Programmable Controllers
TECO SG2 (V3) Programmable Relay Specifications
1.800.972.0436
79
General Specifications
Power Supply
Discrete Inputs
Input Power Voltage Range
12VDC Models: 10.4-14.4V
24VDC Models: 20.4-28.8V
110/220VAC: 85-265VAC
12VDC: 12-point, 150mA
20-point: 150mA
24VDC: 12-point, 90mA
20-point: 150mA
100-240VAC: 90mA
Input Signal ”OFF” Threshold
Power Consumption
Input On delay
4mA @12VDC
3.2mA @24VDC
1.3mA @100-240VAC
12VDC: < 2.5VDC; 24VDC: < 5VDC;
110/220VAC: < 40VAC
12VDC: > 7.5VDC; 24VDC: > 15VDC;
110/220VAC: > 79VAC
DC: 5ms; 240VAC: 50ms; 120VAC: 90ms
Wire Size (all terminals)
26 to 14 AWG
Input Off Delay
DC: 3ms; 240VAC: 50ms; 120VAC: 90ms
Transistor Type
3-wire PNP Sensor compatible
Current consumption
Input Signal ”ON” Threshold
Programming
Programming languages
Ladder/Function Block
High Speed Input frequency
1kHz
Program Memory
300 Lines or 260 Function Blocks
Standard Input frequency
< 40 Hz
Programming storage media
Flash
Required protection
Inverse voltage protection required
Execution Speed
10ms/cycle
Analog Inputs
Built-in HMI
Customizable screens
31 (H coils)
LCD Display
4 lines x 16 characters
Function Keys
8, 4 user-defined (Z inputs)
Auxiliary Coils
Maximum Number
31 T-coils
Timing ranges
0.01s–9999min
Counters
Maximum Number
31 C-coils
Highest count
999999
10 bit
Acceptable Input Range
Base module: Analog input: 0-10VDC voltage, 24VDC
when used as discrete input
Expansion module: Analog input: 0-10VDC voltage or
0-20mA current
126 (63 M-coils, 63 N-coils)
Timers
Maximum Number
Resolution
< 5VDC (as 24VDC discrete input)
> 9.8VDC (as 24VDC discrete input)
Isolation
None
Short circuit protection
Yes
Total number available
Base module: A01-A04
Expansion module: A05-A08
Temperature Input (SG2-4PT Expansion Module)
RTC (Real Time Clock)
Number available
31 R-coils
Resolution
1 min
Time span available
week, year, month, day, hour, min
Daylight Savings feature
Yes
Power off RTC retention
240 hours
Sensor Type
3-wire PT100
Temperature input range
-100°C - 600°C
Resolution
3.5°C
Relay Outputs
Contact material
Ag Alloy
Current rating
8A
HP rating
1/3HP@120V 1/2HP@250V
Maximum Load
Resistive: 8A/point; Inductive: 4A/point
Maximum operating time
15ms (normal condition)
NEW! PID Control (Proportional-Integral-Derivative)
Life expectancy (rated load)
100k operations
Maximum Number
Minimum load
16.7mA
Compare Instructions (Analog, Timer, or Counter Values)
Number available
31 G-coils
Compare functions
EQ, LT, GT, LE, GE, NE
15 Loops (PI Coils)
Transistor Outputs
NEW! Math Instructions
Number available
62 (31 AS Coils, 31 MD Coils) up to 124 additional
(plus unused T, C, R, G coils)
Pulse Outputs
1 PWM and 1 PWM or Pulse Output
Math Operations
+-x/
Standard max. output frequency
PWM max. output frequency
Data Multiplexer Instructions
0.5kHz (1ms on,1ms off)
100Hz
Voltage specification
10-28.8VDC
Number available
15 (MX Coils)
Current capacity
1A
Resolution
2-bit, 4 data registers
Maximum Load
Resistive: 0.5A/point; Inductive: 0.3A/point
Minimum Load
0.2mA
Data Registers
Number available
240 (DR Coils, 16-bit)
Analog Outputs (SG2-2AO Expansion Module)
Shift Instruction
Number available
1 8-bit (S Coil)
Analog Ramp Instructions
Number available
31 (AR Coils)
Environmental
0V–10V (load > 500 ohm), 0-20mA (load < 500 ohm)
Resolution
10-bit
Full scale accuracy
2.5%
Communication Options
Enclosure Type
IP20
Maximum Vibration
1G according to IEC60068-2-6
Operating Temperature Range
Analog output range
Built-in RS485 Communication (SG2-20Vx-x units only)
-4° to 131°F (-20° to 55°C)
Modbus-RTU
Master/Slave mode, 4800-115.2kb,
supports Modbus function codes 1, 3, 5, 6, 16
Storage Temperature Range
-40° to 158°F (-40° to 70°C)
Maximum Humidity
90% (Relative, non-condensing)
DataLink
Link up to 3 SG2-20Vx-x units (1-master, 2-slaves) at 38.4kb
Vibration
0.075mm amplitude; 1.0g acceleration
Remote-I/O
Link up to 8 Remote-I/O slave units (SG2-20Vx-x only) to 1-master unit at 8.4kb
Weight
10-point: 230g; 8-point:190g; 20-point: 345g
Agency Approvals
cUL , CE, UL
20-point Models
72
FREE Ground Shipping!*
for online orders over $500
Expansion Modules
80
126
All Modules
35.4
46.5
98
106
98
90
3-Ø4.5
90
106
98
2-Ø4.5
90
106
10/12-point Models
Dimensions
38
2-Ø4.5
59.6
1016
很抱歉,暂时无法提供与“SG2-12HR-D”相匹配的价格&库存,您可以联系我们找货
