NANOBERRY_MONO_EK
NANOBERRY_MONO_EK
    AMSOSRAM(艾迈斯半导体)
    NanEyeC - 图像传感器 评估板 - 传感器
NANOBERRY_MONO_EK 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 SFH 4727AS   SFH 4727AS OSLON ® Black OSLON Black Series (940 nm) - 50° Applications ——Access Control (IRIS/Vein Scan, Face Recognition) ——Industrial Automation (Machine Controls, Light Barriers, Vision Controls) ——CCTV Surveillance ——Safety and Security, CCTV ——Eye Tracking Features: ——Package: diffuse silicone ——Corrosion Robustness Class: 3B ——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) ——IR lightsource with high efficiency ——Double stack emitter ——Low thermal resistance (Max. 9 K/W) ——Centroid wavelength 940 nm  ——Optimized for high brightness DC operation Ordering Information  Type Radiant intensity  1)2) IF = 1 A; tp = 10 ms Ie Radiant intensity 1) typ. IF = 1 A; tp = 10 ms Ie Ordering Code 900 ... 1400 mW/sr 1,150 mW/sr Q65112A1144 SFH 4727AS R33 900 ... 1400 mW/sr 1,150 mW/sr Q65113A3207  SFH 4727AS 1 Version 1.2 | 2021-04-09 SFH 4727AS   Maximum Ratings TA = 25 °C Parameter Symbol Values Operating temperature Top min. max. -40 °C 125 °C Storage temperature Tstg min. max. -40 °C 125 °C Junction temperature Tj max. 145 °C Forward current IF max. 1500 mA Surge current tp ≤ 800 µs; D = 0.005  IFSM max. 3A Reverse current 3) IR max. 200 mA Power consumption Ptot max. 5.4 W ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD max. 2 kV For the forward current and power consumption please see “maximum permissible forward current” diagram   2 Version 1.2 | 2021-04-09 SFH 4727AS   Characteristics IF = 1000 mA; tp = 10 ms; TA = 25 °C Parameter Symbol Peak wavelength λpeak typ. 950 nm Centroid wavelength λcentroid typ. 940 nm Spectral bandwidth at 50% Irel,max (FWHM) ∆λ typ. 37 nm Half angle φ typ. 25 ° Dimensions of active chip area LxW typ. 1 x 1 mm x mm Rise time (10% / 90%) IF = 3 A; RL = 50 Ω tr typ. 12 ns Fall time (10% / 90%) IF = 3 A; RL = 50 Ω tf typ. 15 ns Forward voltage 4) VF typ. max. 2.9 V 3.4 V Forward voltage 4) IF = 1.5 A; tp = 100 µs VF typ. max. 3.05 V 3.6 V Forward voltage 4) IF = 3 A; tp = 100 µs VF typ. max. 3.5 V 4.2 V Reverse voltage 3) IR = 20 mA VR max. 1.2 V Reverse voltage (ESD device) 3) VR ESD min. 5V Radiant intensity  1) IF = 1.5 A; tp = 100 µs Ie typ. 1720 mW/sr Φe typ. 1340 mW Φe typ. 1990 mW Temperature coefficient of voltage TCV typ. -2 mV / K Temperature coefficient of brightness TCI typ. -0.3 % / K Temperature coefficient of wavelength TCλ typ. 0.3 nm / K Thermal resistance junction solder point real 6) RthJS real typ. max. 5.5 K / W 9.0 K / W Total radiant flux 5) IF = 1 A; tp = 100 µs   Total radiant flux 5) IF = 1.5 A; tp = 100 µs 3 Version 1.2 | 2021-04-09 Values SFH 4727AS   Brightness Groups  TA = 25 °C Group Radiant intensity 1)2) IF = 1000 mA; tp = 10 ms min. Ie Radiant intensity 1)2) IF = 1000 mA; tp = 10 ms max. Ie EB 900 mW/sr 1120 mW/sr FA 1120 mW/sr 1400 mW/sr Only one group in one packing unit (variation lower 1.6:1). Relative Spectral Emission 7), 8) Ie,rel = f (λ); IF = 1000 mA; tp = 10 ms OHF04133 100 I rel %  80 60 40 20 0 800 850 900 950 nm 1050  λ 4 Version 1.2 | 2021-04-09 SFH 4727AS   Radiation Characteristics 7), 8) Ie,rel = f (φ) φ[ ] -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° 0,9 -40° 0,8 -50° 0,7 0,6 -60° 0,5 0,4 -70° 0,3 0,2 -80° 0,1 -90° 0,0 Forward current Relative Total Radiant Flux 7), 8) IF = f (VF); single pulse; tp = 100 µs 7), 8) Φe/Φe(1000mA) = f (IF); single pulse; tp = 100 µs Φ [ ] Φ 1 0.5  1 0.5 0.1 0.1 0.05 0.05 0.01 0.01 2.4 2.6 2.8 3.0 3.2 3.4  [ ] 5 Version 1.2 | 2021-04-09 0.01 0.05 0.1 0.5 1 [ ] SFH 4727AS   Max. Permissible Forward Current Permissible Pulse Handling Capability IF,max = f (TS); Rthjs = 9K / W IF = f (tp); D = parameter; TS = 85°C [ ] [ ] 1400 3 1200 1000 2 800 600 1 :D=1 : D = 0,5 : D =0,2 : D =0,1 : D =0,05 : D =0,02 : D =0,01 : D =0,005 400 200 0 0 20 40 60   6 Version 1.2 | 2021-04-09 80 100 120 [ ] 0 -5 10 10-4 10-3 0.01 0.1 1 10 100 [ ] SFH 4727AS   Dimensional Drawing 9) Further Information: Approximate Weight: 31.0 mg Package marking: Cathode Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43) ESD advice: The device is protected by ESD device which is connected in parallel to the Chip.   7 Version 1.2 | 2021-04-09 SFH 4727AS   Recommended Solder Pad 9) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning.   8 Version 1.2 | 2021-04-09 SFH 4727AS   Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 9 Version 1.2 | 2021-04-09 °C 480 s K/s s SFH 4727AS   Taping 9)   10 Version 1.2 | 2021-04-09 SFH 4727AS   Tape and Reel 10) Reel Dimensions A W Nmin W1 W2 max Pieces per PU 180 mm 12 + 0.3 / - 0.1 mm 60 mm 12.4 + 2 mm 18.4 mm 600 330 mm 12 + 0.3 / - 0.1 mm 60 mm 12.4 + 2 mm 18.4 mm 3000   11 Version 1.2 | 2021-04-09 SFH 4727AS   Barcode-Product-Label (BPL) Dry Packing Process and Materials 9) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 12 Version 1.2 | 2021-04-09 SFH 4727AS   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   13 Version 1.2 | 2021-04-09 SFH 4727AS   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   14 Version 1.2 | 2021-04-09 SFH 4727AS   Glossary 1) Radiant intensity: Measured at a solid angle of Ω = 0.01 sr 2) Brightness: The brightness values are measured with a tolerance of ±11%. 3) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 4) Forward Voltage: The forward voltages are measured with a tolerance of ±0.1 V. 5) Total radiant flux: Measured with integrating sphere. 6) Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g. metal block) 7) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Testing temperature: TA = 25°C (unless otherwise specified) 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   15 Version 1.2 | 2021-04-09 SFH 4727AS   Revision History Version Date Change 1.0 2019-09-05 Initial Version 1.1 2020-08-26 Schematic Transportation Box Dimensions of Transportation Box 1.2 2021-04-09 Ordering Information Reel Dimensions   16 Version 1.2 | 2021-04-09 SFH 4727AS     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 17 Version 1.2 | 2021-04-09
NANOBERRY_MONO_EK 价格&库存
很抱歉,暂时无法提供与“NANOBERRY_MONO_EK”相匹配的价格&库存,您可以联系我们找货
