SG2-20HR-D
SG2-20HR-D
    B+BSMARTWORX
    NANOPLC DC 20-IO RELAY
SG2-20HR-D 数据手册
Programmable Controllers TECO SG2 (V3) Programmable Relay Specifications 1.800.972.0436 79 General Specifications Power Supply Discrete Inputs Input Power Voltage Range 12VDC Models: 10.4-14.4V 24VDC Models: 20.4-28.8V 110/220VAC: 85-265VAC 12VDC: 12-point, 150mA 20-point: 150mA 24VDC: 12-point, 90mA 20-point: 150mA 100-240VAC: 90mA Input Signal ”OFF” Threshold Power Consumption Input On delay 4mA @12VDC 3.2mA @24VDC 1.3mA @100-240VAC 12VDC: < 2.5VDC; 24VDC: < 5VDC; 110/220VAC: < 40VAC 12VDC: > 7.5VDC; 24VDC: > 15VDC; 110/220VAC: > 79VAC DC: 5ms; 240VAC: 50ms; 120VAC: 90ms Wire Size (all terminals) 26 to 14 AWG Input Off Delay DC: 3ms; 240VAC: 50ms; 120VAC: 90ms Transistor Type 3-wire PNP Sensor compatible Current consumption Input Signal ”ON” Threshold Programming Programming languages Ladder/Function Block High Speed Input frequency 1kHz Program Memory 300 Lines or 260 Function Blocks Standard Input frequency < 40 Hz Programming storage media Flash Required protection Inverse voltage protection required Execution Speed 10ms/cycle Analog Inputs Built-in HMI Customizable screens 31 (H coils) LCD Display 4 lines x 16 characters Function Keys 8, 4 user-defined (Z inputs) Auxiliary Coils Maximum Number 31 T-coils Timing ranges 0.01s–9999min Counters Maximum Number 31 C-coils Highest count 999999 10 bit Acceptable Input Range Base module: Analog input: 0-10VDC voltage, 24VDC when used as discrete input Expansion module: Analog input: 0-10VDC voltage or 0-20mA current Input Signal ”OFF” Threshold 126 (63 M-coils, 63 N-coils) Timers Maximum Number Resolution < 5VDC (as 24VDC discrete input) Input Signal ”ON” Threshold > 9.8VDC (as 24VDC discrete input) Isolation None Short circuit protection Yes Total number available Base module: A01-A04 Expansion module: A05-A08 Temperature Input (SG2-4PT Expansion Module) RTC (Real Time Clock) Number available 31 R-coils Resolution 1 min Time span available week, year, month, day, hour, min Daylight Savings feature Yes Power off RTC retention 240 hours Sensor Type 3-wire PT100 Temperature input range -100°C - 600°C Resolution 3.5°C Relay Outputs Contact material Ag Alloy Current rating 8A HP rating 1/3HP@120V 1/2HP@250V Maximum Load Resistive: 8A/point; Inductive: 4A/point Maximum operating time 15ms (normal condition) NEW! PID Control (Proportional-Integral-Derivative) Life expectancy (rated load) 100k operations Maximum Number Minimum load 16.7mA Compare Instructions (Analog, Timer, or Counter Values) Number available 31 G-coils Compare functions EQ, LT, GT, LE, GE, NE 15 Loops (PI Coils) Transistor Outputs NEW! Math Instructions Number available 62 (31 AS Coils, 31 MD Coils) up to 124 additional (plus unused T, C, R, G coils) Pulse Outputs 1 PWM and 1 PWM or Pulse Output Math Operations +-x/ Standard max. output frequency PWM max. output frequency Data Multiplexer Instructions 0.5kHz (1ms on,1ms off) 100Hz Voltage specification 10-28.8VDC Number available 15 (MX Coils) Current capacity 1A Resolution 2-bit, 4 data registers Maximum Load Resistive: 0.5A/point; Inductive: 0.3A/point Minimum Load 0.2mA Data Registers Number available 240 (DR Coils, 16-bit) Analog Outputs (SG2-2AO Expansion Module) Shift Instruction Number available 1 8-bit (S Coil) Analog Ramp Instructions Number available 31 (AR Coils) Environmental 0V–10V (load > 500 ohm), 0-20mA (load < 500 ohm) Resolution 10-bit Full scale accuracy 2.5% Communication Options Enclosure Type IP20 Maximum Vibration 1G according to IEC60068-2-6 Operating Temperature Range Analog output range Built-in RS485 Communication (SG2-20Vx-x units only) -4° to 131°F (-20° to 55°C) Modbus-RTU Master/Slave mode, 4800-115.2kb, supports Modbus function codes 1, 3, 5, 6, 16 Storage Temperature Range -40° to 158°F (-40° to 70°C) Maximum Humidity 90% (Relative, non-condensing) DataLink Link up to 3 SG2-20Vx-x units (1-master, 2-slaves) at 38.4kb Vibration 0.075mm amplitude; 1.0g acceleration Remote-I/O Link up to 8 Remote-I/O slave units (SG2-20Vx-x only) to 1-master unit at 8.4kb Weight 10-point: 230g; 8-point:190g; 20-point: 345g Agency Approvals cUL , CE, UL 20-point Models 72 FREE Ground Shipping!* for online orders over $500 Expansion Modules 80 126 All Modules 35.4 46.5 98 106 98 90 3-Ø4.5 90 106 98 2-Ø4.5 90 106 10/12-point Models Dimensions 38 2-Ø4.5 59.6 ® 1016
SG2-20HR-D 价格&库存
很抱歉,暂时无法提供与“SG2-20HR-D”相匹配的价格&库存,您可以联系我们找货
