at least one register of the output register bank. RO New measurement results were transferred from the temporary storage to the output result registers. 5 4 3 ADCOF(2) LDATA(3) NDATA(4) - - - Corresponds to the inverted signal at the output pin READY. 2 NOTREADY Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 - RO Value Function 0 Measurement progress is finished or not started yet. 70 │ 60 Document Feedback Addr: 0h Bit 1 0 (1) (2) (3) (4) AS7331 Register Description STATUS Bit Name STANDBYSTATE POWERSTATE Default - - Access RO RO Bit Description 1 Measurement is in progress. Value Standby 0 OFF 1 ON Value Power Down state 0 OFF 1 ON Overflow of the internal 24-bit conversion time counter – only possible in SYND mode with externally synchronized start and stop of conversion. The status flag is generated while a measurement is in progress. It always matches to the actual results of the output register bank. A reading process of the register STATUS always resets this status flag. A reading process of the register STATUS and/or at least one result register always resets this status flag. The bit, STATUS:OUTCONVOF, shows an overflow of the 24-bit counter of the internal reference for the conversion time. This can only occur in SYND mode with CREG2:EN_TM = “1” and in case of accordingly long externally given conversion times. After a counter overflow, the counter starts again from zero. The bit, STATUS:MRESOF, shows an overflow in one or more result registers of MRES1 … MRES3. This can only happen if the conversion time is longer than 216 (CREG1:TIME = 7…15 dec), in accordance with a higher input signal. The overflowed register stops at its maximum value, FFFFh. With the bit, STATUS:ADCOF, an input signal overdrive is signalized, which could occur during the measurement cycle limited in time so that no overflow of the result registers (MRESOF) is necessarily produced. However, the measurement results are not correct in this case. To eliminate this issue, the irradiance responsivity (Re) of the sensor has to be decreased via CREG1:GAIN. The status bits, OUTCONVOF, MRESOF, and ADCOF, always correspond to the actual content of the measurement result registers MRES1…3. The bits, STATUS:LDATA and STATUS:NDATA, show the status of the measurement results. At the end of each measurement cycle, the results of the counters are stored in buffer registers. The flag NDATA is set to “1” to show the update (see Figure 56). With the start of each I²C read operation, the content of all buffer registers is transferred to the result registers. This ensures that during the I²C readout operation, the values of the result registers do not change. As long as an I²C-reading of the measurement result registers is in the process (no I²C stop condition has been sent), no further update of the measurement result registers concerning newer data of the buffer registers will happen. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 61 Document Feedback AS7331 Register Description The status bit, NDATA, is reset to “0” after reading the status register or at least one measurement result register. Figure 56: Update Time of the Status Register Bits for an Accurate Measurement and Read Behavior LDATA = ‚0' NDATA = ‚0' LDATA = ‚0' NDATA = ‚0' STATE CONFIGURATION READY LDATA = ‚0' NDATA = ‚0' LDATA = ‚0' NDATA = ‚1' MEASUREMENT 1 LDATA = ‚0' NDATA = ‚1' IDLE TCONV MEASUREMENT 2 TCONV MRES1 … MRES3 RESULTS 1 data fetch I²C activity OSR = 83h start (OSR:SS ← ‚1') IDLE RESULTS 2 data fetch start (OSR:SS ← ‚1') If the buffer registers contain new values (NDATA = “1”) and new measurement finishes before an I²C reading process occurs, the new measurement results are stored in the buffer registers. The older measurement results are overwritten. The status bit, LDATA, shown in Figure 57 indicates this. The LDATA bit is only reset to “0” by reading the status register, as it allows checking for the loss of information after multiple measurement cycles. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 62 Document Feedback AS7331 Register Description Figure 57: Update Time of the Status Register Bits, if Some Measurement Results Were Not Picked Up LDATA = ‚0' NDATA = ‚0' LDATA = ‚0' NDATA = ‚0' STATE CONFIGURATION READY LDATA = ‚0' NDATA = ‚1' MEASUREMENT 1 TCONV MRES1 … MRES3 LDATA = ‚1' NDATA = ‚1' IDLE MEASUREMENT 2 IDLE TCONV RESULTS 1 RESULTS 2 data fetch I²C activity OSR = 83h start (OSR:SS ← ‚1') start (OSR:SS ← ‚1') The status bits, STATUS:STANDBYSTATE and STATUS:POWERSTATE, always show the actual status of the internal control signals for Standby and Power Down. In both cases, it can differ from the actual set bits CREG3:SB and OSR:PD, due to the behavior of the control signals while a measurement is in process. The reading of the 16-bit values of the output result registers always starts with the least significant byte. The measurement value TEMP at address 1h is a 12-bit value, but its higher 4-bits until 16 are filled with 0h. For Measurement modes programmed with CREG1:TIME < 212, there is a TEMP result with a lower resolution. If the SYND mode is used and the OUTCONV register is set inactive by CREG2:EN_TM = “0”, any temperature measurement is not possible. In case CREG2:EN_TM is enabled (“1”), the TEMP value is only valid for conversion times with ≥ 212 internal system clocks, fCLK, represented by the OUTCONV register. Power-on reset, software-reset or return to the Configuration state resets the complete output register bank. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 63 Document Feedback 9 Application Information 9.1 Schematic AS7331 Application Information Figure 58 shows a typical application circuit. Digital and analog grounds should be routed separately onto the printed circuit board and must be connected near the device. Figure 58: Typical Application Circuit VDDA 3.3 V 100 nF 16 VDDD A0 SCL SCL 2 4 5 0Ω A B 11 C 10 AS7331 9 3 SDA SDA DIN0 SYN READY DIN1 VSSD VSSA 12 6 7 VSSA VSSA A1 SYN 8 READY 820 3.3 MΩ 13 1 VSSD 820 Controller 14 VDDD VSSA 15 REX T REXT VSSA VSSA 100 nF VDDA VDDD 3.3 V 100 nF Please make sure all the specified components within the application circuit work according to their operating range and the parameters in the data sheet. For example, voltage regulators (workspace load current, separated analog and digital, or decoupled power supplies based on a common regulator) need special treatment to avoid noise or deviations during operation. 9.2 External Components The AS7331 and its external components for references and/or power supply (e.g. reference resistor, REXT) should be placed on the same PCB side. 9.3 PCB Layout The analog supply must be placed as close as possible to the AS7331. The connection between the analog and digital grounds must be beneath (LP level) and/or near the AS7331. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 64 Document Feedback 10 AS7331 Package Drawings and Markings Package Drawings and Markings Figure 59: AS7331 OLGA16 Package Outline Drawing (1) (2) (3) (4) (5) All dimensions are in millimeters and angles are in degrees. Dimensions and tolerances conform to ASME Y14.5M-1994. N is the total number of terminals. This package contains no lead (Pb). This drawing is subject to change without notice. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 65 Document Feedback 11 AS7331 Tape & Reel Information Tape & Reel Information Figure 60: AS7331 Tape Dimensions (1) (2) All dimensions are in millimeters. Angles in degrees. This drawing is subject to change without notice. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 66 Document Feedback AS7331 Tape & Reel Information Figure 61: AS7331 Reel Dimensions (1) (2) All dimensions are in millimeters. Angles in degrees. This drawing is subject to change without notice. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 67 Document Feedback 12 AS7331 Soldering & Storage Information Soldering & Storage Information Figure 62: Solder Reflow Profile Graph Figure 63: Solder Reflow Profile Parameter Reference Average temperature gradient in preheating Device 2.5 °C/s Soak time tsoak 2 to 3 minutes Time above 217 °C (T1) t1 Max 60 s Time above 230 °C (T2) t2 Max 50 s Time above Tpeak – 10 °C (T3) t3 Max 10 s Peak temperature in reflow Tpeak 260 °C Temperature gradient in cooling Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 Max −5 °C/s 70 │ 68 Document Feedback 13 AS7331 Revision Information Revision Information ● ● Document Status Product Status Definition Product Preview Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Preliminary Datasheet Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Datasheet Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams-OSRAM AG standard warranty as given in the General Terms of Trade Datasheet (discontinued) Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams-OSRAM AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs Changes from previous version to current revision v1-00 Page Initial production version all Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. Correction of typographical errors is not explicitly mentioned. Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 69 Document Feedback 14 AS7331 Legal Information Legal Information Copyrights & Disclaimer Copyright ams-OSRAM AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams-OSRAM AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams-OSRAM AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams-OSRAM AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams-OSRAM AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams-OSRAM AG for each application. This product is provided by ams-OSRAM AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams-OSRAM AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams-OSRAM AG rendering of technical or other services. RoHS Compliant & ams Green Statement RoHS Compliant: The term RoHS compliant means that ams-OSRAM AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories plus additional 4 substance categories (per amendment EU 2015/863), including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br/Cl): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) and do not contain Chlorine (Cl not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams-OSRAM AG knowledge and belief as of the date that it is provided. ams-OSRAM AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams-OSRAM AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams-OSRAM AG and ams-OSRAM AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Headquarters Please visit our website at www.ams.com ams-OSRAM AG Buy our products or get free samples online at www.ams.com/Products Tobelbader Strasse 30 Technical Support is available at www.ams.com/Technical-Support 8141 Premstaetten Provide feedback about this document at www.ams.com/Document-Feedback Austria, Europe For sales offices, distributors and representatives go to www.ams.com/Contact Tel: +43 (0) 3136 500 0 For further information and requests, e-mail us at ams_sales@ams.com Datasheet • PUBLIC DS001047 • v1-00 • 2022-Oct-27 70 │ 70
AS7331_M OLGA16 LF T&RDP 价格&库存
很抱歉,暂时无法提供与“AS7331_M OLGA16 LF T&RDP”相匹配的价格&库存,您可以联系我们找货
