ABDG-SE-IN5420
ABDG-SE-IN5420
    B+BSMARTWORX
    SERIAL DEVICE SERVER 2-PORT
ABDG-SE-IN5420 数据手册
Airborne Industrial Wireless Serial Device Server Serial to 802.11b/g Wireless LAN ABDG-SE-IN5410, ABDG-SE-IN5420 Five Layer Security The Airborne™ line of industrial wireless device servers and Ethernet adapters are built for networking equipment in an array of machine-to-machine (M2M) applications. Available in both single and dual-port models, each wireless device server comes standard with industry-leading RF performance, enterprise class security support, and industrial-strength packaging designed to withstand the most challenging M2M environments. Protecting enterprise networks is one of the most important challenges undertaken by today’s network administrators. Airborne security keeps your data private by using the latest wireless security protocols (WPA2-Enterprise) and SSH tunneling. It protects the network by encrypting configurations and providing an embedded firewall. Today there is no more secure solution for Enterprise class device servers. Quatech supports the broadest range of EAP processes (including EAP-TLS, EAP-TTLS, PEAP and LEAP). In addition, the Airborne line supports the most flexible certificate delivery and management available in the wireless device market. Maximum Protection and Performance Quatech’s ruggedized, industrial device servers are built tough—tough enough to come with a standard 5 year warranty. KEY FEATURES  Extended operating temperature range (-20°C to +85°C)  Plug-n-Play Serial to 802.11 Connectivity and Ethernet to 802.11 Connectivity  Enterprise Class wireless security (WPA2-Enterprise, WPA, WEP, EAP)  Airborne Management Center included for Quatech device discovery, control and management  Variable DC power supply (5-36 VDC) with screw terminal connectors  2 kV serial ESD Surge Suppression  Airborne SpeedLink roaming for enhanced connection reliability  Onboard certificate delivery and storage  Airborne PortFlex capability enables any combination of comm ports (Serial, Ethernet and 802.11 interfaces)  CE and FCC Part 15 Class B Sub C Approval  5 year warranty The Airborne product line is rated to meet full industrial operating temperature range of -20°C to +85°C. The industrial series also incorporates a variable power supply (5-36 VDC) with screw terminal connectors for easy installation. Airbone wireless device servers come standard with an integrated 3 dBi omni antenna. Users may also extend the range of the Airborne line by selecting a higher-gain antenna and magnetic mount options (contact Quatech for an approved list). Quatech’s highly-optimized 32 bit platform delivers superior transmit power and receive sensitivity, leading to greater range and the highest available throughput rates over both the serial and 10/100 Ethernet interfaces. All Airborne Wireless Device Servers are built to meet worldwide regulatory requirements. Certifications include FCC, IOC, CE, ETSI, RoHS and WEEE. 707 Dayton Road | P.O. Box 1040 | Ottawa, IL 61350 +1 815.433.5100 | www.bb-elec.com SpeedLink™ Roaming Flexible for a Broad Range of Applications The latest Airborne SpeedLink™ roaming feature further enhances the high level of connection reliability. SpeedLink™ enables mobile devices to roam quickly and freely throughout a wireless network without loosing important data. If you’re walking around a hospital or driving through a warehouse SpeedLink™ ensures you stay connected. Markets Quatech has delivered high-performance device networking and connectivity solutions around the world since 1983. Today, Airborne wireless device servers and Ethernet adapters operate in a wide-range of M2M applications, including: • Industrial Automation • Medical Devices • Retail/Point of Sale • Vehicle Telematics • Military Communications • Material Handling & Logistics • Energy Management • Test & Measurement • Security & Access Control Airborne’s unique PortFlex™ capability enables users to configure communication ports in any combination through a simple setup wizard. Airborne PortFlex™ supports UART, Ethernet and 802.11 interfaces, and provides the ability to independently configure each port. Data and control can be accessed to and from any of the available ports on the device. For example the serial data can be accessed from the wireless or Ethernet port while the device is managed from the same port without changing the device configuration. Model Selection Guide Interface Model No. RS-232 RS-422/485 WiFi Ports 10/100 Ethernet Security WEP 802.11b/g (64 & 128 bit) WPA WPA2 LEAP EAP ABDG-SE-IN5410 • • 1 • • • • • • • ABDG-SE-IN5420 • • 2 • • • • • • • Accessories PS-SDS Optional 120VAC/DC power supply, providing 5VDC @ 3w (max)/2.1 mm barrel ACH2-AT-DP002 2 dBi portable (Rubber duck) antenna (RP-SMA) ACH2-AT-DP003 5 dBi portable (Rubber duck) antenna (RP-SMA) ACH2-AT-DP011 5 dBi magnetic mount vehicle antenna, indoor/outdoor 707 Dayton Road | P.O. Box 1040 | Ottawa, IL 61350 +1 815.433.5100 | www.bb-elec.com © 2012 B&B Electronics Mfg. Co. Rev. B 1/2012 Airborne Management Center Managing your Airborne™ products is now simpler, whether you have one or one thousand. KEY FEATURES The Quatech Airborne Management Center (AMC) is a device discovery, control and management application that supports individual and group management of all aspects of the devices: • Firmware updating • Configuration management • Access management (passwords) • Virtual COM port installation AMC allows a single or group of devices to have their firmware updated in the background. • Directly launch web browser for devices from AMC • Automatically informs user of new and unmanaged devices • Supports cloning device configurations across groups of units • Manages all DP100, DP500 and DP550 devices • Records configuration changes for automatic update logging • Predefined device configuration templates available • Remembers all discovered devices and maintains a database of their configuration • JAVA application included that will run on Windows, Linux and MacOS platforms • Allows unauthorized devices to be marked as rogue The Quatech Airborne Management Center (AMC) brings Enterprise class device discovery, management and control to the world of M2M wireless devices. This advanced device management application enables single-click maintenance of your entire population of deployed products. From either the directory or table based views, you can: • Update firmware and configurations • Deliver certificates and private keys • Access and monitor groups of devices AMC Command Set With just a single click, AMC provides access to a range of commands and functions: • Locate modules • Launch web browser • Blink POST LED • Refresh, display and edit configs • Install VCOM Driver • Set preconfigured passwords *All trademarks are the property of Quatech, Inc. • Add and manage templates • Update module firmware and Uboot • Restart module • Manage or unmanage • Remove modules • Set modules to rogue VCom port drivers can be installed with one click, enabling the use of legacy software to communicate with networked devices seemlessly through Comm Port Addresses (i.e., com1, com2) in the system’s device manager. Quatech’s VCom driver takes care of routing virtual comm ports to the network devices. 707 Dayton Road | P.O. Box 1040 | Ottawa, IL 61350 +1 815.433.5100 | www.bb-elec.com © 2012 B&B Electronics Mfg. Co. Rev. B 1/2012 Specifications Mechanical Outline Supply 5-36 VDC+/-5%, 500mA (MAX) Wired Interface RS-232 RS-422 RS-485 MEI (2 wire) 10/100 Ethernet (auto sense) Software selectable Power Consumption 2.5W @ 5VDC Frequency 2.4 ~ 2.4835 GHz (US/Canada/Europe) 2.4 ~ 2.497 GHz (Japan) Modulation Technology DSSS, CCK, OFDM Modulation Type DBPSK, DQPSK, CCK, BPSK, QPSK, 16QAM, 64QAM Network Access Modes – Infrastructure – Ad Hoc Channels USA/Canada: 11 channels Europe: 13 channels France: 4 channels Japan: 14 channels 13 channels - 11g Wireless Data Rate 802.11b = 11, 5.5, 2, 1 Mbps 802.11g = 54, 48, 36, 24, 18, 12, 9, 6 Mbps Network Protocols TCP/IP, ARP, ICMP, DHCP, DHS, UDAP, TFTP, UDP, PING, HTTP, FTP Receive Sensitivity 54 Mb/s = -69dBm 6 Mb/s = -86dBm 1 Mb/s = -86dBm Wireless Security Open WEP 64 & 128 bit WPA-PSK (TKIP) WPA2-PSK (AES) 802.1x (EAP) WPA-Enterprise WPA2-Enterprise EAP-TLS/MSCHAPV2 EAP-TTLS/MSCHAPv2 EAP-TTLS(MD5) EAP-PEAPv0/MSCHAPv2 LEAP – Zero host security footprint – Advanced certificate storage & management Secure Communications – SSH and SSL tunneling – Encrypted configuration Antenna RP-SMA antenna connector Integrated omni-directional 3dBi antenna 107.42mm (4.23”) 28.44mm (1.12”) Wireless Technology IEEE 802.11b/g, WiFi compliant Supply In-rush Current 3000mA (MAX) for 20ms Power Connector 2-position terminal block 2.1mm barrel jack Top View DC Characteristics Operating current = 190mA @ 5VDC (Typ.) PS-Poll mode = 140mA @ 5VDC (Typ.) Connectors 1 x DE-9 (DB-9) – IN5410 2 x DE-9 (DB-9) – IN5420 1 x RJ-45 socket 1 x RP-SMA Front View Enclosure Ruggedized metal (Black) DIN rail mounting adapter Dimensions 120.14 mm x 120.12 mm x 29.21 mm (4.89” x 4.73” x 1.15”) Regulatory Approvals FCC Part 15.247, Class B Sub C Modular Approval Industry Canada RSS-210 CE ETSI EN300-328 v1.7.1 ETSI 60950-1 Directive 2004/108/EC ETSI EN 55022:2006 + A1:2007 (emissions) ETSI EN 55024:1998 + A1:2001 ETSI EN 55024:1998 + A2:2003 (immunity) FCC Part 15 Subpart B:2007 – Part 15.107(b) (conducted emissions, Class A) – Part 15.109(g) (radiated emissions, Class B) Industry Canada ICES-003:2004, Issue 4 AS/NZS CISPR 11:2004 (Australia/New Zealand) RoHS and WEEE Compliant Environmental Operating temperature: -20°C to +85°C Storage temperature: -55°C to +150°C Relative humidity: 5% to 95% (non-condensing) LED Indicators 4 Indicator LEDs (POWER, POST, LINK, COMM) Site survey mode Airborne Management Center – Fully supported – Device identification – Enhanced discovery – Configuration management – Firmware update – VCOM install Port View (Model 5020 shown) Serial Connectors DB-9 Male, External View Signal Information DB-9 RS-485 RS-485 RS-232 RS-422 Pin # (4-wire) (2-wire) 1 NC RxD+ RxD+ NC 2 RxD RxD- RxD- -Tx/-Rx 3 TxD TxD+ TxD+ +Tx/+Rx 4 NC TxD- TxD- NC 5 GND GND GND GND 6 NC RTS- NC NC 7 RTS RTS+ NC NC 8 CTS CTS+ NC NC 9 NC CTS- NC NC 707 Dayton Road | P.O. Box 1040 | Ottawa, IL 61350 +1 815.433.5100 | www.bb-elec.com © 2012 B&B Electronics Mfg. Co. Rev. B 1/2012
ABDG-SE-IN5420 价格&库存
很抱歉,暂时无法提供与“ABDG-SE-IN5420”相匹配的价格&库存,您可以联系我们找货
