ZP8D-24RM-LR
ZP8D-24RM-LR
    B+BSMARTWORX
    ZLINK RADIO MODEM 24K 868MHZ
ZP8D-24RM-LR 数据手册
ZP8D-24RM-LR-0809ds page 1/3 ©2009 B&B Electronics. All rights reserved PRODUCT INFORMATION  ZP8D-24RM-LR Industrial Long Range 868 MHz Radio Modem  9 RS-232/422/485 Wire Replacement 9 Serial Data Rates up to 230.4 Kbps  9 Modbus ASCII/RTU   9 Long Range  9 Adjustable Transmitter Power   9 Wide Operating Temperature  9 10 – 48 VDC or 18 – 30 VAC Operation  Ideally suited for applications in which running cable is either to expensive or not practical. If you need to get a serial signal across a river, highway, or just to the other end of your warehouse Zlinx ™ Radio Modems can do the job easier, faster, and less expensive than running cable. Easy plug-andplay setup saves installation time. Since they are Modbus compatible, no external converters are required. Setting up and programming the modem is easy with the Zlinx™ Manager software. The software covers everything from basic to advanced settings B&B ELECTRONICS and firmware updates. • Long Range • Industrial Grade DIN Mount Case • European SRD G3 868 MHz Band • Wide Operating Temperature, -40 to 85 C • FSK Modulation • LED Signal Strength Display • Compact Omni Directional Antenna Included • Software Adjustable Transmitter Output • Point to point or point to multi-point operation ZP8D-24RM-LR-0809ds page 2/3 ©2009 B&B Electronics. All rights reserved PRODUCT INFORMATION  Specifications RS-232 Connector Signals Connector Signals RS-422 Connector Signals Termination RS-485 Connector Signals Modes SD Control Termination Serial Data Baud Data bits Parity Stop bit Link Failure Output Connector Type Current Industrial Bus DB9 F, DCE TD, RD, RTS, CTS, GND Removable Terminal Block TD, RD, GND Removable Terminal Block TDA(-), TDB(+), RDA(-), RDB(+), GND 120 Ohm, DIP Switch Selectable Removable Terminal Block TDA(-), TDB(+), RDA(-), RDB(+), GND 2 or 4 Wire Bit wise enabled 120 Ohm, DIP Switch Selectable 1200 to 230.4 7, 8 None, even, odd, mark, space 1, 2 Removable Terminal Block Open Collector (PNP), Dry Contact 40 mA Modbus ASCII/RTU Compatible Power Connector Voltage Power Consumption Source Terminal Blocks Wire Size Torque LED Indicators Power (RED) RSSI / Signal Level B&B ELECTRONICS Wireless Data Enclosure Material IP Rating Dimensions Mounting Environmental Intended use Op Temperature Storage Temp Op Humidity MTBF MTBF Calc Method Agency Approvals CE RoHS Removable Terminal Block 10 to 48 VDC or 18 to 30 VAC 6.0W Maximum External – Power supply is not included 28 to 16 AWG 0.2 Nm (Newton-Meters) ON = Power Applied, OFF = No Power GEEEN = Strong Yellow = Adequate Red = Weak GREEN – Flashes with data Plastic 30 3.05 x 8.38 x 11.94 cm (without antenna) 35 mm DIN Rail, Panel mount adapter is available, see ordering information Indoor outdoor within an enclosure -40 to 85 C -40 to 85 C 10 to 95% Non-condensing 172981 hours Parts Count Reliability Prediction Declaration of Conformity available For download Yes Radio Frequency Standard Range Frequency Band Transmitter Power Receiver Sensitivity RF Data Rate Duty Cycle Included Antenna Connector Gain Horizontal Beam Impedance VSWR Length Polarization Other Security Number of Channels Addressing Encryption Software Programming OS Features Proprietary RF Range depends on various conditions Ranges up to 40 km are possible 869.4 to 869.65 (868 ) MHz 1mW, 23mW, 100mW, 158mW, 316mW -112dBm @ 24Kbps 24 Kbps 10% hourly duty cycle restriction RP-SMA 3 dBi 360 degrees 50 Ohm < 2.0 21.9 cm Vertical Articulated to allowing it to be used vertically, at a right angle, or any angle in between Single Channel PAN ID, 64-bit addresses 128 bit AES Zlinx Manager Software on CD Windows 2000, 2003 Server, XP, and and Vista AT Command Terminal Emulation RSSI Signal Range Test Modem Emulation Ordering Information 868 MHz Long Range Radio Modem ZP8D-24RM-LR RM-LR824-KIT 868 MHz Radio Modem Kit Includes two radio modems, two 30W, 24V, DIN Rail Power Supplies, and one 6 foot serial cable for programming. Power Supply An external power supply is required but not included. Model DR-30-24 (30W, 24V, DIN Mount) should work in most applications. DRPM25 Panel Mount Adapter High Gain Antennas B&B Electronics has a full line of optional high gain antennas Replacement Items Replacement antenna ZP9D-ANT1 ZP9D-DIN1 Replacement DIN clip and spring ZP9D-TB1 Replacement terminal block and DIP Switch cover B&B ELECTRONICS PRODUCT INFORMATION  ZP8D-24RM-LR-0809ds page 3/3 ©2009 B&B Electronics. All rights reserved
ZP8D-24RM-LR 价格&库存
很抱歉,暂时无法提供与“ZP8D-24RM-LR”相匹配的价格&库存,您可以联系我们找货
