acam-messelectronic gmbH
is now
Member of the
ams Group
The technical content of this acam-messelectronic document is still valid.
Contact information:
Headquarters:
ams AG
Tobelbader Strasse 30
8141 Premstaetten, Austria
Tel: +43 (0) 3136 500 0
e-Mail: ams_sales@ams.com
Please visit our website at www.ams.com
Time-to-Digital Converter
Target Specification
TDC-GP2
2-channel Universal
26th May 2010
Document-No.: DB_GP2_e V2.0
TDC
TDC-GP2
Published by acam-messelectronic gmbh
acam-messelectronic gmbh 2010
Disclaimer / Notes
The information provided by this data sheet is believed to be accurate and reliable. However, no
responsibility is assumed by acam for its use, nor for any infringements of patents or other rights
of third parties that may result from its use. The information is subject to change without notice
and is provided „as is“ without warranty of any kind (expressed or implied). Picostrain is a registered
trademark of acam. All other brand and product names in this document are trademarks or service
marks of their respective owners.
Support
For a complete listing of direct sales, distributors and sales representatives visit the acam website
at:
http://www.acam.de/company/distributors
For technical support you can contact the acam support team in the headquarter in Germany or the
Distributor in your country. The contact details of acam in Germany are:
sales@acam.de
1
or by phone
+49-7244-74190.
acam-messelectronic gmbh - Am Hasenbiel 27 - D-76297 Stutensee-Blankenloch - Germany - www.acam.de
TDC-GP2
Table of Contents
1-4
1 Overview
2 Characterisitcs &
Specifications
2.1 Electrical Characteristics
2-1
2.2 Timings
2-3
2.3 Pin Description
2-6
2.4 Package Drawings
2-7
2.5 Power Supply
2-8
2.6 Register settings
3 Measurement Mode 1
4 Measurement Mode 2
5 Details and Special Functions
2-10
3.1 General Description
3-1
3.2 Measurement Flow
3-2
4.1 General Descriptionweis
4-1
4.2 Measurement Flow
4-2
4.3 Stop Masking
4-7
5.1 Oscillator
5-1
5.2 Fire-pulse Generator
5-4
5.3 Temperature Measurement
5-7
5.4 SPI-interface
5-10
5.5 Fast Initialization
5-11
5.6 Noise Unit
5-11
6 Applications
6-1
7 Miscellaneous
7-1
2
Time-to-Digital-Converter
3
TDC-GP2
TDC-GP2
1
Overview
1.1
Introduction
TDC-GP2 is the next generation of acam generalpurpose TDCs. Higher resolution and smaller package size make it ideal for cost sensitive industrial applications. With special functional blocks like a
fire-pulse generator, stop-enable, temperature measurement, and clock control it is perfectly suited
for ultrasonic flow-meter and heat-meter applications.
1.2
Features
Measurement Mode 1
2 channels with typ. 50 ps resolution rms
2 or 4 sensors
Measurement range 3.5 ns to 1.8 µs (0 to
PT500/PT1000 or higher
1.8µs
between stop channels)
15 ns pulse-pair resolution with 4-fold multihit
capability
Very high resolution: 16 Bit eff.
(0.004 °C resolution for platinum sensors)
Ultra low current (0.08 µA when measuring
4 events can be measured arbitrarily against
every 30 seconds)
each other
Trigger to rising or/and falling edge
General
Windowing for precise stop enable
QFN 32 package
I/O voltage 1.8 V to 5.5 V
Measurement Mode 2
Core voltage 1.8 V to 3.6 V
1 channel with typ. 50 ps resolution rms
1 MHz continuous data rate max.
Measurement range 500 ns to 4 ms
Temperature range – 40 °C to 125 °C
2 x CLKHS pulse-pair resolution with 3-fold
4 wire SPI interface
multihit capability
Fire pulse generator
Clock calibration unit
Each of the 3 events can be assigned to an
Precise stop enable by windowing
adjustable measuring window with 10ns reso-
Trigger to rising and/or falling edge
lution
1-4
1.3
1-5
TDC-GP2
Blockdiagram
TDC-GP2
2
Characterisitcs & Specifications
2.1
Absolute Maximum Ratings
Supply voltage
Vcc vs. GND
- 0.3 to 4.0 V
Vio vs. GND
- 0.3 to 7.0 V
Continous current into Output-Pin (Iout)
30 mA
Storage temperature (Tstg)
- 65 to 150 °C
Junction temperature (Tj)
max.125 °C
Recommended Operating Conditions
Symbol
Parameter
Conditions
Min
Vcc
Core supply voltage*
Vio > Vcc
Vio
I/O supply voltage
tri
Max
Unit
1.8
3.6
V
1.8
5.5
V
Normal Input Rising Time
50
ns
tfa
Normal Input Falling Time
50
ns
tri
Schmitt Trigger Rising Time
5
ms
tfa
Schmitt Trigger Falling Time
5
ms
Ta
Ambient Temperature
120
°C
Tj must not exceed
Typ
-40
125°C
*including the oscillator pins XIN, XOUT, Clk32In, Clk32Out
DC Characteristics (Vio = Vcc = 3.3 V ± 0.3 V, Tj = -40 to +85°C)
Symbol
Parameter
Conditions
I32
Current 32 kHz
Icc + Iio, only 32kHz os-
Min
Typ
Max
Unit
4.5
µA
260
µA
15
mA
0: -> Error routine
Send SO = 0xB0, Read SI = RES_0
Send SO = 0xB1, Read SI = RES_1
Send SO = 0xB2, Read SI = RES_2
Send SO = 0xB3, Read SI = RES_3
Rhot/Rref = RES_0/RES_1
Rcold/Rref = RES_3/RES_2
Go to look-up table to get the temperatures
6-3
6.1.4
TDC-GP2
Current consumption
a. Time measurement
32.768kHz: are provided by the µP: < 1.3 µA
4 MHz:
0 µA in power down, 270 µA when active
TDC:
< 150 nA if not active, 15 mA during active time of the high-speed unit
With 2 measurements per second (forth and back flow) the total consumption is < 3 µA.
b. Temperature measurement
A full measurement over all four ports takes less than 2.5 µAs current. Typically the temperature is
measured once in 30 seconds. The average current then is about 0.085 µA. This is about 50 times
less than with solutions without a TDC.
c. Quiescent current
Thanks to the current optimized 0.35µ technology the quiescent current is less than 150 nA typ.
d. Total system current
The complete current for the measuring unit (TDC, analog part, Transducer) will depend on the analog circuit part. It will be in the range of 4 to 6 µA.
With a low-power µP (e.g. MSP430 series from TI) the average current consumption of the total
device might be in the range of 11 to 16 µA.
It is possible to operate the system from a lithium-thionylchloride AA cell for 10 years without changing the battery. At 6 years runtime it maybe even possible to work with a low-cost 3V CR2450 coin
cell battery.
6-4
TDC-GP2
7
Miscellaneous
7.1
Bug Report
7.1.1
Quartz Oscillator Start Up time
Bug:
When using a quartz resonator for the oscillator the oscillation start up time is about
3 ms even with an optimized circuit. The TDC-GP2‘s automatic on-time control for the
high speed clock is based on 640 µs or 1280 µs delay without any activity. In case of a
quartz resonator this delay is too short and will cause malfunction.
Corrective: There are several options to deal with.
1.Oscillator permanently on
The possibility of switching off the high speed oscillator is added only for current saving. This oscillator needs about 270 µA when running continuously. In all application
without attention to current consumption we recommend to run the high speed oscillator continuously (START_CLKHS=1).
2.Ceramic Resonator
With a ceramic resonator the oscillation start up time is about 200 µs. There is no
problem with TDC-GP2‘s internal delays. We recommend the use of ceramic resonators in all applications targeting ratio measurements (like ultrasonic flow metering).
In all applications that need a quartz resonator and the switch-off functionality we recommend the following measures:
3.Lower Clock Frequency at CLK32In
A clock with lower frequency increases the internal timer delays. In this case we recommend about 4 kHz. The timer delay is increased to 10 ms then. This is enough for a
save oscillation start up time of the quartz.
4.Start/Stop Oscillator by Software
Writing a „1“ or „0“ into Start_CLKHS starts or stops the oscillator by software. This
way a µP can start the oscillator by command and then after 10 ms can send a measurement opcode like START_CYCLE. At the end of the measurement the µP has to
switch off the oscillator by a further command.
7-1
7.1.2
Bug:
TDC-GP2
DIS_PHASENOISE
The TDC-GP2 offers a Phase-Noise function that decouples the calibration clock from
the fire pulse generator. This option was implemented to provide the necessary statistics for averaging in case the user is looking for a resolution much better than 1 LSB
(about 65 ps) and has a a very strong coupling between the start and the reference
clock.
Because of a design bug the phase noise unit might fail in case of distortions on the
power supply. This is relevant only in measurement range 2.
Corrective: The phase noise unit has to be switched off by setting DIS_PHASE_NOISE = 1. In case
the start is already asynchronous to the referenceclock this has no effect on the capability of averaging.
7.2
Last Changes
05.10.2006
3.2.1b&c, 5.1.3, DIS_PHASENOISE=1 required
27.11.2006
5.2.2 Additional corrections
3.2.1 Corrections Example
01.02.2007
5.3 Additional corrections for temp. measurement
26.05.2010
Various smaller error fixes. General layout change
7-2
TDC-GP2
7-3
Data Sheet
Am Hasenbiel 27
Germany / Allemagne
ph. +49 7244 7419 - 0
fax +49 7244 7419 - 29
e-mail: support@acam.de
www.acam.de
很抱歉,暂时无法提供与“TDC-GP2 T&R 2K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+99.797352000+12.94863
