MLS640-244-570
MLS640-244-570
    AVENTOOLS(艾文)
    DIGITAL MICROSCOPE MIGHTY CAM US
MLS640-244-570 数据手册
® AVEN Tools for Advancing Innovation 6 Megapixel Sensor Ergonomic Design Save & Share Images High Magnification Stunning HighResolution Reduces Fatigue and Eye Strain Imaging Software 26x -349x on 22” Monitor Mighty Cam USB Digital Microscope W/ Standard Post Stand Designed for high magnification, this specialized digital microscope has a magnification range of 26.2x - 349.3x (on 22”monitor in full screen mode). This system includes Aven's Mighty Eidos - Integrated HD monitor and inspection camera. View High Res 1080p HD images on the 11.6" LCD monitor. No computer or external monitor required for inspection or image/video capture. The monitor can be tilted to the ideal viewing angle. Built-in USB output for PC connectivity. Includes a 1x objective lens and a 0.5x objective lens. The system also includes Aven's standard post Stand for easy scanning over larger objects. *Monitor not included* Features: - USB 6M CMOS Camera with Imaging Software - Professional Sony 6M CMOS Sensor (3072(H) x 2048(V)) - Easy Plug and Play USB 3.0 Interface - Create large panoramic images with real-time stitching feature - Ideal for use when large objects are to be viewed - Compact and Light Weight - Versatile C/CS lenses mount - Save high resolution image files - Calibrate accurate measurements - Adjust the depth of field in real time Digital Microscope Mighty Cam USB With Standard Post Stand Item Number MLS640-244-570 Magnification 52.4x - 349.3x w/ 1x Objective Lens Magnification 26.2x - 174.6x w/ .5x Objective Lens Resolution 3072(H) x 2048(V) Frame Rate 40FPS Sensor 6mp CMOS 1/1.8” sensor Data Interface USB 3.0 Package Contents Mighty Cam USB, Standard Post Stand, LED Ring Light, Micro Lens System Zoom, Micro Lens Adapter Plate, .5x Objective Lens E-Arm Focus Mount, 1x Objective Lens aventools.com | sales@aventools.com | 734.973.0099 ® AVEN Tools for Advancing Innovation Mighty Cam USB 3.0 6MP CMOS Camera With Imaging Software Aven’s Mighty Cam USB 6M CMOS Camera with imaging and measurement software. Create stunning images with outstanding clarity then measure, annotate and analyze with ease with the imaging software.. Inspect From Your PC In Real Time Aven’s Mighty Cam is equipped with a 6 megapixel sensor and a USB 3.0 output, providing stunning, true-to-life images with minimal lag time. Save Images, Make Measurements, Create Reports The included software provides an easy-to-use, yet sophisticated interface for saving high resolution images, writing annotations, generating reports and accurate measurements. This user-friendly interface is ideal for saving critical data and sharing information. Real-Time Depth Of Field Adjustment When inspecting at high magnification, certain areas of specimen may not be in focus depending on the depth of the object. With the Real-Time Depth of Field feature, operators can adjust the focus parameters, with no need to adjust the physical optics. Create Panoramic Images The software provides a "real-time image stitching" function. It can generate large-sized panoramic images in a few seconds. Requires a gliding stage for optimal performance. Excellent Image Performance The use of a state-of-the-art ISP color-interpolation algorithm effectively corrects the color deviation of the sensor's spectral response, to simulate the human eye's sensitivity to color. The true color in the eyepiece, whether it is a biological bright field, stereo or fluorescence image. Professional Grade Image Sensor Mighty Cam utilizes a Sony 6 megapixel CMOS 1/1.8" sensor-IMX178, with 2.4 x 2.4 ?m pixels. The resolution of the captured image can reach 3072 x 2048. aventools.com | sales@aventools.com | 734.973.0099
MLS640-244-570 价格&库存
很抱歉,暂时无法提供与“MLS640-244-570”相匹配的价格&库存,您可以联系我们找货
