LY CN5M-FAGB-36-3B5A-140-R18 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
SFH 4717AS A01
SFH 4717AS A01
OSLON ® Black
OSLON Black Series (850 nm) - 50°
Applications
—Driver Monitoring / Seat Occupancy Detection
—Gesture Recognition
—Eye Tracking
—Safety and Security, CCTV
Features:
—Package: diffuse silicone
—Corrosion Robustness Class: 3B
—Qualifications: The product qualification test plan is based on the guidelines of AEC-Q101-REV-C,
Stress Test Qualification for Automotive Grade Discrete Semiconductors.
—ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
—IR lightsource with high efficiency
—Double stack emitter
—Low thermal resistance (Max. 9 K/W)
—Centroid wavelength 850 nm
—Optimized for high current pulse operation
Ordering Information
Type
Radiant intensity 1)2)
IF = 1 A; tp = 10 ms
Ie
Not for new design
SFH 4717AS A01
1 Version 1.5 | 2022-01-18
710 ... 1400 mW/sr
typ.
Ie
1,000 mW/sr
Ordering Code
Q65112A1518
SFH 4717AS A01
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Values
Operating temperature
Top
min.
max.
-40 °C
125 °C
Storage temperature
Tstg
min.
max.
-40 °C
125 °C
Junction temperature
Tj
max.
145 °C
Forward current
IF
max.
1500 mA
Forward current pulsed
tp ≤ 450 µs; D ≤ 0.005
IF pulse
max.
5A
Reverse voltage 3)
VR
max.
1V
Reverse current 3)
IR
max.
200 mA
Power consumption
Ptot
max.
5.5 W
ESD withstand voltage
VESD
max.
2 kV
For the forward current and power consumption please see “maximum permissible forward current” diagram
Not for new design
2 Version 1.5 | 2022-01-18
SFH 4717AS A01
Characteristics
IF = 1000 mA; tp = 10 ms; TA = 25 °C
Parameter
Symbol
Peak wavelength
λpeak
typ.
860 nm
Centroid wavelength
λcentroid
typ.
850 nm
Spectral bandwidth at 50% Irel,max (FWHM)
∆λ
typ.
30 nm
Half angle
φ
typ.
25 °
Dimensions of active chip area
LxW
typ.
1 x 1
mm x mm
Rise time (10% / 90%)
IF = 5 A; RL = 50 Ω
tr
typ.
10 ns
Fall time (10% / 90%)
IF = 5 A; RL = 50 Ω
tf
typ.
15 ns
Forward voltage 4)
VF
min.
typ.
max.
2.8 V
3.0 V
3.3 V
Forward voltage 4)
IF = 1.5 A; tp = 100 µs
VF
min.
typ.
max.
2.9 V
3.05 V
3.55 V
Forward voltage 4)
IF = 5 A; tp = 100 µs
VF
min.
typ.
max.
3.2 V
3.5 V
4.4 V
Reverse voltage 3)
IR = 20 mA
VR
max.
1.2 V
Reverse voltage (ESD device) 3)
VR ESD
min.
5V
Ie
typ.
1480 mW/sr
Φe
typ.
1230 mW
Total radiant flux 5)
Φe
typ.
1820 mW
Temperature coefficient of voltage
TCV
typ.
-2 mV / K
Temperature coefficient of wavelength
TCλ
typ.
0.3 nm / K
Thermal resistance junction solder point real 6)
RthJS real
typ.
max.
6.0 K / W
9.0 K / W
Not for new design
IF = 1 A; tp = 100 µs
3 Version 1.5 | 2022-01-18
Values
SFH 4717AS A01
Brightness Groups
TA = 25 °C
Group
min.
Ie
max.
Ie
EA
710 mW/sr
900 mW/sr
EB
900 mW/sr
1120 mW/sr
FA
1120 mW/sr
1400 mW/sr
Only one group in one packing unit (variation lower 1.6:1).
Relative Spectral Emission
7), 8)
Ie,rel = f (λ); IF = 1000 mA; tp = 10 ms
OHF04132
100
I rel %
80
60
40
Not for new design
750
800
850
nm 950
λ
4 Version 1.5 | 2022-01-18
SFH 4717AS A01
Radiation Characteristics
7), 8)
Ie,rel = f (φ)
φ[ ]
-20°
-10°
0° 10° 20° 30° 40° 50° 60° 70° 80° 90°
1.0
-30°
0.9
-40°
0.8
-50°
0.7
0.6
-60°
0.5
0.4
-70°
0.3
0.2
-80°
0.1
-90°
0.0
Forward current
Relative Total Radiant Flux
7), 8)
IF = f (VF); single pulse; tp = 100 µs
Φe/Φe(1000mA) = f (IF); single pulse; tp = 100 µs
Φ
5
Φ
1
0.5
7), 8)
5
1
0.5
0.1
0.1
0.05
0.05
Not for new design
0.01
0.01
2.6
2.8
3.0
3.2
0.005
0.01
3.4
5 Version 1.5 | 2022-01-18
0.05
0.5 1
5
SFH 4717AS A01
7)
Φe = f (TA)
Φ
1.4
Φ
1.2
1.0
0.8
0.6
-40 -20 0
20 40 60 80 100 120
Max. Permissible Forward Current
Permissible Pulse Handling Capability
IF,max = f (TS); Rthjs = 9K / W
IF = f (tp); duty cycle D = parameter; TS = 85°C
IF
OHF05690
2.0
A
1.5
5
4
3
1.0
2
:D=1
: D = 0,5
: D =0,2
: D =0,1
: D =0,05
: D =0,02
: D =0,01
: D =0,005
0.5
Not for new design
1
50
75
100
˚C 150
TS
6 Version 1.5 | 2022-01-18
0 -5
10 10-4 10-3 0.01 0.1
1
10 100
SFH 4717AS A01
Dimensional Drawing
9)
Further Information:
Approximate Weight:
31.0 mg
Package marking:
Cathode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
ESD advice:
The device is protected by ESD device which is connected in parallel to the
Chip.
Not for new design
7 Version 1.5 | 2022-01-18
SFH 4717AS A01
Recommended Solder Pad
9)
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
Not for new design
8 Version 1.5 | 2022-01-18
SFH 4717AS A01
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
3
100
120
2
3
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
Not for new design
60
2
Unit
10
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
9 Version 1.5 | 2022-01-18
°C
480
s
K/s
s
SFH 4717AS A01
Taping
9)
Not for new design
10 Version 1.5 | 2022-01-18
SFH 4717AS A01
Tape and Reel
10)
Reel Dimensions
A
180 mm
W
Nmin
12 + 0.3 / - 0.1 mm
Not for new design
11 Version 1.5 | 2022-01-18
W1
60 mm
W2 max
12.4 + 2 mm
18.4 mm
Pieces per PU
600
SFH 4717AS A01
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
9)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Not for new design
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
12 Version 1.5 | 2022-01-18
SFH 4717AS A01
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Not for new design
13 Version 1.5 | 2022-01-18
SFH 4717AS A01
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Not for new design
14 Version 1.5 | 2022-01-18
SFH 4717AS A01
Glossary
1)
Radiant intensity: Measured at a solid angle of Ω = 0.01 sr
2)
Brightness: The brightness values are measured with a tolerance of ±11%.
3)
Reverse Operation: This product is intended to be operated applying a forward current within the
specified range. Applying any continuous reverse bias or forward bias below the voltage range of light
emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED.
4)
Forward Voltage: The forward voltages are measured with a tolerance of ±0.1 V.
5)
Total radiant flux: Measured with integrating sphere.
6)
Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g.
metal block)
7)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
8)
Testing temperature: TA = 25°C (unless otherwise specified)
9)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
10)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Not for new design
15 Version 1.5 | 2022-01-18
SFH 4717AS A01
Revision History
Version
Date
Change
1.3
2019-10-25
Description
Characteristics
Brightness Groups
Electro - Optical Characteristics (Diagrams)
Glossary
1.4
2021-09-21
Derating (Diagrams)
1.5
2022-01-18
Not for new design
Not for new design
16 Version 1.5 | 2022-01-18
SFH 4717AS A01
Not for new design
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
17 Version 1.5 | 2022-01-18
