I3B12Y/20B05-SCHF
I3B12Y/20B05-SCHF
    B+BSMARTWORX
    HMI 24-DC IN 16-DC OUT 2-ANLG IN
I3B12Y/20B05-SCHF 数据手册
Control/HMI i3-C iCube: All-in-One Control Solution Intelligence raised by the power of three! FREE Config uration Softwa re MODBUS PLRs Features i3-A LCD Monitors PC Touch Panels OIT Touch Panels PLCs i3-B The Power of i3: • 3 screen options • 3 built-in I/O options • 3 communication options • 3 solutions in one (HMI, PLC and open bus connectivity) • 3-year warranty • Programmable function keys • 2 communication ports RS232/RS485 • Embedded Ethernet with Webserver (i3C only) • GSM modem for SMS/Data or Ethernet (options) • Micro SD up to 2GB (option) • Digital and analog I/O (up to 42 points) • Expansion I/O (options) • 4 high-speed counters (10Khz Max) • PID control (up to 32 loops) • Alarm / Recipe / Animation / Bitmaps • Floating Point Math • Real Time Clock • 20+ Protocols (Modbus, AB DF1, Mitsubishi, GE Fanuc, etc.) • 256KB RAM (Ladder), 1MB Graphical • IP65 (NEMA4) CE, cUL, UL, Class 1 Div 2 (A & B versions) • Free configuration software • Input power: 10-30 VDC supply • Class 1, Div 2 Advantages of an Integrated Solution The iCube has capitalized on the progress made in microprocessor technology by condensing traditional control components into a single, compact unit - reducing manufacturing costs, overall power consumption of control solutions and application development time. Allows standardization to a single controller fitting most applications and greater flexibility for future development. The i3 controller offers the benefit of a full PLC - all the timers, math and complex functions as most standard PLC's - combined with PID, temperature and process control, on-board I/O, and expandability. The color HMI is a fantastic interface offering 1,040 custom screens supporting a variety of bit maps, and animation. i3 controllers also have expandable options: Ethernet and GSM/GPRS modem communications, optional built-in web server for the color touch screen controllers. Free configuration manager included - straight-forward programming software used for programming logic and screens. Model No. Screen Keys MicroSD Card Solid State Digital Outputs Relay Digital Outputs Inputs Analog Inputs Universal Analog Inputs Analog Outputs 2 2 2 2 2 2 Temperature Controllers KVM IP Switch Fanless PCs i3 - "A" Version - Monochrome Graphical Screen and Keys - W/ MicroSD function (96.0W x 96.0H x 75.5D mm) i3A12X/10A01-SOOF 2.25" Monotone 128x64 20 Y 12 1 i3A12X/20B05-SOHF 2.25" Monotone 128x64 20 Y 16 6 24 2 i3A12X/13C14-SOHF 2.25" Monotone 128x64 20 Y 12 12 i3 - "B" Version - Monochrome Graphical Touchscreen - W/ MicroSD function (96.0W x 96.0H x 75.5D mm) i3B12Y/10D03-SCHF 3.5" Monotone 160x128 5 Y 12 4 i3B12Y/20B05-SCHF 3.5" Monotone 160x128 5 Y 16 6 24 2 i3B12Y/13C14-SCHF 3.5" Monotone 160x128 5 Y 12 12 i3 - "C" Version - 32 bit Color Graphical Touchscreen - W/ MicroSD function (186.1W x 143.6H x 77.0D mm) i3C12Z/10D03-SCHF 5.7" 32k Color 320x240 6 Y 12 4 i3C12Z/20B05-SCHF 5.7" 32k Color 320x240 6 Y 16 6 24 2 i3C12Z/13C14-SCHF 5.7" 32k Color 320x240 6 Y 12 12 i3 - Serial Expansion Modules - DIN-Rail Mounted You May Also Need… Model No. Description Model No. Description IOS/M04ITX-D1 4 Channel TC input i3-E Ethernet Attachment IOS/M08BDR-D1 8 Channel Digital I/O - 4 inputs + 4 Relay outputs i3-MA GSM/GPRS Modem Attachment IOS/M12BDD-D2 12 Channel Digital I/O - 4 inputs + 8 Trn outputs i3PC45 Programming Cable 9-pin female to RJ-45 IOS/M04IPX-D1 4 Channel RTD input PC501 USB-Serial converter IOS/M08ICX-D1 8 Channel DC current input IOS/M12IDX-D1 12 Channel Digital Inputs IOS/M04OXA-D1 4 channel Analog output 14bit, 0-10/4-20mA www.bb-elec.com 815.433.5100
I3B12Y/20B05-SCHF
物料型号:i3系列控制器有多个型号,包括i3-A、i3-B和i3-C版本,每个版本都有不同的屏幕大小和功能。
器件简介:i3系列控制器是一个集成的控制解决方案,提供HMI、PLC和开放式总线连接。
引脚分配:文档中列出了不同型号控制器的输入输出配置,包括数字和模拟输入输出,以及继电器输出。
参数特性:控制器具有多种特性,如可编程功能键、两个通信端口、嵌入式以太网、GSM调制解调器选项、Micro SD卡扩展、数字和模拟I/O点、高速计数器、PID控制等。
功能详解:i3控制器提供全PLC功能,包括定时器、数学和复杂功能,结合了PID、温度和过程控制,以及板载I/O和可扩展性。HMI界面支持1,040个自定义屏幕,支持多种位图和动画。
应用信息:i3控制器适用于多种应用,通过集成传统控制组件到一个紧凑单元中,减少了制造成本和控制解决方案的总功耗,并缩短了应用开发时间。
封装信息:文档提供了不同版本的控制器尺寸信息,例如i3-A版本尺寸为96.0mm宽x96.0mm高x75.5mm深。
I3B12Y/20B05-SCHF 价格&库存
很抱歉,暂时无法提供与“I3B12Y/20B05-SCHF”相匹配的价格&库存,您可以联系我们找货
