BB-EIS-S-SC-EU
BB-EIS-S-SC-EU
    B+BSMARTWORX
    MEDIA CONVERTER 10/100 TO 100FX
BB-EIS-S-SC-EU 数据手册
10/100 Base-TX to 100Base-FX Media Converters EIS-x-Sx Series PRODUCT FEATURES • • • • • • • • • Media converters do more than just convert copper Ethernet signals to fiber. They allow your LAN to be extended beyond the normal 100 meter limit. By using a pair of media converters, LANs can be extended up to 2km with multimode fiber and up to 20km with single-mode fiber. Since your data is traveling via fiber, it’s protected from ground loop problems and electrical interference present along the cable run. The economical EIS series media converters are stand-alone products that come with a power supply or can be mounted in a 19 inch rack chassis. The optional rack system holds up to 16 of the EIS products and includes one power supply to power installed EIS models via the backplane. A second power supply for the rack system is available. Two power supplies will provide a load-sharing service to add redundancy to your system. If one power supply goes down, the other takes over immediately. 128K bits buffer memory DIP switch configuration for "Link-Fault-Pass-Through", speed, duplex mode 10/100Mbps-Full/Half-duplex Auto-negotiation, Auto-MDI/MDIX Full wire-speed forwarding rate Ships with12VDC external power supply 0°C to +45°C (+32°F to +113°F) operating temperature Aluminum case Desk, wall mount or optional chassis installation Ordering Information Model Number 10/100 Copper Fiber US Power Supply EIS-M-ST 1 (RJ-45) Multi-mode (ST) EIS-M-SC 1 (RJ-45) Multi-mode (ST) EIS-S-SC 1 (RJ-45) Single-mode (SC) European Power Supply (-EU) EIS-M-ST-EU 1 (RJ-45) Multi-mode (ST) EIS-M-SC-EU 1 (RJ-45) Multi-mode (ST) EIS-S-SC-EU 1 (RJ-45) Single-mode (SC) United Kingdom Power Supply (-UK) : EIS-M-ST-UK 1 (RJ-45) Multi-mode (ST) EIS-M-SC-UK 1 (RJ-45) Multi-mode (ST) EIS-S-SC-UK 1 (RJ-45) Single-mode (SC) Distance 2 km 2 km 20 km 2 km 2 km 20 km 2 km 2 km 20 km Accessories EIS-PS-US - EIS Series External Power Adapter 12V US Plug EIS-RACK-16 - Media Converter 19 Inch 2U Rack Chassis - 16 Slots EIS-RACK-PS - Power Supply For EIS-Rack-16, 84 Watts C5UMB3FBG - 3 ft - Beige - Category 5e UTP Patch Cord Assemblies EIS-PS-EU - EIS Series External Power Adapter 12V EU Plug DRT-960-48 - Power Supply, DIN, Metal, 960W, 48V, 340-550Vac 3Phase Input EIS-PS-UK - EIS Series External Power Adapter 12V UK Plug www.bb-elec.com | EIS-x-Sx Series_3713ds 10/100 Base-TX to 100Base-FX Media Converters EIS-x-Sx Series specifications Technology IEEE802.3 10BASE-T Standards IEEE802.3u 100BASETX/100BASE-FX, IEEE802.3x Store-and-Forward Processing Type Half-duplex back-pressure and IEEE802.3xfull-duplex flow control Forward and 14,880pps for 10Mbps; 148,810pps for 100Mbps Filtering Rate: Packet buffer memory: 128K bits Interface 10/100BASE-TX: 1 port Ethernet Port 100BASE-FX: 1 port Per Unit: Power Status (Power) Per port, 10/100T: Link/Activity, Full-duplex/Collision, LED Indicators: Speed Per port, 100FX: Link/Activity, Full-duplex/Collision Power Input Voltage: 12VDC Consumption 1.92W Max. 0.16A @ 12VDC Environmental Operating Temperature: 0 to 45°C (32 to 113°F) Storage Temperature: -10 to 70°C (14 to 158°F) Ambient Relative 5 to 95% (non-condensing) Humidity: Mechanical Enclosure Aluminum case 80.3W x 109.2D x 23.8H mm (3.16W x 4.30D x 0.94H in) Weight: 150g (0.33lb) Installation: chassis system Regulatory Approvals ISO: Manufactured in an ISO9001 facility Safety: UL60950-1 CE Mark Class A Emission Compliance: FCC Part 15 Class A VCCI Class A Dimensions: Mechanical diagram (dimensions in inches & millimeters) 100BASE-FX 10/100 LNK/ACT PWR 0.94 in 2.38 cm RX FDX/COL 100 TX 3.16 in 8.03 cm 4.29 in 10.92 cm 109.2m m TX DC12V orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-EIS-S-SC-EU
物料型号: - EIS-M-ST: 多模光纤(ST),2公里距离 - EIS-M-SC: 多模光纤(SC),2公里距离 - EIS-S-SC: 单模光纤(SC),20公里距离 - 电源型号包括:US、EU、UK
器件简介: - 媒体转换器可以将铜缆以太网信号转换为光纤信号,扩展局域网范围,使用多模或单模光纤。
引脚分配: - 10/100BASE-TX以太网端口:1个RJ-45接口 - 100BASE-FX光纤端口:1个端口
参数特性: - 标准:IEEE802.3 10BASE-T、IEEE802.3u 100BASETX/100BASE-FX、IEEE802.3X - 处理类型:存储转发、半双工回压、IEEE802.3x全双工流量控制 - 缓冲内存:128K位 - 功耗:最大1.92W,12VDC输入
功能详解: - 自动协商、自动MDI/MDIX - 128K位缓冲内存 - 支持全双工流量控制 - 12VDC外部电源适配器 - 工作温度:0°C到+45°C
应用信息: - 适用于需要扩展局域网的应用场景,通过光纤传输数据,避免电气干扰。
封装信息: - 铝制外壳,尺寸:80.3Wx 109.2D x 23.8H mm - 重量:150g - 安装方式:机架系统
BB-EIS-S-SC-EU 价格&库存
很抱歉,暂时无法提供与“BB-EIS-S-SC-EU”相匹配的价格&库存,您可以联系我们找货
