BP09AB0030
BP09AB0030
    B+BSMARTWORX
    CONN BACKSHELL 9POS 180DEG SHLD
BP09AB0030 数据手册
Documentation Number NOVA4799 – pg. 1/2 NovaHood™ Connector Covers The Ultimate in Versatility The NovaHood can be used for any style connector…. crimp-snap, solder and insulation displacement. A connector can be fitted in one or both ends. Cables may be routed from either side or end. Hoods are available for DB-9, DB-15 and DB-25 connectors. NovaHoods-clockwise from top left: black DB-25, Metalized DB-25, black DB-9, black DB-15 Simplified Assembly and Inventory The NovaHood is designed for maximum productivity in cable and interface adapter production while maintaining consistent high quality and low cost. The snap-lock case minimizes assembly time. No screws are required to hold the case together. And the two interlocking shells for each size are identical, simplifying inventory. The Economy of PLASTIC with the Quality and Security of METAL The standard NovaHood is rugged ABS plastic. If you need to meet FCC computer emissions restrictions, Tempest requirements or other applications requiring shielding, the 25-pin NovaHood can be purchased with an optional conductive metal plating to help achieve that goal. Gender-Menders and More In addition to use as a connector backshell, NovaHood can also be used to build gender changers, converters or anything else that requires two D-subminiature connectors. It can be used to build loop-back test plugs or jumper plugs in modem eliminators. Because of its sturdy, integrated design, the cable or system integrity is not compromised by these applications. NovaHoods “Your Way” NovaHoods may be purchased in bulk or in kits. Bulk prices are for two hood halves and a strain relief. Kits contain two hood halves, a strain relief, tie wrap and two 4-40 screws and saddle washers in a plastic bag. Standard color is black. Custom colors or metalizing on other sizes are available on quantity orders. Inquire about NovaHoods to suit your special needs, and for specific quantity order prices. Min. order: 20 pcs. PRICES* Part Number BP0925AK3011 BP25AB0020 BP25AK0020 BP25DK0010 BP25AB0030 SR25AB0030 BP15AB0010 BP15AK0010 BP09AB0010 BP09AB0030 BP09AK0010 Configuration Description Color DB-25/DB-9 DB-25 DB-25 DB-25 DB-25 DB-25 DB-15 DB-15 DB-9 DB-9 DB-9 Adapter - Kit Hood - Bulk Hood - Kit Double-length Hood - Kit Hood - Bulk Strain Relief Hood - Bulk Hood - Kit Hood - Bulk Hood - Bulk Hood - Kit Gray Black Black Black Metalized Metalized Black Black Black Metalized Black See page 2 for product drawings. *Intermediate and extended quantity price breaks available. Inquire. © B&B Electronics – Revised January 2002 This product designed and manufactured in USA of domestic and imported parts by In stock at B&B B&B USA Europe Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Documentation Number NOVA4799 – pg. 2/2 NovaHood™ Connector Covers From B&B Electronics Manufacturing Co. © B&B Electronics – Revised January 2002 This product designed and manufactured in USA of domestic and imported parts by
BP09AB0030 价格&库存
很抱歉,暂时无法提供与“BP09AB0030”相匹配的价格&库存,您可以联系我们找货
