BB-SD-50A-12
BB-SD-50A-12
    B+BSMARTWORX
    DC/DC CONVERTER 12V 50A
BB-SD-50A-12 数据手册
SD-50 50W Single Output DC-DC Converter series ■ Ultra Compact Modbus Gateways Models MESP211D, MESP211T ‧ ‧ ‧ ‧ ‧ www.advantech-bb.com ‧ ‧ ‧ ‧ PRODUCT FEATURES SPECIFICATION MODEL OUTPUT SD-50A-5 DC VOLTAGE 5V RATED CURRENT 10A CURRENT RANGE 0 ~ 10A RATED POWER 50W SD-50B-5 SD-50C-5 • Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 • SD-50A-12 Modbus Flexibility – SerialSD-50C-12 & Ethernet, Masters & Slaves SD-50B-12 SD-50A-24 SD-50B-24 • 12V View Messaging Status in Real Time 24V • 4.2A Ultra Compact IP30 Metal Enclosure 2.1A • 0 ~International Power Supply (included 0 ~ 2.1A 4.2A 50.4W 50.4W RIPPLE & NOISE (max.) Note.2 100mVp-p 120mVp-p 150mVp-p VOLTAGE ADJ. RANGE 11 ~ 16VDC 23 ~ 30VDC VOLTAGE TOLERANCE Note.3 ±2.0% ±1.0% ±1.0% ±0.5% ±0.3% ±0.2% LINE REGULATION 4.5 ~ 5.5VDC Models MESP211D MESP211T, Vlinx™ series Modbus Gateways, connect LOADand REGULATION ±0.5% ±0.3% ±0.2% ORDERING INFORMATION Modbus devices to Ethernet networks and let you monitor and at control Modbus SERIAL SETUP, RISE, HOLD UP TIME 2.5s, 50ms, -----full load MODEL NUMBER PROTOCOL PORT devices from anywhere the Ethernet LAN orA:9.2 WAN. Supporting B:19 up to~16 VOLTAGEonRANGE ~ 18VDC 36VDC C:36 ~ 72VDC MESP211D RS-232/422/485 DB9 Male masters and 32EFFICIENCY slaves, these(Typ.) gateways feature70% an auto-detecting 73% 10/100 76% 72% 75% 78% 74% INPUT MESP211T RS-232/422/485 Removable Ethernet copperDCRJ-45 port and a serial port that supports RS-232/422/485 Block 7A/12V 3A/24V 1.5A/48V 7A/12V 3A/24V 1.5A/48VTerminal 7A/12V CURRENT communications via a DB9 male or a terminal 105 block~ 150% connection. rated output power OVERLOAD ETHERNET PORT 1 80% 1 3A/24V SD-50C-24 ETHERNET CONNECTOR RJ45 83% RJ45 1.5A/48V Protection type : Hiccup mode, recovers automatically after fault condition is removed PROTECTION The product is built for use in industrial environments with a heavy-duty metal 5.75 ~ 6.75V/10% load 16.8 ~ 20V/10% load 31.5 ~ 37.5V/10% load ACCESSORIES OVER enclosure that is panelVOLTAGE (standard) or DIN rail mountable (with optional adapters). Protection type : Hiccup mode, recovers automatically after fault condition is removed SMI6-12-V-P5 - Included Power Supply, 12 VDC 6 Watt, 5MM Plug, International AC Input, The product can be supplied with a DC power source ranging from 10 to 30 -10 ~ +60℃ (Refer to "Derating Curve") International AC Blades WORKING TEMP. VDC and features a barrel connector. A power supply is included. DRAD35 - Optional DIN rail adapter clip (pair) 20 ~ 90% RH non-condensing WORKING HUMIDITY 232NM9 - Optional mull modem crossover cable ENVIRONMENT STORAGE TEMP., HUMIDITY -20 ~ +85℃, 10 ~ 95% RH Ease of Use TEMP. COEFFICIENT ±0.03%/℃ (0 ~ 50℃) Configuration, upgrades and monitoring of the serial server are simple, easy VIBRATION 10 ~ 500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes tasks with Vlinx Manager Software. It installs on your PC giving access to Design refer to LVD SAFETY STANDARDS the serial server via your desktop. Remotely manage the Modbus Gateway I/P-O/P:1.5KVAC I/P-FG:2KVAC O/P-FG:0.5KVAC SAFETY & WITHSTAND VOLTAGE over a LAN or WAN via the build-in web server. This is helpful for off-site ISOLATION RESISTANCE I/P-O/P, I/P-FG, O/P-FG:100M Ohms / 500VDC / 25℃/ 70% RH EMC troubleshooting and can be done with an ordinary web browser. (Note 4) EMC EMISSION EMC IMMUNITY Software Support Compliance to EN55032 (CISPR32) Class B Compliance to EN61000-4-2,3,4,6,8, EN55024, heavy industry level, criteria A 368.5K Hrs min.(SD-50C) MTBFbit), 2003 Server (32/64 bit), 365.6K min.(SD-50A) 357.5K hrs min.(SD-50B) Windows XP (32/64 Vistahrs 32/64 bit), 2008 Server OTHERS DIMENSION 159*97*38mm (L*W*H) (32/64 bit), Windows 7 (32/64 bit), Windows 8 (32/64 bit), Windows 10 (32/64 0.48Kg; 24pcs/12.7Kg/0.75CUFT PACKING bit). NOTE MIL-HDBK-217F (25℃) ℃      All product specifications are subject to change without notice. File Name:SD-50-SPEC 2017-07-14 MESP211D & MESP211T_3617ds orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 SD-50 50W Single Output DC-DC Converter Mechanical Specification Case No. 901 series Unit:mm 152.5 Ultra Compact Modbus Gateways 3.5 7 Models MESP211D, MESP211T 1 www.advantech-bb.com 3 84.5 8.2 4 5 2-M ψ3 97 65 9.5 2 3 PRODUCT FEATURES • • • • • .5 4.5 78 24 Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 Modbus Flexibility – Serial & Ethernet, Masters & Slaves View Messaging Status in Real Time Ultra Compact IP30 Metal Enclosure International Power Supply (included 159 150 Terminal Pin No. Assignment Pin No. 38 3.5 28.5 9 3.5 3Models MESP211D and MESP211T, Vlinx™ series Modbus Gateways, connect M3 Modbus devices to Ethernet networks and let you monitor and control Modbus devices from anywhere on the Ethernet LAN or WAN. Supporting up to 16 22 masters and 32 slaves, these gateways feature an117 auto-detecting 10/100 Ethernet copper RJ-45 port and a serial port that supports RS-232/422/485 communications via a DB9 male or a terminal block connection. 18 ψ 18.5 9 6.5 1 ORDERING INFORMATION 2 3 Assignment DC INPUT V+ DC SERIAL INPUT VPORT FG MODEL NUMBER PROTOCOL MESP211D RS-232/422/485 MESP211T RS-232/422/485 Pin No. Assignment 4 DC OUTPUT -V 5 ETHERNET DC OUTPUT +V ETHERNET DB9 Male Removable Terminal Block PORT 1 CONNECTOR RJ45 1 RJ45 Block Diagram The product is built for use in industrial environments with a heavy-duty metal fosc : 83KHz ACCESSORIES enclosure that is panel (standard) or DIN rail mountable (with optional adapters). SMI6-12-V-P5 - Included Power Supply, 12 VDC 6 Watt, 5MM Plug, International AC Input, The product can be supplied with a DC powerEMI source ranging from 10 to 30 POWER International AC RECTIFIERS +V Blades I/P & FILTER SWITCHING -V VDC and features a barrel connector. A power supply is included. DRAD35 - Optional FILTER DIN rail adapter clip (pair) Ease of Use Configuration, upgradesFG and monitoring of the serial server are simple, easy tasks with Vlinx Manager Software. It installs on your PC giving access to PWM O.L.P. CONTROL the serial server via your desktop. Remotely manage the Modbus Gateway over a LAN or WAN via the build-in web server. This is helpful for off-site troubleshooting and can be done with an ordinary web browser. DETECTION CIRCUIT O.V.P. Static Characteristics(SD-50C-24V) OUTPUT VOLTAGE (V) Software Support Windows XP (32/64 bit), 2003 Server (32/64 bit), Vista 32/64 bit), 2008 Server (32/64 bit), Windows 7 (32/64 bit), Windows 8 (32/64 bit), Windows 10 (32/64 SD-50B,C 100 bit). 80 SD-50A LOAD (%) 60 40 20 -10 -10 0 0 10 20 30 40 50 45 AMBIENT TEMPERATURE (℃) 60 55 (VERTICAL) (HORIZONTAL) 32 350 28 300 24 250 20 200 16 150 12 100 8 50 25 30 35 40 45 50 55 60 65 70 OUTPUT RIPPLE (mVp-p) Derating Curve 232NM9 - Optional mull modem crossover cable 72 INPUT VOLTAGE (V) All product specifications are subject to change without notice. File Name:SD-50-SPEC 2017-07-14 MESP211D & MESP211T_3617ds orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-SD-50A-12 价格&库存
很抱歉,暂时无法提供与“BB-SD-50A-12”相匹配的价格&库存,您可以联系我们找货
