26115
26115
    AVENTOOLS(艾文)
    放大镜,束头带 1x,1.5x,2x,2.5x,3.5x
26115 数据手册
AVEN Tools for Advancing Innovation Hand Held 30mm & 21mm lens 6 LED 3mm Portable & Convenient 10x and 30x Magnification Two level Brightness Hand Held Magnifier 10x-30x w/ LED Light Hand-held LED magnifier with 10x/30x lenses. A high-intensity 6 LED ring light surrounds the main lens for even light distribution. A single LED illuminates objects beneath the 30x lens. Ideal for professional inspection, hobby work, education, reading, gardening applications, DIY applications, and more. Features: • Illuminated handheld magnifier with 6 total LEDs • Ergonomic designed straight handle. • LEDs provides strong light for clear viewing. • Magnification: 10x & 30x • Powered by 3 AAA batteries (not included). • Features an ON/OFF switch button. Hand Held Magnifier Item # 26053 Magnification 10x and 30x Weight 75g Material Glass lens, ABS Plastic Lens Diameter 30mm , 21mm Light 6 LED 3mm, Two level Brightness Battery 3 AAA (not included) aventools.com | sales@aventools.com | 734.973.0099 AVEN Tools for Advancing Innovation Hand Held 75mm & 21mm lens 10 LED 3mm Portable & Convenient 5x and 20x magnification Two level Brightness Hand Held Magnifier 5x-20x w/ LED Light Hand-held LED magnifier with 5x/20x lenses. A high-intensity 10 LED ring light surrounds the main lens for even light distribution. A single LED illuminates objects beneath the 20x lens. The large 75mm main lens provides a large viewing area. Ideal for professional inspection, hobby work, education, reading, gardening applications, DIY applications, and more. Features: • Illuminated handheld magnifier with 11 total LEDs • Ergonomic designed straight handle. • LEDs provides strong light for clear viewing. • Magnification: 5X / 20X. • Powered by 3 AAA batteries (not included). • Features an ON/OFF switch button. Hand Held Magnifier Item # 26054 Magnification 5x and 20x Weight 75g Material Glass lens, ABS Plastic Lens Diameter 75mm , 21mm Light 10 LED 3mm, Two level Brightness Battery 3 AAA (not included) aventools.com | sales@aventools.com | 734.973.0099 AVEN Tools for Advancing Innovation Headband Magnifier 5 Included Lenses 3 LED 5mm Lightweight & Adjustable 1.5x-8x (max 14) Magnification Two level Brightness OptiSight Pro Headband Magnifier with LEDs and Lenses 1x, 1.5x, 2x, 2.5x, 3.5x This innovative headband magnifier is designed for a wide range of hands-free magnification needs. Applications include mechanical processing, electronics repair, jewelry inspection and appraisal, clock and watch repair, carving, hobby work, and more. Includes 5 auxiliary lenses (use up to two lenses at once), and a built-in swing-out lens that can combine for a maximum 14x magnification. Features: • A customizable solution for hands-free magnification • Includes a 5 auxiliary lens kit with storage case • A three LED light panel placed at the front of the device provides bright, shadow-free illumination • The brightness intensity of the LEDs can be adjusted by pressing the button at the top of the light panel • The length of the headband can be adjusted by twisting the headband regulating wheel to the desired length, and locked in place by pressing the wheel in • The non-slip inner padding of the headband is designed for operator comfort for the duration of use OptiSight Pro Headband Magnifier Item # 26115 Magnification 1.5x-8x (max 14x) Weight 1.3 lb Material ABS Plastic, Optical Lenses Light 3 LED 5mm, Two level Brightness Battery USB connected to 3.7v. 300MAH rechargeable battery. System Contents OptiSight Pro Headband Magnifier 5 Piece Auxiliary Lens Kit with Storage Case USB Charging Cable for LED panel, Lens cloth aventools.com | sales@aventools.com | 734.973.0099 AVEN Tools for Advancing Innovation Eye Loupe Inspection Goggles 6x-25x w/ LED Light Aven’s Eye Loupe Inspection Goggles are designed for comfortable up-close inspection. The frames feature bright LEDs for applications where additional illumination is required. This set includes 6 pairs of interchangeable lenses, providing a magnification range of 6x - 25x. Features: • Designed for comfortable up close inspection • Set includes 6 pairs of lenses, ranging from 6x - 25x • Frames can be lengthened/shortened to the required length • The lenses can be flipped upwards when not in use, so the operator does not have to remove the goggles. • The lens barrels can be adjusted horizontally to accommodate the operator’s face Eye Loupe Inspection Goggles Item # 26116 Magnification 6x-25x Included Lens 6x | 8x | 10x | 15x | 20x | 25x Illumination LED lights attached to each lens barrel Length adjustment Frames can be lengthened/shortened Eye loupe adjustment Lens barrels can be flipped upwards when not in use LED Battery Each LED requires 3 LR1130 batteries (included) aventools.com | sales@aventools.com | 734.973.0099 AVEN Tools for Advancing Innovation Portable Magnifier Loupe 20X with LED Light Aven’s 20x eye loupe with LED light for close up inspection. Ideal for hobby inspection, circuit boards quality inspection, gardening, home/ office, jewelry appraisal, education, and more. Features: • Lightweight glass lens magnifier • Powerful 20x magnification • Ideal for close inspection of small objects • Adjustable, bright LED light Portable Magnifier Loupe Item # 26052 Magnification 20x Weight 0.5 lb Dimensions 50mm x 31mm x 25mm Battery Type LR927 aventools.com | sales@aventools.com | 734.973.0099
26115 价格&库存
很抱歉,暂时无法提供与“26115”相匹配的价格&库存,您可以联系我们找货
