AVEN
Tools for
Advancing
Innovation
5” Round
5-Diopter
Glass Lens
Aluminum
Construction
Flexible
lamp
Rotation
Adjustable
Color Temp
Controls
2.25x
Magnification
Adjustment
Locking
Handles
Stays in
Place in Any
Position
3500K6500K
ProVue Deluxe
5D Magnifying Lamp
W/ Dual Temp LEDs
Avens LED Magnification lamp with a 5", 5 diopter round
glass lens (2.25x magnification). Durable metal housing
over the arm and lamp head. 2 Tilt points along the
adjustable arm and a knob to adjust the lamp position.
Features 36 adjust white LEDs and 36 adjustable amber
LEDs. Color temperature range: 3500K-6500K
ProVue Deluxe Mag Lamp W/ Dual Temp LEDs
ProVue Deluxe Features
- 3500K-6500K color temperature range
- Touch-sensitive brightness and color temperature controls
- Fully covered spring balanced arm stays set in any position
- Large 5" 5-Diopter glass lens
- High intensity energy saving LEDs
- Cool operating temperature
- Exceptionally long LED element life (minimum 20,000 hours)
- Ideal for assembly, workshop or inspection applications
- Heavy Duty Table Clamp allows for easy attachment to desk and bench tops
- ESD Safe
Item Number
26501-LFL-LED
Lens Magnification 5-Diopter Lens (2.25x magnification)
Lens Size
5” Round
LED Color
36 White LEDs | 36 Amber LEDs
Lighting Control
On/Off with brightness adjustment
ESD Safe
Yes
Arm Length
36 inch
Package Contents
ProVue Deluxe
Mounting Clamp
4 Screws
aventools.com | sales@aventools.com | 734.973.0099
White/Amber LED
AVEN
Illumination
Tools for
Advancing
Innovation
Similar to Avens previous ProVue Deluxe magnifying lamp this one carries on the same innovative design and features with
one added plus. The new ProVue Deluxe now features color temperature controls. With just the turning of a knob you can
view your object of inspection using either White or Amber LED’s giving you a bright and shadow free view.
Mounting Options
This Magnifying Lamp includes a heavy-duty aluminum
mounting clamp and 4 mounting screws. Easily mounts to
the side of your work station. The screw fastener secures to
the side of any work table up to 1.5" in width. Or you can
mount the ProVue Deluxe LED directly to your work surface.
Replacement Clamp for ProVue Deluxe and
MightyVue Deluxe Magnifying Lamps
Replacement clamps are available on our website in case
of loss or damage of item. This clamp is compatible with
both Avens MightyVue Deluxe (#26505-DSG-LED) and
ProVue Deluxe (#26501-LFL-LED) Magnifying Lamps
Replacement Clamp Part Number
#26501-DSG-CL
很抱歉,暂时无法提供与“26501-LFL-LED”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3711.774631+480.21713
