VESR922T-SC
VESR922T-SC
    B+BSMARTWORX
    ETHERNET TO SER RS-232/422/485
VESR922T-SC 数据手册
Ultra Compact Ethernet Serial Servers VESR900 Series - Fiber Models PRODUCT FEATURES • • • • • • Take control of your serial devices with Vlinx™ VESR9xx Industrial Ethernet Serial Servers. If it has a serial port, it can be monitored and controlled from anywhere on your Ethernet LAN or WAN. Keep it at maximum productivity without leaving your office. Even troubleshoot it from outside your LAN via the Internet. The easy to use Vlinx™ Manager software puts access to your whole shop on your desk. Configure devices, upgrade firmware and monitor activity. Configuration changes can also be made using a web browser. Multiple fiber optic options make integration into any existing network quick. No need to purchase an extra media converter when you can choose from multi-mode SC/ST, 15km single-mode SC/ST, 40 km single-mode SC/ST, or 80 km single-mode SC/ST. VESR92x series servers also feature an additional copper RJ45 port that allows you to connect another Ethernet device or PC work-station. This Pass-through port functions much like an unmanaged switch. Heartbeat connectivity keeps the serial server on-line. If connectivity is lost it will attempt to reconnect every five seconds until a connection is regained. A manual reboot is not required when communications are restored. Ethernet enable serial devices Direct IP, virtual COM port, or paired mode Ethernet pass-through port available Ethernet fiber options Serial RS-232/RS-422/485 ports UL Class 1 Division 2 Ordering Information Serial Model Number Serial Ports Connectors Ethernet Media VESR901-MC 1 DB9 & TB Multi-mode Fiber VESR901-MT 1 DB9 & TB Multi-mode Fiber VESR901-SC* 1 DB9 & TB Single Mode Fiber VESR901-ST* 1 DB9 & TB Single Mode Fiber VESR902D-MC 2 DB9 Multi-mode Fiber VESR902D-MT 2 DB9 Multi-mode Fiber VESR902D-SC* 2 DB9 Single Mode Fiber VESR902D-ST* 2 DB9 Single Mode Fiber VESR902T-MC 2 TB Multi-mode Fiber VESR902T-MT 2 TB Multi-mode Fiber VESR902T-SC* 2 TB Single Mode Fiber VESR902T-ST* 2 TB Single Mode Fiber CAT 5, Multi-mode VESR921-MC 1 DB9 & TB Fiber CAT 5, Multi-mode VESR921-MT 1 DB9 & TB Fiber CAT 5, Single VESR921-SC* 1 DB9 & TB Mode Fiber CAT 5, Single VESR921-ST* 1 DB9 & TB Mode Fiber CAT 5, Multi-mode VESR922T-MC 2 TB Fiber CAT 5, Multi-mode VESR922T-MT 2 TB Fiber CAT 5, Single VESR922T-SC* 2 TB Mode Fiber CAT 5, Single VESR922T-ST* 2 TB Mode Fiber Ethernet Connectors SC ST SC ST SC ST SC ST SC ST SC ST One RJ45, One SC One RJ45, One ST One RJ45, One SC One RJ45, One ST One RJ45, One SC One RJ45, One ST One RJ45, One SC One RJ45, One ST + All serial ports are software configurable for RS-232, RS-422, or RS-485. * 40km and 80km options available. For Copper options please see page 152. Accessories MDR-40-24 - DIN rail mount power supply 24VDC, 1.7 A output power ESR35 - DIN Rail 1 Meter 35mm Steel DRPM25 - 35mm DIN Rail to Panel Mount Bracket TBKT2 - Replacement Terminal Block, One 5 Position 5.08 mm TBKT1 - Replacement Terminal Block, One 2 Position 5.08 mm www.bb-elec.com | VESR900 Series - Fiber Models_3713ds Ultra Compact Ethernet Serial Servers VESR900 Series - Fiber Models Specifications Fiber Optic Technology VESR9xx-Mx Multi-mode / 1310 nm (-) 19 to (-) 14 dBm ~ (-) 32 dBm 62.5 / 125 µm SC or ST 2 km (1.2 miles) VESR9xx-Sx VESR9xx-Sx40 (available) VESR9xx-Sx80 (available) Single-mode / 1310 nm Single-mode / 1310 nm Single-mode / 1510 nm (-) 15 to (-) 8 dBm (-) 5 to 0 dBm (-) 5 to 0 dBm ~ (-) 32 dBm ~ (-) 34 dBm ~ (-) 34 dBm 9 / 125 µm 9 / 125 µm 9 / 125 µm SC or ST SC or ST SC or ST 15 km (9.3 miles) 40 km (25 miles) 80 km (49.7 miles) Network Physical Layer Standards IEEE 802.3 auto detecting & auto MDI/MDX, TD, RD, RTS, CTS, DTR, DSR, DTD, GND Ethernet 10BaseT and 100Base TX Data A(-), Data B(+), GND Protocols TDA(-), TDB(+), RDA(-), RDB(+), GND TCP, IPv4, UDP, ARP, HTTP 1.0, ICMP/PING, Protocols DB9M or Removable Terminal Blocks DHCP/BOOTP Up to 230.4 Kbps IP Mode Static, DHCP TCP/UDP User definable External Other 10 to 48 VDC (58 VDC Maximum) Connection Mode Server, Client, VCOM, Paired Removable Terminal Block (12 – 28 AWG) Client Connection At power up or upon data arrival VESR90x: 4.0 Watts Max. Serial direct COM and Ethernet Auto Search or Power Consumption Search VESR92x: 6.0 Watts Max. specific IP Display PC IP, ping, test VCOM, save test config Mechanical Diagnostics (text readable) LED Indicators Serial Port, Ethernet Link, Ready Firmware Upgrade Vlinx Manager Switches Reset Button Ethernet Pass-through Port (VESR92x) VESR90x:17.145 x 11.237 x 4.572 cm (6.750 x 4.424 x 1.800 in) Dimensions Standards IEEE 802.3, 802.3u, 802.3x VESR92x: 14.86 x 10.11 x 2.96 cm (5.85 x 3.98 x 1.16 in) Enclosure 35mm DIN mount, Plastic, IP 30 Store and Forward with 802.3x full duplex, non Processing Type blocking flow control VESR90x: 149.7 g (0.33 lbs) Weight IEEE 802.3x flow control, back pressure flow VESR92x: 204.1 g (0.45 lbs) Flow Control control Environmental MAC Address Table 2K Operating Temperature -40 to 80°C (-40 to 176°F) Configuration Software Operating Humidity 10 to 95% Non-condensing Windows 2000, XP (32/64 bit), 2003 Server VESR90x: ~ 132309 hours MTBF Vlinx Manager (32/64 bit), Vista (32/64 bit), 2008 Server (32/64 VESR92x: ~ 102593 hours bit), Win 7 (32/64 bit) MTBF Calc Method Parts Count Reliability Prediction Regulatory / Certifications / Safety Network Compliance FCC, CE, NEMA TS2 Serial Memory 8 KB per port UL Listed, File E222870 Network Memory 4 KB UL Class 1 Division 2 Groups A, B, C, D (HAZLOC) File E245458 Network Communications LAN 10/100 Mbps Auto-detecting , 10BaseT or 100BaseTX Type / Wavelength Output Power Receive Sensitivity Cable Connector Range Serial Technology RS-232 RS-485 2-Wire RS-422/485 4-Wire Serial Connector Data Rate Power Source Input Voltage Connector Mechanical diagram VESR90x MODELS Mechanical diagram VESR92x MODELS Ready P1 Link 11.237 cm 4.424 in 17.145 cm 6.750 in Port 1 17.145 cm 6.750 in Port 1 Ready P1 Link 11.237 cm 4.424 in 14.86 cm 5.85 in 10.11 cm 3.98 in 4.572 cm 1.800 in 4.572 cm 1.800 in orders@bb-elec.com support@bb-elec.com 14.86 cm 5.85 in 10.11 cm 3.98 in 2.95 cm 1.16 in 2.95 cm 1.16 in International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
VESR922T-SC 价格&库存
很抱歉,暂时无法提供与“VESR922T-SC”相匹配的价格&库存,您可以联系我们找货
