TMD27123M
TMD27123M
    AMSOSRAM(艾迈斯半导体)
    SMD6模块
    光学传感器 环境,手势 940nm I²C 6-SMD 模块
TMD27123M 数据手册
TMD2712 ALS + Proximity Sensor Module General Description The TMD2712 features proximity detection and digital ambient light sensing (ALS). The extremely tiny 1mm x 2mm module incorporates an IR VCSEL and factory calibrated VCSEL driver. The proximity detection feature provides object detection (e.g. mobile device screen to user’s ear) by photodiode detection of reflected IR energy (sourced by the integrated VCSEL). Detect/release events are interrupt driven, and occur when proximity result crosses upper and/or lower threshold settings. The proximity engine features a wide range offset adjustment to compensate for unwanted IR energy reflection at the sensor. Proximity results are further improved by automatic ambient light subtraction. The ALS and IR photodiodes have dedicated data converters producing 16-bit data. This architecture allows applications to accurately measure ambient light which enables devices to calculate illuminance to control display backlight. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of TMD2712, ALS + Proximity Sensor Module are listed below: Figure 1: Added Value of Using TMD2712 Benefits Features • Optimized for narrow bezel mobile phones • Tiny 1mm x 2mm x 0.5mm module • Reduced power consumption • 1.8V power supply with 1.8V I²C bus • Sleep mode (0.7μA) • VCSEL IR emitter • Enabled superior proximity detection • Integrated factory calibrated 940nm IR VCSEL • Crosstalk and ambient light cancellation • Wide configuration range • Accurate ambient light sensing • High sensitivity • 2 channels (photopic ALS + IR) • Programmable gain and integration time • Industrial design flexibility • Offset emitter/detector package design ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 1 Document Feedback TMD2712 − General Description Applications The TMD2712 applications include: • Mobile phone display management • Mobile phone and wearable user proximity detection • Wearable ambient light measurement Block Diagram The functional blocks of this device are shown below: Figure 2: Functional Blocks of TMD2712 940nm IR VCSEL VDD3 Open Drain Current Sink Lower Proximity Integration IR Prox ADC Prox Data GND Upper Prox Thresholds Proximity Control I2 C Interface SCL SDA ALS Control Photopic CH0 ADC CH0 Data ALS Thresholds CH1 ADC CH1 Data Lower Upper IR Interrupt Open Drain Output INT VDD Page 2 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Pin Assignments Pin Assignments Figure 3: Pin Diagram (Top View) ,17 9'' *1' 6&/ 9'' 6'$ Figure 4: Pin Description of TMD2712 Pin Number Pin Name Description 1 INT Interrupt. Open drain output (active low). If INT is not used, tie to GND for enhanced ESD protection. 2 GND Ground. All voltages are referenced to GND. 3 VDD3 Supply voltage for IR emitter (3.0/3.3V) 4 SDA I²C serial data I/O terminal 5 SCL I²C serial clock input terminal 6 VDD Supply voltage for sensor (1.8V). To enable the device to recover from a high voltage ESD strike, it is recommended to connect VDD to a host GPIO pin for independent power control. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 3 Document Feedback TMD2712 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD Supply Voltage to GND -0.3 1.98 V VDD3 IR Emitter Voltage to GND -0.3 3.6 V VIO Digital I/O Terminal Voltage -0.3 3.6 V IIO Digital Output Terminal Current -1 20 mA Electrostatic Discharge Input Current (latch-up immunity) ± 100 mA ESDHBM HBM Electrostatic Discharge ± 2000 V JEDEC/ESDA JS-001-2017 ESDCDM CDM Electrostatic Discharge ± 500 V JEDEC JS-002-2014 ISCR Class II JEDEC JESD78E Temperature Ranges and Storage Conditions TSTRG Storage Temperature Range -40 85 °C TBODY Package Body Temperature 260 °C RHNC Relative Humidity (non-condensing) 85 % PDISS Power Dissipation 50 mW MSL Moisture Sensitivity Level Page 4 Document Feedback 3 IPC/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” Average power dissipation over a 1 second period Maximum floor life time of 168h ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 6: Recommended Operating Conditions Symbol Parameter Min Typ Max Unit VDD Supply Voltage to Sensor 1.7 1.8 1.98 V VDD3 Supply Voltage to IR Emitter 2.9 3.3 3.6 V Operating Ambient Temperature -30 85 °C TA Note(s): 1. While the device is operational across the temperature range, performance will vary with temperature. Operational characteristics are at 25°C, unless otherwise noted. Figure 7: Operating Characteristics, VDD = 1.8V, TA = 25°C (unless otherwise noted) Symbol fOSC IDD Parameter Conditions Oscillator frequency Supply current Min Typ Max Unit 7.9 8.1 8.3 MHz Active Proximity State (PON=1) (2) 345 Active ALS State (PON=1) (2) 80 Idle State (PON=1) (3) 35 Sleep State (PON = 0) (4) 0.6 (1) μA VOL INT, SDA output low voltage ILEAK Leakage current, SDA, SCL, INT -5 VIH SCL, SDA input high voltage (5) 1.26 VIL SCL, SDA input low voltage TActive 6mA sink current Time from power-on to ready to receive I²C commands 0.6 V 5 μA V 0.54 1.5 V ms Note(s): 1. Values are shown at the VDD pin and do not include current through the IR VCSEL emitter. 2. Active state occurs when PON =1 and the device is actively integrating either proximity or ALS. For proximity, this time is determined by the number of pulses (PPLUSE) and the pulse length (PULSE_LEN). For ALS, this time is determined by the ALS integration time (ATIME). Both proximity and ALS active states can occur at the same time. 3. Idle state occurs when PON=1 and the device is not in the active state. 4. Sleep state occurs when PON = 0 and I²C bus is idle. If sleep state has been entered as the result of operational flow, SAI = 1, PON will remain high. 5. Digital pins: SDA, SCL, INT are tolerant to a communication voltage up to 3.4V ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 5 Document Feedback TMD2712 − Electrical Characteristics Figure 8: ALS Optical Characteristics (VDD = 1.8V, TA = 25°C unless otherwise noted) Parameter Conditions Min Typ Max Unit CH0 ALS sensitivity Warm White LED @ 8μW/cm2 AGAIN = 128x ATIME = 100ms -15% 1113 +15% Counts CH1 ALS sensitivity 940nm LED @ 21.1μW/cm2 AGAIN = 128x ATIME = 100ms -20% 375 +20% Counts 2.68 2.78 2.90 ms 0 1 2 Counts ALS integration step size ALS CH0 / CH1 dark count 0μW/cm2 AGAIN = 1024x ATIME = 50ms ALS 16x gain scaling Relative to 128x 0.125 x ALS 1024x gain scaling Relative to 128x 8.2 x ALS noise (1) AGAIN = 128x ATIME = 100ms 0.05 % (σ) Note(s): 1. Representative result by characterization. Page 6 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Electrical Characteristics Figure 9: Proximity Optical Characteristics (VDD = 1.8V, VDD3 = 3.0V, TA = 25°C unless otherwise noted) Parameter Conditions Response: absolute (1) PGAIN1 = 1x; PGAIN2 = 10x PLDRIVE = 8mA PPULSE = 4 pulses PPULSE_LEN = 34μs HW Averaging = 8 BINSRCH_TARGET = 15 APC = disabled Post Calibration Target material: 18% reflective surface No glass above module Target Size: 100mm x 100mm Target Distance: 30mm Part to Part Variation (3) Same as Response: absolute except target is 51mm diameter diffusor Response: no target (2) Same as Response: absolute except no target Min Typ Max 120 4 14 Unit Counts ±25 % 30 Counts Note(s): 1. Representative result by characterization. 2. Response with no target varies with power supply characteristics and system noise. 3. At factory final test. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 7 Document Feedback TMD2712 − Typical Operating Characteristics Typical Operating Characteristics Figure 10: ALS Average Angular Response to 2700K White LED (pin 1 [-90°] to pin 3 [90°]) Angular Response to 2700K White LED (pin 1 [-90°] to pin 3 [90°]) 1 0.9 ALS Channel (CH0) Response (normalized to 0°) 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -70 -50 -30 -10 10 30 50 70 90 Angle of Incidence (degrees) Figure 11: ALS Average Angular Response to 2700K White LED (pin 6 [90°] to pin 1 [-90°]) Angular Response to 2700K White LED (pin 6 [+90°] to pin 1 [-90°]) 1 0.9 ALS Channel (CH0) Response (normalized to 0°) 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -70 -50 -30 -10 10 30 50 70 90 Angle of Incidence (degrees) Page 8 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Typical Operating Characteristics Figure 12: Spectral Responsivity Spectral Response 1 0.9 Response (normalized to ALS channel) ALS Channel (CH0) 0.8 IR Channel (CH1) Photopic 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 300 400 500 600 700 800 900 1000 1100 Wavelength (nm) Figure 13: Illuminance (Lux) vs Counts (ALS Channel (CH0)) Dynamic Range (ATIME = 100ms) 10000 1000 Illuminance (lux) 100 10 16x 1 128x 1024x 0.1 0.01 0.001 1 10 100 1000 10000 100000 ALS Channel (CH0) [counts] ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 9 Document Feedback TMD2712 − Detailed Description Detailed Description Proximity Proximity results are affected by three fundamental factors: the integrated IR VCSEL emission, IR reception, and environmental factors, including target distance and surface reflectivity. The IR reception signal path begins with IR detection from a photodiode and ends with the 14-bit proximity result in PDATA register. Signal from the photodiode is amplified, and offset adjusted to optimize performance. Offset correction or cross-talk compensation is accomplished by adjustment to the POFFSET register. The analog circuitry of the device applies the offset value as a subtraction to the signal accumulation; therefore a positive offset value has the effect of decreasing the results. Ambient Light Sensing, ALS The ALS reception signal path begins as photodiodes receive filtered light and ends with 16-bit results. Channel 0 contains a photopic filter and channel 1 contains an infrared (IR) filter which is used both for the proximity function and also to accurately measure ambient light levels. Signals from both photodiodes are simultaneously accumulated for a period of time set by the value in ATIME before the results are available. Gain is adjustable by either 128x or 1024x to facilitate operation over a wide range of lighting conditions under dark glass with low transmissivity. Based on the optical glass used on top of the device, custom equations are empirically derived to calculate the amount of ambient light using the ALS results. Page 10 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Detailed Description Operational State Diagram Figure 14: Operational State Diagram SLEEP (PON = 0) IDLE (PON = 1) PEN = 1 AEN = 1 ALS ACTIVE1 Hardware Averaging Loop 2 to 16 Times Update CH0/1 DATA Y Y SAI (if enabled) Proximity ACTIVE2 PWTIME (if enabled) Wait Time Complete PRATE SAI (if enabled) Y PROX_AVG (if enabled) Update PDATA AWTIME (if enabled) IDD Supply Current Sleep Idle Active Note(s): 1. ALS active time = ALS integration time (ATIME) 2. Proximity active time = (7 x PULSE_LEN) + PPULSE x (2x PULSE_LEN + 22μs) + 78.75μs. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 11 Document Feedback TMD2712 − Detailed Description I²C Characteristics The device uses I²C serial communication protocol for communication. The device supports 7-bit chip addressing and both standard and fast clock frequency modes with a chip address of 0x39. Read and write transactions comply with the standard set by Philips (now NXP). Internal to the device, an 8-bit buffer stores the register address location of the desired byte to read or write. This buffer auto-increments upon each byte transfer and is retained between transaction events (i.e. valid even after the master issues a STOP command and the I²C bus is released). During consecutive Read transactions, the future/repeated I²C Read transaction may omit the memory address byte normally following the chip address byte; the buffer retains the last register address + 1. I²C Write Transaction A Write transaction consists of a START, CHIP-ADDRESS WRITE, REGISTER-ADDRESS, DATA BYTE(S), and STOP. Following each byte (9 th clock pulse) the slave places an ACKNOWLEDGE/ NOT-ACKNOWLEDGE (ACK/NACK) on the bus. If NACK is transmitted by the slave, the master may issue a STOP. I²C Read Transaction A Read transaction consists of a START, CHIP-ADDRESS WRITE, REGISTER-ADDRESS, START, CHIP-ADDRESS READ, DATA BYTE(S), and STOP. Following all but the final byte the master places an ACK on the bus (9 TH clock pulse). Termination of the Read transaction is indicated by a NACK being placed on the bus by the master, followed by STOP. Alternately, if the previous I²C transaction was a Read, the internal register address buffer is still valid, allowing the transaction to proceed without “re”-specifying the register address. In this case the transaction consists of a START, CHIP-ADDRESS READ, DATA BYTE(S), and STOP. Following all but the final byte the master places an ACK on the bus (9 th clock pulse). Termination of the Read transaction is indicated by a NACK being placed on the bus by the master, followed by STOP. The I²C bus protocol was developed by Philips (now NXP). For a complete description of the I²C protocol, please review the NXP I²C design specification at: http://www.i2c-bus.org/references/ Page 12 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Detailed Description Timing Diagrams Figure 15: I²C Timing Diagrams ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 13 Document Feedback TMD2712 − Register Description Register Description Figure 16: Register Overview Reset Value Address Register Name R/W 0x80 ENABLE R/W Enables states and interrupts 0x00 0x81 ATIME R/W ADC integration time 0x00 0x82 PRATE R/W Proximity time 0x1F 0x83 AWTIME R/W ALS wait time 0x00 0x84 AILTL R/W ALS interrupt low threshold low byte 0x00 0x85 AILTH R/W ALS interrupt low threshold high byte 0x00 0x86 AIHTL R/W ALS interrupt high threshold low byte 0x00 0x87 AIHTH R/W ALS interrupt high threshold high byte 0x00 0x88 PILTL R/W Proximity interrupt low threshold low byte 0x00 0x89 PILTH R/W Proximity interrupt low threshold high byte 0x00 0x8A PIHTL R/W Proximity interrupt high threshold low byte 0x00 0x8B PIHTH R/W Proximity interrupt high threshold high byte 0x00 0x8C PERS R/W ALS and proximity interrupt persistence filters 0x00 0x8D CFG0 R/W Configuration zero 0x58 0x8E PCFG0 R/W Proximity configuration zero 0x8F 0x8F PCFG1 R/W Proximity configuration one 0x32 0x90 PCFG2 R/W Proximity configuration two 0x20 0x91 REVID R Revision ID 0x00 0x92 ID R Device ID 0x64 0x93 CFG1 R/W Configuration one 0x68 0x94 STATUS R, SC Device status 0x00 0x95 ALSL R ALS (CH0) low data 0x00 0x96 ALSH R ALS (CH0) high data 0x00 0x97 IRL R IR (CH1) low data 0x00 0x98 IRH R IR (CH1) high data 0x00 0x99 PDATAL R Proximity ADC low data 0x00 0x9A PDATAH R Proximity ADC high data 0x00 Page 14 Document Feedback Register Function ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description Register Function Reset Value Address Register Name R/W 0xA6 REVID2 R 0xA8 SOFTRST R/W Soft reset 0x00 0xA9 PWTIME R/W Proximity wait time 0x00 0xAA CFG8 R/W Configuration eight (must be set to 0x29) 0x2A 0xAB CFG3 R/W Configuration three 0x01 0xAE CFG6 R/W Configuration six 0x3F 0xC0 POFFSETL R/W Proximity offset low data 0x00 0xC1 POFFSETH R/W Proximity offset high data 0x00 0xD7 CALIB R/W Proximity offset calibration 0x00 0xD8 CALIB_OFFSET R/W Proximity offset extension 0x00 0xD9 CALIBCFG R/W Proximity offset calibration control 0x50 0xDC CALIBSTAT R Proximity offset calibration status 0x00 0xDD INTENAB R/W Interrupt enables 0x00 0xE6 FAC_L R Factory data low 0x00 to 0xFF 0xE7 FAC_H R Factory data high 0x00 to 0xFF 0xF9 TEST9 R/W Revision ID two Test nine (must be set to 0x06) 0x00 or 0x0F 0x0C Note(s): 1. R = Read Only / W = Write Only / R/W = Read or Write / SC = Self Clearing after access. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 15 Document Feedback TMD2712 − Register Description Detailed Register Description Enable Register (Address 0x80) Figure 17: Enable Register Addr: 0x80 Enable Bit Bit Name Default Access Bit Description 7:5 Reserved 0 RW Reserved. Must be set to default value. 4 PWEN 0 RW This bit activates the proximity wait feature which is set by the PWTIME register. Active high. (1) 3 AWEN 0 RW This bit activates the ALS wait feature which is set by the AWTIME register. Active high. 2 PEN 0 RW This bit activates the proximity detection. Active high. 1 AEN 0 RW This bit actives the ALS function. Active high. 0 PON 0 RW This field activates the internal oscillator and ADC channels. Active high. Note(s): 1. When the ALS function is enabled (AEN = 1), this bit must be set to a one (PWEN = 1). Before activating AEN or PEN, preset each applicable operating mode registers and bits. Page 16 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description ATIME Register (Address 0x81) Figure 18: ATIME Register Addr: 0x81 Bit Bit Name ATIME Default Access Bit Description The ATIME value specifies the ALS integration time in 2.78ms intervals. 0x00 indicates 2.78ms. The maximum ALS count value depends on the integration time. For every 2.78ms, the maximum value increases by 1024. This means that to be able to reach ALS full scale, the integration time has to be at least 64*2.78ms. 7:0 ATIME 0x00 RW Value Integration Cycles Integration Time Maximum ALS Value 0x00 1 2.78ms 1023 0x01 2 5.56ms 2047 0x11 18 50.0ms 18431 0x23 36 100ms 36863 0x3F 64 178ms 65535 0xFF 256 712ms 65535 The ATIME register controls the integration time of the ALS ADCs. The timer is implemented with a down counter with 0x00 as the terminal count. The timer is clocked at a 2.78ms nominal rate. Loading 0x00 will generate a 2.78ms integration time, loading 0x01 will generate a 5.56ms integration time, and so forth. PRATE Register (Address 0x82) Figure 19: PRATE Register Addr: 0x82 PRATE Bit Bit Name Default Access 7:0 PRATE 0x1F RW ams Datasheet, Confidential [v1-01] 2020-Aug-27 Bit Description This register defines the duration of 1 Prox Sample, which is (PRATE + 1)*88μs. Page 17 Document Feedback TMD2712 − Register Description AWTIME Register (Address 0x83) Figure 20: AWTIME Register Addr: 0x83 Bit Bit Name AWTIME Default Access Bit Description Value that specifies the wait time in 2.78ms increments. 7:0 AWTIME 0x00 Value Increments Wait Time 0x00 1 2.78ms (33.4ms) 0x01 2 5.56ms (66.7ms) 0x11 18 50.0ms (600ms) 0x23 36 100ms (1.20s) 0x3F 64 178ms (2.14s) 0xFF 256 712ms (8.54s) RW The wait timer is implemented using a down counter. Wait time = Increment x 2.78ms. If AWLONG is enabled then Wait time = Increment x 2.78ms x 12. AILTL Register (Address 0x84) Figure 21: AILTL Register Addr: 0x84 AILTL Bit Bit Name Default Access Bit Description 7:0 AILTL 0x00 RW This register sets the low byte of the LOW ALS threshold. AILTH Register (Address 0x85) Figure 22: AILTH Register Addr: 0x85 AILTH Bit Bit Name Default Access 7:0 AILTH 0x00 RW Page 18 Document Feedback Bit Description This register sets the high byte of the LOW ALS threshold. ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description The ALS (CH0) channel is compared against low-going 16-bit threshold value set by AILTL and AILTH. The contents of the AILTH and AILTL registers are combined and treated as a sixteen bit threshold value. If the value generated by the ALS channel (CH0) is below the AILTL/H threshold and the APERS value is reached, the AINT bit is asserted. If AIEN is set, then the INT pin will also assert. When setting the 16-bit ALS threshold AILTL must be written first, immediately followed by AILTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 16-bit value. AIHTL Register (Address 0x86) Figure 23: AIHTL Register Addr: 0x86 AIHTL Bit Bit Name Default Access 7:0 AIHTL 0x00 RW Bit Description This register sets the low byte of the HIGH ALS threshold. AIHTH Register (Address 0x87) Figure 24: AIHTH Register Addr: 0x87 AIHTH Bit Bit Name Default Access 7:0 AIHTH 0x00 RW Bit Description This register sets the high byte of the HIGH ALS threshold. The ALS (CH0) channel is compared against high-going 16-bit threshold value set by AIHTL and AIHTH. The contents of the AIHTH and AIHTL registers are combined and treated as a sixteen bit threshold value. If the value generated by the ALS channel (CH0) is above the AIHTL/H threshold and the APERS value is reached, the AINT bit is asserted. If AIEN is set, then the INT pin will also assert. When setting the 16-bit ALS threshold AIHTL must be written first, immediately followed by AIHTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 16-bit value. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 19 Document Feedback TMD2712 − Register Description PILTL Register (Address 0x88) Figure 25: PILTL Register Addr: 0x88 Bit 7:0 Bit Name PILTL PILTL Default 0x00 Access Bit Description RW This register contains the low byte of the 14-bit proximity LOW threshold when APC is enabled. If APC is disabled, this register contains the LOW threshold which is an 8-bit value which is compared against the upper 8-bits of the 10-bit proximity value. PILTH Register (Address 0x89) Figure 26: PILTH Register Addr: 0x89 PILTH Bit Bit Name Default Access Bit Description 7:6 Reserved 00 RW Reserved. Must be set to default value. 5:0 PILTH 0x00 RW This register contains the upper 6 bits of the 14-bit proximity LOW threshold when APC is enabled. If APC is disabled, this register is ignored. The contents of the PILTH and PILTL registers are combined and treated as a fourteen (14) bit threshold low value. If the value generated by the proximity ADC (PDATA) is below the PILTL/H threshold and the PPERS value is reached, then the low proximity threshold is breached. When setting the 14-bit proximity threshold, PILTL must be written first, immediately follow by PILTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 14-bit value. If Automatic Pulse Control (APC) is disabled by setting bit 6 in CFG6 to 1, then the proximity data converts to a 10-bit value. PILTL contains an 8-bit threshold which is compared against the upper 8-bits of the 10-bit value. PILTH is ignored. Page 20 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description PIHTL Register (Address 0x8A) Figure 27: PIHTL Register Addr: 0x8A Bit 7:0 Bit Name PIHTL PIHTL Default 0x00 Access Bit Description RW This register contains the low byte of the 14-bit proximity HIGH threshold when APC is enabled. If APC is disabled, this register contains the HIGH threshold which is an 8-bit value which is compared against the upper 8-bits of the 10-bit proximity value. PIHTH Register (Address 0x8B) Figure 28: PIHTH Register Addr: 0x8B PIHTH Bit Bit Name Default Access Bit Description 7:6 Reserved 00 RW Reserved. Must be set to default value. 5:0 PIHTH 0x00 RW This register contains the upper 6 bits of the 14-bit proximity HIGH threshold when APC is enabled. If APC is disabled, this register is ignored. The contents of the PIHTH and PIHTL registers are combined and treated as a fourteen (14) bit threshold high value. If the value generated by the proximity ADC (PDATA) is above the PIHTL/H threshold and the PPERS value is reached, then the high proximity threshold is breached. When setting the 14-bit proximity threshold, PIHTL must be written first, immediately follow by PIHTH. Internally, the lower 8-bits are buffered until the upper 8-bits are written. As the upper 8-bits are written both the high and low bytes are simultaneously latched as a 14-bit value. If Automatic Pulse Control (APC) is disabled by setting bit 6 in CFG6 to 1, then the proximity data converts to a 10-bit value. PIHTL contains an 8-bit threshold which is compared against the upper 8-bits of the 10-bit value. PIHTH is ignored. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 21 Document Feedback TMD2712 − Register Description PERS Register (Address 0x8C) Figure 29: PERS Register Addr: 0x8C Bit Bit Name PERS Default Access Bit Description This register sets the proximity persistence filter. 7:4 PPERS 0 (0000) Value Interrupt 0 (0000) Every proximity cycle 1 (0001) Any value outside proximity thresholds 2 (0010) 2 consecutive proximity values out of range 3 (0011) 3 consecutive proximity values out of range … …. 15 (1111) 15 consecutive proximity values out of range RW This register sets the ALS persistence filter. 3:0 APERS 0 (0000) RW 0 (0000) Every ALS cycle 1 (0001) Any value outside ALS thresholds 2 (0010) 2 consecutive ALS values out of range 3 (0011) 3 consecutive ALS values out of range 4 (0100) 5 consecutive ALS values out of range 5 (0101) 10 consecutive ALS values out of range 6 (0110) 15 consecutive ALS values out of range 7 (0111) 20 consecutive ALS values out of range … … 13 (1101) 50 consecutive ALS values out of range 14 (1110) 55 consecutive ALS values out of range 15 (1111) 60 consecutive ALS values out of range The frequency of consecutive proximity channel results outside of threshold limits are counted; this count value is compared against the PPERS value. If the counter is equal to the PPERS value an interrupt is asserted. Any time a proximity channel result is inside the threshold values the counter is cleared. Page 22 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description The frequency of consecutive ALS (CH0) channel results outside of threshold limits are counted; this count value is compared against the APERS value. If the counter is equal to the APERS setting an interrupt is asserted. Any time an ALS (CH0) channel result is inside the threshold values the counter is cleared. CFG0 Register (Address 0x8D) Figure 30: CFG0 Register Addr: 0x8D CFG0 Bit Bit Name Default Access 7:3 Reserved 01011 RW Reserved. Must be set to default value. 2 PWLONG 0 RW When PWLONG (PROX Wait Long) is asserted the wait period as set by PWTIME is increased by a factor of 12. 1 AWLONG 0 RW When AWLONG (ALS Wait Long) is asserted the wait period as set by AWTIME is increased by a factor of 12. 0 Reserved 0 RW Reserved. Must be set to default value. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Bit Description Page 23 Document Feedback TMD2712 − Register Description PCFG0 Register (Address 0x8E) Figure 31: PCFG0 Register Addr: 0x8E Bit Bit Name PCFG0 Default Access Bit Description This field along with the PGAIN2 bits in the CFG1 register, sets the gain of the proximity IR sensor. 7:6 PGAIN1 2 (10) RW Value Stage 1 Gain 0 (00) 1x 1 (01) 2x 2 (10) 4x 3 (11) 8x Maximum number of pulses in a single proximity cycle. 5:0 PPULSE 15 (001111) RW Value Maximum Number of Pulses 0 (000000) 1 1 (000001) 2 2 (000010) 3 … … 63 (111111) 64 The PPULSE field sets the maximum number of IR VCSEL pulses that may occur in a proximity cycle. The proximity engine will automatically continue to add IR VCSEL pulses, up to the value set in PPULSE or if a near-saturation condition occurs if Automatic Pulse Control (APC) is enabled. The dynamic range of the sensor is automatically adjusted to detect distant targets as well as prevent saturation from close targets. This operation also reduces power consumption because proximity integration period is automatically shortened when a target is close to the sensor. If Automatic Pulse Control (APC) is disabled by setting bit 6 in CFG6 to 1, then PPULSE always determines the number of proximity pulses to be transmitted. Page 24 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description PCFG1 Register (Address 0x8F) Figure 32: PCFG1 Register Addr: 0x8F PCFG1 Bit Bit Name Default Access Bit Description 7:6 PPULSE_ LENH 00 RW These bits are the 2 most significant bits of the 10-bit Pulse Length control setting. The lower 8 bits are in the PCFG2 register. See the PCFG2 register for details. 5:4 Reserved 11 RW Reserved. Must be set to default value. This field sets the drive strength of the IR VCSEL current. Values are approximate; actual current through the VCSEL is factory trimmed to normalize IR intensity. For lowest part to part variation, 8mA is recommended. 3:0 PLDRIVE 2 (0010) RW Value VCSEL Current 5 (0101) 7mA 6 (0110) 8mA 7 (0111) 9mA 8 (1000) 10mA All other values Reserved PCFG2 Register (Address 0x90) Figure 33: PCFG2 Register Addr: 0x90 Bit Bit Name PCFG2 Default Access Bit Description These bits are the 8 least significant bits of the 10-bit Pulse Length control setting. The upper 2 bits are in the PCFG1 register. The minimum pulse length is 4μs. 7:0 PPULSE_LENL 0x20 RW Value Pulse Length 3 (0000000011) 4μs 32 (0000100000) 33μs Pulse Length = (PULSE_LEN + 1) μs 1023 (1111111111) ams Datasheet, Confidential [v1-01] 2020-Aug-27 1024μs Page 25 Document Feedback TMD2712 − Register Description REVID Register (Address 0x91) Figure 34: REVID Register Addr: 0x91 REVID Bit Bit Name Default Access Bit Description 7:3 Reserved 00000 RO Reserved. 2:0 REV_ID 000 RO Device revision number. ID Register (Address 0x92) Figure 35: ID Register Addr: 0x92 ID Bit Bit Name Default Access 7:2 ID 011001 RO Device type identification. 1:0 Reserved 00 RO Reserved Page 26 Document Feedback Bit Description ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description CFG1 Register (Address 0x93) Figure 36: CFG1 Register Addr: 0x93 CFG1 Bit Bit Name Default Access 7 Reserved 0 RW Bit Description Reserved. Must be set to default value. This field along with the PGAIN1 bits in the PCFG0 register, sets the gain of the proximity IR sensor. For optimal noise performance, PGAIN2 = 5x is recommended. 6:5 PGAIN2 3 (11) RW Value Stage 2 Gain 0 (00) 2.5x 1 (01) 5x 2 (10) Reserved 3 (11) 10x This field sets the gain of the ALS sensor. 4:0 AGAIN ams Datasheet, Confidential [v1-01] 2020-Aug-27 8 (01000) Value ALS Gain 5 (00101) 16x 8 (01000) 128x 11 (01011) 1024x All other values Reserved RW Page 27 Document Feedback TMD2712 − Register Description STATUS Register (Address 0x94) Figure 37: STATUS Register Addr: 0x94 STATUS Register Bit Bit Name Default Access Bit Description 7 ASAT 0 R, SC Analog saturation flag signals that the ALS results may be unreliable due to saturation of the AFE. 6 PSAT 0 R, SC Proximity saturation flag indicates that an ambient- or reflective-saturation event occurred during a previous proximity cycle. 5 PINT 0 R, SC Proximity interrupt flag indicates that proximity results have exceeded thresholds and persistence settings. 4 AINT 0 R, SC ALS interrupt flag indicates that ALS results (CH0) have exceeded thresholds and persistence settings. 3 CINT 0 R, SC Calibration interrupt flag indicates that calibration has completed. 2 ZINT 0 R, SC Zero detection interrupt flag indicates that a zero value in PDATA has caused the proximity offset to be decremented (if AUTO_OFFSET_ADJ = 1). 1 PSAT_REFLECTIVE 0 R, SC The Reflective Proximity Saturation Interrupt flag signals that the AFE has saturated during the IR VCSEL active portion of proximity integration. 0 PSAT_AMBIENT 0 R, SC The Ambient Proximity Saturation Interrupt flag signals that the AFE has saturated during the IR VCSEL inactive portion of proximity integration. All flags in this register can be cleared by setting the bit high. Alternatively, if the INT_READ_CLEAR in the CFG3 register bit is set, then simply reading this register automatically clears all eight flags. ALSL Register (Address 0x95) Figure 38: ALSL Register Addr: 0x95 ALSL Bit Bit Name Default Access 7:0 ALSL 0x00 RO Page 28 Document Feedback Bit Description This register contains the low byte of the 16-bit ALS channel (CH0) data. ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description ALSH Register (Address 0x96) Figure 39: ALSH Register Addr: 0x96 ALSH Bit Bit Name Default Access 7:0 ALSH 0x00 RO Bit Description This register contains the high byte of the 16-bit ALS channel (CH0) data. IRL Register (Address 0x97) Figure 40: IRL Register Addr: 0x97 IRL Bit Bit Name Default Access 7:0 IRL 0x00 RO Bit Description This register contains the low byte of the 16-bit IR channel (CH1) data. IRH Register (Address 0x98) Figure 41: IRH Register Addr: 0x98 IRH Bit Bit Name Default Access 7:0 IRH 0x00 RO Bit Description This register contains the high byte of the 16-bit IR channel (CH1) data. PDATAL Register (Address 0x99) Figure 42: PDATAL Register Addr: 0x99 Bit 7:0 Bit Name PDATAL ams Datasheet, Confidential [v1-01] 2020-Aug-27 PDATAL Default 0x00 Access RO Bit Description This register contains the low byte of the 14-bit proximity ADC data when APC is enabled. If APC is disabled, this register contains the upper 8 most significant bits of the 10-bit proximity value. Page 29 Document Feedback TMD2712 − Register Description PDATAH Register (Address 0x9A) Figure 43: PDATAH Register Addr: 0x9A Bit 7:0 Bit Name PDATAH PDATAH Default Access 0x00 Bit Description This register contains the high byte of the 14-bit proximity ADC data when APC is enabled. If APC is disabled, bits 1:0 contain the lower 2 bits of the 10-bit proximity value. RO Proximity data is stored as a 14-bit value (two bytes). Reading the low byte first latches the high byte. Proximity detection uses an Automatic Pulse Control (APC) mechanism that adjusts the number of pulses per measurement based on the magnitude of the reflected IR signal. As the magnitude of the signal increases, the number of pulses decreases. Proximity detection uses a 10-bit ADC that is extended to a 14-bit dynamic range for PDATA using the following formula: PDATA = ADC value x (16 / actual number of pulses transmitted) PDATA is therefore proportional to the reflected energy independent of the number of pulses transmitted. If Automatic Pulse Control (APC) is disabled by setting bit 6 in CFG6 to 1, then the proximity data converts to a 10-bit value. PDATAL contains the 8 most significant bits of the 10-bit value and PDATAH bit locations 1:0 contain the lower 2-bits. When APC is disabled, only the upper 8-bits are compared against the threshold values contained in PILTL and PIHTL. REVID2 Register (Address 0xA6) Figure 44: REVID2 Register Addr: 0xA6 REVID2 Bit Bit Name Default Access 7:4 Reserved 0000 R Reserved. 3:0 VER_ID 0000 or 1111 R Device version number. Page 30 Document Feedback Bit Description ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description SOFTRST Register (Address 0xA8) Figure 45: SOFTRST Register Addr: 0xA8 SOFTRST Bit Bit Name Default Access 7:2 Reserved 0 RW Reserved. Must be set to default value. RW Writing a 1 to this bit will cause a power on reset. This will immediately terminate all device operation and put the device into the sleep state. RW Writing a 1 to this bit will cause all registers to be reset to their default state. This will immediately terminate all device operation and put the device into the sleep state. 1 POR 0 SOFTRST 0 0 Bit Description PWTIME Register (Address 0xA9) Figure 46: PWTIME Register Addr: 0xA9 Bit Bit Name PWTIME Default Access Bit Description Value that specifies the wait time in 2.78ms increments. 7:0 PWTIME 0x00 Value Increments Wait Time 0x00 1 2.78ms (33.4ms) 0x01 2 5.56ms (66.7ms) 0x11 18 50.0ms (600ms) 0x23 36 100ms (1.20s) 0x3F 64 178ms (2.14s) 0xFF 256 712ms (8.54s) RW The wait timer is implemented using a down counter. Wait time = Increment x 2.78ms. If PWLONG is enabled then Wait time = Increment x 2.78ms x 12. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 31 Document Feedback TMD2712 − Register Description CFG8 Register (Address 0xAA) Figure 47: CFG8 Register Addr: 0xAA CFG8 Bit Bit Name Default Access 7:0 Reserved 0x2A RW Bit Description Reserved. Must be set to 0x29. CFG3 Register (Address 0xAB) Figure 48: CFG3 Register Addr: 0xAB CFG3 Bit Bit Name Default Access Bit Description 7 INT_READ_CLEAR 0 RW If set, then flag bits in the STATUS register will be reset whenever the STATUS register is read over I²C. 6:5 Reserved 0 RW Reserved. Must be set to default value. The Sleep After Interrupt bit is used to place the device into a low power mode upon an interrupt pin assertion. 4 3:0 SAI Reserved 0 0001 RW RW PON SAI INT Oscillator 0 X X OFF 1 0 X ON 1 1 1 ON 1 1 0 OFF Reserved. Must be set to default value. The SAI bit sets the device operational mode following the completion of an ALS or proximity cycle. If AINT and AIEN are both set or if PINT and PIEN are both set, causing an interrupt on the INT pin, and the SAI bit is set, then the oscillator will deactivate. The device will appear as if PON = 0, however, PON will read as 1. The device can only be reactivated (oscillator enabled) by clearing the interrupts in the STATUS register. Page 32 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description CFG6 Register (Address 0xAE) Figure 49: CFG6 Register Addr: 0xAE CFG6 Bit Bit Name Default Access Bit Description 7 Reserved 0 RW Reserved. Must be set to default value. 6 APC_ DISABLE 0 RW Proximity automatic pulse control (APC) disable. 0 = APC enable 1 = APC disable 5:0 Reserved 111111 RW Reserved. Must be set to default value. POFFSETL Register (Address 0xC0) Figure 50: POFFSETL Register Addr: 0xC0 POFFSETL Bit Bit Name Default Access 7:0 POFFSETL 0x00 RW Bit Description This register contains the magnitude portion of proximity offset adjust value. POFFSETH Register (Address 0xC1) Figure 51: POFFSETH Register Addr: 0xC1 POFFSETH Bit Bit Name Default Access Bit Description 7:1 Reserved 0 RW Reserved. Must be set to default value. 0 POFFSETH 0 RW This register contains the sign portion of proximity offset adjust value. Typically, optical and/or electrical crosstalk negatively influence proximity operation and results. The POFFSETL/POFFSETH registers provide a mechanism to remove system crosstalk from the proximity data. POFFSETL and POFFSETH contains the magnitude and sign of a value which adjusts PDATA is generated in the AFE. An offset value in the range of ± 255 is possible. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 33 Document Feedback TMD2712 − Register Description CALIB Register (Address 0xD7) Figure 52: CALIB Register Addr: 0xD7 Bit Bit Name CALIB Default Access Bit Description 7 CALAVG 0 RW Enables proximity hardware averaging as selected with PROX_AVG during calibration. 0 = No hardware averaging 1 = Hardware averaging enabled 6 Reserved 0 RW Reserved. Must be set to default value. 5 ELECTRICAL_ CALIBRATION 0 RW Selects proximity calibration type. 0 = Electrical and optical crosstalk. 1 = Electrical crosstalk only. 4 CALPRATE 0 RW Enables PRATE during calibration. Useful when averaging is enabled. 0 = PRATE ignored 1 = PRATE applied between averaging samples 3:1 Reserved 0 RW Reserved. Must be set to default value. 0 START_OFFSET_CAL 0 RW Set to 1 to start a calibration sequence. Proximity response in systems with electrical and optical crosstalk may be improved by using the calibration feature. Optical crosstalk is caused when the photodiode receives a portion of the VCSEL IR which was unintentionally reflected by a surface other than the target. Electrical offset is caused by electrical disturbance in the sensor AFE, and also influences the proximity result. The calibration routine adjusts the value in POFFSETL/H until the proximity result is as close to the binary search target as possible. Optical and electrical calibration function identically, except that during an electrical calibration the proximity photodiode is disconnected from the AFE. An electrical calibration can be initiated anytime by setting the ELECTRICAL_CALIBRATION and START_OFFSET_CAL bits. To perform an optical (and electrical) calibration do not set the ELECTRICAL_CALIBRATION bit when setting the START_ OFFSET_CALIB. The CINT flag will assert after calibration has finished. Upon completion proximity offset registers are automatically loaded with calibration result. Page 34 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description CALIB_OFFSET Register (Address 0xD8) Figure 53: CALIB_OFFSET Register Addr: 0xD8 CALIB_OFFSET Bit Bit Name Default Access 7:6 Reserved 0 RW Reserved. Must be set to default value. 5 EN_RANGE_ EXTENSION RW Setting this bit to a 1 enables the proximity offset range extension functionality. See the OFFSET_RANGE_ EXTENSION bits. If this bit is set to 0, the offset range extension is disabled. 0 Bit Description Offset range extension selection. 4:0 OFFSET_ RANGE_ EXTENSION 0 (00000) Value Selection 0 (00000) Nominal 1 (00001) Nominal + 1 Step 2 (00010) Nominal + 2 Steps 3 (00011) Nominal + 3 Steps RW Nominal + (Value) Steps 31 (11111) Nominal + 31 Steps For applications with high optical proximity crosstalk (the emitted IR optical signal appears at the IR sensor), the offset range can be extended in discrete steps. To determine the best range extension step for the application, a proximity calibration cycle is initiated and the resulting proximity offset is captured in the POFFSETL/H registers. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 35 Document Feedback TMD2712 − Register Description CALIBCFG Register (Address 0xD9) Figure 54: CALIBCFG Register Addr: 0xD9 Bit Bit Name CALIBCFG Default Access Bit Description Proximity offset calibration result target. 7:5 BINSRCH_ TARGET 2 (010) Value PDATA Target 0 (000) 3 1 (001) 7 2 (010) 15 3 (011) 31 4 (100) 63 5 (101) 127 6 (110) 255 7 (111) 511 RW 4 Reserved 1 RW Reserved. Must be set to default value. 3 AUTO_OFFSET_ ADJ 0 RW If set, this bit causes the value in POFFSETL register to be decremented if PDATA ever becomes zero. PROX_AVG defines the number of ADC samples collected and hardware averaged during a proximity cycle. 2:0 PROX_AVG 0 (000) RW Value Sample Size 0 (000) Disable 1 (001) 2 2 (010) 4 3 (011) 8 4 (100) 16 All other values Reserved The binary search target field is used by the calibration feature to set the baseline value for PDATA when no target is present. For example, calibration of a device in open air, with no target, and BINSEARCH_TARGET setting of 2 causes the PDATA value to be approximately 15 counts. This feature is useful because it forces PDATA result to always be above zero. Page 36 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Register Description The PROX_AVG field sets the number of ADC samples that are averaged. Each ADC sample causes the programmed number of proximity pulses to be transmitted. Once all samples have been completed and the average is calculated, the proximity state machine will then pass this value directly to PDATA. CALIBSTAT Register (Address 0xDC) Figure 55: CALIBSTAT Register Addr: 0xDC CALIBSTAT Bit Bit Name Default Access Bit Description 7:3 Reserved 0 R Reserved. Must be set to default value. 2 OFFSET_ ADJUSTED 0 R Bit is set when the proximity offset has been automatically decremented if AUTO_OFFSET_ ADJ = 1 (see CALIBCFG register). This bit can be cleared by writing 1 to it or setting AUTO_ OFFSET_ADJ to 0. 1 Reserved 0 R Reserved. Must be set to default value. R This flag indicates that calibration has finished. This bit is a copy of the CINT bit in the STATUS register. It will be cleared when the CINT bit is cleared. 0 CALIB_FINISHED 0 INTENAB Register (Address 0xDD) Figure 56: INTENAB Register Addr: 0xDD INTENAB Bit Bit Name Default Access 7 ASIEN 0 RW ALS Saturation Interrupt Enable 6 PSIEN 0 RW Proximity Saturation Interrupt Enable 5 PIEN 0 RW Proximity Interrupt Enable 4 AIEN 0 RW ALS Interrupt Enable 3 CIEN 0 RW Calibration Interrupt Enable 2 ZIEN 0 RW Zero Detect Interrupt Enable 1:0 Reserved 0 RW Reserved. Must be set to default value. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Bit Description Page 37 Document Feedback TMD2712 − Register Description FAC_L Register (Address 0xE6) Figure 57: FAC_L Register Addr: 0xE6 FAC_L Bit Bit Name Default Access 7:0 Reserved 0x00 – 0xFF R Bit Description Reserved for factory use. FAC_H Register (Address 0xE7) Figure 58: FAC_H Register Addr: 0xE7 FAC_H Bit Bit Name Default Access 7:0 Reserved 0x00 – 0xFF R Bit Description Reserved for factory use. TEST9 Register (Address 0xF9) Figure 59: TEST9 Register Addr: 0xF9 TEST9 Bit Bit Name Default Access 7:0 Reserved 0x0C R/W Page 38 Document Feedback Bit Description Reserved. Must be set to 0x06. ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Application Information Application Information Schematic Figure 60: Typical Applications Circuit RPU 1.8V R1 22ȍ 3.0V C1 2.2µF C2 2.2µF RPU 10Kȍ TMD2712 VDD SCL VDD3 SDA GND INT Note(s): 1. Place the 2.2μF VDD (C1) and 2.2μF VDD3 (C2) capacitors within 5mm of the module. 2. The value of the I²C pull up resistors (R PU) should be based on the 1.8V bus voltage, system bus speed and trace capacitance. 3. C1 and C2 are critical components to protect the device during high voltage ESD strikes. 4. In systems subjected to high voltage ESD strikes, it is recommended to connect VDD to a host GPIO pin to allow the device to be independently power cycled. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 39 Document Feedback TMD2712 − Application Information Recommended Circuit Layout Figure 61: With INT Pin Operational With INT pin operational With INT pin tied to GND Note(s): 1. The dominant factor governing device performance is the component placement, not necessarily component value. The placement of the decoupling capacitor, C1, is the most critical. Place the component on the same side of PCB as device as shown in the figure above. Make connection as close as possible to minimize series inductance and resistance. This is critical. Page 40 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Package Drawings & Markings Package Drawings & Markings Figure 62: Package Drawings 3$57('*(72352; &/  &/  &/ 3$57 &/ 72$/6 &/  3$57 &/ 72352; &/  3$57 &/ 72,5 &/  3$57 &/ 72$/6,5 &/  3$57 &/ 72352; &/  352; &/ 72(0,77(5 &/  $ % “ “ “ & ; 6&/ 9'' ,17 ; &/ *1' 6'$  0 & $ %  0 & $ % ;   9'' &/ '(9,&(3,1287 %277209,(: RoHS Green Note(s): 1. All linear dimensions are in millimeters. 2. Dimension tolerances are 0.05mm unless otherwise noted. 3. Contact finish is Au. 4. This package contains no lead (Pb). 5. This drawing is subject to change without notice. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 41 Document Feedback TMD2712 − Package Drawings & Markings Recommended PCB Pad Layout Suggested PCB pad layout guidelines for the surface mount module are shown. Flash Gold is recommended as a surface finish for the landing pads. Figure 63: Recommended PCB Pad Layout ;   &/ ; &/ ; ; Note(s): 1. All linear dimensions are in millimeters. 2. Dimension tolerances are 0.05mm unless otherwise noted. 3. Contact finish is Au. 4. This drawing is subject to change without notice. Page 42 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Tape & Reel Information Tape & Reel Information Figure 64: Tape and Reel Information Note(s): 1. All linear dimensions are in millimeters. Dimension tolerance is ±0.10mm unless otherwise noted. 2. The dimensions on this drawing are for illustrative purposes only. Dimensions of an actual carrier may vary slightly. 3. Symbols on drawing Ao, Bo, and Ko are defined in ANSI EIA Standard 481-B 2001. 4. ams packaging tape and reel conform to the requirements of EIA Standard 481-B. 5. In accordance with EIA standard device pin 1 is located next to the sprocket holes in the tape. 6. This drawing is subject to change without notice. ams Datasheet, Confidential [v1-01] 2020-Aug-27 Page 43 Document Feedback TMD2712 − Soldering & Storage Information Soldering & Storage Information The module has been tested and has demonstrated an ability to be reflow soldered to a PCB substrate. The solder reflow profile describes the expected maximum heat exposure of components during the solder reflow process of product on a PCB. Temperature is measured on top of component. The components should be limited to a maximum of three passes through this solder reflow profile. Figure 65: Solder Reflow Profile Profile Feature Preheat/ Soak Sn-Pb Eutectic Assembly Pb-Free Assembly Temperature Min (Tsmin) 100 °C 150 °C Temperature Max (Tsmax) 150 °C 200 °C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up rate (TL to TP) 3 °C/second max. 3 °C/second max. Liquidous temperature (TL) Time (tL) maintained above TL 183 °C 60-150 seconds 217 °C 60-150 seconds Peak package body temperature (TP) For users TP must not exceed the classification temp. of 235 °C. For suppliers TP must equal or exceed the classification temp. of 235 °C For users TP must not exceed the classification temp. of 260 °C. For suppliers TP must equal or exceed the classification temp. of 260 °C Time (tP) (1) within 5 °C of the specified classification temperature (Tc) 20 (1)seconds 30 (1)seconds Ramp-down rate (TP to TL) 6 °C/second max. 6 °C/second max. Time 25 °C to peak temperature 6 minutes max. 8 minutes max. Note(s): 1. Tolerance for peak profile temperature (TP) is defined as a supplier minimum and a user maximum. Page 44 Document Feedback ams Datasheet, Confidential [v1-01] 2020-Aug-27 TMD2712 − Soldering & Storage Information Figure 66: Solder Reflow Profile Graph Not to Scale – For Reference Only TP Max Ramp Up Rate = 3°C/s Max Ramp Down Rate = 6°C/s TL TC - 5°C tP Temperature (°C) tL Tsmax Preheat Area Tsmin 25 Time (seconds) Storage Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is baked prior to being dry packed for shipping. Devices are dry packed in a sealed aluminized envelope called a moisture-barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. Shelf Life The calculated shelf life of the device in an unopened moisture barrier bag is 12 months from the date code on the bag when stored under the following conditions: • Shelf Life: 12 months • Ambient Temperature:
TMD27123M 价格&库存
很抱歉,暂时无法提供与“TMD27123M”相匹配的价格&库存,您可以联系我们找货
