BB-855-19202
BB-855-19202
    B+BSMARTWORX
    IE-MINIMC/TELCO-LFPT, TP-TX/FX-M
BB-855-19202 数据手册
Industrial Grade 10/100 Miniature Media Converters IE-MiniMc/LFPT & Telco-LFPT PRODUCT FEATURES • • • • Measuring less than 3.5 inches deep and 2 inches wide, the IE-MiniMc Series converters are some of the industry’s smallest copper-to-fiber media converters, with both data connections on the same side. The IE-MiniMc family of media converters are a fraction of the cost of other industrial grade alternatives. These products provide the ease and convenience of plug-and-play operation with features including Auto Negotiation and Auto-Cross. Advanced features such as Link Fault Pass-Through (LFPT) assist operators in identifying breaks in the network when using unmanaged network hardware. Multiple powering options include Power over Ethernet (PoE/PD), -48 VDC for Telco, AC wall adapter and USB, which offers unsurpassed flexibility for a variety of installations. Accessories Extended operating temperature of -25 to +85° C Auto-Cross automatic selection between crossover or straight-through connections Status LEDs Link Fault Pass-Through (LFPT) capability Ordering Information Model Fiber range Fiber Number Ports IE-MiniMc/LFPT 855-19822 MM850-SC 1 2 km 855-19824 MM1300-SC 1 5 km 855-19830 SM1310/PLUS-SC 1 30 km 855-19832 SM1310/LONG-SC 1 80 km 855-19833 SM1550/LONG-SC 1 80 km Ordering Information Model Fiber range Fiber Number Ports IE-MiniMc/Telco-LFPT 855-19202 MM850-SC 1 2 km 855-19204 MM1300-SC 1 5 km 855-19210 SM1310/PLUS-SC 1 30 km 855-19212 SM1310/LONG-SC 1 80 km 855-19213 SM1550/LONG-SC 1 80 km Ethernet PORTS Ethernet Connector 1 1 1 1 1 1 1 1 1 1 Ethernet PORTS Ethernet Connector 1 1 1 1 1 1 1 1 1 1 806-39105 - DIN Rail Clip 806-39638 - Double-USB Power Cable, 36”/.9m 806-39650 - 12”/.3m Barrel-Connector Power Cable 850-13086 - IE-PowerTray/18-AC (-20°C to +70°C), 18-slot AC powered chassis 895-39229 - Wall Mount Bracket 806-39753 - IE-Power/5V Module, AC to DC DIN Rail Power Adapter www.bb-elec.com | IE-MiniMc/LFPT & Telco-LFPT_3713ds Industrial Grade 10/100 Miniature Media Converters IE-MiniMc/LFPT & Telco-LFPT Specifications Technical IEEE 802.3 10Base-T twisted pair IEEE 802.3u 100Base-TX twisted pair IEEE 802.3u 100Base-FX fiber IEEE 802.3af Power Over Ethernet Supports jumbo packets up to 1916 bytes Plug-and-play operation RJ45 and ST or SC ports available 50/125µm or 62.5/125µm multi-mode fiber 9/125µm single-mode fiber Available with single-strand fiber support Includes terminal DC power block Country-specific, high-reliability power adapter Auto Negotiation Auto-Cross for MDI/MDIX Layer 2 packet switching, store and forward (forwarding rate: 14,881 pps for 10 Mbps, 148,100 pps for 100 Mbps) Status LEDs Mechanical 0.83”H x 1.80”W x 3.35”D (2.11 x 4.57 x 8.51 cm) 0.7 lbs (.317 kg) Dimensions Shipping Weight Input specifictaions DC Terminal (Telco): 12 to 48 VDC Barrel Connector: 5 to 24 VDC PoE: Maximum supply voltage is 50V Environmental Operating Temperature: DC or -13° F to 185° F (-25° C to +85° C) PoE (PD) Operating Temperature: AC wall +14° F to +122° F (-10° C to +50° C) adapter Storage Temperature: -31° F to +167° F (-35° C to +75° C) Operating Humidity 5% to 95% (non-condensing) Regulatory Approvals FCC Class A (using DC terminal or PoE power) FCC Class B (using any DC jack, optional) UL/cUL, CSA, CE Mechanical diagram (dimensions in inches & millimeters) 1.04 (26,4) .04 (1.0) 1.40 (35,6) .51 (12,9) REF .31 (7,9) 1.25 (31,75) .46 (11,7) .43 (11,0) .45 (11,4) 3.35 (85,1) 1.81 (46,0) orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: B&B Electronics: 855-19202 855-19210 855-19204 855-19213 855-19212
BB-855-19202 价格&库存
很抱歉,暂时无法提供与“BB-855-19202”相匹配的价格&库存,您可以联系我们找货
