BB-852-10314
BB-852-10314
    B+BSMARTWORX
    GIGA-ACCESSETHERLINX-II, TX/4 +
BB-852-10314 数据手册
10/100/1000 Mbps Managed Multi-port Optical Demarcation Device Giga-AccessEtherLinX-II AC Version PRODUCT FEATURES • • • • • • The Giga-AccessEtherLinX-II enables service providers to offer differentiated “Transparent LAN” services to multi-tenant building and business customers without the need for costly remote routers. Residing at the customer premises, the Giga-AccessEtherLinX-II provides a VLAN-based, Layer 2 entry point to the last mile fiber network to support trunking, differentiating and separating customer traffic. Featuring SNMP management with per-port 802.1Q VLAN, 802.1p QoS, traffic prioritization, bandwidth control and multicast pruning/snooping (using IGMP v1, v2), the Giga-AccessEtherLinX-II is perfect for a wide range of Fiber-to-the-Home, Fiber-to-the-Curb and Fiber-to-the-Business (FTTx) services, and is an ideal solution for delivering Ethernet-based services to customers quickly and cost effectively. Designed with a small footprint, the Giga-AccessEtherLinXII facilitates easy installation inside the premises. It features four 10/100/1000 twisted pair Ethernet downlink ports (for connecting users/LANs), with either a 1000Base-FX fiber or SFP uplink port, and is powered from an internal AC or DC power supply. The Giga-AccessEtherLinX-II accepts traffic containing VLAN tags on the Uplink port and directs that traffic to the twisted pair downlink ports based on the VLAN ID. In addition to assigning 802.1Q VLAN-tags on a per-port basis, users can also “Qualify” the different VLAN TAGS to assign based on the DiffServ or PRI value of the incoming frame. Traffic priority for each port is supported with a hi/low prioritization queues. The Giga-AccessEtherLinX-II includes per port bi-directional bandwidth control, and supports IGMP multicast pruning which ensures only the necessary amount of IP multicast packets are bridged. 802.1Q VLAN-tags on per-port basis, based on DiffServ or PRI values SNMP Manageable QoS - 802.1p-based packet prioritization Per-port bi-directional Bandwidth control VLAN-tagging and Q-in-Q (double-tagging) segregates customer traffic Up and running in less then five minutes Ordering Information Model Fiber range Fiber Number Ports Giga-AccessEtherLinX-II AC 852-10302 SFP 1 Various 852-10303 SX-MM850-SC 1 550 m 852-10304 LX-SM1310-SC 1 15 km 852-10305 LX-SM1310/PLUS-SC 1 40 km 852-10306 LX-SM1550/PLUS-SC 1 80 km 852-10307 LX-SM1550/XLONG-SC 1 100 km SINGLE STRAND FIBER * 852-10310 SSLX-SM1310-SC 1 15 km 852-10311 SSLX-SM1550-SC 1 15 km 852-10312 SSBX-SM1310-SC 1 10 km 852-10313 SSBX-SM1490-SC 1 10 km 852-10314 SSLX-SM1310/PLUS-SC 1 40 km 852-10315 SSLX-SM1550/PLUS-SC 1 40 km 852-10316 SSBX-SM1310/PLUS-SC 1 30 km 852-10317 SSBX-SM1490/PLUS-SC 1 30 km 852-10318 SSLX-SM1490/LONG-SC 1 70 km 852-10319 SSLX-SM1550/LONG-SC 1 70 km Ethernet PORTS Ethernet Connector 4 4 4 4 4 4 RJ45 RJ45 RJ45 RJ45 RJ45 RJ45 4 4 4 4 4 4 4 4 4 4 RJ45 RJ45 RJ45 RJ45 RJ45 RJ45 RJ45 RJ45 RJ45 RJ45 * These products have single-strand fiber technology. Deploy in pairs or connect another compatible B&B IMC LLC single-strand fiber product. Giga-AccessEtherLinX-II also available in CWDM Fiber. Call for details. Accessories 895-39226 - Rackmount Bracket 895-39949 - Rackmount Shelf iView: Windows 2000/XP/Vista/Win7 www.bb-elec.com | Giga-AccessEtherLinX-II AC Version_3713ds 10/100/1000 Mbps Managed Multi-port Optical Demarcation Device Giga-AccessEtherLinX-II AC Version Specifications General Monitors (remote) status without a physical presence or separate “IP” connection through UMA Maintains security; all management traffic can remain isolated from the data traffic Read/write IEEE 802.1Q VLAN-tags Q-in-Q (double-tagging) to further segregate customer VLAN traffic Can assign different TAGS based on DiffServ or PRI values of incoming frames. QoS: IEEE 802.1p-based or DSCP packet prioritization (2 queues [high/low] with 8 levels of priority) VLAN Tag-based on DSCP or priority of incoming frame (“traffic grooming”) Layer 2 packet switching, store and forward operation Forwarding rate: 14,881 pps for 10 Mbps; 148,810 pps for 100 Mbps; 1,488,100 pps for 1000 Mbps Includes per-port bi-directional bandwidth control AutoCross for MDI/MDIX Features Auto Negotiation and Selective Advertising MTU: Supports packets up to 9600 bytes Supports Half- and Full-Duplex operation Supports IEEE 802.3x Flow Control Management Includes GUI-based iView² software, featuring iConfig utility for rapid IP configuration SNMP V1 and V2c compatible Includes DHCP client for IP address assignment Features TFTP client for remote upgrades Supports Telnet - Includes DB-9 connector for serial configuration Includes per port loopback test modes Includes diagnostic LEDs Ethernet Protocols Supported 802.3 10Base-T twisted pair 802.3u 100Base-TX twisted pair 802.3ab 1000Base-T twisted pair 802.3z 1000Base-LX or SX fiber Mechanical Dimensions 1.64” H x 5.64” W x8.95” D (4.2 cm x 14.3 cm x 22.7 cm) Metal 1.6 lbs. (0.6 kg) Enclosure Shipping Weight Power Rating 100-240V AC, 50/60Hz, 0.5/0.25A Environmental Operating Temperature +32° to 122° F (0° to +50° C) Storage Temperature -13° to +158°F (-25° to +70°C) Operating Humidity 5 to 95% Non-condensing Regulatory Approvals FCC Class B UL/cUL, CE, CB Mechanical diagram (dimensions in inches) 2.300 2.63 .82 1.030 .56 .83 .550 3X .64 9.30 1.76 1.03 .97 .96 1.13 orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-852-10314 价格&库存
很抱歉,暂时无法提供与“BB-852-10314”相匹配的价格&库存,您可以联系我们找货
