SG2-12KR-D
SG2-12KR-D
    B+BSMARTWORX
    NANOPLC DC 12-IO RELAY
SG2-12KR-D 数据手册
Programmable Controllers | S G 2 P L R 2 www. factorymation. com SG2 Programmable Relay Specifications Power S upply Dis c rete Inputs Input Power Voltage R ange 12V DC Models : 10.4-14.4V 24V DC Models : 20.4-28.8V 110/220VAC : 85-265VAC Input S ignal ”OF F ” T hres hold Power C ons umption 12V DC : 12-point, 150mA 20-point: 150mA 24V DC : 12-point, 90mA 20-point: 150mA 100-240VAC : 90mA Input On delay 4mA @ 12V DC 3.2mA @ 24V DC 1.3mA @ 100-240VAC 12V DC : < 2.5V DC ; 24V DC : < 5V DC ; 110/220VAC : < 40VAC 12V DC : > 7.5V DC ; 24V DC : > 15V DC ; 110/220VAC : > 79VAC DC : 5ms ; 240VAC : 50ms ; 120VAC : 90ms Wire S ize (all terminals ) 26 to 14 AWG Input Off Delay DC : 3ms ; 240VAC : 50ms ; 120VAC : 90ms Trans is tor Type 3-wire P NP S ens or compatible C urrent cons umption Input S ignal ”ON” T hres hold P rogramming P rogramming languages Ladder/F unction B lock High S peed Input frequency 1kHz P rogram Memory 200 Lines or 99 F unction B locks S tandard Input frequency < 40 Hz P rogramming s torage media F las h R equired protection Invers e voltage protection required E xecution S peed 10ms /cycle A nalog Inputs LC D Dis play 4 lines x 12 characters R es olution T imers Maximum Number 15 T iming ranges 0.01s –9999min C ounters Maximum Number 15 Highes t count 999999 R es olution 1 15 R es olution 1min T ime s pan available week, year, month, day, hour, min Input S ignal ”ON” T hres hold > 9.8V DC (as 24V DC dis crete input) Is olation None S hort circuit protection Yes Total number available A1-A8 R elay Outputs R T C (R eal T ime C lock) Number available Input S ignal ”OF F ” T hres hold 10 bit Analog input: 0-10V DC , 24V DC when us ed as dis crete input < 5V DC (as 24V DC dis crete input) Voltage R ange acceptable C ompare Ins truc tions (A nalog, T imer, or C ounter Values ) C ontact material Ag Alloy C urrent rating 8A HP rating 1/3HP @ 120V 1/2HP @ 250V Maximum Load R es is tive: 8A/point; Inductive: 4A/point Maximum operating time 15ms (normal condition) Number available 15 C ompare vers us other inputs T imer, C ounter, or Numeric values Life expectancy (rated load) 100k operations Minimum load 16.7mA E nclos ure Type IP 20 Trans is tor Outputs Maximum V ibration 1G according to IE C 60068-2-6 P WM max. output frequency 0.5kHz (1ms on,1ms off) Operating Temperature R ange 32° to 131°F (0° to 55°C ) S tandard max. output frequency 100Hz S torage Temperature R ange -40° to 158°F (-40° to 70°C ) Voltage s pecification 10-28.8V DC Maximum Humidity 90% (R elative, non-condens ing) C urrent capacity 1A 0.075mm amplitude 1.0g acceleration 10-point: 230g 8-point:190g 20-point: 345g cUL , C E , UL Maximum Load R es is tive: 0.5A/point; Inductive: 0.3A/point Minimum Load 0.2mA E nvironmental V ibration Weight Agency Approvals Communication Options B uilt-in R S 485 C ommunic ation (S G 2-20V x-x units only) Modbus -R T U S lave mode only, 38.4kb, s upports Modbus function codes 3, 6, 8, 16 DataLink Link up to 3 S G 2-20V x-x units (1-mas ter, 2-s laves ) at 38.4kb R emote-I/O Link up to 8 R emote-I/O s lave units (S G 2-20V x-x only) to 1-mas ter unit at 8.4kb S G 2-MB US S lave C ommunic ation E xpans ion Module S lave mode only, 4.8kb - 38.4kb dip switch s electable, s upports Modbus function Modbus -R T U codes 3, 6, 8, 16, maximum 1 module per S G 2 main unit. Dimensions 10/12-point Models 20-point Models Expansion Modules All Modules SG2-xx-TECO-PLRs - 2709
SG2-12KR-D 价格&库存
很抱歉,暂时无法提供与“SG2-12KR-D”相匹配的价格&库存,您可以联系我们找货
