258-181-556-PRO
258-181-556-PRO
    AVENTOOLS(艾文)
    显微镜,数字式 7x ~ 70x LED
258-181-556-PRO 数据手册
® AVEN Tools for Advancing Innovation Mighty Cam Pro 360 Rotation HDMI, USB and SD Card Outputs Gooseneck LED Task Light High Magnification Inspection From All Angles Capture & Save Images Directly To SD Card Shadow Free Illumination 7x-70x Auto Focus HDMI/USB W/ Macro Lens, Ultra-Glide Stand, LED Task Light and 22” Monitor High definition 1080P auto focus inspection system with a 22" monitor offering superb image quality at 60 frames per second. Working distance 6" with magnification range of 7x-70x. You can operate this system with or without a PC. Without a PC camera connects directly to the included HDMI monitor. View and record images and perform measurements using the included on screen tools. Images & videos can be saved to the included SD card. Connect the camera to a PC to utilize more advance features in the included software. The included dual gooseneck LED light allows you to illuminate the object to get the sharpest and greatest detail. Features: Mighty Cam Pro Camera with Macro Lens, Ultra-Glide Stand and LED Task Light - Includes software Mosaic 2.1 - HDMI, USB2.0 and SD card outlets - Data transfer up to 60 frames per second - Heavy metal base provides excellent stability - Ball Joint provides 360 degree rotation - Save images directly to SD card *no computer required* - Smooth gliding arm allows to move easily across object being viewed - Fast auto focus camera achieves instant clear images with no need to adjust the lens - Camera features HDMI and USB outputs - Inspect directly on an HD monitor or from a computer - Advanced imaging/measurement software included - 7x - 70x magnification at a 6 inch working distance - Includes Aven's Dual Gooseneck LED Task Light, 22" HD monitor Item Number 258-181-556-PRO Magnification 7x -70x (at 6in working distance) Resolution 2MP 1920x1080 Frame Rate 60 fps @HDMI, 30fps @USB2.0 Video Recording 30fps @SD Card, 30 fps @PC Outputs HDMI, USB2.0 and SD Card PC Software Mosaic 2.1 Package Contents Mighty Cam Pro USB/HDMI AutoFocus Dual Gooseneck LED task Light, Computar Macro Lens, 22” HD Monitor, Ultra-Glide Arm Stand aventools.com | sales@aventools.com | 734.973.0099 ® AVEN Tools for Advancing Innovation Included Software HDMI, USB and SD Card Outputs Auto Focus 60fps HDMI Mosaic 2.1 Capture & Save Images Directly To SD Card Full HD 1080p 30fps SD Card, PC and USB Mighty Cam Pro Auto Focus HDMI/USB/SD Aven's Mighty Cam Pro is an all-in-one inspection auto-focus camera. This camera offers both USB and HDMI outputs for inspection from an HD monitor or your PC via the included Mosaic software. This camera features integrated measurement capabilities for measuring without a PC. This camera also features a built-in SD card port for capturing instant high resolution images with no need for a PC. Macro Lens Macro Lens Integrated Measurement System *No PC Required* Built in on screen tools provide powerful measurement functions including freehand line, rectangle, polygon, circle, bicircle, angle, point-line distance and much more. Three different length units of millimeter, centimeter and micrometer are provided to meet various measurement requirements in different applications. Simple calibration tool is also included. Micro Lens Mosaic Software Included Compatible with Mosaic V2.1 Computational Imaging Software. Fast, efficient and worry-free is the core design concept of Mosaic V2.1 software. It adopts a new image "shooting-processing-measurement-reporting" function, modular design, and integrates various intelligent image processing algorithms. It is dedicated to providing users with more simple operation modes and improve work efficiency in all circumstances. Micro Lens Real-Time Image Stitching It can generate large-sized mosaic images in a few seconds while moving the stage, which is light, smooth and worry-free! Real-time depth-of-field fusion. Perfect Color Reproduction Aven’s color processing is capable of a new level of precision, matches the monitor image to the eyepiece view, produces extremely-high color definition. aventools.com | sales@aventools.com | 734.973.0099
258-181-556-PRO 价格&库存
很抱歉,暂时无法提供与“258-181-556-PRO”相匹配的价格&库存,您可以联系我们找货
