BB-305FXE-ST-15
BB-305FXE-ST-15
    B+BSMARTWORX
    UNMANAGED ETHERNET SWITCH
BB-305FXE-ST-15 数据手册
THE INDUSTRIAL NETWORK COMPANY The N-TRON® 305FX is an unmanaged five port Industrial Ethernet Switch. It is housed in a ruggedized DIN-RAIL enclosure, and is designed for use in industrial data acquisition, control, and Ethernet I/O applications. PRODUCT FEATURES • • • • • • • • • • • • • • • Compact Size, Small Footprint Full IEEE 802.3 and 1613 Compliance NEMA TS1/TS2 Compliance American Bureau of Shipping (ABS) Type Approval Extended Environmental Specifications Four 10/100 BaseTX RJ-45 Ports One 100BaseFX Port ST (shown) or SC RJ-45 Ports Support Full/Half Duplex Operation LED Link/Activity Status Indication Store-and-forward Technology Auto Sensing Duplex, Speed and MDIX (RJ-45) Up to 1.0 Gb/s Maximum Throughput Rugged Industrial DIN-RAIL Enclosure Redundant Power Inputs (10-30 VDC) N-View™ OPC Switch Monitoring Option PRODUCT OVERVIEW The 305FX Industrial Network Switch is designed to meet and exceed the most demanding industrial communication requirements while providing high throughput and minimum downtime. The 305FX provides four RJ-45 auto sensing 10/100BaseTX ports, plus a fiber based Fast Ethernet uplink port. All TX ports are full/half duplex capable, using "state of the art" Ethernet switching technology. The 305FX auto-negotiates the speed and flow control capabilities of the four TX port connections, and configures itself automatically. The fiber optic port utilizes industry standard ST or SC duplex connectors and is configured for full duplex operation. Both multimode and singlemode fiber models are available. The TX ports of the 305FX are auto sensing, so there will be no need to make extensive wiring changes due to future upgrades of host computers, plant systems, or Ethernet I/O modules. The switching fabric simply scales up or down automatically to match network environments. The 305FX supports up to 4,000 MAC addresses, enabling these products to support extremely sophisticated and complex network architectures. The 305FX is an ideal candidate for upgrading existing hubs and repeaters to increase bandwidth and determinism by virtually eliminating network collisions. The product provides a cost effective solution while maintaining the plug & play simplicity of an unmanaged hub. The 305FX can simplify plant wiring by eliminating the need to bring data acquisition and control network connections back to a climate controlled environment. The 305FX has extended operating environmental specifications to meet the harsh needs of the industrial environment. For cost savings and convenience the 305FX can be DIN-Rail mounted alongside Ethernet I/O or other industrial equipment. The unique compact size provides a small footprint, conserving space in the most critical dimension. The 305FX can also be panel mounted if desired. To increase reliability, the 305FX includes redundant power inputs. LED's are provided to display the link status and activity of each port, as well as power on/off status. N-VIEW OPC PORT MONITORING (With -N Option Only) The N-TRON N-View OLE for Process Control (OPC) server software can be combined with popular HMI software packages to add network traffic monitoring, trending and alarming to any application using N-TRON switches configured with the N-View option. N-TRON's N-View OPC Server collects 41 different traffic variables per port and 5 system level variables per switch. This information can provide a complete overview of the network load, service quality, and packet traffic. OPC client software can use N-View OPC Server data to resolve network problems quickly and improve system reliability. THE INDUSTRIAL NETWORK COMPANY 305FX-N SPECIFICATIONS BENEFITS Industrial Network Switch Case dimensions Height: Width: Depth: Weight: 3.5" 2.0" 3.4" 0.75 lbs (8.8 cm) (5.0 cm) (8.6 cm) (0.34 kg) Electrical Input Voltage: Input Current: Inrush: 10-30 VDC 250 mA@24V 10Amp/0.9ms@24V Environmental Operating Temperature: Storage Temperature: Operating Humidity: -20oC to 70oC -40oC to 85oC 10% to 95% (Non Condensing) 0 to 10,000 ft. Operating Altitude: Shock and Vibration (bulkhead mounting) Shock: Vibration/Seismic: 200g @ 10ms 50g, 5-200Hz, Triaxial Network Media 10BaseT: 100BaseTX: 100BaseFX Multimode: Singlemode: >Cat3 Cable >Cat5 Cable • • • • • • Compact Size, Small Footprint High Reliability/Availability Extended Environmental Specifications Ruggedized DIN-Rail Enclosure High Performance High MTBF >2M Hours (measured) Ease of Use • • • • • Plug & Play Operation Four Auto Sensing 10/100BaseTX RJ-45 Ports Auto Sensing Duplex, Speed and Cable Type Unmanaged Operation Compact DIN-Rail Package Increased Performance • • • • • • Full Wire Speed Capable 100BaseFX Fiber Uplink Full Duplex Capable Eliminates Network Collisions Increases Network Determinism N-View Switch Viewing Option 50-62.5/125μm 7-10/125μm Ordering Information Connectors 10/100BaseTX: 100BaseFX: Four (1) RJ-45 TX Ports One (1) ST or SC Duplex Port Recommended Wiring Clearance Front: Top: 4" (10.16 cm) 1" (2.54 cm) Fiber Length 2km* 15km** 40km** 80km** TX Power Min -19dBm -15dBm -5dBm -5dBm RX Sensitivity Max -32dBm -29dBm -34dBm -34dBm Wavelength 1310nm 1310nm 1310nm 1550nm Where "YY" is: 15 for 15km max. fiber segment length 40 for 40km max. fiber segment length 80 for 80km max. fiber segment length * Multimode Fiber Optic Cable ** Singlemode Fiber Optic Cable FCC Part 15 Class A UL Listed 1604 (US and Canada) CLASS I, DIV 2, GROUPS A,B,C,D,T4A, CE: EN61000-6-2,4, EN55011, EN61000-4-2,3,4,5,6 ABS Type Approval for Shipboard Applications GOST-R Certified RoHS Compliant 100BaseFX multimode fiber with N-View Firmware Option 100BaseFX singlemode fiber with N-View Firmware Option Where "XX" is: ST for ST style fiber connector SC for SC style fiber connector Fiber Transceiver Characteristics Regulatory Approvals 305FX-XX 305FX-N-XX 305FXE-XX-YY 305FXE-N-XX-YY Contact Information N-TRON Corp. 820 S. University Blvd., Suite 4E Mobile, AL 36609 USA TEL: (251) 342-2164 FAX: (251) 342-6353 Website: www.n-tron.com Email: N-TRON_info@n-tron.com N-TRON Europe GmbH Alte Steinhauserstr 19 6330 Cham / Zg Switzerland TEL: +41 41 7406636 FAX: +41 41 7406637 REV 090804 ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY 305FX Drawings on N-TRON Tech Docs Page ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
BB-305FXE-ST-15 价格&库存
很抱歉,暂时无法提供与“BB-305FXE-ST-15”相匹配的价格&库存,您可以联系我们找货
