AVEN
Tools for
Advancing
Innovation
LED Ring
Light
6.7x - 50x
Continuous
Zoom
Dual Arm
Boom
Stand
Large
Working
Distance
20,000 Hours
High-Output
LED Illumination
10x
Eyepieces
Smooth
Movement
And Excellent
Stability
Wide Field
of View
SPZ-50
Stereo Zoom Microscope
W/ Dual Arm Boom Stand and Integrated Ring Light
Aven's SPZ-50 stereo zoom microscope provides crisp clear 3D
images, long working distance and a wide field of view. 6.7x to
50x continuous zoom with 10x eyepieces.
Includes Aven's Double Arm Boom Stand with an integrated
table clamp. The 22.4" horizontal arm easily glides to the
required position. Comes complete with Aven's E-Arm focus
ount with an integrated LED ring light and LED adjustment controller.
SPZ-50 Stereo Zoom Microscope
- Large zoom ratio 7.46:1- best zoom ratio in class
- Field of View 34.3mm to 3.6mm (1.35" to 0.14")
- Working distance 108mm (4.25") -the best in class
- 17mm (0.67") high eye point wide field 10x eyepieces (field number 23)
for comfortable viewing even for operators with eyeglasses
- Diopter adjustment on both eyepiece tubes
E-Arm Focus Mount with LED Ring Light
- E-Arm compatible with boom stands and articulating arm stands
- 60 integrated LED ring light with dimmer control
- Minimum 20,000 hours of high-output LED illumination
- Fits Aven's binocular and trinocular microscopes
- Low power consumption
Dual Arm boom Stand with Table Clamp
- Table clamp provides excellent stability
- Allows positioning of microscopes over large area
- Heavy duty all metal construction for durability
- Posts are highly polished for smooth operation
- Table clamp securely attaches to your work surface and saves table space
SPZ-50 Stereo Zoom Microscope W/ Ring Light
And Dual Arm Boom Stand
Item Number
SPZ50-209-536
Magnification
6.7x-50x
Zoom Ratio
7.46:1
Body
Binocular
Illumination
LED Ring Light
Working Distance
108mm 4.3in
Eye Pieces
10x wide field (FN:23)
Package Contents
Dual Arm Boom Stand with Table Clamp
aventools.com | sales@aventools.com | 734.973.0099
The AVEN
Advantage
AVEN
Straight Light Path
Single light path with one bend
prevents image distortion
Custom Make Prisms
Prisms custom designed to fit precisely
eliminating gaps for dust and contamination
Unibody Construction
Assures constant prism alignment
Grease-less Nylon Gears
Industrial strength gears with tight tolerances
Single Gear Objective Lens Movement
Keeps the objective lenses aligned for the life of the microscope
Tools for
Advancing
Innovation
很抱歉,暂时无法提供与“SPZ50-209-536”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+30594.819011+3963.09909
