BB-EIR618-2SFP-T
BB-EIR618-2SFP-T
    B+BSMARTWORX
    NETWORK SWITCH-MANAGED 18 PORT
BB-EIR618-2SFP-T 数据手册
18 Port Managed Industrial Ethernet Switches with SFP Gigabit Ports EIR618-2SFP-T PRODUCT FEATURES • • • • • • • • • • The Elinx™ EIR618-2SFP-T Industrial Managed Ethernet Switch provides powerful functionality in a small package. Designed for industrial applications, this switch contain all the standard features of other switches, such at IGMP Snooping, Port Based VLAN, 802.1Q Tag VLAN, RJ45 automatic MDI/MDI-X, auto negotiation, store and forward switching, STP, RSTP, Web Based Management, Ingress Packet Filtering, and Egress Rate Control. These managed switches also come with important industrial features to ensure reliability in an industrial application. X-Ring technology with coupling ring and dual homing allows automatic recovery in less than 300 MS. Dual power inputs ensure reliability. A relay alarm output for port failure notification. DIN Rail and Panel Mounting options on the same IP30 case. Another important feature is automatic e-mail notification for system events such as a cold start, change in network topology, power status or SNMP authentication failure. X-Ring automatic recovery 16 10/100 TX RJ45 ports with MDI/MDI-X 2 combo 10/100/1000TX RJ45 or 100/1000 SFP ports Dual 12 to 48 VDC power inputs Wide operating temperature Relay alarm output IP30 DIN rail or panel mount Automatic e-mail notification for system events SNMP, CLI, or web management Port mirror and port trunk with LACP Ordering Information Model Number Description Industrial Managed Ethernet Switch, 16 10/100 RJ45 EIR618-2SFP-T Ports, plus 2 Combo 10/100/1000 RJ45 or SFP MiniGBIC Ports Accessories MDR-60-24 - DIN Rail Power supply 24VDC, 2.5A, 60W C5UMB3FBL - 3 ft. (1 M) - Blue - Category 5e UTP Patch Cord DFMM-LCLC-1M - Multi-Mode Duplex Fiber Cable, LC To LC, 1 Meter DFSM-LCLC-1M - Single-Mode Duplex Fiber Cable, LC To LC, 1 Meter SFP-1000SX-M-550M-T - SFP Module, 1000Base-SX, Multi-mode 550m, LC Connector (-40 to 85°C) SFP-100FX-M-2KM-T - SFP Module, 100Base-FX, Multi-mode 2km, LC Connector (-40 to 85°C) SFP-1000LX-S-10KM-T - SFP Module, 1000Base-LX, Single-mode 10km, LC Connector (-40 to 85°C) SFP-1000LX-S-20KM-T - SFP Module, 1000Base-LX, Single-mode 20km, LC Connector (-40 to 85°C) SFP-100FX-S-30KM-T - SFP Module, 100Base-FX, Single-mode 30km, LC Connector (-40 to 85°C) www.bb-elec.com | EIR618-2SFP-T_3713ds 18 Port Managed Industrial Ethernet Switches with SFP Gigabit Ports EIR618-2SFP-T specifications Technology 802.3 10Base-T Ethernet, 802.3u 100Base-TX and 100Base-FX Fast Ethernet, 802.3x Flow Control and Back Pressure, 802.1d Spanning Tree, 802.1w Rapid IEEE Standards Spanning Tree, 802.1p Class of Service, 802.1Q VLAN Tag, 802.3ad Port Trunk with LACP, 802.1x RADIUS, 802.3ab 1000BaseT, 802.3z Gigabit fiber Processing Type Store and Forward Flow control on full duplex, Back Pressure on half Flow Control duplex MAC Address Table Size 8 KB Memory 4MB Flash ROM, 32MB DRAM Protocol CSMA/CD SNMP v1, v2c, v3, Web GUI, TELNET, CLI, Menu Driven Management Interface Up to 10 IP addresses can have permission to manage Management Security the switch. 802.1x (RADIUS) Authentication 14,880 bps for 10Base-T Ethernet ports, 148,800 for Transfer Rate 100Base-TX/FX Fast Ethernet ports 1,488,000 bps for Gigabit Fiber Ethernet ports Packet throughput ability 10.7 Mbps @ 64 bytes 2 ports for X-Ring provide redundant backup with a X-Ring recovery time below 300 MS. 4 Selection Rules to filter combinations of Broadcast , Packet Filter Multicast, Unicast, and Unknown packets. Port based and Tag. Up to 256 VLAN groups. GVRP (256 VLAN Groups) LACP Port Trunk. 4 trunk groups / maximum of 4 trunk Port Trunk members. Class of Service 4 priority queues per port Port based, Tag based, or IPv4 Type of Service, IPv6 Quality of Service Different Service IGMP Snooping v1, v2, and v3. 256 multicast groups IGMP and IGMP query Clock Synchronization SNTP Management Security IP Address, 802.1x RADIUS Port Security Static MAC (100 entries) / MAC Filter (100 entries) Port Mirror TX packet only, RX packet only, or TX and RX packet Firmware Update TFTP, TFTP backup and restore DHCP DHCP Client / DHCP Server Bandwidth Control Ingress packet filter and Egress packet limit orders@bb-elec.com support@bb-elec.com INTERFACE LAN/WAN Ports Console Port Port Indicators (each port) System Indicators 16 RJ45 10/100TX, 2 Combo RJ45 10/100/1000 or SFP ports (RJ45 ports disabled when SFP installed) RS-232 RJ45 (DB9 to RJ45 adapter cable included) 10/100: Link/Activity (Green), Full-duplex/Collision (Yellow), Giga Copper: Link/Activity (Green), Speed (1000Mbps Green), SFP: Link/Activity (Green) Green LEDs for Power, Power 1, Power 2, and Master. Orange LED for Fault. Power Input Voltage 12 to 48 VDC, dual source Current Consumption 1.1 A max. Input Connection Terminal Block Relay Alarm 1A @ 24VDC Environmental Operating Temperature -40 to 167°F (-40 to 75°C) Storage Temperature -40 to 185°F (-40 to 85°C) Operating Humidity 0 to 95% Non-condensing MTBF 243301 hours Mechanical Enclosure IP30 DIN mount metal case Mount 35 mm DIN or Panel Dimensions 7.4 x 10.7 x 16.3 cm (2.9 x 4.2 x 6.4 in) Regulatory Approvals FCC Class A EMI EN6100-4-2, -4-3, -4-4, EN6100-4-5, -4-6 Safety EN60950 Free Fall IEC60068-2-32 Shock IEC60068-2-27 Vibration IEC60068-2-6 International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-EIR618-2SFP-T 价格&库存
很抱歉,暂时无法提供与“BB-EIR618-2SFP-T”相匹配的价格&库存,您可以联系我们找货
