AFBR-79EIDZ
AFBR-79EIDZ
    FIT(鸿腾精密)
    TRANSCEIVER
AFBR-79EIDZ 数据手册
AFBR-79EIDZ QSFP+ iSR4 Pluggable, Parallel Fiber-Optics Module for 40Gb Ethernet, 4 x 10Gb Ethernet and InfiniBand Applications Data Sheet Description Features The Avago Technologies AFBR-79EIDZ is a Four-Channel, Pluggable, Parallel, Fiber-Optic QSFP+ Transceiver for 40 Gigabit Ethernet (40GbE) applications with added capability of inter-operating with IEEE 10GBASE-SR compliant products. It also supports 4 x 10G InfiniBand (IB) quadruple data rate (40G-IB-QDR) application and is backward compatible to the 4 x 5G IB dual data rate (20G-IB-DDR) and 4 x 2.5G IB single data rate (10G-IB-SDR) applications. This transceiver is a high performance module for short-range multi-lane data communication and interconnect applications. It integrates four data lanes in each direction with each lane operating at 10.3125 Gbps, giving an aggregated bandwidth of 40 Gbps. This transceiver can also be used for high density 10 Gigabit Ethernet application to allow effective port count of over 100 within 1 RU rack. It allows optical interoperability with any 10 Gigabit Ethernet (10GbE) transceiver, compliant to the IEEE 802.3ae 10GBASE-SR specifications, of form factors such as SFP+, XFP and X2. This transceiver is designated as a QSFP+ iSR4 solution, where the letter i represents interoperability between this QSFP+ transceiver with any 10GBASE-SR compliant modules. • Compliant to the 40GBASE-SR4 and XLPPI Specifications per IEEE 802.3ba-2010 This QSFP+ transceiver link length for either 40 Gigabit Ethernet or high density 10 Gigabit Ethernet application is up to 100 m using OM3 fiber or 150 m using OM4 fiber. These modules are designed to operate over multimode fiber systems using a nominal wavelength of 850nm. The electrical interface uses a 38 contact edge type connector. The optical interface uses an 8 or 12 fiber MTP (MPO) connector. This module incorporates Avago Technologies proven integrated circuit and VCSEL technology to provide reliable long life, high performance, and consistent service. Part Number Ordering Options AFBR-79EIDZ QSFP+ iSR4 module with full real-time digital diagnostic monitoring AFBR-79Q4EKZ* Evaluation Board AFBR-79Q2EKZ** Evaluation Kit * Includes GUI and User Guide ** Includes GUI, User Guide, i-Port and Power Supply Patent - www.avagotech.com/patents • Support optical interoperability with IEEE 802.3ae 10GBASE-SR modules of various form factors such as SFP+, XFP, and X2 • Support 40G-IB-QDR / 20G-IB-DDR / 10G-IB-SDR applications • Compliant to the industry standard SFF-8436 QSFP+ Specification Revision 3.5 • Power Level 1: Max Power
AFBR-79EIDZ 价格&库存
很抱歉,暂时无法提供与“AFBR-79EIDZ”相匹配的价格&库存,您可以联系我们找货
