26700-151-C05-260-570
    AVENTOOLS(艾文)
    显微镜,数字式 13.3x ~ 94.4x LED
26700-151-C05-260-570 数据手册
AVEN Tools for Advancing Innovation Mighty Cam Eidos Inspect from Micro Zoom Mighty Cam Gooseneck Any Angle Lens Eidos LEDs All-in-one Digital Microscope No need to move the part [13.3x - 94.4x] on Post Stand w/ Gooseneck LEDs and 360 Viewer 13.3x - 94.4x Magnification (22” Monitor) Inspect, measure & save images to USB Position LEDs for optimal illumination Digital Inspection and Measurement System featuring our Detented Micro Lens with a 360 Viewer and Mighty Cam Eidos camera mounted on our heavy-duty post stand with adjustable LED Lighting.  The Mighty Cam Eidos features a built-in 11.6” HD monitor with integrated measurement software and image capturing capabilities. Provides a magnification range of 13.3x to 94.4x. HDMI Mode (View on an HD monitor) 0.6x, 1x, 2x, & 4x Detents for Easy Repeatable Measurements Built-in Measurement Capabilities Inspect Parts from Any Angle Mighty Cam Eidos Features •All-in-one compact digital microscope system •360 Viewer allows users to inspect from all angles by simply rotating the viewer •Micro zoom lens with four detented zoom settings (ideal for accurate and repeatable measurements) •Mighty Cam Eidos camera with built-in HD monitor •HDMI mode - view images on an additional monitor •Built-in measurement capabilities •Save images to USB storage - no computer required •Flexible LED goosenecks can be positioned where needed for optimal illumination •Heavy-duty post stand made from all-metal construction *360 viewer is required to be in the off position to perform measurements 13.3x-94.4x on Post Stand w/ Gooseneck LEDs & 360 Viewer Item # 26700-151-C05-260-570 Magnification 360 Viewer ON 13.3x - 94.4x (22” Monitor) 360 Viewer OFF 13.3x - 94.4x (22” Monitor) Working Distance 360 Viewer ON 0.91” (23mm) 360 Viewer OFF 3” (76.2mm) Resolution 1920 x 1080 @ 60FPS Interface HDMI • • • Package Contents • • • • 26100-260: Mighty Cam Eidos 26700-170: 360 Viewer 26700-151-C05: Micro Lens + 0.5x Coupler 26700-151AP: Lens Adapter Plate 26800B-570: Heavy Duty Post Stand 26200B-224: Flexible Gooseneck LEDs with Brightness Control Box 26800B-517: Focus Mount aventools.com | sales@aventools.com | 734.973.0099
26700-151-C05-260-570 价格&库存
很抱歉,暂时无法提供与“26700-151-C05-260-570”相匹配的价格&库存,您可以联系我们找货
