BB-DB9FTB
BB-DB9FTB
    B+BSMARTWORX
    ADAPT DB9F TO TERM BLOCK 9POS
BB-DB9FTB 数据手册
DB to Terminal Block Adapters – DIN Rail Mount & Inline Versions Models DR9MTB, DR9FTB, DR25FTB, DB9MTB, DB9FTB www.advantech-bb.com PRODUCT FEATURES • • • • • DR9MTB DR25FTB Compact size for tight installation spaces Simplify field wiring in industrial cabinets Shielded ground terminal block DIN rail versions - replace DIN mounted devices easily and quickly Inline versions - connect quickly, plug and go DB9FTB Make wiring easy in industrial cabinets or other installations with these DB to terminal block adapters. Compact size is perfect for wiring areas with limited space. DIN rail or inline installation options. Connections can be made quickly without special tools. Install them once then replace components error-free with a simple unplug/re-plug, rather than tediously unfastening and refastening numerous wires individually to terminal blocks. Each pin on the DB connector has a corresponding terminal block that is marked. In addition, an extra terminal block is provided that connects to the shield of the DB connector (used for grounding purposes). The DB connector accepts industrial standard 4-40 locking screws. ORDERING INFORMATION MODEL NUMBER DESCRIPTION MOUNTING DR9MTB DB9 Male to Terminal Block Adapter DIN Rail Mount DR9FTB DB9 Female to Terminal Block Adapter DIN Rail Mount DR25FTB DB25 Female to Terminal Block Adapter DIN Rail Mount DB9MTB DB9 Male to Terminal Block Adapter Inline DB9FTB DB9 Female to Terminal Block Adapter Inline SPECIFICATIONS TECHNOLOGY Terminal Blocks Up to 14 AWG (Compression Clamp Terminal Blocks) Voltage Rating 125 VAC, 150 VDC Current Rating: 1A DR9MTB: DB9 male DR9FTB: DB9 female DB Connector DR25FTB: DB25 female DB9MTB: DB9 male DB9FTB: DB9 female MECHANICAL DR9FTB: 7.4 x 3.3 x 5.5 cm (2.9 x 1.3 x 2.1 in) DR9MTB: 7.4 x 3.3 x 5.5 cm (2.9 x 1.3 x 2.1 in) Dimensions DR25FTB: 7.4 x 7.1 x 5.5 cm (2.9 x 2.8 x 2.1 in) DB9MTB: 4.4 x 3.1 x 2.3 cm (1.7 x 1.2 x 0.9 in) DB9FTB: 3.7 x 3.1 x 1.6 cm (1.5 x 1.2 x 0.5 in) Housing Plastic 35mm or 32mm DIN rail. Mounting Options Inline. DR9MTB: 53.86 gm (1.9 oz) DR9FTB: 53.86 gm (1.9 oz) Weight DR25FTB: 107.73 gm (3.8 oz) DB9MTB: 22.68 gm (0.8 oz) DB9FTB: 22.68 gm (0.8 oz) All product specifications are subject to change without notice. Dx9xTB_DR25FTB_3817ds orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-DB9FTB 价格&库存
很抱歉,暂时无法提供与“BB-DB9FTB”相匹配的价格&库存,您可以联系我们找货
