SPZV50-209-550-PCL
SPZV50-209-550-PCL
    AVENTOOLS(艾文)
    显微镜,立体缩放(三筒) 6.7x ~ 50x LED(60)
SPZV50-209-550-PCL 数据手册
® AVEN Tools for Advancing Innovation LED Ring Light 6.7x-50x Magnification Articulating Arm Large Working Distance 20,000 Hours High-Output LED Illumination 10x Eyepieces Smooth Movement And Excellent Stability Wide Field of View SPZV-50 Stereo Zoom Microscope W/ Articulating Arm Stand and Integrated Ring Light Aven's SPZV-50 stereo zoom microscope provides crisp clear 3D images, long working distance and a wide field of view. 6.7x to 50x continuous zoom with 10x eyepieces. The C-Mount trinocular port on the top of the microscope is designed to be used with an external camera, giving operators the ability to view through the microscope eyepieces or on a monitor. The articulating arm is great for examining parts attached to a large or awkward shaped item. Can be easily moved out of the way when microscope is not in use to create more bench space. Comes complete with Aven's E-Arm focus mount with an integrated LED ring light and LED adjustment controller. SPZV-50 Stereo Zoom Microscope - Large zoom ratio 7.46:1- best zoom ratio in class - Field of View 34.3mm to 3.6mm (1.35" to 0.14") - Working distance 108mm (4.25") -the best in class - 17mm (0.67") high eye point wide field 10x eyepieces (field number 23) for comfortable viewing even for operators with eyeglasses - Diopter adjustment on both eyepiece tubes SPZV-50 Stereo Zoom Microscope W/ Ring Light And Articulating Arm Stand Item Number SPZV50-209-550-PCL Magnification 6.7x-50x - E-Arm compatible with boom stands and articulating arm stands - 60 Integrated LED ring light with dimmer control - Minimum 20,000 hours of high-output LED illumination - Fits Aven's binocular and trinocular microscopes - Low power consumption Zoom Ratio 7.46:1 Body Trinocular Illumination LED Ring Light Working Distance 108mm Eye Pieces 10x wide field Articulating Arm Stand with Table Clamp Package Contents Stereo Zoom Microscope E-Arm Focus Mount with LED Ring Light Articulating Arm Stand with Table Clamp E-Arm Focus Mount with LED Ring Light - Allows great flexibility in positioning microscopes - Can be moved out of way when not in use - All metal construction aventools.com | sales@aventools.com | 734.973.0099 ® The AVEN Advantage AVEN Straight Light Path Single light path with one bend prevents image distortion Custom Make Prisms Prisms custom designed to fit precisely eliminating gaps for dust and contamination Unibody Construction Assures constant prism alignment Grease-less Nylon Gears Industrial strength gears with tight tolerances Single Gear Objective Lens Movement Keeps the objective lenses aligned for the life of the microscope aventools.com | sales@aventools.com | 734.973.0099 Tools for Advancing Innovation
SPZV50-209-550-PCL 价格&库存
很抱歉,暂时无法提供与“SPZV50-209-550-PCL”相匹配的价格&库存,您可以联系我们找货
SPZV50-209-550-PCL
库存:4
SPZV50-209-550-PCL
  • 1+33784.216601+4366.58316
库存:4
