BB-EIR508-T
BB-EIR508-T
    B+BSMARTWORX
    NETWORK SWITCH-MANAGED 8 PORT
BB-EIR508-T 数据手册
EIR508-xxx-x 1713ds - 1/2 © 2008 by B&B Electronics. All rights reserved. Model: EIR508 Series Eight Port Managed Industrial Ethernet Switches Features 9 X-Ring Automatic Recovery 9 Dual 12 to 48 VDC Power Inputs 9 Relay Alarm Output 9 IP30 DIN Rail or Panel Mount 9 Wide Operating Temperature 9 Automatic E-mail Notification for system events 9 SNMP or Web GUI Management Functional Description The Elinx EIR508 series of Industrial Managed Ethernet Switches provide powerful functionality in a small package. Designed for industrial applications, these switches contain all the standard features of other switches, such at IGMP Snooping, Port Based VLAN, 802.1Q Tag VLAN, RJ-45 automatic MDI/MDI-X, auto negotiation, store and forward switching, STP, RSTP, Web Based Management, Ingress Packet Filtering, and Egress Rate Control. These managed switches also come with important industrial features to ensure reliability in an industrial application. X-Ring technology with coupling ring and dual homing allows automatic recovery in less than 300 MS. Dual power inputs ensure reliability. A relay alarm output for port failure notification. DIN Rail and Panel Mounting options on the same IP30 case. Another important feature is automatic e-mail notification for system events such as a cold start, change in network topology, power status or SNMP authentication failure. Ordering Information Model Number EIR508-T EIR508-2MC-T EIR508-2MT-T EIR508-2SC-T Description Industrial Managed Ethernet Switch, 8 10/100 RJ-45 Ports Industrial Managed Ethernet Switch, 6 10/100 RJ-45 Ports, 2 MM FO (SC) Port Industrial Managed Ethernet Switch, 6 10/100 RJ-45 Ports, 2 MM FO (ST) Port Industrial Managed Ethernet Switch, 6 10/100 RJ-45 Ports, 2 SM FO (SC) Port (30 KM) EIR508-xxx-x 1713ds - 2/2 © 2008 by B&B Electronics. All rights reserved. Specifications Technology IEEE Standards 802.3 10Base-T Ethernet, 802.3u 100Base-TX and 100Base-FX Fast Ethernet 802.3x Flow Control and Back Pressure, 802.1d Spanning Tree, 802.1w Rapid Spanning Tree 802.1p Class of Service, 802.1Q VLAN Tag Store and Forward Flow control on full duplex, Back Pressure on half duplex 2 KB 1 MB CSMA/CD SNMP, Web GUI, and reset to factory default button 14,880 bps for Ethernet ports, 14,8800 for Fast Ethernet ports 64 bytes to 1522 bytes (with VLAN tag) 1.49 Mbps @ 64 bytes 2 ports for X-Ring provide redundant backup with a recovery time below 300 MS. 4 Selection Rules to filter combinations of Broadcast , Multicast, Unicast, and Unknown packets. Port based and Tag. Up to 64 VLAN groups 4 priority queues per port Port based, Tag based, or IPv4 Type of Service IGMP v1 and Query mode. Up t o 256 groups SNTP IP Address TX packet only or TX and RX packet TFTP DHCP Client Function to obtain addresses from DHCP server Ingress Packet Filter rules and Egress Rate Control Processing Type Flow Control MAC Address Table Size Memory Buffer Protocol Management Transfer Rate Transfer Packet Size Packet throughput ability X-Ring Packet Filter VLAN Class of Service Quality of Service IGMP Clock Synchronization Management Security Port Mirror Firmware Update DHCP Bandwidth Control Interface RJ-45 Ports Fiber Ports Port Indicators (each port) System Indicators 10/100BaseT with auto negotiation, Full/Half Duplex, MDI/MDI-X 100Base FX, single-mode or multi-mode with ST or SC connectors Green LED for Link / Activity and Yellow LED for Full Duplex / Collision Green LEDs for Power, Power 1, Power 2, and Master. Yellow LED for Fault. Fiber Optics Fiber Type Multimode Single Mode Distance 2 KM 30 KM Wavelength 1310 nm 1310 nm Power Input Voltage Current Consumption Input Connection Relay Alarm 12 to 48 VDC, dual source 0.8 A max. Terminal Block 1A @ 24VDC Mechanical Enclosure Mount Dimensions IP30 Aluminum Case 35 mm DIN or Panel 2.3 x 5.7 x 4.3 in (5.8 x 14.5 x 10.9 cm) Cable 62.5/125 um 9/125 um Output Optical Power -10 to 0 dBm -15 to -8 dBm Input Power Min < -28 dBm < -34 dBm SNMP MIB SNMP Trap RFC 1213 MIBII RFC 1493 Bridge MIB RMON RFC 1757 RFC 2674 VLAN MIB RFC 1643 Ethernet like MIB RFC 1215 Trap MIB Private MIB for switch info Up to 3 Trap Stations Cold Start Port link up Port link down Authentication Failure Power status Port Alarm Fault Alarm X-Ring Environmental CE Declaration of Conformity Manufacturer’s Name B&B Electronics Mfg CO Manufacturer’s 707 Dayton Road Address PO Box 1040 Ottawa, IL 61350 USA Model Numbers EIR508-T, EIR508-2xx-T series Description Industrial Managed Switch Type Light Industrial ITE Equipment Application of Council Directive 89/336/EEC Standards EN55022 EN61000-4-2, -4-3, -4-4, -4-5 EN61000-4-6, -4-8, -4-11, -4-12 EN61000-6-2, -6-4 Michael J. Fahrion, Director of Engineering Operating Temperature Storage Temperature Operating Humidity MTBF EIR508-T MTBF EIR508-2xx-T -40 to 167 F (-40 to 75 C) -40 to 185 F (-40 to 85 C) 0 to 95% NC 319175 hours 315109 hours Regulatory Approvals EMI Safety Free Fall Shock Vibration FCC Class A EN6100-4-2, -4-3, -4-4, EN6100-4-5, -4-6 EN60950 IEC60068-2-32 IEC60068-2-27 IEC60068-2-6
BB-EIR508-T 价格&库存
很抱歉,暂时无法提供与“BB-EIR508-T”相匹配的价格&库存,您可以联系我们找货
