BB-508TX-A
BB-508TX-A
    B+BSMARTWORX
    UNMANAGED ETHERNET SWITCH
BB-508TX-A 数据手册
THE INDUSTRIAL NETWORK COMPANY The N-TRON® 508TX Series Industrial Ethernet Switch offers outstanding performance and ease of use. It is ideally suited for connecting Ethernet enabled industrial and/or security equipment and can be optionally configured with advanced Ethernet communication management functions PRODUCT FEATURES • • • • • • • • • • • Full IEEE 802.3 and 1613 Compliance NEMA TS1/TS2 Compliance American Bureau of Shipping (ABS) Type Approval Eight 10/100 BaseTX RJ-45 Ports -40º to 85ºC Operating Temperature Auto Sensing 10/100BaseTX, Duplex, and MDIX Store-and-forward Technology Up to 2.6 Gb/s Backplane Throughput Rugged Industrial DIN-Rail Enclosure Redundant Power Inputs (10-30 VDC) Bi-Color LED's For Link, Speed, Activity & Duplex Status Advanced Management Features (With -A option only): • • • • • • IGMP Snooping VLAN QoS Trunking Mirroring N-ViewTM (Remote Monitoring Using OPC Technology) Advanced Management Functions The 508TX-A offers several management functions that can be easily configured using the COM Port (DB 9 Connector located on the right side of the switch). IGMP Snooping - Internet Group Management Protocol is a feature that allows the 508TX-A switch to forward and filter multicast traffic intelligently. VLAN - Virtual Local Area Network allows segmentation of the switch in order to create two or more separate local area network domains. QoS - Quality of Service provides prioritization of network traffic in order to provide better network service. The primary goal of QoS is to improve the latency of prioritized Ethernet packets required for ring management, real-time and other interactive applications. Trunking - Trunking (aggregation) enables multiple physical ports to be linked together and function as one uplink to another N-TRON trunking capable switch configured in the same manner, thereby increasing the bandwidth between switches. This configuration can provide increased bandwidth and redundancy to applications requiring high levels of fault tolerant operation. Port Mirroring - This 508TX-A function allows the traffic on one port to be duplicated and sent to a designated mirror port. Port mirroring can be used to monitor Ethernet traffic on the designated source port using the assigned mirror port. N-View OPC Switch Monitoring (With -A or -N Option Only) The N-TRON N-View OLE for Process Control (OPC) server software can be combined with popular HMI software packages to add network traffic monitoring, trending and alarming to any application using N-TRON switches configured with the N-View option. N-TRON's N-View OPC Server collects 41 different traffic variables per port and 5 system level variables per switch. This information can provide a complete overview of the network load, service quality, and packet traffic. OPC client software can use N-View OPC Server data to resolve network problems quickly and improve system reliability. Industrial Packaging and Specifications The N-TRON 508TX is designed to operate in industrial environments. It is housed in a rugged steel enclosure that can be DIN-RAIL or panel mounted, and an optional rackmount kit is also available. The 508TX comes standard with extended temperature rating, extended shock and vibration specs, redundant power inputs, and a high MTBF (greater than 2M hours). Ease of Use The N-TRON 508TX requires no setup unless the advanced port functions are utilized. The eight 10/100BaseTX ports are auto sensing and auto configuring. Each copper port is automatically negotiated for maximum speed and performance by default. Bi-color LED's are provided to display the link status, link speed and activity of each port as well as power on/off status. Performance The N-TRON 508TX uses "state of the art" IEEE 802.3 Fast Ethernet 10/100BaseTX switching technology. This technology eliminates network collisions and increases network determinism. Up to 4,000 MAC addresses are supported enabling sophisticated and complex network architectures. A high speed processor and backplane allows wire speed capability on all ports simultaneously. THE INDUSTRIAL NETWORK COMPANY 508TX Industrial Ethernet Switch Ordering Information 508TX Eight 10/100BaseTX Ports 508TX-N 508TX with N-View 508TX-A 508TX with N-View and Advanced Management Features 508TX-A Specifications Switch Properties Number of MAC Addresses: Aging Time: Latency Type.: Backplane Speed: Switching Method: 4,000 20s, Programmable (-A) 2.1 μs 2.6Gb/s Store & Forward Case Dimensions Height: Width: Depth: Weight: Din-Rail: 2.3" (5.8cm) 5.9" (15cm) 3.5" (8.8cm) 1.6 lbs (0.8kg) 35mm Electrical Redundant Input Voltage: Input Current: Inrush: 10-30 VDC 200 mA@24V 9.0Amp/0.6ms@24V Environmental Operating Temperature: Operating Humidity: Operating Altitude: -20oC to 70oC (Standard) -40oC to 85oC (Extended) 10% to 95% (Non Condensing) 0 to 10,000 ft. Shock and Vibration (bulkhead mounting) Shock: 200g @ 10ms Vibration/Seismic: 50g, 5-200Hz, Triaxial Serial Configuration Port Com Parameters: 9600,n,8,1 Network Media 10BaseT: 100BaseTX: Connectors 10/100BaseTX: >Cat3 Cable >Cat5 Cable Eight (8) RJ-45 Copper Ports Recommended Wiring Clearance Front: 4" (10.16 cm) Side: 1" (2.54 cm) Regulatory Approvals FCC/CE (CFR 47, Part 15, Subpart B, Class A) EMC Dir 89/336/EEC, EN 50204, EN 55011 EN61000-4-2/3/4/5/6/8/11, EN61000-6-2/4 ANSI C63.4, ICES-003 UL /cUL: Class I, Div 2, Groups A, B, C, D and T4A UL 508 and UL 1604 CAN/CSA-C22.2 No.213, ATEX II 3 G Ex nA ABS Type Approval for Shipboard Applications GOST-R Certified, RoHS Compliant Designed to comply with: IEEE 1613 for Electric Utility Substations NEMA TS1/TS2 for Traffic Control Contact Information Reliability MTBF: >2Million Hours N-TRON Corp. 820 S. University Blvd., Suite 4E Mobile, AL36609USA TEL: (251) 342-2164 FAX: (251) 342-6353 Website: www.n-tron.com Email: N-TRON_info@n-tron.com N-TRON Europe GmbH Alte Steinhauserstr 19 6330 Cham / Zg Switzerland TEL: +41 41 7406636 FAX: +41 41 7406637 REV 090804 ® 2009 N-TRON, Corp., N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA. THE INDUSTRIAL NETWORK COMPANY 508TX Drawings on N-TRON Tech Docs Page ® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
BB-508TX-A 价格&库存
很抱歉,暂时无法提供与“BB-508TX-A”相匹配的价格&库存,您可以联系我们找货
