SPZ-50-534-223
SPZ-50-534-223
    AVENTOOLS(艾文)
    显微镜,立体缩放(双筒) 6.7x ~ 50x LED
SPZ-50-534-223 数据手册
® AVEN Tools for Advancing Innovation OLED Ring Light 6.7x - 50x Continuous Zoom Dual Arm Boom Stand Large Working Distance Provides Reduced Glare And Natural Light Tone 10x Eyepieces Smooth Movement And Excellent Stability Wide Field of View SPZ-50 Stereo Zoom Microscope W/ OLED Ring Light And Double Arm Boom Stand True binocular microscope. Provides crisp clear 3D images, long working distance and a wide field of view. 6.7x to 50x continuous zoom with 10x eyepieces. Includes OLED Ring Light with 4 panels. When compared to standard LED ring lights, the OLED Ring Light provide reduced glare and a natural light tone. SPZ-50 Stereo Zoom Microscope - View images through the eyepiece or a monitor simultaneously. - Click stop zoom adjustment for accurate measuring - Large zoom ratio 7.46:1- best zoom ratio in class - Field of View 34.3mm to 3.6mm (1.35" to 0.14") - Working distance 108mm (4.25") -the best in class - 17mm (0.67") high eye point wide field 10x eyepieces (field number 23) for comfortable viewing even for operators with eyeglasses - Diopter adjustment on both eyepiece tubes OLED Ring Light OLED Ring Light - 4 Organic Light Emitting Diode panels provide even, natural illumination with no glare or shadows - Includes a dimmer box to control the light intensity - Panels can be tilted up and down to provide the ideal illumination angle Double Arm Boom Stand - Heavy Base couples with ball bearing slide allows for easy positioning of the microscope - 605mm height available with extension post - All metal construction - Ideal for use when large objects are to be viewed E-Arm Focus Mount - Rack & Pinion Mechanism with Coarse Focus Adjustment - 50mm focusing distance in vertical direction Standard LED Ring Light SPZ-50 Stereo Zoom Microscope W/ OLED Ring Light And Double Arm Boom Stand Item Number SPZ-50-534-223 Magnification 6.7x-50x Zoom Ratio 7.46:1 Body Binocular Illumination 100mm OLED Ring Light Working Distance 108mm 4.3in Eye Pieces 10x wide field (FN:23) Package Contents 1ea SPZ True Binocular Stereo Zoom Microscope Body with Photo tube 2 ea. 10x Eyepieces 2 ea. Rubber Eye guards 1 ea. Dust Cover 1 ea. aventools.com | sales@aventools.com | 734.973.0099 Tools for Advancing Innovation ® AVEN Example System OLED Ring Light Example System For Microscopes Ring light with 4 OLED panels. Each panel can be tilted up and down, allowing for the ideal illumination angles. When compared to standard LED ring lights, the OLED Ring Light provides reduced glare and a natural light tone. Includes a dimmer control box and a ring light adapter. Organic Light Emitting Diode The OLED ring light consists of four Organic Light Emitting Diode (OLED) panels, providing uniform, shadow-free illumination. OLED offers excellent color rendering close to natural light for ideal observation of true-to-life colors. Each panel can be tilted up and down, allowing for the ideal illumination angles. OLED Ring Light Standard LED Ring Light Reduced Glare, Natural Light Tone When compared to standard LED ring lights, the OLED Ring Light provides reduced glare and a natural light tone. Dimmer Control Box The dimmer control box gives users the ability to determine the brightness intensity. Ring Light Adapter The OLED system includes a ring light adapter for easy attachment to any Aven stereo zoom microscope. OLED Ring Light For Microscopes Item Number 26200B-223 Weight 1.2 lbs Dimensions 9 x 11.5 x 1.5 in Color Temp 5400K Illumination at 100mm 800lx - 2500lx (5000lx w/tilted panels) Power Supply AC Adapter Life Time Approx. 10,000 hrs at middle intensity Package Contents OLED Ring Light Power Supply Ring Light Adapter aventools.com | sales@aventools.com | 734.973.0099
SPZ-50-534-223 价格&库存
很抱歉,暂时无法提供与“SPZ-50-534-223”相匹配的价格&库存,您可以联系我们找货
