THE INDUSTRIAL NETWORK COMPANY
7506GX2
The N-TRON® 7506GX2 Fully Managed Industrial Ethernet Switch
provides all gigabit performance in a compact form factor. The 7506GX2 is
ideally suited for use in high traffic industrial applications such as security
and video surveillance where maximum throughput, a small footprint and
industrial ruggedness are required.
PRODUCT FEATURES
• Four 10/100/1000BaseT(X) RJ-45 Ports
• Two SFP (Mini-GBIC) Gigabit Transceivers (Optional)
• 1000BaseSX/LX Fiber with LC style connectors or
• 1000BaseT Copper with RJ-45 connectors
• -40o to 80oC Operating temperature
• ESD and Surge Protection Diodes on all Ports
• Auto Sensing 10/100/1000BaseT(X), Duplex, and MDIX
• Store-and-forward Technology
• Rugged DIN-Rail Enclosure
• Onboard Temperature Sensor
• Redundant Power Inputs (10-49VDC)
• Configurable Bi-Color Fault Status LED
Fully Managed Features:
SNMP v1, v2, v3 and Web Browser Management
Configuration backup via Optional SD card (NTCD)
Jumbo Frame Support (9720 Bytes)
EtherNet/IP™ CIP Messaging
Detailed Ring Map and Fault Location Charting
N-Ring™ Technology with ~30ms Healing
N-View™ OPC Monitoring
N-Link™ Redundant N-Ring Coupling
IGMP Auto Configuration
802.1Q tag VLAN and Port VLAN
802.1p QoS and Port QoS, and DSCP
LLDP (Link Layer Discovery Protocol)
Port Trunking
Port Mirroring
802.1d, 802.1w, 802.1D RSTP
DHCP Server, Option 82 relay, Option 61
Local Port IP Addressing
Management Features
The 7506GX2 offers several management functions that can be easily
configured using a web browser.
Automatic IGMP Snooping - Internet Group Management Protocol is
a feature that allows the 7506GX2 switch to forward and filter multicast
traffic intelligently.
VLAN - Virtual Local Area Network allows you to segment the switch
in order to create two or more separate local area network domains.
QoS - Quality of Service provides prioritization of network traffic
in order to provide better network service. The primary goal of QoS
is to improve the latency of prioritized Ethernet packets required for
ring management, real-time video, and other interactive applications.
Port Trunking - Trunking (link aggregation) enables multiple
physical ports to be linked together and function as one uplink to
another N-TRON trunking capable switch configured in the same
manner, thereby increasing the bandwidth between switches. This
configuration can provide increased bandwidth and redundancy
to applications requiring high levels of fault tolerant operation.
Port Mirroring - This function allows the traffic on one port to be duplicated
and sent to a designated mirror port. Port mirroring can be used to monitor
Ethernet traffic on the designated source port using the assigned mirror port.
Rapid Spanning Tree Protocol - RSTP allows the switch to be
configured in a ring or mesh topology, and provides support for
redundant path communications with high speed (rapid) healing.
Remote Monitoring Options - For ease of configuration and monitoring,
the 7506GX2 offers web browser management and N-View OLE for process
control (OPC) server software. The N-TRON N-View software can be
combined with popular HMI software packages to add network traffic
monitoring, trending, and alarming to any application using N-TRON
switches. In addition, SNMP is available for switch link and status
monitoring. The status LED can be configured to respond to power failure
on power input 1 or input 2, N-Link fault, port usage fault, N-Ring broken,
partial break high, partial break low, or if multiple ring managers are detected.
N-Ring Technology - N-TRON's 7506GX2 ring manager using N-TRON's
N-Ring technology offers expanded ring size capacity, detailed fault
diagnostics, and a standard healing time of ~30ms. The 7506GX2
ring manager periodically checks the health of the ring via
heart beat packets. If the ring manager stops receiving these health check
packets, it converts the ring to a linear topology within ~30ms. When
all switches in the ring are N-TRON fully managed switches, a detailed
ring map and fault location chart will also be provided on the ring
manager’s web browser and OPC server to identify the health status
of the ring. N-Link ™ allows the linking of two N-Rings. Up to 250
fully managed N-TRON switches can participate in N-Ring topologies.
LLDP - Link Layer Discovery Protocol is a vendor neutral discovery
protocol that allows switches and other LLDP capable devices on an
IEEE802 LAN to advertise their capabilities to, and discover information
from neighboring LAN members. Discovered information is stored in a MIB
accessible through SNMP management tools such as N-TRON's iSNMP.
DHCP - Dynamic Host Configuration Protocol is a network application
protocol used by devices (DHCP clients) to obtain configuration information
for operation in an Internet Protocol network. DHCP can make it easy to
add new machines to the network. N-TRON supports DHCP Server, Client,
Option 61, and Option 82. The 7506GX2 also supports Local Port IPAddressing.
This allows an IP address to be assigned to a specific port without using DHCP.
Industrial Packaging and Specifications - The 7506GX2 is designed
to operate in industrial environments. It is housed in a rugged extruded
aluminum DIN-Rail enclosure. It has extended industrial specifications and
features to meet or exceed the operating parameters of connected equipment.
These include extended temperature ratings, extended shock and vibration
specs, redundant power inputs, and high MTBF (greater than 2M hours).
Ease of Use - The 10/100/1000BaseT(X) ports are auto sensing and auto
configuring. Each copper port is automatically negotiated for
maximum speed and performance by default, but can also be hard
coded through the user interface. A high speed processor allows wire
speed capability on all 10/100/1000BaseT(X) ports simultaneously.
7506GX2 Industrial Ethernet Switch Ordering Information
7506GX2
7506GX2-SX
7506GX2-LX-10
NTSFP-TX
NTSFP-SX
NTSFP-LX-ZZ
NTCD-128
NTPS-24-1.3
1000-PM
URMK
Where:
Four 10/100/1000BaseT(X) Ports and two SFP ports without (optional) modules
Four 10/100/1000BaseT(X) Ports and two SFP ports with 2 NTSFP-SX Multimode modules installed
Four 10/100/1000BaseT(X) Ports and two SFP ports with 2 NTSFP-LX-10 Singlemode modules installed
Optional SFP (Mini-GBIC) Transceiver with One 1000BaseT GB Copper Port
Optional SFP (Mini-GBIC) Transceiver with One 1000BaseSX Multimode GB Fiber Optic Port
Optional SFP (Mini-GBIC) Transceiver with One 1000BaseLX Singlemode GB Fiber Optic Port
Optional SD Card, Configuration Device
N-TRON Power Supply - (1.3 Amp @ 24VDC)
Panel Mount kit
Universal Rack Mount Kit
ZZ = 10, 40, or 70 for GB Singlemode
7506GX2 Specifications
Switch Properties
Number of MAC Addresses:
Aging Time:
Latency Typical:
Switching Method:
SFP Gigabit Fiber Transceiver Characteristics
4000
Programmable
1.6 μs
Store-and-Forward
3.8"
2.0"
3.9"
1.1lbs
35mm
Electrical
Redundant Input Voltage:
Input Current (max):
N-TRON Power Supply:
10-49 VDC (Regulated)
440mA max.@24VDC
NTPS-24-1.3 (1.3A@24V)
Operating Altitude:
(9.6cm)
(5.1cm)
(9.9cm)
(0.48kg)
-40oC to 80oC
-40oC to 85oC
5% to 95%
(Non Condensing)
0 to 10,000 ft.
Shock and Vibration (bulkhead mounted)
Shock:
200g @ 10ms
Vibration/Seismic:
50g, 5-200Hz, Triaxial
Reliability
MTBF:
550m for 50/125μm*
Wavelength
>2 Million Hours
Recommended Wiring Clearance
Front:
4"
(10.16 cm)
Side:
1"
(2.54 cm)
-9.5dBm/-4dBm
-17dBm
850nm
Assumed Fiber Loss
Laser Type
Case Dimensions
Height:
Width:
Depth:
Weight (max):
DIN-Rail Mount:
Environmental
Operating Temperature:
Storage Temperature:
Operating Humidity:
Fiber Length
TX Power Min
RX Sensitivity Max
VCSEL
10km**
40km**
70km**
-9.5dBm/-3.5dBm -2dBm/3dBm 0dBm/5dBm
-24dBm
-20dBm
-22dBm
1310nm
1310nm
1550nm
-0.5dB/km
-0.35dB/km
-0.25dB/km
FP
DFB
DFB
* SX Fiber Optic Cable
** LX Fiber Optic Cable
Network Media
10BaseT:
100BaseTX:
1000BaseT:
>Cat3 Cable
>Cat5 Cable
>Cat5e Cable
Connectors
10/100/1000BaseT(X): Four (4) RJ-45 Copper Ports
1000BaseT:
Up to Two (2) RJ-45 Gigabit
Copper Ports (optional)
1000BaseSX/LX:
Up to Two (2) LC Duplex Gigabit
Fiber Ports (optional)
Regulatory Approvals
FCC Title 47, Part 15, Subpart B - Class A; ICES-003 - Class A
CE: EN61000-6-2:2001; EN61000-6-4:2007
EN61000-4-2, 3, 4, 5, 6
GOST-R Certified, RoHS Compliant
Designed to comply with:
UL Listed (US and Canada) 1604; ANSI/ISA-12.12.01-2007
Class I, Div. 2, Groups A, B, C, D, and T4A
IEEE 1613 for Electric Utility Substations
NEMA TS1/ TS2 for Traffic control
Contact Information
N-TRON Corp.
820 S. University Blvd., Suite 4E
Mobile, AL 36609 USA
TEL: (251) 342-2164
FAX: (251) 342-6353
Website: www.n-tron.com
Email: N-TRON_info@n-tron.com
N-TRON Asia
Unit 1209, Level 12
Chong Hing Finance Center
288 Nanjing Road West
200003 Shanghai
P.R. China
TEL: +86-021-6133-7770
FAX: +86-021-6133-7999
N-TRON Europe GmbH
Alte Steinhauserstr 19
6330 Cham / Zg Switzerland
TEL: +41 41 7406636
FAX: +41 41 7406637
REV 091202
® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Product names mentioned herein are for identification purposes only and
may be trademarks and/or registered trademarks of their respective company. Specifications subject to change without notice. The responsibility for the use and application
of N-TRON products rests with the end user. N-TRON makes no warranties as to the fitness or suitability of any N-TRON product for any specific application. N-TRON Corporation
shall not be liable for any damage resulting from the installation, use, or misuse of this product. Printed in USA.
® 2009 N-TRON, Corp. N-TRON and the N-TRON logo are trademarks of N-TRON, Corp. Specifications subject to change without notice. Printed in USA.
