VESR424D-ST
VESR424D-ST
    B+BSMARTWORX
    ETHERNET TO SER RS-232/422/485
VESR424D-ST 数据手册
VESR4x4-0712ds-1/4 B&B ELECTRONICS © 2011 by B&B Electronics. All rights reserved. VESR4x4 Vlinx ™ 4-Port Industrial Ethernet Serial Servers 9 Ruggedized for extreme applications 9 Heavy Industrial 61000-6-2 EMC tested 9 IEC600068-2-27 (shock) and 600068-2-6 (vibration) tested 9 Wide Operating Temperature (-40 to 80C) 9 Independent Serial Port selection for RS-232, RS-422, or RS-485 9 Wide Voltage input 10 to 58VDC, via terminal block or locking barrel plug Direct IP Mode VESR4x4 Serial Servers connect serial devices (RS-232, RS-422 or RS485) to Ethernet networks, allowing the serial device to become a node on TCP/IP or UDP/IP socket applications communicate directly with serial devices the network. The serial ports can be accessed over a LAN/WAN using Direct IP Mode, Virtual COM Port, or Paired Mode connections. VESR4x4 Serial Servers feature 10BaseT or 100BaseTX copper network media and several fiber optic media options, depending on the model. Many models also feature an additional copper Ethernet pass-through port. VESR4x4 Serial Servers are built for use in industrial environments and feature heavy duty metal enclosures that are panel and DIN rail mountable. The product operates from a range of DC power supply voltages and features pluggable terminal block power connectors as well as a locking barrel connector that facilitates redundant power sources. Virtual COM Mode Fiber Optic Ethernet Ports - Choose a serial server with fiber optic Ethernet ports when the application requires long distance runs or high Communicate with serial devices through your network as if they were connected to a physical COM port. RFI/EMI noise is present. Many applications require a high level of noise immunity and fiber eliminates this problem between devices. Fiber optic connections far exceed the 100m limitation of standard Ethernet copper ports. Multi-mode fiber can be extended up to 2km distance while single- PRODUCT INFORMATION mode fiber can run as far as 20km. Ease of Use- Configuration, upgrades and monitoring of the serial server are simple, Easy tasks with Vlinx Manager Software. It installs right on your PC giving you access the serial server via your desktop. Remotely Paired Mode Serial devices communicate with each other by tunneling through your network. manage the serial server over a LAN or WAN via the build-in web server. This is helpful for off-site troubleshooting and can be done with a simple web browser. www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 VESR4x4-0712ds-2/4 © 2011 by B&B Electronics. All rights reserved. B&B ELECTRONICS Specifications RS-232 (DB9) RS232 (terminal block) RS-485 2-Wire RS-422/485 4-Wire Serial Connector Data Rate Type / Wavelength Output Power Receive Sensitivity Cable Connector Range Source Input Voltage Connector Power Consumption LED Indicators Switches Dimensions Enclosure Operating Temp Operating Humidity MTBF MTBF Calc Method Serial Memory Network Memory IP Port Addresses LAN Ethernet PRODUCT INFORMATION Protocols IP Mode TCP Connection Mode Client Connection Search Diagnostics Firmware Upgrade Standards Processing Type Flow Control OS Compatibility Compliance Serial Technology TD, RD, DTR, DSR, RTS, CTS, DCD plus Signal Ground TD, RD, RTS, CTS) plus Signal Ground Data A(-), Data B(+), GND TDA(-), TDB(+), RDA(-), RDB(+), GND DB9M or Removable Terminal Blocks Up to 230.4 Kbps Fiber Optic Technology VESR424-Sx VESR424x-Mx Multi-mode / 1310 nm Single-mode / 1310 nm (-)19 to (-) 14 dBm (-) 15 to (-) 8 dBm (-) 32 dBm 62.5 / 125 μm SC or ST 1.2 miles (2 km) (-) 32 dBm 9 / 125 μm SC or ST 12.4 miles (20 km) Power External 10 to 58 VDC Removable Terminal Block (16 – 28 AWG) 6.0 Watts Max. Mechanical Serial Port, Ethernet Link, Speed Reset Button VESR4x4:1.8 x 4.4 x 6.75 in (4.57 x 12.2 x 17.1 cm) 35mm DIN mount, Metal, IP 30 Environmental -40 to 80°C (-40 to 176° F) 10 to 95% Non-condensing VESR4x4: 70273 hours Parts Count Reliability Prediction Network 8 KB per port 4 KB 5300 – Heartbeat and configuration Setting in TCP Mode (paired mode) 8888 – VESR4x4 Update Network Communications 10/100 Mbps Auto-detecting , 10BaseT or 100BaseTX Network Physical Layer Standards IEEE 802.3 auto detecting & auto MDI/MDX, 10BaseT and 100Base TX Protocols TCP, IPv4, UDP, ARP, HTTP 1.0, ICMP/PING, DHCP/BOOTP Static, DHCP User definable Other Server, Client, VCOM, Paired At power up or upon data arrival Serial direct COM and Ethernet Auto Search or specific IP Display PC IP, ping, test VCOM Web GUI through Ethernet Ethernet Pass-through Port (VESR424) IEEE 802.3, 802.3u, 802.3x Store and Forward with 802.3x full duplex, non blocking flow control IEEE 802.3x flow control, back pressure flow control Configuration Software Windows 2000, XP (32/64 bit), 2003 Server (32/64 bit), Vista (32/64 bit), 2008 Server (32/64 bit), Windows 7 (32/64 bit) Regulatory / Certifications / Safety FCC Part 15 Class A, CE NEMA TS2 Shock IEC 600068-2-27 Vibration IEC 600068-2-6 www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 VESR4x4-0712ds-3/4 B&B ELECTRONICS © 2011 by B&B Electronics. All rights reserved. Ordering Information Model Number Ethernet Ports Ethernet Connector 1 Ethernet Connector 2 Serial Connector (x4) VESR414D 1 RJ-45 --- DB9 Male VESR414T 1 RJ-45 --- Terminal Block VESR424D 2 RJ-45 RJ-45 DB9 Male VESR424D-MC 2 Multi-mode SC RJ-45 DB9 Male VESR424D-MT 2 Multi-mode ST RJ-45 DB9 Male VESR424D-SC 2 Single-mode SC RJ-45 DB9 Male VESR424D-ST 2 Single-mode ST RJ-45 DB9 Male VESR424T 2 RJ-45 RJ-45 Terminal Block VESR424T-MC 2 Multi-mode SC RJ-45 Terminal Block VESR424T-MT 2 Multi-mode ST RJ-45 Terminal Block VESR424T-SC 2 Single-mode SC RJ-45 Terminal Block VESR424T-ST 2 Single-mode ST RJ-45 Terminal Block Accessory Items Power Supply Cable Rail Panel Mount Bracket Kit Din Rail Mount, 24VDC, 40 Watt MDR-40-24 12VDC, Locking Barrel PS12VLB-INT-MED 232NM9 Null Modem Crossover Cable for DTE to DTE connection ERS35 one-meter length of steel 35mm DIN Rail #9030 PRODUCT INFORMATION Note: PS12VLB-INT-MED locking barrel connector: Female Locking Barrel 5.5 mm OD, 2.5 mm Center Conductor, 9 mm long, Center Positive www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 VESR4x4-0712ds-4/4 PRODUCT INFORMATION B&B ELECTRONICS © 2011 by B&B Electronics. All rights reserved. Mechanical Diagram Dimensional Diagram of a VESR424 Serial Server (dimensions in inches & millimeters) www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
VESR424D-ST 价格&库存
很抱歉,暂时无法提供与“VESR424D-ST”相匹配的价格&库存,您可以联系我们找货
