26700-140
26700-140
    AVENTOOLS(艾文)
    显微镜,数字式 17x ~ 110x LED,可调节
26700-140 数据手册
® AVEN Tools for Advancing Innovation MicroVue Ergonomic Design High Magnification FULL HD USB output Build in 11” Monitor on 11” Monitor 17x-110x 1920* 1080P Directly Save Image/Video Digital Microscope W/ Built-In HD Monitor Aven's MicroVue™ Digital Microscope is an all-in-one inspection system. Designed for high magnification, the MicroVue™ offers a magnification range of 17x - 110x on it's built- in 11.6" monitor. Inspecting objects on a monitor offers an ergonomic inspection process, eliminating the eye strain and body fatigue associated with frequent optical microscope use. MicroVue Digital Microscope with Built-In HD Monitor MicroVue Features - Built-in 11.6" monitor for ergonomic viewing - 17x - 110x magnification (on the built-in monitor) - HDMI output for external monitor viewing Built-in measurement capabilities - Save image/video files to USB storage device (USB included) - Compact design saves bench top space Item Number 26700-140 Output HDMI, USB Mouse, USB Storage Frame Rate 1920*1080P 60fps Magnification 17x-110x Effective Pixels Full HD Power DC-12V/2A Sensor 1/3” Package Contents MicroVue Microscope, 11” Attached Monitor, Mouse, Power Adapter, USB aventools.com | sales@aventools.com | 734.973.0099 ® AVEN Tools for Advancing Innovation Minimum Magnification 8.6x Magnification 0.5X Auxiliary Lens Maximum Magnification For MicroVue The MicroVue 0.5x Objective Lens is designed to enhance the versatility of the MicroVue Digital Microscope. When in use, the magnification range becomes 8.6x – 55.2x on the MicroVue 11.6” monitor. By reducing the magnification range by 50%, the field of view increases, providing more viewing area to inspect a larger surface area. This lens easily screws to the bottom of the MicroVue Digital Microscope for crystal-clear high-resolution inspection 55.2x Magnification MicroVue Digital Microscope W/ Built-In HD Monitor - Built-in 11.6" monitor for ergonomic viewing - 17x - 110x magnification (on the built-in monitor) - HDMI output for external monitor viewing Built-in measurement capabilities - Save image/video files to USB storage device (USB included) - Compact design saves bench top space 0.5X Auxiliary Lens For MicroVue #26700-140 Item Number 26700-140-L05X Compatible Item # 26700-140 (MicroVue) Magnification 8.6x - 55.2x (on 11.6” Monitor) aventools.com | sales@aventools.com | 734.973.0099 ® AVEN Tools for Advancing Innovation Minimum Magnification 34.4x Magnification Maximum Magnification 2X Auxiliary Lens For MicroVue The MicroVue 2.0x Objective Lens is designed to enhance the versatility of the MicroVue Digital Microscope. When in use, the magnification range is 34.4x – 221x on the MicroVue 11.6” monitor. This lens easily screws to the bottom of the MicroVue Digital Microscope for crystal-clear high-resolution inspection 221x Magnification MicroVue Digital Microscope W/ Built-In HD Monitor - Built-in 11.6" monitor for ergonomic viewing - 17x - 110x magnification (on the built-in monitor) - HDMI output for external monitor viewing Built-in measurement capabilities - Save image/video files to USB storage device (USB included) - Compact design saves bench top space 2X Auxiliary Lens For MicroVue #26700-140 Item Number 26700-140-L20X Compatible Item # 26700-140 (MicroVue) Magnification 34.4x - 221x (on 11.6” Monitor) aventools.com | sales@aventools.com | 734.973.0099 ® AVEN Tools for Advancing Innovation Focus Mount w/ 32MM Arbor for Boom Stands For MicroVue Designed to enhance the versatility of the MicroVue Digital Microscope, this Focus Mount with Arbor allows operators to connect the MicroVue to a boom stand. Boom stands are ideal for scanning over larger objects, a feature not available with standard post stands. MicroVue Digital Microscope W/ Built-In HD Monitor - Built-in 11.6" monitor for ergonomic viewing - 17x - 110x magnification (on the built-in monitor) - HDMI output for external monitor viewing Built-in measurement capabilities - Save image/video files to USB storage device (USB included) - Compact design saves bench top space #26700-140 Focus Mount For MicroVue Item Number 26700-140-M32 Compatible Item # 26700-140 (MicroVue) aventools.com | sales@aventools.com | 734.973.0099
26700-140 价格&库存
很抱歉,暂时无法提供与“26700-140”相匹配的价格&库存,您可以联系我们找货
