ETS-1C-N-SL60VDC
ETS-1C-N-SL60VDC
    B+BSMARTWORX
    RELAY TB 60VDC
ETS-1C-N-SL60VDC 数据手册
Industrial Components Terminal Blocks Power Supplies Enclosures Relays Surge Protection Octal Base & Miniature/Cube Relays Electromechanical relays at low prices, industry best quality Features • ID label • Input LED status indicator • Output status flag • Industry socket compatible • Push to test button • Lock-down door for circuit testing B&B Electronics has partnered with Magnecraft to offer you electromechanical relays, solid state relays, timers and voltage Electromechanical relays – octal base • 24 VDC, 24 VAC, 120 VAC, 240 VAC input coils • DPDT or 3PDT contact outputs • 16 A contact rating • Optional MOV, Diode and RC filter modules Model No. 750XBXM4L-24A 750XBXM4L-120A 750XBXM4L-240A 750XBXM4L-24D 750XCXM4L-24A 750XCXM4L-120A 750XCXM4L-24D Coil Recommended Voltage Configuration Socket 24 VAC DPDT 70-750D8-1 120 VAC DPDT 70-750D8-1 240 VAC DPDT 70-750D8-1 24 VDC DPDT 70-750D8-1 24 VAC 3PDT 70-750D11-1 120 VAC 3PDT 70-750D11-1 24 VDC 3PDT 70-750D11-1 sensors. Our low prices, combined with Magnecraft quality, add up to a huge benefit to you. Electromechanical relays – miniature, cube • 24 VDC, 24 VAC, 120 VAC, 240 VAC input coils • SPDT, DPDT or 4PDT contact outputs • 15 A contact rating • Optional MOV, Diode and RC filter modules Model No. 781XAXML-240A 782XBXM4L-24A 782XBXM4L-120A 782XBXM4L-240A 782XBXM4L-24D 784XDXM4L-24A 784XDXM4L-120A 784XDXM4L-240A 784XDXM4L-24D Coil Recommended Voltage Configuration Socket 240 VAC SPDT 70-781D-1 24 VAC DPDT 70-782D-1 120 VAC DPDT 70-782D-1 240 VAC DPDT 70-782D-1 24 VDC DPDT 70-782D-1 24 VAC 4PDT 70-784D-1 120 VAC 4PDT 70-784D-1 240 VAC 4PDT 70-784D-1 24 VDC 4PDT 70-784D-1 Relay Sockets and Accessories Finger safe isolated circuits Model No. 70-781D5-1 70-782D8-1A 70-782D14-1 70-784D-1 70-750D8-1 70-750D11-1 Description Socket Socket Socket Socket Socket Socket Series 781 Series 782 Series TDR782 Series 784 Series 750XB Series 750XC Series MOV, Diode and RC modules available online at www.bb-elec.com/RelayAccessories Interface Relay Modules Slim, 6mm width for tight installations Features ETS-ICN-SL-24VDC Model # SRSI24AC/DC SRSI60AC/DC SRSI110AC/DC SRSI230AC/DC ETS-1C-N-SL06VDC ETS-1C-N-SL12VDC ETS-1C-N-SL24VDC ETS-1C-N-SL60VDC • Slim design, ONLY 6mm wide! • LED indication for coil status • Built in protection circuit Description Slim Relay Socket Slim Relay Socket Slim Relay Socket Slim Relay Socket SPST Relay SPST Relay SPST Relay SPST Relay www.bb-elec.com • Contact rating up to 6A • Wide temperature -40 to +70°C • UL recognized/CE approved Input Voltage 6-24VAC/DC 48-60VAC/DC 110-125VAC/DC 220-240VAC/DC 6 VDC coil 12 VDC coil 24 VDC coil 60 VDC coil 815.433.5100 861SSR210-DR1 Reliable, long service life, no moving parts Features • Input red LED status indicators • Finger-safe covers • Mounted aluminum heat sinks 22M Solid S M ta Relays te DIN Ra il Configuration SPST SPST SPST SPST SPST SPST SPST SPST SPST SPST SPST SPST SPST SPST Contact Rating 10A, AC 10A, AC 15A, DC 25 AC 40 AC 10 AC 25 AC 40 AC 10A, AC 10A, AC 20A, AC 30A, AC 20A, AC 30A, AC Relays Coil Voltage 3-32VDC 90-280VAC 3-32VDC 90-280 VAC 90-280 VAC 3-32 VDC 3-32 VDC 3-32 VDC 90-280VAC 4-32VDC 90-280VAC 90-280VAC 4-32VDC 4-32VDC Enclosures Package Type DIN Rail Mount DIN Rail Mount DIN Rail Mount Panel mount Panel mount Panel mount Panel mount Panel mount DIN Rail Mount DIN Rail Mount DIN Rail Mount DIN Rail Mount DIN Rail Mount DIN Rail Mount W6225AXXSZS-DC3 Power Supplies Model No. 861SSR210-DC1 861SSR210-AC1 861SSR115-DD W6225AXXSZS-AC90 W6240AXXSZS-AC90 W6210AXXSZS-DC-3 W6225AXXSZS-DC3 W6240AXXSZS-DC3 SSR210DIN-AC22 SSR210DIN-DC22 SSR220DIN-AC22 SSR230DIN-AC22 SSR220DIN-DC22 SSR230DIN-DC22 Solid State Relays – DIN Rail • 3 to 32 VDC or 90 to 280 VAC inputs • SPST contact outputs • 10 A or 25 A output rating • Isolated, zero voltage switching • 4000 VRMS isolation • RC and RFI suppression Terminal Blocks Solid State Relays – Panel Mount • 3 to 32 VDC or 90 to 280 VAC inputs • SPST contact outputs • 10 A, 25 A or 40 A output rating • Isolated, zero voltage switching • 4000 VRMS isolation • Internal snubber to protect from transients Smaller 22mm footprint SSRDIN230DIN-DC22 Surge Protection DIN Rail Timers, Voltage and Current Sensing Relays Most timing ranges, functions and voltages in a modular package TDR782XBXA-24D 831VS-120A Timers – DIN rail • 2 packages available • Universal input from 12 to 240 VDC or VAC • 7 or 10 timing functions from 0.1s to 10 days • Green input and red output status LED • 3/5A DPDT or 15A SPDT contact rating Voltage Sensors – DIN rail • 24-120VAC and 220-277VAC • 120 VAC input • Independent upper and lower limits • Time delay setting • 7 or 10 timing functions • Green input and red output status LED • 15A SPDT contact rating www.bb-elec.com Current Sensors – DIN rail • 24-240VAC input • Adjustable current setpoint • Adjustable time delay up to 10 seconds • 16A SPDT output contact rating Model No. Description 821TD10H-UNI Timer with 10 functions TDR782XBXA-24D Timer with 7 functions, 24VDC* TDR782XBXA-24A Timer with 7 functions, 24VAC* TDR782XBXA-110A Timer with 7 functions, 120VAC* 831VS-120A Voltage Sensor, 120VAC 831VS-240A Voltage Sensor, 240VAC 841CS1-UNI Current sensor, 1A 841CS2-UNI Current sensor, 2A 841CS5-UNI Current sensor, 5A *NOTE: TDR782 requires 70-782D14-1 socket. 815.433.5100 Industrial Components Solid State Relays, Sockets & Accessories 821TD10H-UNI
ETS-1C-N-SL60VDC
1. 物料型号:文档列出了多种型号的继电器和固态继电器,例如750XBXM4L-24A、750XCXM4L-24A、861SSR210-DC1等。
2. 器件简介:文档介绍了Magnecraft品牌的电磁继电器和固态继电器,包括它们的低价格和高质量。
3. 引脚分配:提供了不同型号继电器的引脚配置,如DPDT、3PDT、4PDT等。
4. 参数特性:列出了继电器的输入线圈电压、接触输出、接触额定电流等参数,例如24VDC、24VAC、120VAC、240VAC输入线圈,15A或16A接触额定电流。
5. 功能详解:文档描述了继电器的功能特点,如行业兼容插座、测试按钮、锁定门、输入LED状态指示器等。
6. 应用信息:提到了继电器的应用,如工业组件、固态继电器、定时器和电压传感器等。
7. 封装信息:提供了继电器的封装类型,如DIN导轨安装、面板安装等。
ETS-1C-N-SL60VDC 价格&库存
很抱歉,暂时无法提供与“ETS-1C-N-SL60VDC”相匹配的价格&库存,您可以联系我们找货
