DR-15-5
DR-15-5
    B+BSMARTWORX
    AC/DC CONVERTER 5V 15W
DR-15-5 数据手册
15W Single Output Industrial DIN Rail Power Supply DR-15 series ■ ‧ ‧ ‧ ‧ ‧Ⅱ ‧ ‧ ‧ ‧ .. SPECIFICATION MODEL OUTPUT INPUT DR-15-5 DR-15-12 DR-15-15 DR-15-24 DC VOLTAGE 5V 12V 15V 24V RATED CURRENT 2.4A 1.25A 1A 0.63A CURRENT RANGE 0 ~ 2.4A 0 ~ 1.25A 0 ~ 1A 0 ~ 0.63A RATED POWER 12W 15W 15W 15.2W RIPPLE & NOISE (max.) Note.2 80mVp-p 120mVp-p 120mVp-p 150mVp-p VOLTAGE ADJ. RANGE 10.8 ~ 13.2V 13.5 ~ 16.5V 21.6 ~ 26.4V VOLTAGE TOLERANCE Note.3 ±2.0% ±1.0% ±1.0% ±1.0% LINE REGULATION ±1.0% ±1.0% ±1.0% ±1.0% LOAD REGULATION ±1.0% ±1.0% ±1.0% ±1.0% SETUP, RISE TIME 1000ms, 50ms/230VAC HOLD UP TIME (Typ.) 70ms/230VAC VOLTAGE RANGE 85 ~ 264VAC FREQUENCY RANGE 47 ~ 63Hz 83.5% 85% 4.75 ~ 5.5V 77% AC CURRENT (Typ.) INRUSH CURRENT (Typ.) 0.88A/115VAC 0.48A/230VAC COLD START 35A/115VAC 65A/230VAC Note.5 PROTECTION OVER VOLTAGE WORKING TEMP. WORKING HUMIDITY ENVIRONMENT STORAGE TEMP., HUMIDITY EMC (Note 4) OTHERS 84% 105 ~ 160% rated output power Protection type : Constant current limiting, recovers automatically after fault condition is removed 5.75 ~ 6.75V 13.8 ~ 16.2V 17.25 ~ 20.25V 27.6 ~ 32.4V Protection type : Shut off o/p voltage, clamping by zener diode -20 ~ +60℃ (Refer to "Derating Curve") 20 ~ 90% RH non-condensing -40 ~ +85℃, 10 ~ 95% RH TEMP. COEFFICIENT VIBRATION SAFETY STANDARDS WITHSTAND VOLTAGE ±0.03%/℃ (0 ~ 50℃) 10 ~ 500Hz, 2G 10min./1cycle, period for 60min. each along X, Y, Z axes; Mounting: Compliance to IEC60068-2-6 UL60950-1, TUV EN60950-1 approved, design refer to EN50178 ISOLATION RESISTANCE EMC EMISSION I/P-O/P:100M Ohms / 500VDC / 25℃/ 70% RH Compliance to EN55011, EN55022 (CISPR22), EN61204-3 Class B, EN61000-3-2,-3 EMC IMMUNITY MTBF Compliance to EN61000-4-2, 3, 4, 5, 6, 8, 11, EN55024, EN61000-6-2, EN61204-3, heavy industry level, criteria A DIMENSION PACKING NOTE 16ms/115VAC at full load 120 ~ 370VDC EFFICIENCY (Typ.) OVERLOAD SAFETY & 1000ms, 50ms/115VAC at full load I/P-O/P:3KVAC 1172.3K hrs min. MIL-HDBK-217F (25℃) 25*93*56mm (W*H*D) 0.1Kg; 140pcs/15Kg/0.92CUFT ℃       File Name:DR-15-SPEC 2011-06-17 DR-15 15W Single Output Industrial DIN Rail Power Supply Mechanical Specification Case No.985A series Unit:mm 67.2 44.2 56 47 26.7 4 46.5 46.5 93 N 5 Vadj. 5 25 35 LED -V L +V ADMISSIBLE DIN-RAIL:TS35/7.5 OR TS35/15 Block Diagram RECTIFIERS & FILTER EMI FILTER I/P RECTIFIERS & FILTER POWER SWITCHING +V -V DETECTION CIRCUIT O.L.P. CONTROL O.V.P. Derating Curve Output Derating VS Input Voltage 100 100 90 80 80 70 LOAD (%) LOAD (%) 60 40 20 -20 0 10 20 30 40 50 AMBIENT TEMPERATURE (℃) 60 70 (VERTICAL) 60 50 40 85 95 100 115 120 140 160 180 200 220 240 264 INPUT VOLTAGE (VAC) 60Hz File Name:DR-15-SPEC 2011-06-17
DR-15-5 价格&库存
很抱歉,暂时无法提供与“DR-15-5”相匹配的价格&库存,您可以联系我们找货
